Canon Support for EOS Rebel T6 | Canon U.S.A., Inc.
        EOS Rebel T6
- Windows 11
 - Windows 10 (x64)
 - Windows 10
 - Windows 8.1 (x64)
 - Windows 8.1
 - Windows 8 (x64)
 - Windows 8
 - Windows 7 (x64)
 - Windows 7
 - Windows Vista (x64)
 - Windows Vista
 - Windows Me
 - Windows XP (x64)
 - Windows XP
 - Windows 98
 - Windows 95
 - Windows Server 2022
 - Windows Server 2019 (x64)
 - Windows Server 2016 (x64)
 - Windows Server 2012 (x64)
 - Windows Server 2008 (x64)
 - Windows Server 2003 (x64)
 - Windows Server 2003 R2
 - macOS Tahoe v26
 - macOS Sequoia v15
 - macOS Sonoma v14
 - macOS Ventura v13
 - macOS Monterey v12
 - macOS Big Sur v11.0
 - macOS Catalina v10.15
 - macOS Mojave v10.14
 - macOS High Sierra v10.13
 - macOS Sierra v10.12
 - OS X El Capitan v10.11
 - OS X Yosemite v10.10
 - OS X Mavericks v10.9
 - OS X Mountain Lion v10.8
 - OS X Lion v10.7
 - Mac OS X Snow Leopard v10.6
 - Mac OS X v10.1
 - Mac OS 9
 - Linux ARM
 - Linux MIPS
 - Linux 64bit
 - Linux 32bit
 - SAP
 - Windows Server 2025
 - Windows NT
 - Linux
Camera Connect
image.canon
Software Development Kit
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
SELECT ERROR CODE
| Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
| Type | Digital, AF/AE single-lens reflex camera with built-in flash  |
| Recording Media | SD, SDHC and SDXC Memory Cards Not compliant to UHS-I (Ultra High Speed) standards. Compatible with Eye-Fi Cards. Multimedia cards (MMC) cannot be used. (A card error will be displayed.)  |
| Image Format | Approx. 22.3mm x 14.9mm  |
| Compatible Lenses | Canon EF Lenses (including EF-S lenses, excluding EF-M lenses)  |
| Lens Mount | Canon EF mount  |
| Type | CMOS Sensor  |
| Pixels | Effective pixels: Approx. 18.00 megapixels Total pixels: Approx. 18.70 megapixels  |
| Pixel Unit | Approx. 4.30 µm square  |
| Aspect Ratio | 3:2 (Horizontal : Vertical)  |
| Color Filter System | RGB primary color filters  |
| Low Pass Filter | Fixed position in front of the image sensor  |
| Dust Deletion Feature |
| Recording Format | Design Rule for Camera File System 2.0 and EXIF 2.3  |
| File Size | Large: Approx. 17.90 Megapixels (5184 x 3456) Medium: Approx. 8.00 Megapixels (3456 x 2304) Small 1: Approx. 4.50 Megapixels (2592 x 1728) Small 2: Approx. 2.50 Megapixels (1920 x 1280) Small 3: Approx. 0.35 Megapixels (720 x 480) RAW: Approx. 17.90 Megapixels (5184 x 3456)  |
| Backup Recording | N/A  |
| File Numbering | The following three types of file numbering method can be set:
| Color Space | sRGB, Adobe RGB  |
| Picture Style |
| Auto White Balance | Auto white balance with the image sensor  |
| Color Temperature Compensation | Blue/amber bias: ±9 levels Magenta/green bias: ±9 levels Corrected in reference to the current WB mode's color temperature.  |
| Color Temperature Information Transmission | Provided  |
| Type | Eye-level single lens reflex (with fixed pentamirror)  |
| Coverage | Approx. 95% vertically and horizontally (with Eye point approx. 21mm)  |
| Magnification | Approx. 0.8x / 22.4° (-1m-1 (dpt) with 50mm lens at infinity)  |
| Eye Point | Approx. 21 mm (At -1m-1 from the eyepiece lens center)  |
| Dioptric Adjustment Correction | Adjustable from approx. -2.5 to +0.5 m-1 (dpt)  |
| Focusing Screen | Fixed  |
| Mirror | Quick-return half mirror (Transmittance: reflectance ratio of 40:60)  |
| Viewfinder Information |
| Depth Of Field Preview | Enabled with Custom Function  |
| Type | TTL secondary image-forming phase-difference detection system with AF-dedicated CMOS sensor  |
| AF Points | 9 points Cross-type AF sensitive to f/5.6 with center AF point  |
| AF Working Range | With One-Shot AF EV 0-18 (center AF point) EV 1-18 (other AF points) (at room temperature and ISO 100, based on Canon's testing standards)  |
| Focusing Modes |
| AF Point Selection |
| Selected AF Point Display | Indicated by superimposed display in the viewfinder and on the LCD monitor.  |
| AF Assist Beam | Intermittent firing of built-in flash Effective range: Center: Approx. 13.1 ft. / 4.0m Periphery: Approx. 11.5 ft. / 3.5m With an EOS-dedicated Speedlite attached, the Speedlite's AF-assist beam is emitted instead.  |
| Metering Modes | Dual-layer metering sensor with the area divided into 63 zones.
| Metering Range | EV 1-20 (room temperature, ISO 100, evaluative metering)  |
| Exposure Control Systems | Creative Zone
| AE Lock |
| Type | Vertical-travel shutter with electronic first-curtain control and mechanical second-curtain control  |
| Shutter Speeds | 1/4000 to 30 sec., Bulb (Total shutter speed range) X-sync at 1/200 sec. Settable in 1/3- or 1/2-stop increments.  |
| Shutter Release | Soft-touch electromagnetic release  |
| Self Timer | 10-sec. or 2-sec. Delay  |
| Shutter Lag Time |
| Type | Auto pop-up, retractable, built-in flash in the pentamirror  |
| Flash Metering System | E-TTL II autoflash (Evaluative, Average), FE lock  |
| Guide Number | Approx. 30.2 ft./9.2m (at ISO 100)  |
| Recycling Time | Approx. 2 sec.  |
| Flash Coverage | Up to approx. 17mm focal length (equivalent to approx. 28mm in 135 format)  |
| FE Lock | Possible  |
| Flash Exposure Compensation | Up to ±2 stops in 1/3- or 1/2-stop increments Flash exposure compensation for built-in flash and external Speedlite can be set with the camera.  |
| Flash Metering | E-TTL II autoflash (evaluative flash metering and average flash metering), FE lock  |
| Flash Exposure Compensation | ±2 stops in 1/3-stop or 1/2-stop increments  |
| Drive Modes |
| Continuous Shooting Speed | Max. approx. 3.0 fps  |
| Metering Modes | Evaluative metering (315-zone) AE lock possible. The active metering timer can be changed.  |
| Metering Range | EV 0-20 (room temperature, ISO 100)  |
| Grid Display | One of two types of grids can be selected and displayed on the screen.
| Exposure Simulation | Provided  |
| Silent Shooting | Not provided  |
| File Format | MOV: Movie: MPEG4 AVC/H.264 * Variable (average) bit rate Audio: Linear PCM  |
| File Size | [Full HD] 1920 x 1080 (30 fps/24 fps): 340 MB/min. [HD] 1280 x 720 (60 fps): 340 MB/min. [SD] 640 x 480 (30 fps): 90 MB/min.  |
| Frame Rates | 1920 x 1080 (Full HD): 30 fps (29.97 fps) / 24 fps (23.98 fps) 1280 x 720 (HD): 60 fps (59.94 fps) 640 x 480 (SD): 30 fps (29.97 fps)  |
| Focusing |
| Exposure Compensation | Possible (±3 stops in 1/3-stop increments)  |
| Type | TFT color, liquid-crystal monitor  |
| Monitor Size | 3.0-inch (Screen aspect ratio of 4:3) Approx. 7.5cm diagonal (approx. 6.0cm wide, approx. 4.5cm high)  |
| Pixels | Approx. 920,000 dots  |
| Coverage | Approx. 170° vertically and horizontally  |
| Brightness Control | Adjustable to one of seven levels  |
| Coating | Not provided  |
| Interface Languages | 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese)  |
| Display Format |
| Highlight Alert | On the detailed information and histogram displays, highlight areas with no image data will blink.  |
| Items | When you press the Quick Control button while shooting images, you can set various functions. The functions that can be set vary depending on whether the shooting mode is viewfinder shooting, Live View shooting or movie shooting.  |
| Protection | Erase protection can be applied or canceled for a single image, all images in a folder or all images in the card.  |
| Erase | Erase unprotected image(s) with selection from Single image, Selected images, All images on folder or All images in a card.  |
| Compatible Printers | PictBridge-compatible and Wi-Fi equipped printers  |
| Printable Images | RAW and JPEG images compliant to Design rule for Camera File System. Movies cannot be printed.  |
| DPOF | Complies to DPOF Version 1.1  |
| Custom Functions | 11 Custom Functions with 33 settings settable with the camera  |
| Custom Controls | Not Provided  |
| Camera User Settings | Not Provided  |
| My Menu Registration | Up to six kinds of function settings can be selected and registered from the Menu options or any of the top-tier menu options of Custom Functions.  |
| USB Terminal | Hi-Speed USB (USB 2.0) For computer communication and PictBridge For connection with the GPS receiver GP-E2  |
| Video Out Terminal | HDMI Type C (Resolution switches automatically) Video output: (Switches automatically to 1, 2, 3 or 4 to suit the TV set.)
| Extension System Terminal | Compatible with Remote Switch RS-60E3  |
| Gigabit-Ethernet | Compatible Canon cameras are not guaranteed to support Eye-Fi card functions, including wireless transfer. In case of an issue with the Eye-Fi card, please consult with the card manufacturer. The use of Eye-Fi cards may not be approved in all regions, or from one region to another; please contact the card manufacturer for status of approval in the country/region of use.  |
| Battery | Battery Pack LP-E10 x 1 The camera can be powered by an AC power supply by using the household power outlet accessories (sold separately).  |
| Battery Check | Automatic battery check when the power switch is turned ON. Battery level indicated in one of the four levels on LCD monitor.  |
| Power Saving | Power turns off after the set time of non-operation elapses * [Auto power off] settable to 30 sec., 1 min., 2 min., 4 min., 8 min., 15 min. or disable  |
| Date/Time Battery | Built-in secondary battery Maintains date/time for about 3 months when fully charged  |
| Start-up Time | Approx. 0.1 sec. (Based on CIPA testing standards)  |
| Dimensions (W x H x D) | Approx. 5.08 x 3.99 x 3.06 in. / 129.0 x 101.3 x 77.6mmIn CIPA guidelines.  |
| Weight | Approx. 17.11 oz. / 485g (In accordance with CIPA guidelines)Approx. 15.52 oz. / 440g (Body only)  |
| Working Temperature Range | 32-104°F/0-40°C  |
| Working Humidity Range | 85% or less All data are based on Canon's Standard Test Method. Subject to change without notice. If a problem occurs with a non-Canon lens attached to the camera, consult the lens maker. Canon, DIGIC and EOS Rebel are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. HDMI, the HDMI logo and High-Definition Multimedia Interface are registered trademarks or trademarks of HDMI Licensing, LLC in the United States and/or other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.  |
| USB Tethered SDK | Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
 - Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
 next to your download
