Canon Support for EOS 70D EF-S 18-135mm IS STM Lens Kit | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type | CMOS Sensor |
Pixels | Effective pixels: Approx. 20.2 Megapixels Total pixels: Approx. 20.9 Megapixels |
Pixel Unit | 4.1 µm square |
Total Pixels | Approx. 19.0 megapixels |
Aspect Ratio | 3:2 (Horizontal: Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Fixed position in front of the image sensor |
Dust Deletion Feature | (1) Self Cleaning Sensor UnitRemoves dust adhering to the low-pass filter. Self-cleaning executed automatically (taking approx. 2 sec.) when power is turned on or off. Manual execution also possible (taking approx. 5 sec.).(2) Dust Delete Data acquisition and appending The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images. The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots.(3) Manual cleaning |
Recording Format | Complete with Design rule for Camera File System 2.0 and EXIF 2.30 |
Image Format | Still: JPEG: JPG, RAW: CR2 (Canon Raw 2nd edition), RAW+JPEG Video: MOV (Image data: H.264, Audio: Linear PCM) |
File Size | 3:2 Aspect Ratio Large: Approx. 20.0 Megapixels (5472 x 3648); Medium: Approx. 8.9 Megapixels (3648 x 2432); Small 1: Approx. 5.0 Megapixels (2736 x 1824); Small 2: Approx. 2.50 Megapixels (1920 x 1280); Small 3: Approx. 0.35 Megapixels (720 x 480) RAW: Approx. 20.0 Megapixels (5472 x 3648); mRAW: Approx. 11.2 Megapixels (4104 x 2736); sRAW: Approx. 5.0 Megapixels (2736 x 1824) 4:3 Aspect Ratio Large: Approx. 17.7 Megapixels (4864 x 3648); Medium: Approx. 7.9 Megapixels (3248 x 2432); Small 1: Approx. 4.4 Megapixels (2432 x 1824); Small 2: Approx. 2.2 Megapixels (1696 x 1280); Small 3: Approx. 0.31 Megapixels (640 x 480) RAW: Approx. 17.7 Megapixels (4864 x 3648); mRAW: Approx. 10.0 Megapixels (3648 x 2736); sRAW: Approx. 4.4 Megapixels (2432 x 1824)16:9 Aspect Ratio Large: Approx. 16.8 Megapixels (5472 x 3072); Medium: Approx. 7.5 Megapixels (3648 x 2048); Small 1: Approx. 4.2 Megapixels (2736 x 1536); Small 2: Approx. 2.1 Megapixels (1920 x 1080); Small 3: Approx. 0.29 Megapixels (720 x 408) RAW: Approx. 16.8 Megapixels (5472 x 3072); mRAW: Approx. 9.5 Megapixels (4104 x 2310); sRAW: Approx. 4.2 Megapixels (2736 x 1536)1:1 Aspect Ratio Large: Approx. 13.3 Megapixels (3648 x 3648); Medium: Approx. 5.9 Megapixels (2432 x 2432); Small 1: Approx. 3.3 Megapixels (1824 x 1824); Small 2: Approx. 1.6 Megapixels (1280 x 1280); Small 3: Approx. 0.23 Megapixels (480 x 480)RAW: Approx. 13.3 Megapixels (3648 x 3648); mRAW: Approx. 7.5 Megapixels (2736 x 2736); sRAW: Approx. 3.3 Megapixels (1824 x 1824) |
Backup Recording | Not Available |
File Numbering | The following three types of file numbering methods can be set: (1) Continuous numbering * The numbering of captured images will continue even after you replace the camera's card. (2) Auto reset * When you replace the camera's card, the numbering will be reset to start from 0001. If the new card already contains images, the numbering will continue from the last recorded image on the card. (3) Manual reset * Resets the file number to 0001, and creates a new folder automatically. |
Color Space | sRGB, Adobe RGB |
Picture Style | Auto, Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined 1-3 * In Basic Zone modes, "Auto" is set automatically. * In Creative Zone modes, you can select or set the Picture Style. * Default settings for [User Defined 1-3] are [Auto]. |
Settings | Auto, Preset (Daylight; Shade; Cloudy, Twilight, Sunset; Tungsten light; White Fluorescent Light; Flash), Custom (Approx. 2,000° - 10,000°K), Color Temperature (Approx. 2,500° - 10,000°K) |
Auto White Balance | Auto white balance with the image sensor |
Color Temperature Compensation | Blue/amber bias: ±9 levels Magenta/green bias: ±9 levels * Correction based on the current WB mode's color temperature. |
Color Temperature Information Transmission | Provided |
Type | Eye-level SLR (with fixed pentaprism) |
Coverage | Approx. 98% vertically and horizontally (with eye point approx. 22mm) |
Magnification | Approx. 0.95x / 27.9° (50mm lens at ∞, -1m-1 dpt) |
Eye Point | Approx. 22mm (At -1m-1 from the eyepiece lens center) |
Dioptric Adjustment Correction | Adjustable from approx. -3.0 to +1.0m-1 (dpt) |
Focusing Screen | Fixed |
Mirror | Quick-return half mirror (transmission: reflection ratio of 40:60) |
Viewfinder Information | AF information AF points, focus confirmation, AF area selection modeExposure information Shutter speed, aperture, ISO speed (always displayed), AE lock, exposure level, spot metering circle, exposure warningFlash information Flash ready, flash exposure compensation, high-speed sync, FE lock, red-eye reduction lightImage information Highlight tone priority (D+), maximum burst (2-digit display), card informationComposition information Grid, electronic levelAlert symbol |
Depth Of Field Preview | Enabled with depth-of-field preview button |
Type | TTL secondary image-forming, phase-difference detection with AF-dedicated CMOS sensor |
AF Points | 19-point cross-type AF All AF points are cross-type at f/5.6. Center AF point is cross-type at f/2.8. |
AF Working Range | Center AF Point: EV -0.5 to 18* Other AF Points: EV 0 to EV 18* * At room temperature and ISO 100, based on Canon's testing standards |
Focusing Modes | (1) Autofocus One-Shot AFPredictive AI Servo AFAI Focus AF*Switches between One-Shot AF and AI Servo AF(2) Manual focus |
AF Point Selection | (1) Manual selection (2) Auto selection *Automatically set in Basic Zone modes. |
Selected AF Point Display | Indicated by translucent liquid crystal display in the viewfinder and on the LCD monitor. |
AF Assist Beam | Intermittent firing of built-in flash Effective range: Approx. 13.1 ft. / 4.0m at center, approx. 11.5 ft. / 3.5m at periphery * With an EOS-dedicated Speedlite attached, the Speedlite's AF-assist beam is emitted instead. * Compatible with AF assist-beam (intermittent firing) of 320EX, 270EX II and 270EX flashes. |
Metering Modes | TTL maximum aperture metering with 63-zone metering sensor:Evaluative metering (linked to all AF points)Partial metering (center, approx. 7.7% of viewfinder)Spot metering (center, approx. 3.0% of viewfinder)Center-weighted average metering |
Metering Range | EV 1-20 (at 73°F/23°C, ISO 100) |
Exposure Control Systems | Creative Zone (1) Program AE (shiftable) (2) Shutter-priority AE (3) Aperture-priority AE (4) Manual exposure (5) Bulb (6) Custom shooting mode Basic zone (1) Scene Intelligent Auto (Program AE / non-shiftable) (2) Flash OFF (3) Creative Auto (4) Special Scene1) Portrait 2) Landscape 3) Close-up 4) Sports 5) Night Portrait 6) Handheld Night Scene 7) HDR Backlight Control |
ISO Speed Range | For Stills: Manual setting range of ISO 100-12800, expansion to ISO 25600 equivalent*1: Depends on the minimum and maximum of Auto ISO setting. *2: If shooting in bright light results in overexposure, the ISO speed can be set as low as ISO 100. *3: Auto, Night Portrait and Handheld Night Scene are excluded. *4: If you use bounce flash with an external Speedlite in the Creative Auto, Portrait, Landscape, Close-up, Sports or P modes, the ISO speed is set automatically within ISO 400-1600. |
Exposure Compensation | (1) Manual: ±5 stops in 1/3- or 1/2-stop increments (2) AEB: ±3 stops in 1/3- or 1/2-stop increments * Manual exposure compensation and AEB can be set in combination. * AEB is set in the following sequence: Standard exposure, decreased exposure, and increased exposure. If AEB is used with the self-timer, three continuous shots will be taken regardless of the current drive mode. * Number of bracketed shots: 2, 3, 5 or 7 settable with C.Fn. |
AE Lock | (1) Auto AE lock * In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved. (2) Manual AE lock * Enabled with the AE lock button (Press again to update.) in all metering modes. |
Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled |
Shutter Speeds | 1/8000 to 30 sec., X-sync at 1/250 sec. (Total shutter speed range. Available range varies by shooting mode.) |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. or 2-sec. delay |
Shutter Lag Time | (1) During SW-1 ON, time lag between SW-2 ON and start of exposure: Approx. 0.06 sec. * About 0.1 sec. in case of silent shooting. (2) Time lag between simultaneous SW-1/SW-2 ON and start of exposure: Approx. 0.14 sec. * About 0.18 sec. in case of silent shooting. * Time lag with the aperture stopped down by 3.5 stops or less (Excludes AF operation time). |
Type | Auto pop-up, retractable, built-in flash in the pentaprism |
Guide Number | Approx. 39.4 ft./12m (at ISO 100) |
Flash Coverage | Up to 17mm focal length (equivalent to approx. 27mm in 135 format) |
Flash Exposure Compensation | Up to ±3 stops in 1/3- or 1/2-stop increments |
Flash Metering | E-TTL II autoflash (evaluative flash metering and average flash metering), FE lock |
Flash Exposure Compensation | ±3 stops in 1/3- or 1/2-stop increments |
FE Lock | Provided |
External Flash Settings | (1) External flash function setting * Flash firing, E-TTL II auto flash system, flash mode, wireless master, zoom, sync setting, flash exposure compensation, FEB, and clear setting. * With the 600EX-RT and ST-E3-RT, radio wireless transmission control is possible. (2) External flash C.Fn setting * The actual setting options for (1) and (2) will differ depending on the Speedlite used. |
Drive Modes | (1) Single shooting (2) High-speed continuous shooting (3) Low-speed continuous shooting (4) Silent single shooting (5) Silent continuous shooting (6) 10-sec. self-timer/Remote control (7) 2-sec. self-timer/Remote control |
Continuous Shooting Speed | High-speed continuous shooting: Max. approx. 7.0 fps * At 1/500 sec. or faster shutter speed, and at the maximum aperture (varies depending on the lens) Low-speed continuous shooting: Max approx. 3.0 fps. Silent continuous shooting: Max approx. 3.0 fps. |
Maximum Burst | Based on 8GB memory Card: JPEG Large/Fine: Approx. 40 Shots RAW: Approx. 15 Shots RAW+JPEG Large/Fine: 8 Shots Based on 8GB UHS-I memory card: JPEG Large/Fine: Approx. 65 Shots RAW: Approx. 16 Shots RAW + JPEG Large/Fine: 8 Shots * Figures are based on Canon's testing standards (ISO 100 and Standard Picture Style). * At ISO 12800, maximum burst will greatly decrease due to internal processing. |
Shooting Modes | Still photo shooting and video shooting |
Focusing | (1) AF operation with Dual Pixel CMOS AF, One-shot AFFace Detection plus Tracking AFFlexiZone - Multi* 31 zones * AF at the touched zoneFlexiZone - Single(2) TTL secondary image-forming, phase-difference detection with AF operation, One-shot AFManual selection: Single point AFManual selection: Zone AFAuto selection: 19-point AF* Automatically set in Basic Zone modes(3) Manual focus* Manual focusing by enlarging images by approx. 5 to 10 times |
Metering Modes | Real-time evaluative metering with image sensor. (1) Evaluative metering (315 zones) (2) Partial metering (approx. 10.3% of Live View screen) (3) Spot metering (approx. 2.6% of Live View screen) (4) Center-weighted average metering * AE lock possible. The active metering time can be changed. |
Metering Range | EV 1-18 (with Dual Pixel CMOS AF at 73°F/23°C and ISO 100) |
Grid Display | Three grids provided: (1) Grid 1: 3 vertical and 3 horizontal lines (2) Grid 2: 6 vertical and 4 horizontal lines (3) Grid 3: 3 vertical and 3 horizontal lines + diagonal |
Exposure Simulation | Provided |
Silent Shooting | Provided (Mode 1 and Mode 2) |
File Format | MOV: Movie: MPEG-4 AVC / H.264 * Variable (average) bit rate Audio: Linear PCM *Meta information is embedded in the MOV file (no separate THM file) |
File Size | Recording Size: [Full HD] 1920 x 1080 (30 fps/25fps/24fps): 235 MB/min. with IPB compression 685 MB/min. with All-I compression [HD] 1280 x 720 (60 fps/50 fps): 205 MB/min. with IPB compression 610 MB/min. with All-I compression [SD] 640 x 480 (30 fps/25 fps): 78 MB/min. with IPB compression * If the file size exceed 4GB, a new file will be automatically created. ** See following section for actual frame rates. |
Frame Rates | 1920 x 1080 (Full HD): 30p (29.97) / 25p / 24p (23.976) 1280 x 720 (HD): 60p (59.94) / 50p 640 x 480 (SD): 30p (29.97) / 25p |
Continuous Shooting Time | Based on 8GB Memory Card [1920 x 1080] 30 fps / 25 fps / 24 fps: 32 min. with IPB compression 11 min. with All-I compression [1280 x 720] 60 fps / 50 fps: 37 min. with IPB compression 12 min. with All-I compression [640 x 480] 30 fps / 25 fps: 97 min. with IPB or All-I compression * The maximum recording time is limited to 29 min. 59 sec. ** See Frame Rates section for actual frame rates |
Focusing | Dual Pixel CMOS AF (1) One-shot AF (2) Servo AF (3) Manual Focus *Magnify the image by approx. 5x or approx. 10x and focus manually. AF using AF point selection:Face Detection plus Tracking AFFlexiZone - Multi* 31 zones * AF at the touched zoneFlexiZone - Single |
Exposure Control | (1) Program AE for movie shooting * In Basic Zone modes, P, Av, and Tv modes * Shutter speed 1/30 - 1/4000 sec. (Signal accumulation time), aperture, and ISO speed automatically set.(2) Manual exposure * Shutter speed (signal accumulation time), aperture, and ISO speed (auto/manual) manually set. The shutter speed (signal accumulation time) is limited to 1/4000 sec. at the maximum and to 1/30 sec. at the minimum for 24/25/30 fps or 1/60 sec. or higher for 50/60 fps. |
Exposure Compensation | Provided (±3 stops in 1/3-stop increments) * For movies, exposure compensation will not be applied beyond ±3 stops even if the exposure compensation has been set beyond ±3 stops.* For still photo shooting, the exposure compensation can be set and applied up to ±5 stops. |
Type | TFT color, liquid-crystal monitor with Touch Panel LCD (capacitive type) |
Monitor Size | Wide 3.0-inch (Screen aspect ration of 3:2) 7.7cm diagonal (6.37cm wide, 4.25cm high) |
Pixels | Approx. 1,040,000 dots |
Coverage | Approx. 100% |
Brightness Control | Adjustable to one of seven levels |
Coating | Anti-smudge, anti-reflection coating |
Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese) |
On LCD Monitor | Single image displaySingle image, basic information, detailed information, histogramIndex display4-image index, 9-image indexJump display1/10/100 images, by date, by folder, movies only, stills only, by rating |
Highlight Alert | With single-image display (Info.) and single-image display, overexposed highlight areas will blink |
Histogram | Brightness / RGB |
Items | When you press the Quick Control function button under the following conditions, you can set the functions below: * The settable functions depend on the shooting mode. Viewfinder shooting:Shutter speed, aperture, ISO speed, exposure compensation/ AEB, flash exposure compensation, Picture Style, White balance, White balance correction/White balance bracketing, Auto Lighting Optimizer, Metering mode, AF operation, Drive mode/Self-timer, image-recording quality, Flash firings, Ambience-based shots, Light/scene-based shots, Special scene modes, and wireless LAN connection.Live View shooting:Scene Setting, AF method, Drive mode, Metering mode, Image-recording quality, White balance, Picture Style, Auto Lighting Optimizer, Creative Filters, Flash firing, Ambience-based shots, Light/scene-based shots, and Background blurring/sharpening.Movie shooting:AF Method, Drive mode, Movie-recording size, Digital zoom, White Balance, Picture Style, Auto Lighting Optimizer and Video Snapshot. When you press the Quick Control function button under the following conditions, you can set the functions below:During still photo playback:Image protect, image rotate, rating, Creative Filters, resize, Cropping, and image jump with Main DialDuring movie playback:Image protect, rating, and image jump with Main Dial |
Protection | Erase protection can be applied / canceled for a single image, all images in a folder, or all images on the card |
Erase | Erase single image, erase selected images, erase all images in folder, erase all images on a card, or erase only unprotected images |
Compatible Printers | PictBridge-compatible printers |
Printable Images | RAW, JPEG, and RAW+JPEG images complying to Design rule for Camera File System * Movies cannot be printed. |
DPOF | Complies to DPOF Version 1.1 |
Compatible Images | Not Provided |
Custom Functions | 23 Custom Functions settable with camera |
Custom Controls | The following camera controls can be customized by assigning the desired function: Shutter button halfway pressing, AF-ON button, AE lock button, Depth-of-field preview button, Lens AF Stop button, SET button, Main Dial, Quick Control Dial, and Multi-controller |
My Menu Registration | Up to six items from top-tier menu options and Custom Function settings can be registered |
USB Terminal | For personal computer communication and PictBridge (Hi-Speed USB) Audio (stereo)/video (NTSC/PAL) output To connect a GP-E2 GPS Receiver * When connected via interface cable, GP-E2 cannot be used with Wi-Fi® functions simultaneously. *When GP-E2 is connected via hot shoe, Wi-Fi® functions and GP-E2 can be used simultaneously. * PC communication and direct printing cannot be performed when Wi-Fi® functions are used. |
Video Out Terminal | HDMI Type C (Switches automatically to suit the resolution) Video output: 1080/60i, 1080/50i, 480/60p, 576/50p *Switches automatically to 1, 2, 3, or 4 to suit the TV |
Battery | Battery Pack LP-E6 x1 *With the AC Adapter Kit ACK-E6, AC power is possible. *With Battery Grip BG-E14, it is possible to use two Battery Pack LP-E6 units. |
Number of Shots | |
Battery Life | (1) Camera Body Only, LP-E6 x1(2) Using Battery Grip BG-E14 |
Battery Check | Automatic battery level check when power is turned ON Battery level indicated in 6 levels. |
Power Saving | Power turns off after the set time of non-operation elapses *[Auto power off] settable to 1 min., 2 min., 4 min., 8 min., 15 min., 30 min., or disable |
Date/Time Battery | Built-in secondary battery It is not replaceable by the user. It recharges when LP-E6 is loaded or when the AC adapter is connected. Without any recharging, the backup battery can maintain the date/time for approx. 3 months. The backup battery taxes approx. 8 hours to be fully recharged. |
Start-up Time | Approx. 0.15 sec. (Based on CIPA testing standards) |
Dimensions (W x H x D) | Approx. 5.5 x 4.1 x3.1 in. Approx. 139.0 x 104.3 x 78.5mm |
Weight | Approx. 26.7 oz. / 755g (W Model: CIPA standard) Approx. 23.8 oz. / 675g (W Model: Body only) |
Working Temperature Range | 32-104°F/0-40°C |
Working Humidity Range | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
