Canon Support for EOS 77D | Canon U.S.A., Inc.
EOS 77D
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- macOS 26
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital AF/AE single-lens reflex camera with built-in flash |
Recording Media | SD/SDHC/SDXC memory cards
Image Format | Approx. 22.3 x 14.9mm (APS-C Size) |
Compatible Lenses | Canon EF lenses (including EF-S lenses, excluding EF-M lenses) |
Lens Mount | Canon EF mount |
Type | CMOS sensor (supporting Dual Pixel CMOS AF) |
Pixels | Effective pixels: Approx. 24.2 Megapixels Total pixels: Approx. 25.8 Megapixels |
Pixel Unit | Approx. 3.72 µm square |
Aspect Ratio | 3:2 (Horizontal: Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Installed in front of the image sensor, non-detachable |
Dust Deletion Feature |
Recording Format | Compliant to Design rule for Camera File system 2.0 and EXIF 2.3 |
Image Format | Still Image: JPEG, RAW (14 bit Canon Original) Video: MOV (Full HD Movie: MPEG4 AVC/H.264*; Audio: Linear PCM), MP4 (Movie: MPEG4 AVC/H.264*; Audio: AAC) * Variable (averaged) bit rate |
File Size | 3:2 Aspect Ratio Large: 6000 x 4000 Medium: 3984 x 2656 Small 1: 2976 x 1984 Small 2: 2400 x 1600 RAW: 6000 x 4000 4:3 Aspect Ratio Large: 5328 x 4000* Medium: 3552 x 2664 Small 1: 2656 x 1992 Small 2: 2112 x 1600* RAW: 6000 x 4000 16:9 Aspect Ratio Large: 6000 x 3368* Medium: 3984 x 2240* Small 1: 2976 x 1680* Small 2: 2400 x 1344 RAW: 6000 x 4000 1:1 Aspect Ratio Large: 4000 x 4000 Medium: 2656 x 2656 Small 1: 1984 x 1984 Small 2: 1600 x 1600 RAW: 6000 x 4000
File Numbering | The following three types of file numbering method can be set:
RAW + JPEG Simultaneous Recording | Simultaneous recording is possible using a combination of RAW and JPEG (Large). |
Color Space | sRGB, Adobe RGB |
Picture Style |
Settings |
Auto White Balance | Option between ambience priority and white priority settings |
Color Temperature Compensation | Blue/amber bias: ±9 levels Magenta/green bias: ±9 levels Corrected in reference to the current WB mode’s color temperature. |
Type | Eye-level SLR (with fixed pentamirror) |
Magnification | Approx. 0.82x / 23.2° (50mm lens at ∞, -1m-1 dpt) |
Eye Point | Approx. 19mm (At -1m-1 from the eyepiece lens center) |
Dioptric Adjustment Correction | Adjustable from approx. -3.0 to +1.0m-1 (dpt) |
Focusing Screen | Fixed |
Mirror | Quick-return half mirror (transmission: reflection ratio of 40:60) |
Viewfinder Information | Displayed with transparent liquid crystal
Depth Of Field Preview | Provided with depth of field preview button |
Metering Modes | 7560-pixel RGB+IR metering sensor 63-zone (9 x 7) metering (1) Evaluative metering (linked to all AF points) (2) Partial metering (center, approx. 6.0% of viewfinder) (3) Spot metering (center, approx. 3.5% of viewfinder) (4) Center-weighted average metering |
Metering Range | EV 1-20 (room temperature, ISO 100, evaluative metering) |
Exposure Control Systems |
AE Lock |
Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled |
Shutter Speeds | 1/4000 to 30 sec., bulb (total shutter speed range. Available range varies by shooting mode.) X-sync at 1/200 sec. |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. or 2-sec. delay |
Shutter Lag Time |
Type | Auto pop-up, retractable built-in flash at the pentamirror |
Flash Metering System | E-TTL II autoflash with all EX Series Speedlites |
Guide Number | Approx. 39.4 / 12 (at ISO 100 in feet / meters) |
Flash Coverage | Up to approx. 17mm focal length (equivalent to approx. 28mm in 135 format) |
FE Lock | Provided |
Flash Exposure Compensation | ±2 stops in 1/3 - or 1/2 - stop increments
Flash Exposure Compensation | ±2 stops in 1/3- or 1/2-stop increments |
External Flash Settings |
Drive Modes and Continuous Shooting Speed during Viewfinder Shooting |
Shooting Modes | Still photo shooting and video shooting |
Focusing |
Metering Modes | Real-time metering with image sensor
Metering Range | EV 0-20 (room temperature, ISO 100, evaluative metering) |
Grid Display |
Exposure Simulation | ±3 stop increments |
File Format | MP4 Video: MPEG-4 AVC / H.264
MOV: LL-I (FHD 29.98, time-lapse movies only) |
Focusing |
Range | Full range (0-255) |
Type | TFT color, liquid-crystal monitor |
Monitor Size | 3.0-inch (screen aspect ratio of 3:2) Approx. 3.03 in./7.70cm diagonal (approx. 2.51 in./6.37cm width, approx. 1.67 in/4.25cm height) |
Pixels | Approx. 1.04 million dots |
Coverage | Approx. 95%* * When the aspect ratio is 16:9, vertical viewfinder coverage is approx. 93%. |
Brightness Control | Adjustable to one of seven brightness levels |
Coating | Clear View LCD II
Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese) |
Display Format |
Highlight Alert | With detailed information display, overexposed highlight areas with no image data will blink |
Histogram | Brightness and RGB |
Items | Pressing the Quick Control button displays the Quick Control screen during viewfinder shooting, Live View shooting, movie shooting and playback. After selecting an item, you can select contents by operating the Main Dial. |
Protection |
Erase | Except protected images
Compatible Printers | PictBridge-compatible printers (wireless LAN only) |
Printable Images | JPEG images compliant to Design rule for Camera File System
DPOF | Complies to DPOF Version 1.1 |
Custom Functions | 14 Custom Functions with 34 settings settable with the camera |
Custom Controls | Functions can be assigned to the following control parts:
USB Terminal | Hi-Speed USB (USB 2.0)
Video Out Terminal | Type C (resolution switches automatically)
Extension System Terminal | 3.5mm diameter stereo mini jack
Battery | Battery Pack LP-E17 x 1
Battery Check | Automatic battery check when the power switch is turned ON. Displayed in 4 levels. |
Power Saving | Power turns off after the set time (10/30* or 30 sec., 1, 2, 4, 8 or 15 min.) of non-operation elapses * Normally 10 sec. is set. 30 sec. will be set for function setting, Live View shooting, image playback, etc. |
Date/Time Battery | Built-in secondary battery When fully-charged, the date/time can be maintained for approx. 3 months
Start-up Time | Approx. 0.2 sec. (based on CIPA testing standards) |
Dimensions (W x H x D) | Approx. 5.16 x 3.93 x 3.00 in. (131.0 x 99.9 x 76.2mm)
Weight | Approx. 19.05 oz. / 540g (including battery pack and SD memory card) Approx. 17.39 oz. / 493g (body only) |
Working Temperature Range | 32-104°F/0-40°C |
Working Humidity Range | 85% or less |
USB Tethered SDK | Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
