Canon Support for EOS 60D | Canon U.S.A., Inc.
        EOS 60D
- Windows 11
 - Windows 10 (x64)
 - Windows 10
 - Windows 8.1 (x64)
 - Windows 8.1
 - Windows 8 (x64)
 - Windows 8
 - Windows 7 (x64)
 - Windows 7
 - Windows Vista (x64)
 - Windows Vista
 - Windows Me
 - Windows XP (x64)
 - Windows XP
 - Windows 98
 - Windows 95
 - Windows Server 2022
 - Windows Server 2019 (x64)
 - Windows Server 2016 (x64)
 - Windows Server 2012 (x64)
 - Windows Server 2008 (x64)
 - Windows Server 2003 (x64)
 - Windows Server 2003 R2
 - macOS Tahoe v26
 - macOS Sequoia v15
 - macOS Sonoma v14
 - macOS Ventura v13
 - macOS Monterey v12
 - macOS Big Sur v11.0
 - macOS Catalina v10.15
 - macOS Mojave v10.14
 - macOS High Sierra v10.13
 - macOS Sierra v10.12
 - OS X El Capitan v10.11
 - OS X Yosemite v10.10
 - OS X Mavericks v10.9
 - OS X Mountain Lion v10.8
 - OS X Lion v10.7
 - Mac OS X Snow Leopard v10.6
 - Mac OS X v10.1
 - Mac OS 9
 - Linux ARM
 - Linux MIPS
 - Linux 64bit
 - Linux 32bit
 - SAP
 - Windows Server 2025
 - Windows NT
 - Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type
| Type | Digital AF/AE SLR |
| Recording Media | Type I and II CF card |
| Image Format | 22.7 x 15.1 mm (0.89 x 0.59 in.) |
| Compatible Lenses | Canon EF lenses. |
| Lens Mount | Canon EF mount |
Image Sensor
| Type | High-sensitivity, high-resolution, single-plate, color CMOS |
| Pixels | Effective pixels: Approx. 6.3 megapixels |
| Total Pixels | Approx. 6.52 megapixels |
| Aspect Ratio | 3:2 |
| Color Filter System | RGB primary color filter |
| Low Pass Filter | Located in front of the imaging element, non-removable |
Recording System
| Recording Format | Design rule for Camera File system (JPEG) and RAW. Exif 2.2 compliant |
| Image Format | JPEG and RAW |
| File Size | 1) Large/Fine: Approx. 2.5 MB (3072 x 2048), (2) Large/ Normal: Approx.1.3 MB (3072 x 2048), (3) Middle/Fine: Approx. 1.4 MB (2048 x 1360), (4) Middle/Normal: Approx. 0.7 MB (2048 x1360), (5) Small / Fine: Approx. 0.9 MB (1536 x 1024), (6) Small/ Normal: Approx. 0.5 MB (1536 x 1024), (7) RAW: Approx. 7.4 MB (3072 x 2048) |
| Folders | Set automatically |
| File Numbering | (1) Serial numbering, (2) Auto reset |
| Interface | USB Ver. 1.1 |
White Balance
| Settings | Auto, daylight, overcast, tungsten light, fluorescent light, flash, and manual (read off 18% gray card or white subject) |
Viewfinder
| Type | SLR-type, eye-level viewfinder (with fixed pentaprism and no condenser lens) |
| Coverage | Approx. 95% vertically and horizontally with respect to the effective pixels |
| Eye Point | 20mm |
| Dioptric Adjustment Correction | -3.0 - +1.0 diopter |
| Focusing Screen | Fixed, new laser matte screen |
| Mirror | Quick-return half mirror (Transmission: reflection ratio of 40:60, no mirror cut-off with EF 600mm f/4 or shorter lens) |
| Viewfinder Information | AF points, partial metering circle, shutter speed, aperture, shots remaining, busy, CF card full, CF card error, no CF card, AElock, FE lock, exposure level, flash exposure compensation, flash ready, highspeed sync and AF/MF focus confirmation |
| Depth Of Field Preview | Enabled with depth-of-field preview button |
| Eyepiece Shutter | None |
Autofocus
| Type | Multi-BASIS, TTL-CT-SIR (TTL secondary phase difference detection) |
| AF Points | 3 |
| AF Working Range | EV 0.5-18 (at ISO 100) |
| Focusing Modes | One-Shot AF, Predictive AI Servo AF, One-Shot/Predictive AI Servo AF (D60 automatically selects One-Shot AF or AI Servo AF), Manual focusing (MF) |
| AF Point Selection | Automatic selection or manual selection |
| Selected AF Point Display | Superimposed in viewfinder and indicated on LCD panel |
| AF Assist Beam | Incandescent lamp, maximum effective range 12.5 ft./3.8m |
Exposure Control
| Metering Modes | TTL full aperture metering with 35-zone SPC. (1) Evaluative metering, (2) Partial metering at center (approx. 9.5% of viewfinder), (3) Centerweighted average metering |
| Metering Range | EV 2-20 (at normal temperature with 50mm f/1.4 lens at ISO 100) Exposure Control Systems: Program AE (shiftable), shutter-priority AE, aperture priority AE, depth-of-field AE, full auto, programmed image control modes (Portrait, Landscape, Close-up, Sports, and Night Scene), E-TTL flash AE, and manual |
| ISO Speed Range | Equivalent to ISO 100-1000 |
| Exposure Compensation | Auto exposure bracketing (AEB): +/-2 stops in 1/2 or 1/3-stop incrementsManual: +/-2 stop in 1/2 or 1/3-stop increments |
| AE Lock | Auto: Operates in One-Shot AF mode evaluative metering when focus is achievedManual: By AE lock button in all metering modes |
Shutter
| Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled |
| Shutter Speeds | 1/4000 to 30 sec. (1/3 and 1/2-stop increments), bulb, X-sync at 1/200 sec. |
| Shutter Release | Soft-touch electromagnetic release |
| Self Timer | Electronically-controlled 10-sec. delay |
| Remote Control | Remote control with N3 type contact |
Built in Flash
| Type | Auto pop-up, retractable, built-in flash in the pentaprism with serial control, E-TTL autoflash |
| Guide Number | 12/39 (at ISO 100 in meters/feet) |
| Recycling Time | Approx. 3 sec. |
| Flash Ready Indicator | Flash-ready icon lights on in viewfinder |
| Flash Coverage | Up to 18mm lens angle of view (equivalent to 28mm in 35mm format) |
External Speedlite
| EOS Dedicated Speedlite | E-TTL autoflash with EX series Speedlite |
Drive System
| Drive Modes | Single frame, Continuous, self-timer |
| Continuous Shooting Speed | Approx. 3 fps (at 1/250 sec. or faster shutter speed) Max. burst during continuous shooting: 8 shots |
LCD Monitor
| Type | TFT color LCD monitor |
| Monitor Size | 1.8 inches |
| Pixels | Approx. 114,000 pixels |
| Coverage | 100% with respect to the effective pixels |
| Brightness Control | 2-level (standard/brighter) adjustment provided |
Playback
| Display Format | (1) Single image with information(2) Single image(3) 9-image index(4) Magnified(5)Auto play |
| Highlight Alert | In the single image with information display mode, the highlight portions which do not contain image information will blink |
Image Protection and Erase
| Protection | A single image can be protected or unprotected |
| Erase | A single image or all images stored in a CompactFlash card can be erased if they are unprotected |
Menus
| Menu Categories | (1) Shooting Menus [8] (2) PlaybackMenus [4] (3) Setup Menus [11]  |
| LCD Monitor Language | English, Japanese, French, or German |
| Firmware Update | Updating by the user is possible |
Power Source
| Battery | One Battery Pack BP-511 (lithium ion rechargeable battery) |
| Number of Shots |
Dimensions and Weight
| Dimensions (W x H x D) | 5.9 x 4.2 x 3.0 in. / 149.5 x 106.5 x 75 mm |
| Weight | 27.5 oz. / 780g |
Operating Environment
| Working Temperature Range | 0 - 40° C / 32-104° F |
| Working Humidity Range | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
 - Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
 next to your download
