Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 07.07.21
File Size 6.16 MB
Date 11.11.25
File Size 142.00 B
Date 11.11.25
File Size 142.00 B
Date 11.11.25
File Size 142.00 B
Date 11.11.25
File Size 142.00 B
Date 11.11.25
File Size 142.00 B
Date 10.31.22
File Size 145.00 B
Date 11.11.25
File Size 142.00 B
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
Type Digital Single-Lens Non-Reflex Af/Ae Camera
Recording Medium Cfexpress Card
Type B: Card Slot
Sd Card Speed Class-Compatible
Sd Card
Compatible With Uhs-Ii
Eye-Fi Cards And Multimedia Cards (Mmc) Are Not Supported.
Compatible Lenses Canon Rf Lens Group (Excluding Ef, Ef-S And Ef-M Lenses)
When Using Mount Adapter Ef-Eos R: Canon Ef Or Ef-S Lenses (Excluding Ef-M Lenses)
Lens Mount Canon Rf Mount
Type Cmos Sensor (Compatible With Dual Pixel Cmos Af)
Pixels Effective Pixels: Approx. 45.0 Megapixels
Pixel Unit Approx. 4.40 µm Square
Total Pixels Approx. 47.1 Megapixels
Aspect Ratio 3:2 (Horizontal: Vertical)
Color Filter System Rgb Primary Color Filters
Low Pass Filter Installed In Front Of The Image Sensor, Non-Detachable
Dust Deletion Feature
  1. Self Cleaning Sensor Unit
    • Removes Dust Adhering To The Low-Pass Filter.
    • At Power Off Only / Enable / Disable. Performed Automatically (Taking About Approx. 2 Sec. As Indi-Cated On The Screen) Or Manually (Taking About Approx. 8 Sec. As Indicated On The Screen).
    • After Manually Activated Cleaning, The Camera Will Automatically Restart (Power Off To On).
    • When [Multi Shot Noise Reduction], [Multiple Exposures], Or [Hdr Mode] Is Set, [Clean Now] And [Clean Manually] Cannot Be Selected.
  2. Dust Delete Data Acquisition And Appending
    • The Coordinates Of The Dust Adhering To The Low-Pass Filter Are Detected By A Test Shot And Appended To Subsequent Images.
    • The Dust Coordinate Data Appended To The Image Is Used By The Eos Canon Digital Professional Software (V. 4.14 And Higher) To Automatically Erase The Dust Spots.
    • Not Available With Ef-S Lenses, In Cropped Shooting Or Multi-Exposure Shooting.
  3. Manual Cleaning (By Hand)
Recording Format Compliant To Design Rule For Camera File System 2.0 And Exif 2.3*.
* Supports Time Difference Information In Exif 2.31.
File Size 3:2 Aspect Ratio
Large/Raw/C-Raw: 8192 X 5464
Medium: 5808 X 3872
Small 1: 4176 X 2784
Small 1: 2976 X 1984
Small 2: 2400 X 1600
1.6x (Crop)*
Large/Raw/C-Raw: 5088 X 3392
4:3 Aspect Ratio
Large: 7280 X 5464
Medium: 5152 X 3872
Small 1: 3712 X 2784
Small 2: 2112 X 1600
16:9 Aspect Ratio
Large: 8192 X 4608
Medium: 5808 X 3264
Small 1: 4176 X 2344
Small 2: 2400 X 1344
1:1 Aspect Ratio
Large: 5456 X 5456
Medium: 3872 X 3872
Small 1: 2784 X 2784
Small 2: 1600 X 1600
  • Values For Recording Pixels Are Rounded To The Nearest 100,000 Or 10,000.
  • For Raw And Jpeg Images, Information Outside The Cropping Area Is Not Retained.
  • Jpeg Images Are Generated In The Set Aspect Ratio.
  • Raw Images Are Generated In [3:2], And The Set Aspect Ratio Is Appended.
* Indicate An Inexact Proportion.
File Numbering The Following File Numbers Can Be Set:
  1. File Numbering Methods
    1. Continuous Numbering
      1. The Numbering Of Captured Images Continues Even After You Replace The Card.
    2. Auto Reset
      1. When You Replace The Card, The Numbering Will Be Reset To Start From 0001. If The New Sd Card Already Contains Images, The Numbering Will Continue From The Last Recorded Image In The Card.
  2. Manual Reset
    1. Resets The File Number To 0001, And Creates A New Folder Automatically.
* When Manually Resetting The File Number, Folders Can Also Be Renamed.
Raw Jpeg Simultaneous Recording Simultaneous Recording Of Any Combination Of Raw/C-Raw And Jpeg/Heif Image-Recording Quality Is Supported.
Color Space Selectable Between Srgb And Adobe Rgb
Picture Style
  1. Auto
  2. Standard
  3. Portrait
  4. Landscape
  5. Fine Detail
  6. Neutral
  7. Faithful
  8. Monochrome
  9. User Defined 1-3
    • In Scene Intelligent Auto, [Auto] Will Be Set Automatically.
    • [Standard] Is The Default Setting For [User Def. 1-3].
Settings
  1. Auto
  2. Day Light
  3. Shade
  4. Cloudy*
  5. Tungsten Light
  6. White Fluorescent Light
  7. Flash
  8. Custom (Custom Wb)
  9. Color Temperature
* Effective Also In Twilight And Sunset.
Auto White Balance Option Between Ambience Priority And White Priority Settings.
Color Temperature Compensation Blue/Amber Bias: ±9 Levels
Magenta/Green Bias: ±9 Levels
Corrected In Reference To The Current Wb Mode's Color Temperature.
Type Oled Color Electronic Viewfinder; Approx. 5.76 Million Dots Resolution
Coverage Approx. 100% Vertically And Horizontally Relative To The Shooting Image Area (With Image Quality L, At Approx. 23mm Eyepoint).
Magnification Approx. 0.76x / Approx. 35.5 Degrees (With 50mm Lens At Infinity, -1 M-1)
Eyepoint Approx. 23mm (At -1 M-1 From The Eyepiece Lens End)
Viewfinder Information
  1. Maximum Burst
  2. Possible Shots/Sec. Until Self-Timer Shoots
  3. Focus Bracketing/ Multiple-Exposure/Hdr Shooting/Multi Shot Noise Reduction/Bulb Time/Interval Timer
  4. Shooting Mode
  5. Af Method
  6. Af Operation
  7. Image Quality
  8. Card
  9. Drive Mode
  10. Metering Mode
  11. No. Of Remaining Shots For Focus Bracketing, Multiple Exposures, Or Interval Timer
  12. Electronic Level
  13. Movie Recording Time Available
  14. Battery Level
  15. Image Stabilizer (Is Mode)
  16. Histogram (Brightness/Rgb)
  17. Quick Control Button
  18. Anti-Flicker Shooting
  19. White Balance/White Balance Correction
  20. Picture Style
  21. Auto Lighting Optimizer
  22. Still Photo Cropping / Aspect Ratio
  23. Af Point (1-Point Af)
  24. Aeb/Feb
  25. View Assist
  26. Hdr Pq
  27. Flash Ready / Fe Lock / High-Speed Sync
  28. Electronic Shutter
  29. Touch Shutter / Create Folder
  30. Ae Lock
  31. Shutter Speed / Multi-Function Lock Warning
  32. Aperture Value
  33. Wi-Fi® Function
  34. Wi-Fi® Signal Strength
  35. Bluetooth® Function
  36. Exposure Simulation
  37. Magnify Button
  38. Iso Speed
  39. Highlight Tone Priority
  40. Exposure Compensation
  41. Exposure Level Indicator
Type Dual Pixel Cmos Af
Af Working Range Ev -6 To 20 (F/1.2 Lens*, Center Af Point, One-Shot Af, At 73°F/23°C, Iso 100, One-Shot Af)
* Except Rf Lenses With A Defocus Smoothing (Ds) Coating.
Af Point Selection
Af Method
Face+Tracking Af
Spot Af
1-Point Af
Expand Af Area
(Above, Below, Left And Right/Around)
Zone Af
Large Zone Af (Vertical/Horizontal)
Metering Modes Real-Time Metering With Image Sensor (384 [24x16 Zone Metering])
  1. Evaluative Metering (Af Point-Linked)
  2. Partial Metering (Approx. 6.1% Of The Area At The Center Of The Screen)
  3. Spot Metering (Approx. 3.1% Of The Area At The Center Of The Screen)
  4. Center-Weighted Average Metering
Metering Range Ev -3 - 20 (At 73°F/23°C, Iso 100) (Still Photo Shooting)
Exposure Control Systems
  1. Scene Intelligent Auto
  2. Flexible-Priority Ae (Fv)
  3. Program Ae (P)
  4. Shutter-Priority Ae (Safety Shift Possible) (Tv)
  5. Aperture-Priority Ae (Safety Shift Possible) (Av)
  6. Manual Exposure (M)
  7. Bulb
  8. Custom Shooting Mode C1, C2, C3
Iso Speed Range
Available Iso Speeds; User-Set
Normal Iso 10051200 (1/3- Or 1-Stop Increments)
Expanded L: Equivalent To Iso 50, H: 102400
  • For [Highlight Tone Priority], The Minimum Iso Speed Limit Will Be Iso 200 To 51200.
  • Expanded Iso Cannot Be Set For Hdr Mode Or During Hdr Pq Shooting.
User-Defined Iso Range - Still Photo Shooting
Iso Speed Range Iso Speed
Minimum L (50)51200 (In 1-Stop Increments)
Maximum Iso 100H (102400) (In 1-Stop Increments)
* Expanded Iso Speeds Are Noted As Being Equivalent To These Speeds.
User-Defined Auto Iso Range - Still Photo Shooting
Auto Range Iso Speed
Minimum Iso 10025600 (In 1-Stop Increments)
Maximum Iso 20051200 (In 1-Stop Increments)
Iso Auto Details In Still Photo Shooting
Shooting Mode No Flash Using Flash
Auto Iso 10012800 Iso 1001600*3
P Iso 100*1*2-51200*2 Iso 100*1*2-6400*24
Tv
Av
M
B Iso 4003
*1 Iso 200 When [Highlight Tone Priority] Is Set To [Enable] Or [Enhanced].
*2 Varies Depending On [Maximum] And [Minimum] Of [Auto Range].
*3 If Outside The Setting Range, Changed To The Value Most Close To Iso 400.
*4 Iso 1600 When Using A Lens That Is Not Compatible With "Variable Control Of Maximum Iso Auto Limit For E-Ttl".
Manual ±5 Stops In 1/3- Or 1/2-Stop Increments
Aeb ±5 Stops In 1/3- Or 1/2-Stop Increments
Ae Lock
  1. Auto Ae Lock
    • The Metering Mode For Ae Lock After Focus Can Be Customized.
  2. User-Applied Ae Lock
    • In The Fv, P, Tv, Av And M Modes, Enabled With The Ae Lock Button. (Press Again To Update.)
    • Enabled In All Metering Modes.
Type Electronically Controlled Focal-Plane Shutter
  1. Electronic First Curtain Or Mechanical Shutter
  2. Electronic Shutter*
* Cannot Be Used In Conjunction With The Following Functions: Flash Photography, Hdr Shooting,Multiple Exposures, Multi Shot Noise Reduction, Aeb, Hdr Pq, Anti-Flicker Shooting, Dual Pixel Raw Shooting, Digital Lens Optimizer [High].
* A Shutter Release Sound Is Not Generated. However, Note That The Sounds Other Than The Shutter Release Sound (Aperture, Focusing Lens Drive Sound/Electronic Sound, Etc.) May Be Generated.
* In Electronic Shutter Shooting Under Conditions Such As Flash Firing By Other Cameras Or With Fluores-Cent Lighting Or Other Flickering Light Sources, A Strip Of Light Or Banding Due To The Brightness Difference May Be Recorded In The Image.
Shutter Speeds When [Mechanical] Or [Elec. 1st- Curtain] Is Set: 1/8000-30 Sec, Bulb
When [Electronic] Is Set: 1/8000-0.5 Sec.
Shutter Release Soft-Touch Electromagnetic Release
Self Timer 10-Sec. Delay, 2-Sec. Delay
Shutter Lag Time
Drive Mode Flash Mechanical Shutter Electronic 1st Curtain Electronic Shutter
Shutter-Release Time Lag
* Measured With Shutter Button Pressed Fully From Half-Pressed Position
Not Used Approx. 81 Ms Approx. 50 Ms Approx. 50 Ms
Used N/A N/A -
Flash Metering E-Ttl Ii Flash Metering
  1. Evaluative (Face Priority)
  2. Evaluative
  3. Average
Flash Exposure Compensation ±3 Stops In 1/3- Or 1/2-Stop Increments
E-Ttl Balance
Ambience Priority, Standard, Flash Priority
Compatible E-Ttl Speedlites
Canon Ex- And El-Series Speedlites
Fe Lock Provided
External Flash Settings The Camera Can Set The Following With Ex Series Speedlites:
  1. External Flash Control
    • Flash Firing, E-Ttl Ii Flash Metering, Slow Synchro, Safety Fe, Flash Mode, Wireless Function, Flash Zoom, Shutter Synchronization And Flash Exposure Compensation
  2. Flash Custom Function Setting
    • The Setting Options For Both (1) And (2) Will Differ Depending On The Speedlite Used.
Focusing Dual Pixel Cmos Af
Shooting Times
Resolution And Frame Rate Mode Approx. Shooting Time (23°C / 73°F)*1 Recommended Scene
8k 30p Full Sensor Width 20 Min 8k Productions Where A Full-Frame Mirrorless Can Be Utilized To Get Unique Angles Alongside A Main Camera Or Additional Cropping For 4k Productions.
Full Sensor Width Raw 20 Min As Above But With The Additional Workflow Flexibility Of Raw.
4k 120p Full Sensor Width 15min*2 Shorter Bursts Of Slow Motion.
4k 60p Full Sensor Width 35min*3 High-Frame Rate High Resolution Productions And Independent Films.
Aps-C Crop
(5.1k Oversampled)
25 Min When Additional Reach Is Required With Higher Frame Rates E.G. Wildlife And Sports And News Gathering Within A 4k Production Or Even For Tighter Full Hd Crops In Post.
4k 30p Full Sensor Width Not Limited By Heat Interviews, Longer Duration Capture Such As Weddings.
Full Sensor Width Hig Quality
(8.2k Oversampling)
30 Min When Additional Resolution Is Required With A 4k30p Production Or For A Full Hd Workflow Where Cropping Can Be Desirable With High Resolution.
Aps-C Crop
(5.1k Oversampled)
Not Limited By Heat When Additional Reach Is Required E.G. Wildlife And Sports And News Gathering Within A 4k Production Or Even For Tighter Full Hd Crops In Post.
*1 Time Available For Continuous Shooting In 23°C / 73°F Environment, From A Cold Start. If The Camera Is In Lv Mode Standby Before Shooting Or The Ambient Temperature Is High, The Shooting Time May Be Shorter.
*2 Recording Stops At 7minutes And 30seconds For High Frame Rate Video. Indicates The Time When Recording Can Be Resumed Immediately.
*3 Recording Is Limited To 29 Minutes 59 Seconds. Indicates The Time When Recording Can Be Resumed Immediately.
Estimated Camera Recovery Time
Estimated Recovery Times Are Indicated Below. These Are Affected By Various Factors Such As Ambient Temperature, Continued Camera Operation And The Selected Shooting Resolution.The Time Until Full Record Time Is Available Will Vary With Ambient Temperature.
Resolution And Frame Rate Waiting Period (Minutes)
(23°C / 73°F)*
Approximate Maximum Recording Time After Waiting Period (Minutes)
8k 30p 10 3
20 8
4k 60p 10 10
Type Tft Color, Liquid-Crystal Monitor
Screen Monitor Size 3.2-Inch (Screen Aspect Ratio Of 3:2)
3.15 In./8.01cm Diagonal (2.63 In./6.67cm Width, 1.75 In./4.44cm Height)
Pixels Approx. 2.1 Million Dots
Coverage Approx. 100% Vertically/Horizontally
Brightness Control Manually Adjustable To One Of Seven Brightness Levels
Coating Clear View Lcd Ii
  • Anti-Smudge Coating Applied.
  • Anti-Reflection Coating Not Applied.
Interface Languages 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese)
Image Display Format
Item Still Photo Movie
Magnify Zoom Display 1.5x-10x (5 Levels) -
Af Point Display Yes -
Grid Display Off / 3×3 / 6×4 / 3×3+Diag -
Rating Off / 1 To 5 Stars
Select Images / Select Range / All Images In Folder / All Images On Card /
All Found Images
Image Search Search Conditions
Rating / Date / Folder / Protect / Type Of File
Protect Select Images / Select Range / All Images In Folder / Unprotect All Images In Folder / All Images On Card /
Unprotect All Images On Card /All Found Images
In-Camera Raw Image Processing Supported -
Resizing Supported -
Cropping Supported -
Highlight Alert The White Areas With No Image Data Will Blink.
Back To TopQuick Control Function
Function
The Quick Control Screen Is Accessed By Pressing The Quick Control Button During Still Photo Shooting.
Protection
  1. Single Image (Select Image)
  2. Select Range
  3. All Images In A Folder
  4. All Images On Card
    • Image Browsing And Image Search Can Be Based On Ratings.
    • Ratings-Based Image Selections Also Possible With Dpp.
  5. All Found Images (Only During Image Search)
Erase
Except Protected Images
  1. Select Images To Erase
  2. Select Range
  3. All Images In Folder
Compatible Printers Not Supported
Dpof Compliant To Dpof Version 1.1
Custom Controls
Customizable Buttons
Shutter Button
Movie Button
Mode Button
Af-On Button
Ae Lock Button
Af Point Selection Button
Depth Of Field Preview Button
Lens Af Stop Button
Multi-Function Button
Lcd Panel Illumination Button
Set Button
Multi-Controller
Customizable Dials
Main Dial
Quick Control Dial 1 And 2
Control Ring
My Menu Registration
  • Up To Six Top-Tier Menu Items And Custom Functions Can Be Registered.
  • Up To Five My Menu Tabs Can Be Added.
My Menu Tab Overall Operations
  • Adding A Tab
  • Deleting Tabs In A Batch
  • Deleting All Tab Items
  • Setting The Menu Display
My Menu Tab Detailed Operations
  • Selecting A Registered Item
  • Sorting Registered Items
  • Deleting Selected Registered Items
  • Deleting Registered Items In A Batch
  • Deleting Tabs
  • Changing A Tab Name (16 Ascii Characters)
Usb Terminal Equivalent To Hi-Speed Usb (Usb 3.1 Gen 2)
  • For Pc Communication
  • Terminal Type: Usb Type-C
  • Shared With Terminal For In-Camera Charging With Usb Power Adapter Pd-E1.
  • In-Camera Charging: Equivalent To Usb Type-C (5 V/1.5 A), But Use Should Be Restricted To Usb Power Adapter Pd-E1.
Video Out Terminal Hdmi Micro Out Terminal Type D (Resolution Switches Automatically) / Cec Not Compatible
  • Images Can Be Displayed Through The Hdmi Output And On Screen At The Same Time.
  • Images Will Not Be Displayed Unless [Ntsc] Or [Pal] Is Properly Set According To The Video System Of The Tv Set.
Microphone Input Terminal/Headphone Terminal
3.5mm Diameter Stereo Mini Jack
Battery Lp-E6nh/Lp-E6n/Lp-E6
  • With The Ac Adapter Ac-E6n + Dc Coupler Dr-E6, Ac Power Is Possible.
  • With The Usb Power Adapter Pd-E1, In-Camera Charging Of Lp-E6nh Is Possible. The Usb Power Adapter Pd-E1 Is Not Compatible With Powering The Camera.
Battery Check Automatic Battery Check When The Power Switch Is Turned On.
Displayed In 6 Levels On Top Lcd Panel.
  • Battery Level Can Be Checked On The Lcd Panel And In The Viewfinder.
    Battery Info Display In Set-Up Menu:
  • Type Of Power Source Used.
  • Remaining Capacity (Percentage Of Battery Charge Remaining).
  • Recharge Performance: (3-Level Display Of Battery's Ability To Hold A Charge)
Start Up Time Approx. 0.4 Sec.
  • Based On Cipa Testing Standards.
Dimensions W X H X D Approx. 5.45 X 3.84 X 3.46 In. / 138 X 97.5 X 88.0mm
  • Based On Cipa Standards.
Weight Approx. 1.63 Lbs. / 738g (Including Battery, Cfexpress Card; Without Body Cap)
Approx. 1.43 Lbs. / 650g (Body Only; Without Battery, Card Or Body Cap)
Operating Humidity Range 85° Or Less
Working Temperature Range 32-104° F / 0-+40° C
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
What is the Stop Motion Animation Service?
We have released a new upgrade service for various EOS R series cameras.
This upgrade enables you to capture Stop Motion Animation.
For more details of the service and compatible camera’s click Learn More.
Pricing
Model Price*
Various EOS R cameras $100
*Tax and shipping fees are NOT included
*All pricing is subject to change Thank you,
Customer Support Operations
Canon U.S.A., Inc.
Contact Information for Inquiries
Canon Customer Support Center
Phone: 1-800-OK-CANON (toll free), 1-800-652-2666
For additional support options: https://www.usa.canon.com/support
Title Canon Support | Firmware Notice: EOS R5: Firmware Version 1.2.0
Advisory Type
Date 11.17.20
Title Canon Support | Firmware Notice: EOS R5: Firmware Version 1.1.0
Advisory Type
Date 08.25.20
Title Canon Support | Firmware Notice: EOS R5: Version 1.4.0
Advisory Type
Date 08.17.21
Title Canon Support | Firmware Notice: EOS R5: Firmware Version 1.1.1
Advisory Type
Date 09.08.20
Title Canon Support | Firmware Notice: EOS R5: Firmware Version 1.5.0
Advisory Type
Date 11.30.21
Title Canon Support | Firmware Notice: EOS R5: Firmware Version 1.3.0
Advisory Type
Date 03.28.21
Title Canon Support | Service Notice: Future Firmware plan to support advanced video recording functions for EOS-1D X Mark III and EOS R5
Advisory Type
Date 08.25.20
Title Canon Support | Firmware Notice: EOS R5: Firmware Version 1.3.1
Advisory Type
Date 04.12.21
Title Firmware Notice: EOS R5: Firmware Version 1.5.1
Advisory Type
Date 02.16.22
Title Firmware Notice: EOS R5: Firmware Version 1.5.2
Advisory Type
Date 03.16.22
Title Firmware Notice: EOS R5: Firmware Version 1.6.0
Advisory Type
Date 07.21.22
Title Service Notice: EOS Webcam Utility Pro app: Version 2.0.30 features
Advisory Type Service Notice
Date 05.23.23
Title Service Notice: Kokomo by Canon Early Access App for Meta Quest 2: Version 0.0.102 Features
Date 05.23.23
Title Service Notice: EOS Webcam Utility Pro v2.3
Date 11.13.24
Title Service Notice: EOS Webcam Utility Pro Software for macOS: Version 2.1.18
Date 05.01.24
Title Firmware Notice: EOS R5: Firmware Version 2.2.1
Advisory Type Firmware Notice
Date 11.20.25
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
