Canon Support for EOS R6 Mark II | Canon U.S.A., Inc.
EOS R6 Mark II
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital interchangeable lens, mirrorless camera |
Image Processor | DIGIC X |
Recording Media | (Two) SD card slots
Compatible Lenses | Canon RF lens group (including RF-S lenses) When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses) |
Lens Mount | Canon RF mount |
Type | Full-frame CMOS sensor (compatible with Dual Pixel CMOS AF) |
Effective pixels | Approx. 24.2 megapixels |
Screen Size | Approx. 36.0 x 24.0 mm |
Pixel Unit | Approx. 6.00 µm square |
Total Pixels | Approx. 25.6 megapixels |
Aspect Ratio | 3:2 (Horizontal:Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Installed in front of the image sensor, non-detachable |
Dust Deletion Feature |
Recording Format | Compliant to Design rule for Camera File system 2.0 and Exif 2.31*. *Supports time difference information in Exif 2.31. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Image Format | JPEG, HEIF, RAW / C-RAW / Dual Pixel RAW/ RAW burst (CR3), C-RAW (Canon original) ;Movies: ALL-I (Time-lapse video only), IPB (MP4) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
File Size |
* At H+ Drive setting (12 fps), using Mechanical or 1st-curtain Electronic shutter. *1: Number of shots using a 32 GB card that conforms to Canon testing standards. *2: Number of shots using a 32 GB UHS-II card that conforms to Canon testing standards. *3: When set to [HDR shooting (HDR PQ): Disable]. *4: When set to [HDR shooting (HDR PQ): Enable]. |
File Numbering | The following file numbers can be set:
RAW + JPEG / HEIF Simultaneous Recording | Simultaneous recording of any combination of RAW/C-RAW and JPEG/HEIF image-recording quality is supported. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Color Space | Selectable between sRGB and Adobe RGB | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Picture Style |
Settings |
*2: White balance can be adjusted during movie recording. |
Auto White Balance | Option between ambience priority and white priority settings, using SET button |
White Balance Shift | Blue/amber bias: ±9 levelsMagenta/green bias: ±9 levelsCorrected in reference to the current WB mode's color temperature. |
Type | OLED color electronic viewfinder; 0.5-inch, approx. 3.69 million dots |
Coverage | Approx. 100% vertically and horizontally relative to the shooting image area (with image quality L, at approx. 23mm eyepoint). |
Magnification / Angle of View | Approx. 0.76x / Approx. 35.2 degrees (with 50mm lens at infinity, -1 m-1) |
Eye Point | Approx. 23mm (at -1 m-1 from the eyepiece lens end) |
Dioptric Adjustment Range | Approx. -4.0 to + 2.0 m-1 (dpt) |
Viewfinder Information |
Focus Method | Dual Pixel CMOS AF |
Number of AF zones available for Automatic Selection | AF area: Horizontal: Approx. 100% x Vertical: Approx. 100%(100% x 100% AF coverage in Face Detect + Tracking AF; coverage can vary, depending upon lens being used)Stills: Max. 1053 zones (39 x 27)Movies: Max. 1053 zones (39 x27) |
Selectable Positions for AF Point | AF area: Horizontal: Approx. 90% x Vertical: Approx. 100%Stills: Max. 4897 positions (83 x 59)Movies: Max 4067 positions (83 x 49) |
AF Working Range | EV -6.5 to 20 (f/1.2 lens*, center AF point, One-Shot AF,at 73°F/23°C, ISO 100 * Except RF lenses with a Defocus Smoothing (DS) coating. |
Focusing brightness range (still photo shooting) | EV 6.5 to 21 (with an f/1.2 lens,* center AF point, One-Shot AF at room temperature, and ISO 100)* Except RF lenses with a Defocus Smoothing (DS) coating. |
Focusing brightness range (in movie recording) | 4K: EV 4.0 to 21Full HD: EV 4.5 to 21(with an f/1.2 lens,* center AF point, One-Shot AF at room temperature, ISO 100, and29.97 / 25.00 fps.)* Except RF lenses with a Defocus Smoothing (DS) coating. |
Available AF Areas |
Available Subject Detection |
Eye Detection | Auto:
Metering Modes | Real-time metering from CMOS image sensor (384 [24x16] metering zones)
Metering Range | EV -3 - 20 (at 73°F/23°C, ISO 100)(Still Photo Shooting) | ||||||||||||||||||||||||||||||||||||
Exposure Modes |
ISO Speed Range | Manually Set
ISO Auto range settings in still photo shooting
ISO Auto details in still photo shooting
*1: ISO 200 when set to [Highlight tone priority: Enable/Enhanced]. *2: Varies depending on the [Maximum] and [Minimum] settings for [Auto range]. *3: If outside the setting range, changed to the value closest to ISO 400. |
Exposure Compensation |
AE Lock |
Type | Electronically controlled focal-plane shutter
Shutter Speeds | Mechanical / 1st-curtain Electronic shutter: 1/8000th sec 30 seconds, in 1/3 or 12-step increments Electronic shutter: 1/8000th sec 30 seconds, in 1/3 or 12-step increments (1/16,000th possible, if user-set in Tv or M shooting modes) |
X-sync Speed | Mechanical Shutter: 1/200 sec.Elec. 1st-curtain: 1/250 sec. |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. delay, 2-sec. delay |
Still Photo IS | In-body IS operation can be selected when using a non-IS lens.
Accessory Shoe | Canon Multi-function accessory shoe Optional Canon AD-E1 adapter required for conventional shoe-mount flashes and accessories |
E-TTL balance | Ambience priority, standard, flash priority |
Flash Exposure Compensation | ±3 stops in 1/3- or 1/2-stop increments |
Continuous flash control | E-TTL each shot / E-TTL 1st shot |
Drive Modes andContinuous Shooting Speed |
1. Continuous shooting speed is lower under certain shooting and measurement conditions: shutter speed, aperturevalue subject conditions, brightness, type of lens, timing when internal memory becomes full (temporarily disables shooting) - Mechanical / electronic 1st curtain: use of flash, anti-flicker shooting: Enable, Dual Pixel RAW shooting- Enable, type of battery, battery level, temperature, use of a battery grip, use of WFT, use of built-in Wi-Fi. - Electronic shutter: State of aperture in continuous shooting * With Certain lenses, zooming during continuous shooting with electronic shutter may cause changes in exposure even at the same f/number. 2. Automatically switches among modes A (drive mode icon lit in green), B (drive mode icon lit in white), and C (drive mode icon flashing in white). Operating Mode is for reference only automatically set by camera, is dependent on factors such as battery power level, battery type, and lens in use, and cannot be set by user. * For flash shooting, values for AE, flash metering, and WB do not change after the first shot. |
HDR Shooting (HDR PQ) | Disable / Enable | ||||||||
Still Photo HDR PQ |
Movie HDR PQ |
Continuous HDR Shooting (still images) | 1 shot only / Every shot |
Shooting Times |
*1 Time available for continuous shooting in 23°C / 73°F environment, from a cold start. If the camera is in LV mode standby before shooting or the ambient temperature is high, the shooting time may be shorter. *2 According to Canon measurement conditions when using UHS-II cards conforming to Canon testing standards. *3 The maximum duration of shooting may be shorter under some circumstances even if recording begins from cold start, due to a rise in temperature inside the camera caused by pre-shooting camera setting operations or by prolonged use of the Live View mode. When the card is full, movie recording stops automatically. In this case, duration time when you erase the data and restart shooting. |
File Format | Normal Movies
* Recording in AAC when [Audio compression] (C.Fn4) is set to [Enable] or Linear PCM when set to [Disable]. |
Estimated Recording time, Movie Bit Rate and File Size | H.264/AVC (Canon Log: Off, HDR PQ: Off)
* Bit rate only applies to video output, not audio or metadata. * Audio is recorded when [C.Fn4 audio compression:Enable] (Audio: AAC) is set. * Movie recording stops when the maximum recording time per movie is reached. * No audio is recorded for approx. the last two frames with the compression method for movie recording quality set to IPB (Standard) or IPB (Light) and the camera set to [C.Fn4 Audio compression: Enable]. Moreover, the video and sound may be slightly out of sync when movies are played back in Windows. * Mbps megabits per second (8 megabits = 1 megabyte) |
Estimated Recording Time, Continued. | H.265/HEVC (Canon Log: On or HDR PQ: On)
* Bit rate only applies to video output, not audio or metadata. * Audio is recorded when [C.Fn4 audio compression:Enable] (Audio: AAC) is set. * Movie recording stops when the maximum recording time per movie is reached. 31 min. * No audio is recorded for approx. the last two frames with the compression method for movie recording quality set to IPB (Standard) or IPB (Light) and the camera set to [C.Fn4 Audio compression: Enable]. Moreover, the video and sound may be slightly out of sync when movies are played back in Windows. * Mbps megabits per second (8 megabits = 1 megabyte) |
Card Performance Requirements |
Video AF | Dual Pixel CMOS AF; Movie Servo AF available in AF Menu | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ExposureCompensation | ±3 stops in 1/3- or 1/2-stop increments | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Time Code | Yes (Count up, Start time setting, Movie recording count, Movie play count, HDMI time code on/off, HDMI rec. command on/off, Drop frame enable/disable) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Movie Pre-recording (On/Off) | 3 or 5 seconds; user-selectable | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Time-lapse Movie Setting | Interval 2 sec 99:59:59; Number of frames 23,600; Movie recording size 4K/Full HD; Auto exposure fixed @ first frame/auto for each frame; Beep per frame recorded (volume setting 0/silent 5) | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Time-lapse Playback Frame Rate | 29.97 (set to NTSC); 25.00fps (set to PAL) |
Type | TFT color, liquid-crystal monitor |
Monitor Size | 3.0-inch (screen aspect ratio of 3:2) 2.95 in./7.5cm diagonal (2.44 in./6.2cm width, 1.65 in./4.2cm height) |
Dots | Approx. 1.62 million dots |
Coverage | Approx. 100% vertically/horizontally |
Brightness Control | Manually adjustable to one of seven brightness levels |
Touch-screen Operation | Supported for AF Point selection; Touch AF; Touch Shutter; Menu selection; Quick Control Menu; Magnified view |
Coating | Clear View LCD II
Interface Languages | 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese) |
Display Format |
Highlight Alert | The white areas with no image data will blink. | ||||||||||||||||||||||||||||||
Histogram | Brightness and RGB |
Function | The Quick Control screen can be accessed by pressing the Quick Control button during shooting, recording, or playback. |
Quick Control Screen | The following settings are available for the [Quick Control screen] during movie recording.
Protection |
Erase | Except protected images
Compatible Printers | Not supported |
DPOF | Compliant to DPOF Version 1.1 |
Supporting Standards | Equivalent to IEEE 802.11 b/g/n/a/ac Standards | |||||||||||||||||||||||||||
Transmission Method | DS-SS modulation (IEEE 802.11b)OFDM modulation (IEEE 802.11g/n/a/ac) | |||||||||||||||||||||||||||
Transition Frequency (Central Frequency) | 2.4 GHz bandFrequency: 2412 to 2462 MHzChannels: 1 to 11 channels5.0 GHz bandFrequency: 5180 to 5825 MHzChannels: 36 to 165 channels1 | |||||||||||||||||||||||||||
Connection Method | (1) Camera access point mode(2) Infrastructure mode | |||||||||||||||||||||||||||
Security |
Communication with a Smartphone |
Remote Operation Using EOS Utility | The camera can be controlled via Wi-Fi® or USB, with Canon EOS Utility software installed in a compatible Mac or Windows computer. | |||||||||||||||||||||||||||
Print from Wi-Fi® Printers | Not supported. | |||||||||||||||||||||||||||
Send Images to a Web Service | image.canon: Video files (MP4) and JPEG, HEIF, RAW or C-RAW still images can be uploaded to image.canon servers.From image.canon, images can be sent to specific social media and 3rd-party cloud image services. |
Standards Compliance | Bluetooth Specification Version 5.0 compliant (Bluetooth Low Energy technology) |
Transmission Method | GFSK modulation |
Bluetooth Pairing | Smartphone up to 10 devices; BR-E1 remote controller 1 unit |
Available Functions | Dial direction during Tv/Av; Control ring rotation direction; Customize buttons; Customize dials | ||||
Custom Controls | Customizable Buttons Shutter button Movie button AF-ON button AE lock button AF point button Depth of field preview button Lens AF stop button Multi-function button Set button Multi-controller Lens function button Speedlite menu direct button |
Customizable Dials | Main dial Quick control dial 1 & 2 Lens Control ring |
My Menu Registration | • Up to six top-tier menu options and Custom Function settings can be registered. • Up to five My Menu tabs can be added.
USB Terminal | Equivalent to SuperSpeed USB (USB 3.1 Gen 1)
HDMI Out Terminal | HDMI micro OUT terminal Type D (Resolution switches automatically) / CEC not compatible
Microphone terminal | 3.5mm diameter stereo mini jack |
Headphone terminal | Compatible with 3.5mm diameter stereo mini-plug |
Battery | Canon LP-E6NH battery pack (also compatible with LP-E6N and LP-E6 battery packs)
Optional Battery Grip | Compatible with Canon Battery Grip BG-R10 (Accepts one or two LP-E6NH, LP-E6N, or LP-E6 battery packs) |
Battery Check | Automatic battery check when the power switch is turned ON. Displayed in 5 levels in viewfinder, and on LCD screen. Battery info display in Set-up Menu:
Start-up Time | Approx. 0.4 sec.
Dimensions (W x H x D) | Approx. 5.45 x 3.87 x 3.48 in. / 138 x 98.4 x 88.4mm Based on CIPA standards. |
Weight | Approx. 1.5 lbs. / 680g (including battery, SD memory card; without body cap) Approx. 1.3 lbs. / 598g (body only; without battery, card or body cap) |
Working Temperature Range | 32-104° F / 0-+40° C |
Working Humidity | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
What is the Stop Motion Animation Service?
We have released a new upgrade service for various EOS R series cameras.
This upgrade enables you to capture Stop Motion Animation.
For more details of the service and compatible camera’s click Learn More.
Pricing
Model | Price* |
Various EOS R cameras | $100 |
*Tax and shipping fees are NOT included
*All pricing is subject to change Thank you,
Customer Support Operations
Canon U.S.A., Inc.
Contact Information for Inquiries
Canon Customer Support Center
Phone: 1-800-OK-CANON (toll free), 1-800-652-2666
For additional support options: https://www.usa.canon.com/support
