Canon Support for EOS Rebel T8i | Canon U.S.A., Inc.
EOS Rebel T8i
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 04.01.25
File Size 142.00 B
Date 07.07.21
File Size 6.16 MB
Date 04.01.25
File Size 142.00 B
Date 04.01.25
File Size 142.00 B
Date 10.31.22
File Size 145.00 B
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type Digital AF/AE single-lens reflex camera
Image Processor DIGIC 8
Recording Media
SD/SDHC/SDXC memory cards
  • SD speed class-compatible
  • UHS-I compatible
  • High-speed writing is supported when a UHS-I compatible SD card is used
  • Eye-Fi card is not supported
  • Multimedia cards (MMC) cannot be used (card error will be displayed)
Image Format Approx. 22.3 x 14.9mm (APS-C Size)
Compatible Lenses Canon EF lenses (including EF-S lenses, excluding EF-M lenses)
Lens Mount Canon EF mount
Type CMOS sensor (supporting Dual Pixel CMOS AF)
Pixels Effective pixels: Approx. 24.1* Megapixels
Total pixels: Approx. 25.8* Megapixels
* Rounded to the nearest 100,000.
Pixel Unit Approx. 3.72µm square
Aspect Ratio 3:2 (Horizontal:Vertical)
Color Filter System RGB primary color filters
Low Pass Filter Installed in front of the image sensor, non-detachable
Dust Deletion Feature (1) Self Cleaning Sensor Unit
  • Removes dust adhering to the low-pass filter.
  • Self-cleaning activated automatically (in-progress display for approx. 2 sec.) when power is turned on or off. Manual operation also possible (in-progress display for approx. 8 sec.).
  • After the cleaning is performed, the camera will automatically restart (power OFF to ON).
(2) Dust Delete Data acquisition and appending
  • The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
  • The dust coordinate data appended to the image is used by the compatible versions of Canon's Digital Photo Professional software to automatically erase the dust spots.
(3) Manual cleaning
Recording Format Compliant to Design rule for Camera File system 2.0 and EXIF 2.31
File Size 3:2 Aspect Ratio
Large: 24 Megapixels (6000 x 4000)
Medium: Approx. 10.6 Megapixels (3984 x 2656)
Small 1: Approx. 5.9 Megapixels (2976 x 1984)
Small 2: Approx. 3.8 Megapixels (2400 x 1600)
RAW / C-RAW: Approx. 24 Megapixels (6000 x 4000)
4:3 Aspect Ratio
Large: Approx. 21.3 Megapixels (5328 x 4000)
Medium: Approx. 9.5 Megapixels (3552 x 2664)
Small 1: Approx. 5.3 Megapixels (2656 x 1992)
Small 2: Approx. 3.4 Megapixels (2112 x 1600)
16:9 Aspect Ratio
Large: Approx. 20.2 Megapixels (6000 x 3368)
Medium: Approx. 8.9 Megapixels (3984 x 2240)
Small 1: Approx. 5.0.Megapixels (2976 x 1680)
Small 2: Approx. 3.2 Megapixels (2400 x 1344)
1:1 Aspect Ratio
Large: Approx. 16 Megapixels (4000 x 4000)
Medium: Approx. 7.1 Megapixels (2656 x 2656)
Small 1: Approx. 3.9 Megapixels (1984 x 1984)
Small 2: Approx. 2.6 Megapixels (1600 x 1600)
File Numbering The following three types of file numbering method can be set:
(1) File numbering method
Continuous numbering
  • The numbering of captured images will continue even after you replace the camera's card.
Auto reset
  • When you replace the camera's card, the numbering will be reset to start from 0001. If the new card already contains images, the numbering will continue from the last recorded image in the card.
(2) Manual reset
  • Resets the file number to 0001, and creates a new folder automatically.
RAW + JPEG Simultaneous Recording Simultaneous recording of RAW or C-RAW plus Large/Fine JPEG is supported.
Color Space sRGB/Adobe RGB
Picture Style (1) Auto
(2) Standard
(3) Portrait
(4) Landscape
(5) Fine Detail
(6) Neutral
(7) Faithful
(8) Monochrome
(9) User Def. 13
  • In Basic Zone modes, [Auto] will be set for < Fish-eye effect > and < HDR art standard > of the < Creative filters > mode, and [Standard] will be set for other modes.
  • In Creative Zone modes, you can select or set any Picture Style.
  • [Auto] is the default setting for [User Def. 13]. Any Picture Style can be selected, modified, and saved to any User-defined setting.
Settings (1) Auto (Ambience priority/White priority)
(2) Daylight
(3) Shade
(4) Cloudy*
(5) Tungsten light
(6) White fluorescent light
(7) Flash
(8) Custom (Custom WB)
(9) Color temperature (K) (Manually adjustable between 2000 - 10000K)
* Effective also in twilight and sunset.
Auto White Balance Option between ambience priority and white priority settings
White Balance Shift Blue/amber bias: ±9 levels
Magenta/green bias: ±9 levels
Corrected in reference to the current WB modes color temperature.
Type Eye-level optical viewfinder (with fixed pentamirror)
Coverage At approx. 19mm eye-point
Vertical / Horizontal approx. 95%
(With 50mm f/1.8 STM lens; Large/Fine JPEG image, 3:2 aspect ratio)
Magnification Approx. 0.82x/23.2° (with 50mm lens at infinity, -1m -1 )
Eye Point Approx. 19mm (at -1m -1 from the eyepiece lens center)
Dioptric Adjustment Correction Adjustable from approx. -3.0 to +1.0m -1 (dpt)
Focusing Screen Fixed
Mirror Quick-return all-surface half mirror
Viewfinder Information Displayed with transparent liquid crystal
(1) AF point information
  • Including Area AF frame
(2) Spot metering circle
(3) Electronic level
(4) Grid
(5) Aspect line
(6) Flicker detection
Depth Of Field Preview Provided with depth of field preview button
Type TTL secondary image-forming phase-difference detection system with AF-dedicated sensor
AF Points
Up to 45 points (cross-type AF points: max. 45)
AF Points and AF Patterns
AF Points (max.)
Dual cross-type AF points supporting f/2.8 and f/5.6
1
Cross-type AF points supporting f/5.6
45
AF points supporting f/8
27
(Cross-type AF point 9)
  • The number of AF points, cross-type AF points, dual cross-type AF points and f/8 AF support varies depending on the lens used.
  • Note that, with aspect ratio of 1:1, the maximum number of AF points becomes 35. (Each left and right end line of AF points in total of ten are not usable.)
AF Working Range
Conditions: One-Shot AF, at 73°F/23°C, ISO 100 (based on Canon's testing standards and environment)
AF Point
Brightness
One center AF point focusing supporting f/2.8
EV -3 to 18
One center AF point focusing supporting f/5.6
EV -1 to 18
Peripheral AF points focusing supporting f/5.6
EV -0.5 to 18
Focusing Modes (1) Autofocus
  1. One-Shot AF
  2. AI Servo AF
  3. AI Focus AF
    • Switches between One-Shot AF and AI Servo AF automatically.
(2) Manual focus
AF Area Selection (1) Single-point AF (Manual selection)
  • The check mark cannot be removed from this option.
(2) Zone AF (Manual selection of zone)
  • All the AF points are divided into nine focusing zones.
(3) Large Zone AF (Manual selection of zone)
  • All the AF points are divided into three focusing zones.
(4) Automatic selection AF (45 points)
Automatic AF Point Selection: EOS iTR AF EOS iTR AF (face Priority):
Gives greater priority to people's faces when AF points are selected automatically.
With One-Shot AF:
  • Faces of people in the AF area take precedence, and when no faces are detected, the camera focuses on the closest subject.
  • When an AF-assist beam fires, AF points are selected automatically using only AF information.
With AI Servo AF:
  • AF points are selected automatically in the AF area to keep tracking the face in focus.
  • When no faces are detected, AF points are selected in the AF to keep tracking the same color with the focused subject.
  • If a face is deteced when tracking the subject other than the face, the focusing point may switch to the detected face.
AF Assist Beam
Intermittent firing of built-in flash
Effective range
Center
Approx. 13.1 ft. / 4.0m
Periphery
Approx. 11.5 ft. / 3.5m
With an EOS-dedicated Speedlite attached, the Speedlite's AF-assist beam is emitted instead.
Metering Modes 220,000-pixel RGB+IR metering sensor
216-zone (18 x 12) metering optical viewfinder
(1) Evaluative metering (linked to all AF points)
(2) Partial metering (center, approx. 6.5% of viewfinder)
(3) Spot metering (center, approx. 2.0% of viewfinder)
(4) Center-weighted average metering
Metering Range EV 120 (room temperature, ISO 100, evaluative metering)
Exposure Control Systems (1) Creative Zone
  1. Program AE (Shiftable)
  2. Shutter-priority AE
  3. Aperture-priority AE
  4. Manual exposure (including bulb)
(2) Basic Zone
  1. Scene Intelligent Auto (Program AE/non-shiftable)
  2. Special Scene (SCN)
    1. Portrait
    2. Smooth skin
    3. Group Photo
    4. Landscape
    5. Close-up
    6. Sports
    7. Kids
    8. Food
    9. Candlelight
    10. Night Portrait
    11. Handheld Night Scene (Takes 4 quick shots; processed in-camera into one finished JPEG image)
    12. HDR Backlight Control (Takes 3 quick shots; processed in-camera into one finished JPEG image)
3) Creative Filters
  1. Grainy B/W
  2. Soft Focus
  3. Fish-eye Effect
  4. Water Painting Effect
  5. Toy Camera Effect
  6. Miniature Effect
  7. HDR Art Standard
  8. HDR Art Vivid
  9. HDR Art Bold
  10. HDR Art Embossed
ISO Speed Range
Manual setting
Normal ISO Speed
ISO 100;25600 (in 1/3-stop increments)
Expanded ISO Speed
ISO 51200
For [Highlight tone priority], the settable ISO speed range will be ISO 200-25600.
Auto ISO Speed Settings
Shooting Mode
ISO Settings
No Flash
Flash (built-in) *1
Flash (external) *1
Scene Intelligent Auto, Creative Auto
ISO 10025600 ISO 4003200 ISO 4001600
Flash Off
ISO 10025600
* 1 If fill-in flash will cause overexposure, ISO 100 or a higher ISO will be set.
Exposure Compensation
Manual
±5 stops in 1/3- or 1/2-stop increments*
AEB
±3 stops in 1/3- or 1/2-stop increments
* Up to ±2 stops, indicated in the viewfinder.
* Up to ±3 stops when [Shooting screen: Guided] is set.
AE Lock (1) Auto AE lock
  • In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved.
(2) User-applied AE lock
  • In the P, Tv, Av and M modes, enabled with the AE lock button. (Press again to update.)
  • Possible with all metering modes.
Type Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled
  • Viewfinder shooting Mechanical 1st and 2nd curtain
  • Live View shooting Electronic 1st curtain/Mechanical 2nd curtain
  • Live View with flash: equivalent to Viewfinder shooting
Shutter Speeds 1/4000 to 30 sec., bulb (total shutter speed range. Available range varies by shooting mode.)
X-sync at 1/200 sec.
Creative Zone: 1/4000-30 sec., bulb
Basic Zone: 1/4000-1 sec.
Self Timer 10-sec. delay, 2-sec. delay
Shutter Lag Time (1) With shutter button half-pressed time between fully pressed and start of exposure: approx. 0.070 sec.
(2) Time lag when shutter button fully pressed without initially being pressed half-way: approx. 0.250 sec.
  • Time lag with the aperture stopped down by 3 stops or less from the open aperture.
    Excludes AF operation time.
Flash Metering E-TTL II autoflash (Evaluative- face priority, Evaluative, Average), FE Lock
Flash Exposure Compensation ±2 stops in 1/3- or 1/2-stop increments (when set on camera body)
FE Lock Provided
Continuous Shooting Priority (CSP) Mode Supported (with accessory Canon Speedlites only)
External Flash Settings (1) External flash control
  • Flash firing, E-TTL II metering, Flash mode, Wireless functions, Flash zoom, Shutter synchronization, Flash exposure compensation, Flash exposure bracketing and Clear settings.
  • The radio wireless flash functions can be set from the camera.
(2) External flash Custom Function setting
  • The setting options for both (1) and (2) will differ depending on the Speedlite used.
Drive Modes and Continuous Shooting Speed during Viewfinder Shooting (1) Single shooting
(2) High-speed continuous shooting
  • Max. approx. 7.0 fps. (Viewfinder Shooting)
  • Max. approx. 7.5 fps. (Live View Shooting)
  • Maximum continuous shooting speed with 1/1000 sec. or faster shutter speed, maximum aperture (varies depending on the lens), Anti-flicker shooting set to Disable, with a fully-charged Battery Pack LP-E17 and at room temperature (73°F/23°C).
(3) Low-speed continuous shooting
  • Max. approx. 3.0 fps
(4) Self-timer: 10 sec. or 2 sec. delay (Remote Control possible with optional accessory Canon BR-E1 Remote Controller)
(5) 2 sec. self-timer / remote control
(6) Continuous shooting after 10-sec. self-timer (2 to 10 shots)
Maximum Burst: Image file sizes, number of shots, burst rates
Image-recording Quality
Image File Size
(approx. MB)
Possible Shots
(approx.)
Maximum Burst
(approx.)
Large (Fine)
8.4 3,600 170
Large (Normal)
4.5 6,610 170
Medium (Fine)
4.6 6,480 167
Medium (Normal)
2.6 11,400 167
Small 1 (Fine)
3.1 9,690 163
Small 1 (Normal)
1.8 16,010 163
Small 2
1.8 16,340 164
RAW
27.2 1,120 40
C-RAW
15.8 1,930 75
RAW + Large (Fine)
35.6 850 35
C-RAW + Large (Fine)
24.2 1,250 57
The number of shots available and standard maximum burst in viewfinder shooting with a 32GB UHS-I card conforming to Canon testing standards.
The file size, number of possible shots and maximum burst vary depending on shooting conditions (aspect ratio of 3:2, subject, memory card brand, ISO speed, Picture Style, etc.)
Shooting Modes Still photo shooting and video shooting
Focusing (1) Dual Pixel CMOS AF
  • Dual Pixel CMOS AF is possible with all EF and EF-S lenses.
  • Contrast AF is not provided for still-image Live View shooting
(2) Manual focus
  • Magnifying the image by 5x or 10x for manual focus possible.
  • Manual Focus Peaking available
Metering Modes 384-zone (24 x 16)
Real-time metering with image sensor
  • AE lock possible. The metering timer can be changed.
(1) Evaluative metering- supported
(2) Partial metering (center, approx. 5.8% of viewfinder)
(3) Spot metering (center, approx. 2.9% of viewfinder)
  • AE lock possible. The active metering timer can be changed.
Metering Range EV -220 (room temperature, ISO 100, evaluative metering)
Grid Display (1) Off
(2) 3x3
(3) 6x4
(4) 3x3+diag
File Format MP4
Video: MPEG-4 AVC / H.264
  • Variable (averaged) bit rate
Audio: AAC
  • Color sampling YCbCr 4:2:0 (8-bit); Color matrix Rec.ITU-R BT.709
MOV: ALL-I (4K UHD 29.97 and FHD 29.97, time-lapse movies only)
Video Recording Size and Frame Rates
Movie Recording
Frame Rate (FPS)
Compression Method
4K UHD* (3840 x 2160)
23.98 fps IPB (Standard)
Full HD (1920 x 1080)
59.954 fps IPB (Standard)
29.97 fps
23.98 fps
IPB (Standard)
29.97 fps IPB (Light)
HD (1280 x 720)
59.94 fps IPB (Standard)
HDR movies
(1920 x 1080)
29.97 fps IPB (Standard)
Creative filter movies
(1920 x 1080)
29.97 fps
23.98 fps
IPB (Standard)
4K UHD Time-lapse movies*
(3840 x 2160)
29.97 fps ALL-I
Full HD Time-lapse movies
29.97 fps ALL-I
Video snapshots (1920 x 1080)
* The image is cropped around the center of the image sensor.
Estimated Recording Time, Movie Bit Rate, and File Size
Total Recording Time on Card (approx.)
Movie Bit Rate
File Size (approx.)
8GB
32GB
128GB
4K UHD
23.98 fps
IPB
(Standard)
8 min. 35 min. 2 hrs. 21 min. Approx.120 Mbps
Approx. 861 MB/min.
Full HD
59.94 fps
IPB
(Standard)
17 min. 1 hr. 10 min. 4 hrs. 43 min. Approx. 60 Mbps
Approx. 432 MB/min.
29.97 fps
23.98 fps
IPB
(Standard)
35 min. 2 hr. 20 min. 9 hrs. 23 min. Approx. 30 Mbps
Approx. 217 MB/min.
29.97 fps
IPB (Light)
1 hr. 26 min. 5 hrs. 47 min. 23 hrs. 11 min. Approx. 12 Mbps
Approx. 88 MB/min.
HD
59.94 fps
IPB
(Standard)
40 min. 2 hrs. 42 min. 10 hrs. 49 min. Approx. 26 Mbps
Approx. 188 MB/min.
If the recording time reaches 29 min. 59 sec., the movie shooting stops automatically.
Bit rate indicates video output only, auido is not included.
File size and time indicates video output + audio
With [Digital IS: Disable] set.
  • Contrast AF is only during 4K video recording
(2) Manual focus
    (Magnification not possible during movie shooting).
  • Manual Focus Peaking availble
Range Full range (0255)
Exposure Control
Shooting Mode
Frame Rate
Shutter Speed (sec.)
Aperture Value Setting
ISO Speed (recommended exposure index)
Setting
Range (sec.)
Setting
Range
Movie Auto Exposure
59.94 fps
Auto 1/4000-1/60 *1 Auto Auto ISO 100-12800
Conditions that affect the minimum ISO speed.
  • Highlight tone priority: ISO 200
    Conditions that affect the maxiumum ISO speed.
  • In 4K UHD movie recording: ISO 6400
  • When digital zoom is set: ISO 6400
  • [Max. for Auto] setting
  • Expanded ISO speeds: H (equivalent to ISO 25600)
29.97 fps
1/4000-1/30
23.98 fps
1/4000-1/25
Movie Manual Exposure
23.98 - 59.94 fps
Manual 1/4000-1/8 Manual Manual Auto
Exposure modes in movie shooting:
  • P, Tv, or Av movie auto exposure only
  • M manual exposure control
* 1/30 when [Movie Auto slow shutter] is set to [Enable]
Exposure Compensation Up to ±3 stops in 1/3- or 1/2-stop increments
Type TFT color, liquid-crystal monitor
Monitor Size 3.0-inch (screen aspect ratio of 3:2)
Approx. 3.0 in./7.5cm diagonal (approx. 2.5 in./6.2cm width, approx. 1.6 in/4.2cm height)
Dots Approx. 1.04 million dots
Angle of view Approx. 170° vertically and horizontally
Brightness Control Adjustable to one of seven brightness levels
Coating Clear View LCD II
  • Anti-smudge coating not applied.
  • Anti-reflection coating not applied.
Interface Languages 29 (English, Japanese; Arabic, Chinese [Simplified/Traditional], Czech, Danish, Dutch, Finnish, French, German, Greek, Hindi, Hungarian, Indonesian, Italian, Korean, Malay, Norwegian, Polish, Portuguese, Romanian, Russian, Spanish, Swedish, Thai, Turkish, Ukrainian, Vietnamese)
Display Format (1) Single-image display
  • No information display
  • Basic information display
  • Detailed shooting information display
    • Basic shooting information
    • Lens information and RGB histogram
    • White balance
    • Picture Style and sharpness
    • Contrast, color saturation and color tone
    • Color space and noise reduction
    • Lens aberration correction
    • GPS information (when GPS Receiver is used)
(2) Index display
  • 4-image
  • 9-image
  • 36-image
  • 100-image
Highlight Alert With detailed information display, overexposed highlight areas with no image data will blink.
Histogram Brightness and RGB
Items Pressing the Quick Control button displays the Quick Control screen during viewfinder shooting, Live View shooting, movie shooting and playback.
After selecting an item, you can select contents by operating the Main Dial.
Protection (1) Single image (select image)
(2) Select range
(3) All images in a folder
(4) All images in a card
(5) All found images (only during image search)
Erase Except protected images
(1) Select image to erase
(2) Select range
Compatible Printers Images can be sent via Wi-Fi to a PictBridge-compatible (Wireless LAN) printer and printed.
Printable Images JPEG images compliant to Design rule for Camera File System
  • RAW images cannot be printed.
  • Movies cannot be printed.
DPOF Compliant to DPOF Version 1.1
Select Image Supported
* RAW/C-RAW images and movies cannot be specified for printing.
Custom Functions 14 Custom Functions can be configured
Custom Controls Functions can be assigned to the following control parts:
  • Shutter button (halfway pressing)
  • AF-ON button
  • AE lock button
  • DISP button
  • SET button
My Menu Registration
Up to six top-tier menu options and Custom Function settings can be registered.
Up to five My Menu tabs can be added.
My Menu tab overall operations
Adding a tab
Deleting tabs in a batch
Deleting all tab items
Setting the menu display
My Menu tab detailed operations
Selecting item to register
Sorting registered items
Deleting selected registered items
Deleting registered items in a batch
Deleting tabs
Changing a tab name (16 ASCII characters)
USB Terminal Hi-Speed USB (USB 2.0; Micro-B connection type)
  • For PC communication
  • For GP-E2 connection
  • For Connect Station connection
HDMI Video/audio Output HDMI mini OUT terminal (Type C), CEC not compatible
* images will not be displayed unless [NTSC] or [PAL] is properly set according to the video system of the TV set.
HDMI HDR Output OFF / ON
  • HDMI HDR output can be used for HDR TVs.
    * HDMI output of RAW images consists of HDR images.
    * HDMI output of JPEG involves processing to simulate HDR images.
    * An HDR display icon is shown when the camera is connected via HDMI to an HDR TV.
    * Still photos: Supports RAW, C-RAW, and JPEG in single-image display.
    * Display is delated by approx. 1 sec. for RAW and C-RAW images, which are processed.
    * Not supported during movie playback.
  • HDR specification: Conforms to ITU-R BT.2100 (PQ)
External microphone input terminal 3.5mm diameter stereo mini jack
  • Directional Stereo Microphone DM-E1 connection
Battery Battery Pack LP-E17 x 1
  • With the AC Adapter AC-E6N and DC Coupler DR-E18, AC power operation is possible.
Battery Life
Shooting Method
Battery
Temperature
Shooting Condition
AE 100%
50% flash use
Viewfinder shooting
LP-E17
At 73°F/23°C
Approx. 1240 Approx. 800
Live View shooting
LP-E17
At 73°F/23°C
Approx. 360 Approx. 310
Battery Check Automatic battery check when the power switch is turned ON. Displayed in 4 levels.
Power Saving Power turns off after the set time (10/30* or 30 sec., 1, 2, 4, 8 or 15 min.) of non-operation elapses
* Normally 10 sec. is set. 30 sec. will be set for function setting, Live View shooting, image playback, etc.
Date/Time Battery Built-in secondary battery
When fully-charged, the date/time can be maintained for approx. 3 months
  • Recharge time: approx. 8 hrs.
  • To become capable to maintain the right date/time for 3 months after main battery power depletion.
Start-up Time Approx. 0.3 sec. (based on CIPA testing standards)
Dimensions (W x H x D) Approx. 5.16 x 4.04 x 3.00 in. (131.0 x 102.6 x 76.2mm)
  • CIPA compliant.
Weight Approx. 18.17 oz. / 515g (including battery pack and SD memory card)
Approx. 16.61 oz. / 471g (body only)
Working Temperature Range 32-104°F / 0-+40°C
Working Humidity Range
85% or less
USB Tethered SDK Are a developer and want to control select Canon cameras within your application? The Canon EDSDK allows you to set various camera settings, take a picture, and the retrieving of images remotely using a USB connection. The EDSDK is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information.
Wireless API Are a developer and want to control select Canon cameras within your application? The Canon CCAPI allows you to set various camera settings, take a picture, and the retrieving of images remotely using a Wi-Fi connection. The CCAPI is available at the Canon Developer Community website. Go to https://developercommunity.usa.canon.com for more information.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
Title Service Notice: EOS Webcam Utility Pro app: Version 2.0.30 features
Advisory Type Service Notice
Date 05.23.23
Title Service Notice: Kokomo by Canon Early Access App for Meta Quest 2: Version 0.0.102 Features
Date 05.23.23
Title Service Notice: EOS Webcam Utility Pro v2.3
Date 11.13.24
Title Service Notice: EOS Webcam Utility Pro Software for macOS: Version 2.1.18
Date 05.01.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
