Canon Support for EOS Rebel T100 | Canon U.S.A., Inc.
EOS Rebel T100
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- macOS 26
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type | Digital, single-lens reflex, AF/AE camera with built-in flash |
Recording Media | SD memory card, SDHC memory card, SDXC memory card |
Image Format | Approx. 22.3 x 14.9 mm |
Compatible Lenses | Canon EF Lenses (including EF-S lenses and excluding EF-M lenses) |
Lens Mount | Canon EF mount |
Type | CMOS sensor |
Effective Pixels | Approx. 18.0 megapixels (rounded to the nearest 100,000) |
Aspect Ratio | 3:2 |
Dust Deletion Feature | Dust Delete Data appending, Clean manually |
Recording Format | Design rule for Camera File System (DCF) 2.0 |
Pixels recorded | L (Large) : Approx. 17.9 megapixels (5184 x 3456)M (Medium) : Approx. 8.0 megapixels (3456 x 2304)S1 (Small 1) : Approx. 4.5 megapixels (2592 x 1728)S2 (Small 2) : Approx. 2.5 megapixels (1920 x 1280)S3 (Small 3) : Approx. 350,000 pixels (720 x 480)RAW : Approx. 17.9 megapixels (5184 x 3456)* Rounded to the nearest 100,000. (For the S3, rounded to the nearest 10,000.) |
Folders | Possible |
File Numbering | Continuous, Auto reset, Manual reset |
Picture Style | AutoStandardPortraitLandscapeNeutralFaithfulMonochromeUser Defined 1-3 |
Basic + | Ambience-based shots, Light/scene-based shots |
Auto White Balance | Auto (Ambience priority), Auto (White priority), Preset (Daylight, Shade, Cloudy, Tungsten light, White fluorescent light, Flash), Custom White balance correction, and White balance bracketing provided * Flash color temperature information transmission enabled |
Noise reduction | Applicable to long exposures and high ISO speed shots |
Automatic image brightness correction | Auto Lighting Optimizer provided |
Highlight tone priority | Provided |
Lens peripheral illumination correction | Provided |
Type | Eye-level pentamirror |
Field of view coverage | Vertical/Horizontal approx. 95% with eyepoint approx. 21 mm |
Magnification | Approx. 0.8x (-1 m-1 with 50mm lens at infinity) |
Standard diopter | Approx. -1.0 m-1 (dpt) |
Eyepoint | Approx. 21 mm (from eyepiece lens center at -1 m-1) |
Focusing Screen | Fixed, Precision Matte |
Mirror | Quick-return type |
Depth Of Field Preview | Enabled with Custom Function setting |
Type | TTL secondary image-forming phase-difference detection system with AF-dedicated sensor |
AF Points | 9 points All AF points support f/5.6 Cross-type AF with center AF point |
Focusing brightness range | EV 0 - 18 (Center AF point) EV 1 - 18 (Other AF points) |
AF operation | One-Shot AF, AI Servo AF, AI Focus AF |
AF Assist Beam | Small series of flashes fired by built-in flash |
Metering Modes | 63-zone TTL open-aperture metering#60;br/>Evaluative metering (linked to all AF points)#60;br/>Partial metering (approx. 10% of viewfinder at center)#60;br/>Center-weighted average metering |
Metering brightness range | EV 1 - 20 (at room temperature, ISO 100) |
Shooting mode | Basic Zone modes#60;br/>Scene Intelligent Auto, Creative Auto, Portrait, Landscape, Close-up, Sports, Food, Night Portrait#60;br/>Creative Zone modes#60;br/>Program AE, Shutter-priority AE, Aperture-priority AE, Manual exposure |
ISO speed (Recommended exposure index) | Basic Zone modes: ISO 100 - ISO 3200 set automatically Creative Zone modes: ISO 100 - ISO 6400 set manually (whole-stop increments), ISO 100 - ISO 6400 set automatically, maximum ISO speed settable for ISO Auto, or ISO expansion to H (equivalent to ISO 12800) *2 If fill-flash results in overexposure, minimum limit can be set to ISO 100. *3 If you use bounce flash with an external Speedlite in Basic Zone modes (except Night Portrait) or P mode, the ISO speed is automatically set within ISO 800 to ISO 1600 (or up to the set maximum limit) in accordance with the brightness. *4 Fixed to ISO 400 in Food mode. If you use bounce flash with an external Speedlite in Food mode, the ISO speed is automatically set in the range within ISO 400 to ISO 1600. *5 When the maximum ISO speed is ISO 400, the speed is fixed at ISO 400. |
AE Lock | Auto Applied in One-Shot AF with evaluative metering when focus is achieved#60;br/>Manual:With AE lock button |
Type | Electronically-controlled, focal-plane shutter |
Shutter Speeds | 1/4000 sec. to 30 sec. (Total shutter speed range. Available range varies by shooting mode.), Bulb, X-sync at 1/200 sec. |
Built in Flash | Retractable, manually raised flash Guide No.: Approx. 9.2/30.2 (ISO 100, in meters/feet) or approx. 13/42.7 (ISO 200, in meters/feet) Flash coverage: Approx. 17mm lens angle of view Recharge time: Approx. 2 sec. |
Flash Metering | E-TTL II autoflash |
External Speedlite | Compatible with EX-series Speedlites |
Flash exposure compensation | ±2 stops in 1/3- or 1/2-stop increments |
FE Lock | Provided |
PC terminal | Not provided |
Drive Modes | Single shooting, Continuous shooting, Self-timer with 10-sec. or 2-sec. delay and 10-sec. delay with continuous shooting |
Continuous Shooting Speed | Max. approx. 3.0 shots/sec |
Maximum Burst | JPEG Large/Fine: Full RAW: 6 shots RAW+JPEG Large/Fine: 5 shots * Figures are based on Canons testing standards (ISO 100 and Standard Picture Style) using an 8 GB card. * Full indicates that shooting is possible until the card becomes full. |
Aspect ratio | 3:2, 4:3, 16:9, 1:1 |
Focus method | Contrast detection (FlexiZone-Single, Face detection Live mode), Phase-difference detection (Quick mode) Manual focus (approx. 5x / 10x magnification possible) |
Focusing brightness range | EV 1 - 18 (at room temperature, ISO 100) |
Metering Modes | Real-time metering with image sensor |
Metering Range | EV 0 - 20 (at room temperature, ISO 100) |
Grid Display | Two types |
Recording Format | MOV |
Movie | MPEG-4 AVC/H.264 Variable (average) bit rate |
Audio | Linear PCM |
Recording size and frame rate | 1920x1080 (Full HD): 30p/25p/24p 1280x720 (HD): 60p/50p 640x480 (VGA) : 30p/25p * 30p: 29.97 fps, 25p: 25.00 fps, 24p: 23.98 fps, 60p: 59.94 fps, 50p: 50.00 fps |
Focus method | Same as focusing with Live View shooting |
Metering mode | Center-weighted average and evaluative metering with the image sensor |
Metering brightness range | EV 0 - 20 (at room temperature, ISO 100) |
Exposure control | Autoexposure and manual exposure |
Exposure compensation | L±3 stops in 1/3-stop increments |
ISO speed (Recommended exposure index) | With autoexposure shooting: ISO 100 - ISO 6400 set automatically With manual exposure: ISO 100 - ISO 6400 set automatically/manually |
Video snapshots | Settable to 2 sec./4 sec./8 sec |
Sound recording | Built-in monaural microphone |
Grid display | Two types |
Still photo shooting | Not possible during movie shooting |
Type | TFT color, liquid-crystal monitor |
Monitor Size and dots | Approx. 6.8 cm (2.7 in.) (4:3) with approx. 230,000 dots |
Brightness adjustment | Manual (7 levels) |
Interface languages | 25 |
Feature guide | Displayable |
Image display format | Basic info, basic info + image quality/playback number, shooting info. display, histogram, index display (4/9) |
Zoom magnification | Approx. 1.5x - 10x |
Highlight Aleert | Overexposed highlights blink |
Image browsing method | Single image, jump by 10 or 100 images, by shooting date, by folder, by movies, by stills, by rating |
Image rotation | Possible |
Ratings | Provided |
Movie playback | Enabled (LCD monitor, HDMI) Sound playback on the camera not possible |
Image protection | Possible |
Slide show | All images, by date, by folder, by movies, by stills, by rating Five transition effects selectable |
Background music | Selectable for slide shows and movie playback |
Creative filters | Grainy B/W, Soft focus, Fish-eye effect, Toy camera effect, Miniature effect |
Resize | Possible |
Compatible Printers | PictBridge-compatible printers |
Printable Images | JPEG and RAW images |
Print ordering | DPOF Version 1.1 compatible |
Standards compliance | IEEE 802.11b/g/n |
Transmission method | DS-SS modulation (IEEE 802.11b) OFDM modulation (IEEE 802.11g/n) |
Transmission range | Approx. 15 m / 49.2 ft. * When connected to a smartphone * With no obstructions between the transmitting and receiving antennas and no radio interference |
Transmission frequency (central frequency) | Frequency: 2412 to 2462 MHz Channels: 1 to 11 ch |
Connection method | Frequency: 2412 to 2462 MHz Channels: 1 to 11 ch |
Connection method | Infrastructure mode*, camera access point mode * Wi-Fi Protected Setup supported |
Security | Authentication method: Open system, Shared Key,WPA/WPA2-PSK Encryption: WEP, TKIP, AES |
Connection to smartphones | Images can be viewed, controlled, and received using a smartphone |
Transfer images between cameras | Transferring one image, Transferring selected images, Transferring resized images |
Print from Wi-Fi printers | Images can be sent to a printer supporting Wi-Fi |
Send images to a Web service | Images in the camera or links to images can be sent to registered Web services |
Custom Functions | 10 |
My Menu registration | Possible |
Copyright information | Entry and appending possible |
Digital terminal | HHi-Speed USB equivalent: Computer communication, Direct printing, Connect Station CS100 connection |
HDMI mini OUT terminal | Type C (Auto switching of resolution) |
Remote control terminal | Not provided |
Eye-Fi card | Compatible |
Battery | Battery Pack LP-E10 (Quantity 1) |
Number of possible shots (Based on CIPA testing standards, with 50% flash use) | With viewfinder shooting: Approx. 500 shots at room temperature (23°C/73°F), approx. 410 shots at low temperatures (0°C/32°F) With Live View shooting: Approx. 180 shots at room temperature (23°C/73°F),approx. 170 shots at low temperatures (0°C/32°F) * With a fully-charged Battery Pack LP-E10. |
Movie shooting time | Approx. 1 hr. 15 min. at room temperature (23°C/73°F) Approx. 1 hr. 10 min. at low temperatures (0°C/32°F) * With a fully-charged Battery Pack LP-E10. |
Dimensions (W x H x D) | Approx. 129.0 x 101.6 x 77.1 mm / 5.08 x 4.00 x 3.04 in. |
Weight | Approx. 436 g / 15.38 oz. (Including battery and card), Approx. 389 g / 13.72 oz. (Body only) |
Working Temperature Range | 0-40°C / 40-104°F |
Working Humidity Range | 85% or less |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
