Canon Support for EOS Rebel T7 | Canon U.S.A., Inc.
EOS Rebel T7
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
Type Digital, Af/Ae Single-Lens Reflex Camera With Built-In Flash
Recording Medium Sd, Sdhc And Sdxc Memory Cards
Compatible With Sd Speed Class Cards.
Not Compatible With Uhs Speed Class Cards.
Compatible With Eye-Fi Cards.
Multimedia Cards (Mmc) Cannot Be Used. (A Card Error Will Be Displayed.)
Image Format
Approx. 22.3mm X 14.9mm
Compatible Lenses Canon Ef Lenses (Including Ef-S Lenses And Excluding Ef-M Lenses)
Lens Mount Canon Ef Mount
Type Cmos Sensor
Pixels Approx. 24.10 Megapixels (Rounded To The Nearest 100,000)
Pixel Unit Approx. 3.72 µm Square
Total Pixels Approx. 24.70 Megapixels (Rounded To The Nearest 100,000)
Aspect Ratio 3:2 (Horizontal: Vertical)
Color Filter System Rgb Primary Color Filters
Low Pass Filter Installed In Front Of The Image Sensor, Non-Detachable
Dust Deletion Feature
  1. Dust Delete Data Acquisition And Appending
    • The Coordinates Of The Dust Adhering To The Low-Pass Filter Are Detected By A Test Shot And Appended To Subsequent Images.
    • The Dust Coordinate Data Appended To The Image Is Used By The Eos Software To Automatically Erase The Dust Spots.
  2. Manual Cleaning By Hand
    • Self Cleaning Sensor Unit Not Provided.
Recording Format Compliant To Design Rule For Camera File System 2.0 And Exif 2.30
Image Format
Jpeg, Raw (14 Bit Canon Original)
File Size 3:2 Aspect Ratio
Large: 6000 X 4000
Medium: 3984 X 2656
Small 1: 2976 X 1984
Small 2: 1920 X 1280
Small 3: 720 X 480
Raw: 6000 X 4000
4:3 Aspect Ratio
Large: 5328 X 4000*
Medium: 3552 X 2664
Small 1: 2656 X 1992
Small 2: 1696 X 1280*
Small 3: 640 X 480
Raw: 6000 X 4000
16:9 Aspect Ratio
Large: 6000 X 3368*
Medium: 3984 X 2240*
Small 1: 2976 X 1680*
Small 2: 1920 X 1080
Small 3: 720 X 408*
Raw: 6000 X 4000
1:1 Aspect Ratio
Large: 4000 X 4000
Medium: 2656 X 2656
Small 1: 1984 X 1984
Small 2: 1280 X 1280
Small 3: 480 X 480
Raw: 6000 X 4000
* The Dimensions Will Not Attain A Perfect Aspect Ratio.
Values Are Rounded To The Nearest 100,000. (Nearest 10,000 For S3.)
For Jpeg, The Image Will Be Generated According To The Selected Aspect Ratio.
Raw Images Are Generated In [3:2], And The Set Aspect Ratio Is Appended.
File Numbering The Following Three Types Of File Numbering Methods Can Be Set:
  1. Continuous Numbering
    • The Numbering Of Captured Images Will Continue Even After You Replace The Card. (The Numbering Continues Even When The Folder Changes.)
  2. Auto Reset
    • When You Replace The Camera's Card, The Numbering Will Be Reset To Start From 0001. If The New Card Already Contains Images, The Numbering Will Continue From The Last Recorded Image In The Card.
  3. Manual Reset
    • Resets The File Number To 0001, And Creates A New Folder Automatically.
Color Space Srgb, Adobe Rgb
Picture Style
  • Auto
  • Standard
  • Portrait
  • Landscape
  • Fine Detail
  • Neutral
  • Faithful
  • Monochrome
  • Smooth Skin
  • Self Portrait
  • User Defined 1-3
    1. In Basic Zone Modes, "Auto" Is Set Automatically.
    2. In Creative Zone Modes, You Can Select And Set The Picture Style.
    3. Default Settings For [User Defined 1-3] Are [Auto].
Auto White Balance Option Between Ambience Priority And White Priority Settings
Settings
  1. Auto (Ambience Priority/White Priority)
  2. Daylight
  3. Shade
  4. Cloudy*
  5. Tungsten Light
  6. White Fluorescent Light
  7. Flash
  8. Custom (Custom Wb)
* Effective Also In Twilight And Sunset.
Color Temperature Compensation Blue/Amber Bias: ±9 Levels
Magenta/Green Bias: ±9 Levels
Corrected Based On The Current Wb Mode's Color Temperature.
Type Eye-Level Single Lens Reflex (With Fixed Pentamirror)
Coverage Approx. 95% Vertically And Horizontally (With Eye Point Approx. 21mm)
Magnification Approx. 0.8x / 22.4° (-1m-1 With 50mm Lens At Infinity)
Eyepoint Approx. 21mm (At -1m-1 From Eyepiece Lens Center)
Dioptric Adjustment Correction Adjustable From Approx. -2.5 To +0.5 M-1 (Dpt)
Focusing Screen Fixed
Mirror Quick-Return Half Mirror
Viewfinder Information Af Point, Af Point Activation Indicator, Iso Speed, White Balance Correction, Focus Indicator, Maximum Burst, Monochrome Shooting, Iso Speed, Highlight Tone Priority, Exposure Level Indicator, Exposure Compensation Amount Aeb Range, Red-Eye Reduction Lamp On, Aperture, Card Full Warning, Card Error Warning, No Card Warning, Shutter Speed, Fe Lock, Busy, Built-In Flash Recycling, Flash Exposure Compensation, High-Speed Sync (Fp Flash), Fe Lock/Feb In-Progress, Flash-Ready, Fe Lock Out Of Range Warning, Ae Lock/Aeb In-Progress, Focusing Screen
Depth Of Field Preview Possible (With C.Fn-9 (Assign Set Button) Setting)
Type Ttl Secondary Image-Forming Phase-Difference Detection System With Af-Dedicated Sensor
Af Points 9 Points
All Af Points Support F/5.6
Cross-Type Af With Center Af Point
Af Working Range
With One-Shot Af (At Room Temperature And Iso 100, Based On Canons Testing Standards)
Ev 018 (Center Af Point)
Ev 118 (Other Af Points)
Focusing Modes
  1. Autofocus
    1. One-Shot Af
    2. Predictive Ai Servo Af
    3. Ai Focus Af
      • Switches Between One-Shot Af And Ai Servo Af Automatically.
  2. Manual Focus
Af Point Selection
  1. Manual Selection
  2. Auto Selection
    • Af Point Selection For Basic Zone Modes Is Fixed To Automatic Selection.
Selected Af Point Display Indicated By Superimposed Display In The Viewfinder And On The Lcd Monitor.
Af Assist Beam Intermittent Firing Of Built-In Flash
Effective Range:
Center: Approx. 13.1 Ft. / 4.0m
Periphery: Approx. 11.5 Ft. / 3.5m
With An Eos-Dedicated Speedlite Attached, The Speedlite's Af-Assist Beam Is Emitted Instead.
Metering Modes Dual-Layer Metering Sensor With The Area Divided Into 63 Zones.
  1. Evaluative Metering (Supporting All Af Points)
  2. Partial Metering (Center, Approx. 10% Of Viewfinder)
  3. Center-Weighted Average Metering
* Spot Metering Not Provided.
Metering Range Ev 1-20 (Room Temperature, Iso 100, Evaluative Metering)
Exposure Control Systems Creative Zone
  1. Program Ae (Shiftable)
  2. Shutter-Priority Ae
  3. Aperture-Priority Ae
  4. Manual Exposure (Including Bulb)
Basic Zone
  1. Scene Intelligent Auto (Program Ae/Non-Shiftable)
  2. Flash Off
  3. Creative Auto
  4. Portrait
  5. Landscape
  6. Close-Up
  7. Sports
  8. Food
  9. Night Portrait
Iso Speed Range
Manual Iso Setting: Iso 1006400 (In Whole-Stop Increments), Expandable Equivalent To Iso 12800.
If Highlight Tone Priority Is Set, The Iso Speed Is Automatically Set Within Iso 200 To Iso 6400.
Iso Auto Setting: Iso 1006400
In Creative Zone Modes, The Maximum Iso Speed (Iso 400, 800, 1600, 3200 Or 6400) For Iso Auto Can Be Set.
Shooting Mode Iso Settings
Scene Intelligent Auto, Flash Off, Creative Auto, Landscape, Close-Up, Sports, Food, Night Portrait Iso 1003200
Portrait Iso 100
P, Tv, Av, M Iso 1006400*1
With Flash Iso 800*2,3,4,5
With Bulb Exposures Iso 800*5
*1 Depends On The Set Maximum Limit Of Iso Speed.
*2 If Fill-Flash Results In Overexposure, Minimum Limit Can Be Set To Iso 100.
*3 If You Use Bounce Flash With An External Speedlite In Basic Zone Modes (Except Night Portrait) Or P Mode, The Iso Speed Is Automatically Set Within Iso 800 To Iso 1600 (Or Up To The Set Maximum Limit) In Accordance With The Brightness.
*4 Fixed To Iso 400 In Food Mode. If You Use Bounce Flash With An External Speedlite In Food Mode, The Iso Speed Is Automatically Set In The Range Within Iso 400 To Iso 1600.
*5 When The Maximum Iso Speed Is Iso 400, The Speed Is Fixed At Iso 400.
Ae Lock
  1. Auto Ae Lock
    • In The One-Shot Af Mode With Evaluative Metering, Ae Lock Takes Effect When Focus Is Achieved.
  2. Manual Ae Lock
    • In P, Tv And Av Modes, Possible With The Ae Lock Button. (Press Again To Update.)
    • Possible In All Metering Modes.
Type Vertical-Travel Shutter With Electronic First-Curtain Control And Mechanical Second-Curtain Control
Shutter Speeds 1/4000 To 30 Sec., Bulb (Total Shutter Speed Range)
X-Sync At 1/200 Sec.
Settable In 1/3- Or 1/2-Stop Increments.
Shutter Release Soft-Touch Electromagnetic Release
Self Timer 10-Sec. Or 2-Sec. Delay
Shutter Lag Time
  1. During Sw-1 On, Time Lag Between Sw-2 On And Start Of Exposure: Approx. 120 Ms
  2. Time Lag Between Simultaneous Sw-1/Sw-2 On And Start Of Exposure: Approx. 240 Ms
Remote Control Possible By Using Remote Switch Rs-60e3
Type Auto Pop-Up, Retractable, Built-In Flash In The Pentamirror
Flash Metering System E-Ttl Ii Autoflash (Evaluative, Average), Fe Lock
Guide Number Approx. 30.2 Ft./9.2m (At Iso 100)
Recycling Time Approx. 2 Sec.
Flash Coverage Up To Approx. 17mm Focal Length (Equivalent To Approx. 28mm In 35mm Format)
Fe Lock Possible
Flash Exposure Compensation Up To ±2 Stops In 1/3- Or 1/2-Stop Increments
Flash Exposure Compensation For Built-In Flash And External Speedlite Can Be Set With The Camera.
Flash Exposure Compensation ±2 Stops In 1/3-Stop Or 1/2-Stop Increments
Drive Modes
  1. Single Shooting
  2. Continuous Shooting
    • Max. Approx. 3.0 Fps
    • Shutter Speed 1/500 Sec., Maximum Aperture
    • Continuous Shooting Speed May Become Slower Depending On The Shutter Speed, Aperture, Subject Condition, Brightness, Lens Model, Flash Use, Remaining Battery Capacity, Etc.
  3. 10-Sec. Self-Timer
  4. 2-Sec. Self-Timer
  5. Continuous Shooting After 10-Sec. Self-Timer (2 To 10 Shots)
Continuous Shooting Speed Max. Approx. 3.0 Fps
Shooting Modes Still Photo And Video Recording
Focusing
  1. (1) Contrast Af
    1. Flexizone-Single
    2. Face Detection Live Mode
      • Covers Approx. 80% Of The Image Display Area Vertically And Horizontally.
    3. Quick Mode
      • Ttl Secondary Image Registration, Phase-Difference Detection With Af-Dedicated Sensor.
      • Af Point Manual Selection Anda Selection Possible.
      • Automatically Set In Basic Zone Modes.
  2. Manual Focus
    • Magnify The Image By Approx. 5x Or 10x And Focus Manually.
Metering Modes Evaluative Metering (315-Zone)
  • Ae Lock Possible. Metering Timer Duration Can Be Changed.
Metering Range Ev 0-20 (Room Temperature, Iso 100)
Grid Display One Of Two Types Of Grids Can Be Selected And Displayed On The Screen.
  1. Grid 1: 2 Vertical And 2 Horizontal Lines (3x3)
  2. Grid 2: 5 Vertical And 3 Horizontal Lines (6x4)
File Format Mov:
Movie: Mpeg4 Avc/H.264
* Variable (Average) Bit Rate
Audio: Linear Pcm
File Size [Full Hd]
1920 X 1080 (30 Fps/24 Fps): 340 Mb/Min.
[Hd]
1280 X 720 (60 Fps): 340 Mb/Min.
[Sd]
640 X 480 (30 Fps): 90 Mb/Min.
Frame Rates 1920 X 1080 (Full Hd): 30 Fps (29.97 Fps) / 24 Fps (23.98 Fps)
1280 X 720 (Hd): 60 Fps (59.94 Fps)
640 X 480 (Sd): 30 Fps (29.97 Fps)
Focusing
  1. Contrast Af
  2. Manual Focus
    • Magnify The Image By 5x Or 10x And Focus Manually.
Exposure Control
  1. Program Ae For Movie Shooting
    • Shutter Speed 1/30-1/4000 Sec. (Signal Accumulation Time), Aperture And Iso Speed Automatically Set.
  2. Manual Exposure
    • Shutter Speed (Signal Accumulation Time), Aperture And Iso Speed (Auto/Manual) Manually Set. The Shutter Speed (Signal Accumulation Time) Is Limited To 1/4000 Sec. At The Maximum And To 1/30 Sec. At The Minimum For 24/30 Fps Or To 1/60 Sec. Or Higher For 60 Fps.
Exposure Compensation Possible (±3 Stops In 1/3-Stop Increments)
Type Tft Color, Liquid-Crystal Monitor
Screen Monitor Size 3.0-Inch (Screen Aspect Ratio Of 4:3)
Approx. 7.5cm Diagonal (Width: Approx. 6.0cm, Height: Approx. 4.5cm)
Pixels Approx. 920,000 Dots
Coverage Approx. 170° Vertically And Horizontally
Brightness Control Adjustable To One Of Seven Brightness Levels
Interface Languages 25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Hungarian, Czech, Romanian, Ukraine, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese)
Image Display Format
  1. Single Image Display
    • Basic Information
    • Basic Information + Image Quality/Image File Number
    • Shooting Information
    • Histogram Display
  2. Index Display; 4 Or 9 Images
Highlight Alert On The Detailed Information And Histogram Displays, Highlight Areas With No Image Data Will Blink.
Back To TopQuick Control Function
During Shooting
When You Press The Quick Control Button While Shooting Images, You Can Set Various Functions.
Settable Functions Differ Between Viewfinder Shooting, Live View Shooting And Movie Shooting.
During Playback
When You Press The Quick Control Button During Playback, You Can Set Various Functions.
Settable Functions Differ Between Still Photo Shooting And Movie Shooting.
Protection Erase Protection Can Be Applied/Canceled For A Single Image, All Images In A Folder Or All Images In The Card.
Erase Erase Unprotected Image(S) With Selection From Single Image, Selected Images, All Images On Folder Or All Images In A Card.
Compatible Printers Pictbridge-Compatible Printers
Printable Images Raw And Jpeg Images Compliant To Design Rule For Camera File System (Dcf)
Movies Cannot Be Printed.
Dpof Dpof Print Ordering Provided (Complies To Dpof Version 1.1)
Custom Functions 11 Custom Functions With 33 Settings Settable With The Camera
Custom Controls Not Provided
Camera User Settings Not Provided
My Menu Registration Menu Functions, Custom Functions
Up To Six Kinds Of Function Settings Can Be Selected And Registered From The Top-Tier Menu Functions.
Usb Terminal Hi-Speed Usb Equivalent
  • Computer
  • Pictbridge
  • Connect Station Cs100 Connection
  • Gps Receiver Gp-E2 Connection
Video Out Terminal Hdmi Type C (Resolution Switches Automatically)
Video Output: (Switches Automatically To 1, 2, 3 Or 4 To Suit The Connected Device.)
  1. 1080/60i
  2. 1080/50i
  3. 480/60p
  4. 576/50p
Extension System Terminal Remote Switch Rs-60e3 Terminal
Back To TopWi-Fi* (Wireless Lan) And Nfc Functions
Standards Compliance
Ieee 802.11b/G/N
Transmission Range
Approx. 49.21 Ft. / 15m
  • When Communicating With A Smartphone Or Tablet.
  • With No Obstructions Between The Antennas And No Radio Interference From Other Devices.
Connection Method
  1. Camera Access Point Mode
  2. Infrastructure Mode
Nfc Connection
Possible
Battery Battery Pack Lp-E10 X 1
  • The Camera Can Be Powered By An Ac Power Supply By Using The Household Power Outlet Accessories (Sold Separately).
Battery Check Automatic Battery Check When The Power Switch Is Turned On.
Battery Level Indicated In One Of The Four Levels On Lcd Monitor.
Power Saving Power Turns Off Automatically After The Set Time Of Non-Operation Elapses.
  • * [Auto Power Off] Settable To 30 Sec., 1 Min., 2 Min., 4 Min., 8 Min., 15 Min. Or Disable
Date Time Battery Built-In Secondary Battery
Maintains Date/Time For About 3 Months When Fully Charged
Start Up Time Approx. 0.1 Sec. (Cipa Standards)
Dimensions W X H X D Approx. 5.08 X 3.99 X 3.06 In. / 129.0 X 101.3 X 77.6mm
  • Cipa Compliant.
Weight Approx. 16.75 Oz. / 475g (Including Battery And Card)
Approx. 15.06 Oz. / 427g (Body Only)
Operating Temperature Range 32-104°F / 0-40°C
Operating Humidity Range 85% Or Less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Canon Support | Service Notice: Photo Culling App Version 1.1
Advisory Type
Date 06.01.21
Title Canon Support | Regarding the security advisory for Canon digital cameras related to PTP (Picture Transfer Protocol) communication functions and firmware update functions.
Advisory Type
Date 09.11.19
Title Canon Support | Firmware Notice: EOS Rebel T7: Firmware Version 1.1.0
Advisory Type
Date 10.18.20
Title Canon Support | Firmware Notice: EOS Rebel T7: Firmware Version 1.0.1
Advisory Type
Date 02.12.20
Title Canon Support | Service Notice: Photo Culling App Version 2.0 for iOS
Advisory Type
Date 11.16.21
Title Service Notice: EOS Webcam Utility Pro app: Version 2.0.30 features
Advisory Type Service Notice
Date 05.23.23
Title Service Notice: Kokomo by Canon Early Access App for Meta Quest 2: Version 0.0.102 Features
Date 05.23.23
Title Service Notice: EOS Webcam Utility Pro v2.3
Date 11.13.24
Title Service Notice: EOS Webcam Utility Pro Software for macOS: Version 2.1.18
Date 05.01.24
Title Firmware Notice: EOS Rebel T7: Firmware Version 1.2.1
Advisory Type Firmware Notice
Date 02.21.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
