Canon Support for EOS Rebel T100 | Canon U.S.A., Inc.
EOS Rebel T100
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 02.27.18
File Size 9.60 MB
Date 07.08.21
File Size 6.16 MB
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 05.20.24
File Size 15.56 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
Digital, single-lens reflex, AF/AE camera with built-in flash
Recording Media
SD memory card, SDHC memory card, SDXC memory card
Image Format
Approx. 22.3 x 14.9 mm
Compatible Lenses
Canon EF Lenses (including EF-S lenses and excluding EF-M lenses)
Lens Mount
Canon EF mount
Type
CMOS sensor
Effective Pixels
Approx. 18.0 megapixels (rounded to the nearest 100,000)
Aspect Ratio
3:2
Dust Deletion Feature
Dust Delete Data appending, Clean manually
Recording Format
Design rule for Camera File System (DCF) 2.0
Pixels recorded
L (Large) : Approx. 17.9 megapixels (5184 x 3456)M (Medium) : Approx. 8.0 megapixels (3456 x 2304)S1 (Small 1) : Approx. 4.5 megapixels (2592 x 1728)S2 (Small 2) : Approx. 2.5 megapixels (1920 x 1280)S3 (Small 3) : Approx. 350,000 pixels (720 x 480)RAW : Approx. 17.9 megapixels (5184 x 3456)* Rounded to the nearest 100,000. (For the S3, rounded to the nearest 10,000.)
Folders
Possible
File Numbering
Continuous, Auto reset, Manual reset
Picture Style
AutoStandardPortraitLandscapeNeutralFaithfulMonochromeUser Defined 1-3
Basic +
Ambience-based shots, Light/scene-based shots
Auto White Balance
Auto (Ambience priority), Auto (White priority), Preset (Daylight, Shade, Cloudy, Tungsten light, White fluorescent light, Flash), Custom
White balance correction, and White balance bracketing provided
* Flash color temperature information transmission enabled
Noise reduction
Applicable to long exposures and high ISO speed shots
Automatic image brightness correction
Auto Lighting Optimizer provided
Highlight tone priority
Provided
Lens peripheral illumination correction
Provided
Type
Eye-level pentamirror
Field of view coverage
Vertical/Horizontal approx. 95% with eyepoint approx. 21 mm
Magnification
Approx. 0.8x (-1 m-1 with 50mm lens at infinity)
Standard diopter
Approx. -1.0 m-1 (dpt)
Eyepoint
Approx. 21 mm (from eyepiece lens center at -1 m-1)
Focusing Screen
Fixed, Precision Matte
Mirror
Quick-return type
Depth Of Field Preview
Enabled with Custom Function setting
Type
TTL secondary image-forming phase-difference detection system with AF-dedicated sensor
AF Points
9 points
All AF points support f/5.6
Cross-type AF with center AF point
Focusing brightness range
EV 0 - 18 (Center AF point)
EV 1 - 18 (Other AF points)
AF operation
One-Shot AF, AI Servo AF, AI Focus AF
AF Assist Beam
Small series of flashes fired by built-in flash
Metering Modes
63-zone TTL open-aperture metering#60;br/>Evaluative metering (linked to all AF points)#60;br/>Partial metering (approx. 10% of viewfinder at center)#60;br/>Center-weighted average metering
Metering brightness range
EV 1 - 20 (at room temperature, ISO 100)
Shooting mode
Basic Zone modes#60;br/>Scene Intelligent Auto, Creative Auto, Portrait, Landscape, Close-up, Sports, Food, Night Portrait#60;br/>Creative Zone modes#60;br/>Program AE, Shutter-priority AE, Aperture-priority AE, Manual exposure
ISO speed (Recommended exposure index)
Basic Zone modes: ISO 100 - ISO 3200 set automatically
Creative Zone modes: ISO 100 - ISO 6400 set manually (whole-stop increments), ISO 100 - ISO 6400 set automatically, maximum ISO speed settable for ISO Auto, or ISO expansion to H (equivalent to ISO 12800)
*2 If fill-flash results in overexposure, minimum limit can be set to ISO 100.
*3 If you use bounce flash with an external Speedlite in Basic Zone modes (except Night Portrait) or P mode, the ISO speed is automatically set within ISO 800 to ISO 1600 (or up to the set maximum limit) in accordance with the brightness.
*4 Fixed to ISO 400 in Food mode. If you use bounce flash with an external Speedlite in Food mode, the ISO speed is automatically set in the range within ISO 400 to ISO 1600.
*5 When the maximum ISO speed is ISO 400, the speed is fixed at ISO 400.
AE Lock
Auto Applied in One-Shot AF with evaluative metering when focus is achieved#60;br/>Manual:With AE lock button
Type
Electronically-controlled, focal-plane shutter
Shutter Speeds
1/4000 sec. to 30 sec. (Total shutter speed range. Available range varies by shooting mode.), Bulb, X-sync at 1/200 sec.
Built in Flash
Retractable, manually raised flash
Guide No.: Approx. 9.2/30.2 (ISO 100, in meters/feet) or approx. 13/42.7 (ISO 200, in meters/feet)
Flash coverage: Approx. 17mm lens angle of view
Recharge time: Approx. 2 sec.
Flash Metering
E-TTL II autoflash
External Speedlite
Compatible with EX-series Speedlites
Flash exposure compensation
±2 stops in 1/3- or 1/2-stop increments
FE Lock
Provided
PC terminal
Not provided
Drive Modes
Single shooting, Continuous shooting, Self-timer with 10-sec. or 2-sec. delay and 10-sec. delay with continuous shooting
Continuous Shooting Speed
Max. approx. 3.0 shots/sec
Maximum Burst
JPEG Large/Fine: Full
RAW: 6 shots
RAW+JPEG Large/Fine: 5 shots
* Figures are based on Canons testing standards (ISO 100 and Standard Picture Style) using an 8 GB card.
* Full indicates that shooting is possible until the card becomes full.
Aspect ratio
3:2, 4:3, 16:9, 1:1
Focus method
Contrast detection (FlexiZone-Single, Face detection Live mode), Phase-difference detection (Quick mode)
Manual focus (approx. 5x / 10x magnification possible)
EV 1 - 18 (at room temperature, ISO 100)
Metering Modes
Real-time metering with image sensor
Metering Range
EV 0 - 20 (at room temperature, ISO 100)
Grid Display
Two types
Recording Format
MOV
Movie
MPEG-4 AVC/H.264
Variable (average) bit rate
Audio
Linear PCM
Recording size and frame rate
1920x1080 (Full HD): 30p/25p/24p
1280x720 (HD): 60p/50p
640x480 (VGA) : 30p/25p
* 30p: 29.97 fps, 25p: 25.00 fps, 24p: 23.98 fps, 60p: 59.94 fps, 50p: 50.00 fps
Focus method
Same as focusing with Live View shooting
Metering mode
Center-weighted average and evaluative metering with the image sensor
Exposure control
Autoexposure and manual exposure
Exposure compensation
L±3 stops in 1/3-stop increments
With autoexposure shooting:
With manual exposure:
ISO 100 - ISO 6400 set automatically/manually
Video snapshots
Settable to 2 sec./4 sec./8 sec
Sound recording
Built-in monaural microphone
Grid display
Two types
Still photo shooting
Not possible during movie shooting
Type
TFT color, liquid-crystal monitor
Monitor Size and dots
Approx. 6.8 cm (2.7 in.) (4:3) with approx. 230,000 dots
Brightness adjustment
Manual (7 levels)
Interface languages
25
Feature guide
Displayable
Image display format
Basic info, basic info + image quality/playback number, shooting info. display, histogram, index display (4/9)
Zoom magnification
Approx. 1.5x - 10x
Highlight Aleert
Overexposed highlights blink
Image browsing method
Single image, jump by 10 or 100 images, by shooting date, by folder, by movies, by stills, by rating
Image rotation
Possible
Ratings
Provided
Movie playback
Enabled (LCD monitor, HDMI) Sound playback on the camera not possible
Image protection
Possible
Slide show
All images, by date, by folder, by movies, by stills, by rating
Five transition effects selectable
Background music
Selectable for slide shows and movie playback
Creative filters
Grainy B/W, Soft focus, Fish-eye effect, Toy camera effect, Miniature effect
Resize
Possible
Compatible Printers
PictBridge-compatible printers
Printable Images
JPEG and RAW images
Print ordering
DPOF Version 1.1 compatible
Standards compliance
IEEE 802.11b/g/n
Transmission method
DS-SS modulation (IEEE 802.11b)
OFDM modulation (IEEE 802.11g/n)
Transmission range
Approx. 15 m / 49.2 ft.
* When connected to a smartphone
* With no obstructions between the transmitting and receiving antennas and no radio interference
Transmission frequency (central frequency)
Frequency: 2412 to 2462 MHz
Channels: 1 to 11 ch
Connection method
Connection method
Infrastructure mode*, camera access point mode
* Wi-Fi Protected Setup supported
Security
Authentication method: Open system, Shared Key,WPA/WPA2-PSK
Encryption: WEP, TKIP, AES
Connection to smartphones
Images can be viewed, controlled, and received using a smartphone
Transfer images between cameras
Transferring one image, Transferring selected images, Transferring resized images
Print from Wi-Fi printers
Images can be sent to a printer supporting Wi-Fi
Send images to a Web service
Images in the camera or links to images can be sent to registered Web services
Custom Functions
10
My Menu registration
Possible
Copyright information
Entry and appending possible
Digital terminal
HHi-Speed USB equivalent: Computer communication,
Direct printing, Connect Station CS100 connection
HDMI mini OUT terminal
Type C (Auto switching of resolution)
Remote control terminal
Not provided
Eye-Fi card
Compatible
Battery
Battery Pack LP-E10 (Quantity 1)
Number of possible shots (Based on CIPA testing standards, with 50% flash use)
With viewfinder shooting:
Approx. 500 shots at room temperature (23°C/73°F), approx. 410 shots at low temperatures (0°C/32°F)
With Live View shooting:
Approx. 180 shots at room temperature (23°C/73°F),approx. 170 shots at low temperatures (0°C/32°F)
* With a fully-charged Battery Pack LP-E10.
Movie shooting time
Approx. 1 hr. 15 min. at room temperature (23°C/73°F)
Approx. 1 hr. 10 min. at low temperatures (0°C/32°F)
Dimensions (W x H x D)
Approx. 129.0 x 101.6 x 77.1 mm / 5.08 x 4.00 x 3.04 in.
Weight
Approx. 436 g / 15.38 oz. (Including battery and card),
Approx. 389 g / 13.72 oz. (Body only)
Working Temperature Range
0-40&deg;C / 40-104&deg;F
Working Humidity Range
85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Service Notice: Photo Culling App Version 1.1
Advisory Type
Date 06.01.21
Title Firmware Notice: EOS Rebel T100: Firmware Version 1.1.0
Advisory Type Firmware Notice
Date 05.18.23
Title Service Notice: EOS Webcam Utility Pro app: Version 2.0.30 features
Advisory Type Service Notice
Date 05.23.23
Title Service Notice: Kokomo by Canon Early Access App for Meta Quest 2: Version 0.0.102 Features
Date 05.23.23
Title Service Notice: EOS Webcam Utility Pro v2.3
Date 11.13.24
Title Service Notice: EOS Webcam Utility Pro Software for macOS: Version 2.1.18
Date 05.01.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
