Canon Support for EOS Digital Rebel XTi | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 10.20.10
File Size 11.20 MB
Date 03.31.07
File Size 4.49 MB
Date 06.09.08
File Size 5.33 MB
Date 03.31.07
File Size 3.67 MB
Date 09.30.07
File Size 11.53 MB
Date 10.14.10
File Size 8.08 MB
Date 04.13.09
File Size 7.50 MB
Date 07.22.12
File Size 6.88 MB
Date 06.09.08
File Size 10.99 MB
Date 06.09.08
File Size 4.94 MB
Date 04.15.09
File Size 6.96 MB
Date 01.24.12
File Size 10.69 MB
Date 03.31.07
File Size 6.92 MB
Date 04.01.25
File Size 142.00 B
Date 03.04.10
File Size 12.70 MB
Date 03.31.07
File Size 3.65 MB
Date 07.22.12
File Size 6.38 MB
Date 04.01.25
File Size 142.00 B
Date 11.21.07
File Size 2.34 MB
Date 10.14.10
File Size 8.41 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
Type Digital AF/AE SLR with built-in flash
Recording Media CompactFlash (CF) Card Type I & II
Image Format 0.87 x 0.58 in./22.2 x 14.8mm (APS-C size sensor)
Compatible Lenses Canon EF and EF-S lenses
Lens Mount Canon EF mount
Image Sensor
Type High-Sensitivity, high-resolution, single-plate, CMOS sensor
Pixels Approx. 10.10 megapixels
Total Pixels Approx. 10.50 megapixels
Aspect Ratio 3:2 (Horizontal : Vertical)
Color Filter System RGB primary color filters
Low Pass Filter Fixed position in front of the CMOS sensor
Dust Deletion Feature (1) Automatic sensor cleaning
(2) User-activated sensor cleaning
(3) Dust Delete Data appended to image data
Recording System
Recording Format JPEG, RAW, and RAW+JPEG simultaneous recording provided. The RAW and JPEG images are saved as separate files in the CF card.
Image Format JPEG, RAW (Canon .CR2)
File Size (1) Large/Fine: Approx. 3.8MB (3,888 x 2,592)
(2) Large/Normal: Approx. 2.0MB (3,888 x 2,592)
(3) Medium/Fine: Approx. 2.3MB (2,816 x 1,880)
(4) Medium/Normal: Approx. 1.2MB (2,816 x 1,880)
(5) Small/Fine: Approx. 1.3MB (1,936 x 1,288)
(6) Small/Normal: Approx. 0.7MB (1,936 x 1,288)
(7) RAW: Approx. 9.8MB (3,888 x 2,592)
File Numbering (1) Continuous numbering (2) Auto reset (3) Manual reset (the image numbering is reset to 0001, a new folder is created where subsequent images are saved)
Color Space Selectable between sRGB and Adobe RGB
Picture Style Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Def. 1-3
Interface USB 2.0 Hi-Speed, mini-B port. NTSC/PAL for video output
White Balance
Settings Auto, Preset (Daylight, Shade, Cloudy, Tungsten Light, White Fluorescent Light, Flash), Manual (Custom, or user-set Color Temperature)
Auto White Balance Auto white balance with the image sensor
Color Temperature Compensation White balance bracketing: +/- stops in 1-stop increments
White balance correction: blue/amber bias +/- 9 levels, magenta/green bias +/- 9 levels
Color Temperature Information Transmission Provided
Viewfinder
Type Eye-level SLR with pentamirror
Coverage Approx. 95% horizontally and vertically
Magnification 0.8x (-1 dpt with 50mm lens at infinity)
Eye Point Approx. 21mm
Dioptric Adjustment Correction -3.0 to +1.0 diopter
Mirror Quick-return half mirror (Transmission: reflection ratio of 40:60)
Viewfinder Information AF (AF points, focus confirmation light), Exposure (shutter speed, aperture, exposure level, AE lock, exposure compensation, AEB level, bulb), Flash (flash ready, red-eye reduction lamp on, high-speed sync, FE lock, FEB shooting, flash exposure compensation, insufficient flash warning during FE lock), White balance correction, Maximum burst, CF card full warning, CF card error warning, No CF card warning
Depth Of Field Preview Enabled with depth-of-field preview button (with Speedlite 580EX, 430EX, MR-14EX or MT-24EX; pressing the depth-of-field preview button fires a modeling flash)
Autofocus
Type TTL-CT-SIR with CMOS sensor
AF Points 9 AF points
AF Working Range EV -0.5-18 (ISO 100 at 73&deg;F/23&deg;C)
Focusing Modes Autofocus: One-Shot AF, Predictive AI Servo AF, AI Focus AF (automatic switching between One-Shot/Predictive AI Servo AF); Manual Focus (MF)
AF Point Selection Automatic selection, Manual AF point selection
Selected AF Point Display Superimposed on viewfinder and LCD monitor
AF Assist Beam Intermittent firing of built-in flash (Emitted automatically when necessary under low light, and linked to all 9 AF points. Not emitted in the Landscape, Sports and Flash OFF modes)
Exposure Control
Metering Modes Max. aperture TTL metering with 35-zone SPC
(1) Evaluative metering (linked to all AF points)
(2) Partial metering (approx. 9% at center of viewfinder)
(3) Center-weighted average metering
Metering Range EV 1-20 (ISO 100 at 73&deg;F/23&deg;C with EF 50mm f/1.4 USM lens)
ISO Speed Range Basic Zone: automatically set by the camera
Creative Zone: equivalent to ISO 100-1,600
Exposure Compensation (1) User-set with multi-controller (2) AEB (Auto Exposure Bracketing)
Bracketing range: +/- 2 stops in 1/3- or 1/2-stop increments
AE Lock Auto: Applied in One-Shot AF mode with evaluative metering when focus is achieved
User-set: Applied with AE lock button
Shutter Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled1/4000 to 30 sec. (1/3- and 1/2-stop increments), X-sync at 1/200 sec.Soft-touch electromagnetic release; shutter "lag time" approx. 100 msec.10 sec. delay, 2 sec. delay with C.Fn-7-1 (mirror lockup)Remote control with Remote Switch RS-60E3 or Wireless Remote Controllers RC-1/RC-5
Type Vertical-travel, mechanical, focal-plane shutter with all speeds electronically controlled
Shutter Speeds 1/4000 to 30 sec. (1/3- and 1/2-stop increments), X-sync at 1/200 sec.
Shutter Release Soft-touch electromagnetic release; shutter "lag time" approx. 100 msec.
Self Timer 10 sec. delay, 2 sec. delay with C.Fn-7-1 (mirror lockup)
Remote Control Remote control with Remote Switch RS-60E3 or Wireless Remote Controllers RC-1/RC-5
Built in Flash
Type Auto pop-up, retractable, built-in flash in the pentaprism
Guide Number 43 ft./13m (ISO 100)
Recycling Time Approx. 3 sec.
Flash Ready Indicator Flash-ready indicator lights in viewfinder
Flash Coverage 17mm lens focal length (equivalent to 27mm in 135 format)
FE Lock Provided
Flash Exposure Compensation +/-2 stops in 1/3- and 1/2-stop increments
External Speedlite
EOS Dedicated Speedlite E-TTL II autoflash with EX Series Speedlites
Zooming to Match Focal Length Provided
PC Terminal N/A
Drive System
Drive Modes Single, Continuous, Self-timer/Remote control
Continuous Shooting Speed Approx. 3 fps (at shutter speed of 1/250 sec. or faster)
Maximum Burst JPEG: approx. 27 frames (Large/Fine)
RAW: approx. 10 frames
RAW+JPEG: approx. 8 frames (Large/Fine)
LCD Monitor
Type TFT color, liquid-crystal monitor
Monitor Size 2.5 in. diagonal with a viewing angle of approx. 160&deg; vertically and horizontally
Pixels Approx. 230,000 pixels
Coverage Approx. 100%
Brightness Control 7 levels provided
Interface Languages 18
Playback
Display Format Single image, 9-image index, Magnified zoom (approx. 1.5x to 10x), Auto play, Auto review right after shooting, Histogram, Rotate, Jump
Highlight Alert In the single image (INFO) display mode, the highlight portions containing no image information will blink
Histogram Brightness, RGB
Image Protection and Erase
Protection A single image can be protected or unprotected
Erase A single image or all images stored in a CF card can be erased if they are unprotected
Direct Printing
Compatible Printers PictBridge, CP Direct, and Bubble Jet Direct-compatible printers
Printable Images JPEG images (DPOF printing possible)
Easy Print feature Provided
DPOF: Digital Print Order Format
DPOF Version 1.1 compatible
Direct Image Transfer
Compatible Images JPEG and RAW images
*Images to be used for wallpaper on the personal computer screen must be JPEG images
Customization
Custom Functions 11 Custom Functions with 29 settings
Power Source
Battery Battery Pack NB-2LH, quantity 1
*AC power enabled with AC Adapter ACK-DC20
*With Battery Grip BG-E3, size-AA batteries can be used
Battery Life [Number of shots: Approx.]
*The above figures apply when a fully-charged Battery Pack NB-2LH is used.
*The figures above are based on CIPA (Camera & Imaging Products Association) testing standards
Battery Check Automatic
Power Saving Provided; power turns off after 30 sec., 1, 2, 4, 8, or 15 min.
Date/Time Battery One CR2016 Lithium Battery
Start-up Time Approx. 0.2 sec.
Dimensions and Weight
Dimensions (W x H x D) 4.98 x 3.71 x 2.56 in./126.5 x 94.2 x 65mm
Weight 18 oz./510g (body only)
Operating Environment
Working Temperature Range 32-104&deg;F/0-40&deg;C
Working Humidity Range 85% or less
Battery Pack
Type For NB-2LH
Rechargeable lithium-ion battery
Rated Voltage 7.4 V DC
Battery Capacity 720 mAh
Dimensions (W x H x D) 33.3 x 16.2 x 45.2mm/1.3 x 0.6 x 1.8 in.
Weight Approx. 43 g/1.5 oz.
Battery Charger
Type For CB-2LW
Compatible Battery Battery Pack NB-2LH
Recharging Time Approx. 105 min.
Rated Input 100 - 240 V AC, 50/60 Hz
Rated Output 8.4 V DC
Working Temperature Range 0&deg;C-40&deg;C/32&deg;F - 104&deg;F
Dimensions (W x H x D) 91 x 56 x 22.5mm/3.6 x 2.2 x 0.9 in.
Weight Approx. 68 g/2.4 oz.
Kit Lens
Angle of View For EF-S 18-55mm f/3.5-5.6 II
Diagonal extent: 74&deg;20' - 27&deg;50'
Horizontal extent: 64&deg;30' - 23&deg;20'
Vertical extent: 45&deg;30' - 15&deg;40'
Lens Construction 11 elements in 9 groups
Minimum Aperture f/22 - 36
Closest Focusing Distance 0.28m/0.92 ft. (from image sensor plane)
Maximum Magnification and Field of View 18mm: 0.10x (248 x 161mm/9.8 x 6.3 in.)
55mm: 0.28x (81 x 54mm/3.2 x 2.1 in.)
Filter Size 58mm
Hood EW-60C
Diameter x Length 68.5 x 66mm/2.7 x 2.6 in.
Weight Approx. 190 g/6.7 oz.
Case LP814
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
