Canon Support for EOS-1D Mark IV | Canon U.S.A., Inc.
EOS-1D Mark IV
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type | High-sensitivity, high-resolution, single-plate, CMOS sensor |
Pixels | Approx. 16.10 Megapixels |
Total Pixels | Approx. 17.00 Megapixels |
Aspect Ratio | 3:2 (Horizontal:Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Fixed position in front of the image sensor |
Dust Deletion Feature | (1) Self Cleaning Sensor Unit - Helps remove dust adhering to the low-pass filter. - Automatic cleaning when power on and off, and manual cleaning. - Low-pass filter has a fluorine coating. (2) Dust Delete Data acquisition and appending - The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images - The dust coordinate data appended to the image is used by the provided software to automatically minimize the dust spots (3) Manual cleaning |
Recording Format | DCF 2.0 (Exif 2.21): JPEG, RAW and RAW+JPEG simultaneous recording possible. Multiple options for recording images on two memory cards, and onto compatible external USB hard drives (via optional Wireless File Transmitter WFT-E2/2A, E2 IIA*) |
Image Format | JPEG, RAW, M-RAW, S-RAW (Canon .CR2) MOV |
File Name | The file name can be set to one of three formats: 1. Factory-default, four-character alphanumeric name 2. Any four characters (User setting 1) 3. Any three characters plus the image size (User setting 2). If 3 is set and an M-RAW image is taken, the fourth character will be "M." The above three settings also apply to the file name for movies. If 3 is set, the forth character will be "_" (underscore). |
File Size | JPEG 1) Large: Approx. 16.00 megapixels (4896 x 3264) 2) Medium 1: Approx. 12.40 megapixels (4320 x 2880) 3) Medium 2: Approx. 8.40 megapixels (3552 x 2368) 4) Small: Approx. 4.00 megapixels (2448 x 1632)LOSSLESS RAW 1) RAW: Approx. 16.00 megapixels (4896 x 3264) 2) M-RAW: Approx. 9.00 megapixels (3672 x 2448) 3) S-RAW: Approx. 4.00 megapixels (2448 x 1632) |
Folders | Folder creation/selection enabled |
Recording Functions | (1) Standard - No automatic switching of recording media (2) Automatic switching of recording media - When the current recording media becomes full, it switches to another recording media automatically and continues recording (3) Separate recording - Set the desired image size (L, M1, M2, S, RAW, M-RAW, S-RAW) for each recording media before shooting - The image size set for one captured image will be applied to all the recording media (4) Recording of identical images - The same image is recorded to all recording media. (Also possible with RAW+JPEG.) - Movies cannot be recorded simultaneously to multiple recording media - If simultaneous recording has been set, movies will be recorded to the recording media set with [Play] on the [Recording func+media/folder sel.] screen. - If a still photo is taken during movie shooting and (3) or (4) has been set, the still photo will be recorded to each recording media in the image size that was set. |
Backup Recording | Enabled - With external recording media connected via WFT-E2 IIA* and WFT-E2/E2A (Firmware Ver. 2.0.0 or higher). - Two options: 1. Quick backup (Backup folder created automatically and folder name set automatically.), 2. Backup (Backup folder created manually and folder name can be entered manually.) - Images in the card are backed up in the external recording media's root directory based on the card's DCIM folder structure. * This device has not been authorized as required by the rules of the Federal Communications Commission. This device is not, and may not be offered for sale or lease, or sold or leased, until authorization is obtained. |
File Numbering | (1) Continuous numbering (2) Auto reset (3) Manual reset (the image numbering is reset to 0001, a new folder is created automatically) |
Image Copy | Image copying between recording media enabled (images with checkmarks or all images in folder or card) |
Color Space | sRGB, Adobe RGB |
Picture Style | Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Def. 1-3 |
Auto White Balance | Auto white balance, taken from imaging sensor |
Color Temperature Compensation | White balance bracketing: Three consecutive images, Up to +/- 3 levels in 1-stop increments White balance correction: blue/amber bias and/or magenta/green bias (Corrected in reference to the current WB mode's color temperature.) +/- 9 levels; manually set by user. When blue/amber bias and magenta/green bias set with White balance correction, white balance bracketing cannot be set together during white balance correction |
Color Temperature Information Transmission | Provided |
Type | Eye-level SLR with fixed pentaprism |
Coverage | Approx. 100% horizontally and vertically |
Magnification | Approx. 0.76x (with 50mm lens at infinity, -1 m-1) Angle of view: Approx. 28.3° |
Eye Point | 20mm (at -1m-1, from eyepiece lens center) |
Dioptric Adjustment Correction | Adjustable from -3.0 to +1.0 m-1 (dpt) |
Mirror | Quick-return half mirror (Transmission: reflection ratio of 37:63) |
Depth Of Field Preview | Enabled with depth-of-field preview button |
Eyepiece Shutter | Built-in |
Type | TTL-AREA-SIR AF-dedicated CMOS sensor |
AF Points | Area AF with 45 AF points - 8 mm (H) x 15 mm (W) - All 45 AF points are horizontal-line sensitive at f/5.6 (vertical). Thirty-nine of the 45 AF points are vertical-line sensitive at f/2.8 for cross-type focusing. For automatic AF point selection, cross-type focusing with 19 AF points is used. (The 39 cross-type AF points are used only during manual AF point selection.) - When using some f/4 lenses (including when using f/2.8 lens + Extender 1.4x), cross-type focusing with 39 AF point is possible. |
AF Working Range | EV -1-18 (at 23°C/73°F with 50mm f/1.4 lens at ISO 100) |
Focusing Modes | Autofocus 1) One-Shot AF 2) Predictive AI Servo AF - The following can be set: C.Fn III -2: Focus-tracking sensitivity, C.Fn III -3: Servo operation method and shutter-release timing, C.Fn III -4: Servo operation method in case a closer object enters the focus center during subject-tracking. (2) Manual focus |
AF Point Selection | 1) The 45 AF points can be selected automatically or any one of them can be selected manually. To select an AF point, press the AF point selection button, then use the Multi-controller, Main Dial, or Quick Control Dial. With C.FN III -8-3, the 18 expanded AF points are instead used to search for the subject. 2) During manual AF point selection, the six AF points (or 26 AF points during automatic AF point selection) other than the 39 cross-type AF points will work as horizontal line-sensitive sensors at f/5.6. The two AF points at the immediate top and bottom of the center AF point have improved detection performance and precision due to the increase in the number of lines to two for the f/5.6 sensor. (The 39 cross-type AF points are used only during manual AF point selection.) |
Selected AF Point Display | Superimposed in viewfinder and on LCD panel |
AF Assist Beam | None - When an external, EOS-dedicated Speedlite is attached to the camera, the AF-assist beam from the Speedlite will be emitted when necessary. - Compatible with the 270EX's AF-assist beam (a series of small flashes) |
Metering Modes | 63-zone TTL full aperture metering (1) Evaluative metering (linked to all AF points) (2) Partial metering (approx. 13.5% of screen, at center) (3) Spot metering (approx. 3.8% of screen, at center) Center spot meteringAF point-linked spot metering Multi-spot metering (max. 8 spot metering entries)(4) Center-Weighted average metering |
Metering Range | EV 0-20 (at 23°C/73°F with 50mm f/1.4 lens at ISO 100) |
ISO Speed Range | Auto, ISO 100-12800 (1/3-stop or 1-stop increments: C.Fn I -2),Expandable - ISO Auto set by default. With all C.Fn to their default setting, automatically set within ISO 100-12800. - With C.Fn I -3 (ISO speed range), the highest and lowest settable ISO speed can be set. By setting L (ISO 50) for the lowest speed and H1 (ISO 25600), H2 (ISO 51200), H3 (ISO 102400) [TD] for the highest, ISO speed expansion is possible. - In manual ISO setting, if the upper ISO speed limit is set to H1, H2, H3 [TD], and the lower ISO speed limit to L with C.Fn I-3, the settable ISO speed range will be ISO 100-12800. - In ISO Auto, even if the upper ISO speed limit is set to H1, H2, H3 [TD], and the lower ISO speed limit to L with C.Fn I-3, ISO Auto speed range will be ISO 100-12800. However, if the lower and higher ISO speed limits have been set to a narrower range, ISO speed will be automatically set within that range. - In P, Tv, Av modes and C.Fn I -8-2 (Tv/Av safety shift) is set, C.Fn I -3's ISO range limit will be canceled when the standard exposure cannot be obtained, even if C.Fn I-3 has set the lowest and highest settable ISO speed to a narrower range. It will be automatically controlled within the range of ISO100-12800. - In ISO Auto and C.Fn I-8-1 (Tv/Av safety shift) is set, the C.Fn I-12's shutter speed range limit and C.Fn I-13's aperture range limit will be canceled when the standard exposure cannot be obtained. C.Fn I-3's upper and lower limits will be applied to control the ISO speed range. With C.Fn II-3 (Highlight tone priority) set, even if C.Fn I-3 has set the lower ISO speed limit to L and the upper ISO speed limit to H1, H2, H3, the ISO Auto range and manual ISO range will be ISO 200-12800. However, if the lower and higher ISO speed limits have been set to a narrower range with C.Fn I-3, the settable range will be ISO 200 to the higher speed limit set. - When checking the ISO speed of still photos or movies shot at H3 (ISO 102400) in commercially available software, the correct ISO speed value may not be displayed (the EXIF information standard cannot record ISO 102400 settings). - When imprinting the shooting information for images shot at H2, H3 ISO speeds during ISO speed range expansion, the ISO speed setting may not be correctly printed. |
Exposure Compensation | Exposure Compensation (user-set): +/-3 stops in 1/3- or 1/2-stop increments. Auto Bracketing (AEB): 3 shots, up to +/- 3 stops, in 1/3 or 1/2 stop increments, in all exposure modes. Can be changed via C.Fn I-6 to 2, 5, or 7 shots. Bracketing order can be changed via C.Fn I-5. *Except during movie Manual exposure. |
AE Lock | Auto: Applied in One-Shot AF mode with Evaluative metering when focus is achieved Manual (user-set): By AE lock button in all metering modes |
Shutter | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled1/8000 to 30 sec. (1/3-, 1/2-, or 1-stop increments: C.Fn I -1), X-sync at 1/300 sec. - The shutter speed range can be limited with C.Fn I -12 and the aperture range limited with C.Fn I -13Soft-touch electromagnetic release10-sec. delay, 2-sec. delay Canon N3-type terminal |
Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled |
Shutter Speeds | 1/8000 to 30 sec. (1/3-, 1/2-, or 1-stop increments: C.Fn I -1), X-sync at 1/300 sec. - The shutter speed range can be limited with C.Fn I -12 and the aperture range limited with C.Fn I -13 |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. delay, 2-sec. delay |
Remote Control | Canon N3-type terminal |
EOS Dedicated Speedlite | E-TTL II autoflash with all EX Series Speedlites |
Zooming to Match Focal Length | Provided |
Flash Metering | E-TTL II autoflash |
Flash Exposure Compensation | ±3 stops in 1/3- or 1/2-stop increments |
FE Lock | Provided |
External Flash Settings | Flash function settings, Flash C.Fn settings / Clear all Speedlite C.Fn's |
PC Terminal | Provided; accepts third-party flash units with sync line voltages up to 250V maximum |
Drive Modes | Single, silent, high-speed continuous (approx. 10 fps), low-speed continuous (approx. 3 fps), 10- or 2-sec. self-timer |
Continuous Shooting Speed | Approx. 10 fps (at a shutter speed of 1/500 sec. or faster in all recording modes); fastest speed can be lowered if desired via Custom Function III-16 |
Maximum Burst | The maximum burst during continuous shooting is as follows: JPEG Large (Compression rate 8): Approx. 85 shots, RAW: Approx. 26 shots,RAW+JPEG Large (Compression rate 8): Approx. 20 shots Although the file size is larger than the EOS-1D Mark III due to the increase in pixels, the improved internal processing enables stress-free continuous shooting. |
Shooting Modes | (1) Remote Live View shooting (with a personal computer installed with EOS Utility) (2) Live View shooting |
Focusing | 1) Manual focus 2) Autofocus (One-Shot AF) - AF enabled by pressing the shutter button halfway or pressing the AF-ON button. 1. Live mode - One point, contrast AF. Switching to another AF point possible. 2. (Face detection) Live mode - Face detection, Contrast AF. When multiple faces are detected, face selection is possible with the multi-controller. - Magnified view not possible. 3. Quick mode - 45-point, phase-difference AF (Same as viewfinder shooting), One-shot AF. - Manual AF point selection enabled. |
Metering Modes | Evaluative metering with the image sensor |
Metering Range | EV 0-20 (at 23°C/73°F with EF 50mm f/1.4 USM lens, ISO 100) |
Magnified View | Magnifiable by 5x or 10x at AF point |
Grid Display | Provided |
Exposure Simulation | Provided |
Type | TFT color, liquid-crystal monitor |
Monitor Size | 3.0 in. |
Pixels | Approx. 920,000 dots (VGA) |
Coverage | Approx. 100% |
Brightness Control | Adjustable to one of seven brightness levels - During playback, illumination adjustable by pressing the illumination button. |
Display Format | Single image, 4-image index, 9-image index, Jump, Magnified zoom (approx. 1.5x to 10x), Histogram, Auto rotate, Rotate Live view: view image before shooting on LCD monitor; live histogram and live simulation of exposure level possible with C.Fn IV-16-1 |
Protection | Single image, all images in a folder, or all images in the memory card can be protected or cancel the image protection |
Erase | Single image, all images in a folder, all images in the memory card or check-marked images can be erased or unprotected |
Compatible Printers | PictBridge-compatible printers |
Printable Images | RAW/M-RAW/S-RAW and JPEG images complying to Design rule for Camera File System - Regarding RAW/M-RAW/S-RAW images, only those captured by the EOS-1D Mark IV can be printed. - Movies cannot be printed. |
DPOF | Version 1.1 compatible |
Custom Functions | A total of 62 Custom Functions from C.Fn I to IV can be set with the camera |
My Menu Registration | Provided |
Save Camera Settings | Provided |
Register Basic Camera Settings | Provided |
C.Fn Registration Settings | Provided |
Recording Time | Max. 30 sec. per sound clip/voice memo |
Menu Categories | (1) Shooting (2) Playback (3) Setup, (4) Custom function/My Menu |
LCD Monitor Language | 25: English, German, French, Dutch, Danish, Portuguese, Finnish, Italian,Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech,Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean and Japanese |
Battery | Battery Pack LP-E4 x 1 * With the AC Adapter Kit ACK-E4, AC power is possible. |
Battery Life | Viewfinder Shooting - At 73°F/23°C: Approx. 1500 - At 32°F/0°C: Approx. 1200 Live View Shooting - At 73°F/23°C: Approx. 270 - At 32°F/0°C: Approx. 230 * Based on a fully-charged LP-E4 and CIPA (Camera & Imaging Products Association) testing standards. |
Battery Check | Automatic battery check when the power switch is turned ON Displayed in one of six levels * Displayed on LCD panel, in the viewfinder, and battery information screen. |
Power Saving | Provided. Power turns off after 1, 2, 4, 8, 15, 30 min. |
Date/Time Battery | One CR2025 lithium battery x 1 |
Start-up Time | Approx. 0.1 sec. (Based on CIPA testing standards) * Approx. 0.2 sec. based on previous specification standard. |
Dimensions (W x H x D) | 6.1 x 6.2 x 3.1 in./156 x 156.6 x 79.9mm |
Weight | Approx. 1180 g / 41.6 oz. |
Working Temperature Range | 32-113°F/0-45°C |
Working Humidity Range | 85% or less |
Type | For LP-E4 Rechargeable lithium ion battery |
Rated Voltage | 11.1 V DC |
Battery Capacity | 2300mHh |
Dimensions (W x H x D) | 68.4 x 34.2 x 92.8mm/2.7 x 1.3 x 3.7 in. |
Weight | 180g/6.3 oz. (excluding protective cover) |
Type | For LC-E4 Charger dedicated to the Battery Pack LP-E4 |
Recharging Time | Approx. 120 min. (for 1 pack) |
Rated Input | 100-240 V AC (50/60 Hz) 12 V/24 V DC |
Rated Output | 12.6 V DC, 1.55 A |
Working Temperature Range | 0°C-40°C/32°F - 104°F |
Dimensions (W x H x D) | 155 x 52.3 x 95mm/6.1 x 2.1 x 3.7 in. |
Weight | 340g/12.0 oz. (excluding power cord and protective covers) |
Type | For ACK-E4 * Car Battery Cable CB-570 connectable. |
Rated Input | 12.6 V DC |
Rated Output | 11.1 V DC |
Cord Length | Approx. 2.3 m/7.5 ft. |
Working Temperature | 0°C-45°C/32°F-113°F |
Working Humidity | 85% or less |
Weight (Approx.) | 165g/5.8 oz. (excluding protective cover) |
USB Tethered SDK | Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
