Canon Support for EOS 60D | Canon U.S.A., Inc.
EOS 60D
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 07.23.12
File Size 6.38 MB
Date 01.25.12
File Size 10.69 MB
Date 08.25.10
File Size 1.67 MB
Date 10.15.10
File Size 8.41 MB
Date 07.23.12
File Size 6.88 MB
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 04.02.12
File Size 19.49 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
Type Digital AF/AE SLR
Recording Media Type I and II CF card
Image Format 22.7 x 15.1 mm (0.89 x 0.59 in.)
Compatible Lenses Canon EF lenses.
Lens Mount Canon EF mount
Image Sensor
Type High-sensitivity, high-resolution, single-plate, color CMOS
Pixels Effective pixels: Approx. 6.3 megapixels
Total Pixels Approx. 6.52 megapixels
Aspect Ratio 3:2
Color Filter System RGB primary color filter
Low Pass Filter Located in front of the imaging element, non-removable
Recording System
Recording Format Design rule for Camera File system (JPEG) and RAW. Exif 2.2 compliant
Image Format JPEG and RAW
File Size 1) Large/Fine: Approx. 2.5 MB (3072 x 2048), (2) Large/ Normal: Approx.1.3 MB (3072 x 2048), (3) Middle/Fine: Approx. 1.4 MB (2048 x 1360), (4) Middle/Normal: Approx. 0.7 MB (2048 x1360), (5) Small / Fine: Approx. 0.9 MB (1536 x 1024), (6) Small/ Normal: Approx. 0.5 MB (1536 x 1024), (7) RAW: Approx. 7.4 MB (3072 x 2048)
Folders Set automatically
File Numbering (1) Serial numbering, (2) Auto reset
Interface USB Ver. 1.1
White Balance
Settings Auto, daylight, overcast, tungsten light, fluorescent light, flash, and manual (read off 18% gray card or white subject)
Viewfinder
Type SLR-type, eye-level viewfinder (with fixed pentaprism and no condenser lens)
Coverage Approx. 95% vertically and horizontally with respect to the effective pixels
Eye Point 20mm
Dioptric Adjustment Correction -3.0 - +1.0 diopter
Focusing Screen Fixed, new laser matte screen
Mirror Quick-return half mirror (Transmission: reflection ratio of 40:60, no mirror cut-off with EF 600mm f/4 or shorter lens)
Viewfinder Information AF points, partial metering circle, shutter speed, aperture, shots remaining, busy, CF card full, CF card error, no CF card, AElock, FE lock, exposure level, flash exposure compensation, flash ready, highspeed sync and AF/MF focus confirmation
Depth Of Field Preview Enabled with depth-of-field preview button
Eyepiece Shutter None
Autofocus
Type Multi-BASIS, TTL-CT-SIR (TTL secondary phase difference detection)
AF Points 3
AF Working Range EV 0.5-18 (at ISO 100)
Focusing Modes One-Shot AF, Predictive AI Servo AF, One-Shot/Predictive AI Servo AF (D60 automatically selects One-Shot AF or AI Servo AF), Manual focusing (MF)
AF Point Selection Automatic selection or manual selection
Selected AF Point Display Superimposed in viewfinder and indicated on LCD panel
AF Assist Beam Incandescent lamp, maximum effective range 12.5 ft./3.8m
Exposure Control
Metering Modes TTL full aperture metering with 35-zone SPC. (1) Evaluative metering, (2) Partial metering at center (approx. 9.5% of viewfinder), (3) Centerweighted average metering
Metering Range EV 2-20 (at normal temperature with 50mm f/1.4 lens at ISO 100) Exposure Control Systems: Program AE (shiftable), shutter-priority AE, aperture priority AE, depth-of-field AE, full auto, programmed image control modes (Portrait, Landscape, Close-up, Sports, and Night Scene), E-TTL flash AE, and manual
ISO Speed Range Equivalent to ISO 100-1000
Exposure Compensation Auto exposure bracketing (AEB): +/-2 stops in 1/2 or 1/3-stop incrementsManual: +/-2 stop in 1/2 or 1/3-stop increments
AE Lock Auto: Operates in One-Shot AF mode evaluative metering when focus is achievedManual: By AE lock button in all metering modes
Shutter
Type Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled
Shutter Speeds 1/4000 to 30 sec. (1/3 and 1/2-stop increments), bulb, X-sync at 1/200 sec.
Shutter Release Soft-touch electromagnetic release
Self Timer Electronically-controlled 10-sec. delay
Remote Control Remote control with N3 type contact
Built in Flash
Type Auto pop-up, retractable, built-in flash in the pentaprism with serial control, E-TTL autoflash
Guide Number 12/39 (at ISO 100 in meters/feet)
Recycling Time Approx. 3 sec.
Flash Ready Indicator Flash-ready icon lights on in viewfinder
Flash Coverage Up to 18mm lens angle of view (equivalent to 28mm in 35mm format)
External Speedlite
EOS Dedicated Speedlite E-TTL autoflash with EX series Speedlite
Drive System
Drive Modes Single frame, Continuous, self-timer
Continuous Shooting Speed Approx. 3 fps (at 1/250 sec. or faster shutter speed) Max. burst during continuous shooting: 8 shots
LCD Monitor
Type TFT color LCD monitor
Monitor Size 1.8 inches
Pixels Approx. 114,000 pixels
Coverage 100% with respect to the effective pixels
Brightness Control 2-level (standard/brighter) adjustment provided
Playback
Display Format (1) Single image with information(2) Single image(3) 9-image index(4) Magnified(5)Auto play
Highlight Alert In the single image with information display mode, the highlight portions which do not contain image information will blink
Image Protection and Erase
Protection A single image can be protected or unprotected
Erase A single image or all images stored in a CompactFlash card can be erased if they are unprotected
Menus
Menu Categories (1) Shooting Menus [8]
(2) PlaybackMenus [4]
(3) Setup Menus [11]
LCD Monitor Language English, Japanese, French, or German
Firmware Update Updating by the user is possible
Power Source
Battery One Battery Pack BP-511 (lithium ion rechargeable battery)
Number of Shots
Dimensions and Weight
Dimensions (W x H x D) 5.9 x 4.2 x 3.0 in. / 149.5 x 106.5 x 75 mm
Weight 27.5 oz. / 780g
Operating Environment
Working Temperature Range 0 - 40&deg; C / 32-104&deg; F
Working Humidity Range 85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Service Notice: Photo Culling App Version 1.1
Advisory Type
Date 06.01.21
Title Canon Support | Safety Notice: Counterfeit Lithium-ion Battery Packs and Chargers (updated)
Advisory Type
Date 01.23.12
Title Canon Support | Firmware Notice: EOS 60D: Firmware Version 1.1.2
Advisory Type
Date 11.27.16
Title Canon Support | Service Notice: Photo Culling App Version 2.0 for iOS
Advisory Type
Date 11.16.21
Title Canon Support | Service Notice: EOS 7D, EOS 40D, EOS 50D, and EOS 60D: Peripheral AF points do not function as cross-type AF points
Advisory Type
Date 02.20.11
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
