Canon Support for EOS Rebel SL3 | Canon U.S.A., Inc.
        EOS Rebel SL3
- Windows 11
 - Windows 10 (x64)
 - Windows 10
 - Windows 8.1 (x64)
 - Windows 8.1
 - Windows 8 (x64)
 - Windows 8
 - Windows 7 (x64)
 - Windows 7
 - Windows Vista (x64)
 - Windows Vista
 - Windows Me
 - Windows XP (x64)
 - Windows XP
 - Windows 98
 - Windows 95
 - Windows Server 2022
 - Windows Server 2019 (x64)
 - Windows Server 2016 (x64)
 - Windows Server 2012 (x64)
 - Windows Server 2008 (x64)
 - Windows Server 2003 (x64)
 - Windows Server 2003 R2
 - macOS Tahoe v26
 - macOS Sequoia v15
 - macOS Sonoma v14
 - macOS Ventura v13
 - macOS Monterey v12
 - macOS Big Sur v11.0
 - macOS Catalina v10.15
 - macOS Mojave v10.14
 - macOS High Sierra v10.13
 - macOS Sierra v10.12
 - OS X El Capitan v10.11
 - OS X Yosemite v10.10
 - OS X Mavericks v10.9
 - OS X Mountain Lion v10.8
 - OS X Lion v10.7
 - Mac OS X Snow Leopard v10.6
 - Mac OS X v10.1
 - Mac OS 9
 - Linux ARM
 - Linux MIPS
 - Linux 64bit
 - Linux 32bit
 - SAP
 - Windows Server 2025
 - Windows NT
 - Linux
Camera Connect
image.canon
Software Development Kit
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
SELECT ERROR CODE
| Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
| Type | Digital AF/AE single-lens reflex camera with built-in flash  |
| Recording Media | SD/SDHC/SDXC memory cards
| Image Format | Approx. 22.3 x 14.9mm (APS-C)  |
| Compatible Lenses | Canon EF lenses (including EF-S lenses, excluding EF-M lenses)  |
| Lens Mount | Canon EF mount  |
| Type | CMOS sensor (supporting Dual Pixel CMOS AF)  |
| Pixels | Approx. 24.1 megapixels  |
| Pixel Unit | Approx. 3.72 µm square  |
| Total Pixels | Approx. 25.8 megapixels  |
| Aspect Ratio | 3:2 (Horizontal : Vertical)  |
| Color Filter System | RGB primary color filters  |
| Low Pass Filter | Installed in front of the image sensor, non-detachable  |
| Dust Deletion Feature |
| Recording Format | Compliant to Design rule for Camera File system 2.0 and Exif 2.31* * Supports time difference information  |
| Image Format | JPEG, RAW (14-bit Canon original), C-RAW (Canon original)  |
| File Size | 3:2 Aspect Ratio Large: 6000 x 4000 Medium: 3984 x 2656 Small 1: 2976 x 1984 Small 2: 2400 x 1600 RAW: 6000 x 4000 4:3 Aspect Ratio Large: 5328 x 4000* Medium: 3552 x 2664 Small 1: 2656 x 1992 Small 2: 2112 x 1600* RAW: 6000 x 4000 16:9 Aspect Ratio Large: 6000 x 3368* Medium: 3984 x 2240* Small 1: 2976 x 1680* Small 2: 2400 x 1344* RAW: 6000 x 4000 1:1 Aspect Ratio Large: 4000 x 4000 Medium: 2656 x 2656 Small 1: 1984 x 1984 Small 2: 1600 x 1600 RAW: 6000 x 4000 * Indicate an inexact proportion.
| File Numbering |
| RAW + JPEG Simultaneous Recording | Simultaneous recording is possible using a combination of RAW and JPEG/Large(Fine).  |
| Color Space | sRGB/Adobe RGB  |
| Picture Style |
| Settings |
| Auto White Balance | Option between ambience priority and white priority settings  |
| Color Temperature Compensation | Blue/amber bias: ±9 levels Magenta/green bias: ±9 levels * Corrected in reference to the current WB modes color temperature. * Blue/amber and magenta/green correction can be set at the same time.  |
| Type | Eye-level SLR (with fixed pentaprism)  |
| Coverage | Approx. 95% vertical/horizontal coverage (at approx. 19mm eye point and Large image size)  |
| Magnification | Approx. 0.87x/24.5° (with 50mm lens at infinity, -1 m-1)  |
| Eye Point | Approx. 19mm (At -1m-1 from the eyepiece lens center)  |
| Dioptric Adjustment Correction | Adjustable from approx. -3.0 to +1.0 m-1 (dpt)  |
| Focusing Screen | Fixed  |
| Mirror | Quick-return half mirror  |
| Viewfinder Information | Spot metering circle, AF point activation indicator, AF point, ISO speed indicator, Focus indicator, Maximum burst, ISO speed, Highlight tone priority, Exposure level indicator, Exposure compensation amount, AEB range, Red-eye reduction lamp ON, Exposure compensation, Aperture, Shutter speed, Bulb exposure, FE lock, Busy, Built-in flash recharging, No card warning, Card error, Card full warning, error code, Flash exposure compensation, High-speed sync, FE lock / FEB in-progress, Flash-ready, Improper FE lock warning, AE lock, AEB in-progress, Warning icon  |
| Depth of Field Preview | Provided with customized DISP button settings.  |
| Type | TTL secondary image-forming phase-difference detection system with AF-dedicated sensor  |
| AF Points | 9 points Center AF point is AF cross-type supporting f/5.6. Center AF point is vertical line-sensitive supporting f/2.8. Other AF points is vertical line-sensitive or horizontal line-sensitive AF supporting f/5.6.  |
| AF Working Range | With One-Shot AF, at 73°F/23°C, ISO 100 EV -0.518 (center AF point) EV 0.518 (other AF points) (Based on Canon’s testing standards and environment)  |
| Focusing Modes |
| AF Point Selection |
| AF Assist Beam |
| Metering Modes | 63-zone metering sensor
| Metering Range | EV 1 - 20 (at 73°F/23°C, ISO 100, evaluative metering)  |
| Exposure Control Systems |
| ISO Speed Range | Manual Setting
 Auto ISO Speed Settings
| Exposure Compensation |
| AE Lock |
| Type | Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled
| Shutter Speeds | Creative Zone: 1/4000 to 30 sec., bulb * X-sync at 1/200 sec. Basic Zone: 1/4000 to 1 sec.  |
| Shutter Release | Soft-touch electromagnetic release  |
| Self Timer | 10-sec. delay, 2-sec. delay, continuous shooting after 10 sec. (2 to 10 shots)  |
| Shutter Lag Time | With SW-1 ON, time lag between SW-2 ON and start of exposure: approx. 0.075 sec.
| Flash Metering | E-TTL II autoflash (Evaluative, Average), FE Lock  |
| Flash Exposure Compensation | ±2 stops in 1/3- or 1/2-stop increments
| FE Lock | Provided  |
| External Flash Settings | The camera can set the following with EX series Speedlites:
| Drive Modes and Continuous Shooting Speed during Viewfinder Shooting |
| Maximum Burst |
| Shooting Modes | Still photo shooting and video shooting  |
| Focusing |
| Metering Modes | Real-time metering with image sensor
| Metering Range | EV -220 (at 73°F/23°C, ISO 100, evaluative metering)  |
| Grid Display |
| File Format | MP4 Video: MPEG-4 AVC / H.264
| Video Recording Size and Frame Rates | Video Recording Size and Frame Rates
 * The image is cropped around the center of the image sensor. Time-lapse movie (MP4)
 * Some limitations apply when Scene 1, Scene 2, or Scene 3 is used. Continuous Shooting Time
| Focusing |
| Exposure Control |
| Range | Full range (0-255)  |
| Exposure Control | * In Basic Zone modes, exposure control is exerted as appropriate for the detected scene.  |
| Exposure Compensation | Up to ±3 stops in 1/3- or 1/2-stop increments  |
| Type | TFT color, liquid-crystal monitor  |
| Monitor Size | 3.0-inch (screen aspect ratio of 3:2) Approx. 2.95 in./7.50cm diagonal (approx. 2.46 in./6.24cm width, approx. 1.64 in/4.16cm height)  |
| Pixels | Approx. 1.04 million dots  |
| Coverage | Approx. 170° vertically and horizontally  |
| Brightness Control | Adjustable to one of seven brightness levels  |
| Coating | Clear View LCD II
| Interface Languages | 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, and Japanese)  |
| Display Format |
| Highlight Alert | With detailed information display, overexposed highlight areas with no image data will blink.  |
| Histogram | Brightness and RGB  |
| Items | Pressing the Quick Control button displays the Quick Control screen during viewfinder shooting, Live View shooting, movie shooting and playback. After selecting an item, you can select contents by operating the Main Dial.  |
| Protection |
| Erase | Except protected images
| Compatible Printers | Images can be sent via Wi-Fi® to a PictBridge-compatible (Wireless LAN) printer and printed.  |
| DPOF | Complies to DPOF Version 1.1  |
| Standards Compliance | IEEE 802.11b/g/n  |
| Transmission Method | DS-SS modulation (IEEE 802.11b) OFDM modulation (IEEE 802.11g/n)  |
| Transmission Range | Approx. 10 m/32.8 ft. *When communicating with a smartphone or tablet *With no obstructions between the transmitting and receiving antennas and no radio interference  |
| Transition Frequency (Central Frequency) | Frequency: 24122462 MHz Channels: 111 channels  |
| Connection Method | Camera Access Point Mode and Infrastructure mode  |
| Security | Authentication method: Open system, Shared key, WPA/WPA2-PSK Encryption: WEP, TKIP, AES  |
| Communication with a Smartphone | Images can be viewed, controlled, and received using a smartphone. Remote control of the camera using a smartphone is possible. Images can be sent to a smartphone.  |
| Transfer Images Between Cameras | Not supported.  |
| Connect to Connect Station | Images can be sent to and saved on Connect Station.  |
| Remote Operation Using EOS Utility | Remote control functions and image viewing functions of EOS Utility can be used wirelessly.  |
| Print from Wi-Fi® Printers | Images can be sent to a Wi-Fi® printer.  |
| Send Images to a Web Service | Images in the camera or links to images can be sent to registered Web services.  |
| Standards Compliance | Not supported.  |
| Standards Compliance | Bluetooth® Specification Version 4.1 compliant (Bluetooth® low energy technology)  |
| Transmission Method | GFSK modulation  |
| Custom Functions | 11 Custom Functions settable with the camera  |
| Custom Controls | Functions can be assigned to the following control parts:
| My Menu Registration | Up to six items from the menu items and the top-tier items of Custom Functions can be registered to each tab. Up to five My Menu tabs can be added.
| USB Terminal | Hi-Speed USB (USB 2.0)
| Video Out Terminal | Type C (Resolution switches automatically)
| Extension System Terminal | 3.5mm diameter stereo mini jack
| Battery | Battery Pack LP-E17 x 1
| Battery Life |
| Battery Check | Automatic battery check when the power switch is turned ON. Displayed in 4 levels.  |
| Power Saving | Power turns off after the set time (10/30* or 30 sec., 1, 2, 4, 8 or 15 min.) of non-operation elapses. * Normally 10 sec. is set. 30 sec. will be set for function setting, Live View shooting, image playback, etc.  |
| Date/Time Battery | Built-in secondary battery When fully-charged, the date/time can be maintained for approx. 3 months
| Start-up Time | Approx. 0.2 sec. (based on CIPA testing standards)  |
| Dimensions (W x H x D) | Approx. 4.82 x 3.65 x 2.75 in. (122.4 x 92.6 x 69.8mm)
| Weight | Black Approx. 15.84 oz. / 449g (Including battery and card) Approx. 14.18 oz. / 402g (Body only) White Approx. 15.91 oz. / 451g (Including battery and card) Approx. 14.25 oz. / 404g (Body only)  |
| Working Temperature Range | 32-104°F/0-40°C  |
| Working Humidity Range |
| USB Tethered SDK | Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
| Wireless API | Are a developer and want to control select Canon cameras within your application? The Canon CCAPI allows you to set various camera settings, take a picture, and the retrieving of images remotely using a Wi-Fi connection. The CCAPI is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
 - Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
 next to your download
