Canon Support for FAXPHONE L100 | Canon U.S.A., Inc.
FAXPHONE L100
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.05.19
File Size 6.10 MB
Date 10.17.13
File Size 3.10 MB
Date 10.17.13
File Size 4.78 MB
Date 10.17.13
File Size 5.10 MB
Date 10.09.20
File Size 819.56 KB
Date 09.12.25
File Size 1.20 MB
Date 12.22.17
File Size 809.44 KB
Date 09.25.23
File Size 1.20 MB
Date 04.24.19
File Size 815.66 KB
Date 04.24.19
File Size 647.96 KB
Date 04.20.22
File Size 1.50 MB
Date 10.04.19
File Size 815.82 KB
Date 09.17.24
File Size 1.20 MB
Date 02.04.20
File Size 652.13 KB
Date 03.24.23
File Size 1.60 MB
Date 07.13.21
File Size 652.14 KB
Date 12.22.17
File Size 647.92 KB
FAXPHONE L100
Products High Sierra V10.13 Mojave V10.14 Catalina V10.15 Big Sur V11.0 Monterey V12.0 Sonoma V14 Sequoia 15
FAXPHONE L100
Printer Specifications
Printer Type Monochrome Laser
Print Speed Up to 19 ppm (letter)
First Print Time Approx. 8 seconds
Printer Language UFR II LT (Host-based)
Print Resolution Up to 600 x 400 dpi
(1200 x 600 dpi quality)
Maximum Print Size Up to Legal
Print Modes Watermark, Toner Save, Page Composer
Print Memory 64 MB (Shared)
Copier Specifications
Copy Type Monochrome Laser
Copy Speed Up to 12.4 cpm (letter)
Copy Resolution Up to 600 x 600 dpi
Original Type Text, Text & Photo, Photo
Halftones 256 Levels
Warm-up Time 14 seconds or less
First Copy Time Approx. 22 seconds
Recovery Time Approx. 3.5 seconds
Maximum Number of Copies 99 copies
Zoom 50 - 200% in 1% increments
Copy Size Up to Legal
Copy Features Density adjustment
Toner Saver Mode
Copy Memory 64 MB (shared)
Fax Specifications
Modem Speed Up to 33.6 Kbps (Super G3)1
Fax Resolution Up to 200 x 400 dpi (super fine)
Transmission Time MMR (approx 3 seconds)
Memory Capacity Up to 512 sheets2
Speed Dials 30 one-touch speed dials
100 coded dials
Group Dialing 129 destinations
Sequential Broadcasting 140 destinations
Receive Modes FAX Only, Manual, Answering, Fax/Tel Auto Switch
Fax Features Dual Access, Remote RX, Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial, Manual Fax Forwarding
Memory Backup 5 minutes
Activity Reports Activity Result & Activity Management
pC Fax TX only
Paper Handling Specifications
Standard Paper Source(s) 150-sheet cassette3
Document Feeder 30-sheet Simplex3
Paper Output Approx. 100 sheets (face down)
Paper Weight 16 to 43 lb. bond
Media Sizes Letter, Legal, Statement, Executive, A4, A5, B5
Media Types Plain Paper, Heavy Paper, Recycled Paper, Transparency, Label, Envelope
Envelope Capacity 10 envelopes
Envelope Types Com 10, Monarch, DL, C5
Connectivity and Software Specifications
Standard Interface(s) USB Device 2.0 Hi-Speed5
OS Compatibility Windows&reg; 8, Windows 7, Windows Vista&reg;, Windows XP/2000, Mac OS X 10.4.9 and up
Cable Included Power Cord, Phone Cable (USB not included)
Environmental Specifications
Power Consumption During Operation: Approx. 410W
Standby: Approx. 10W
Energy Saver: Approx. 1.4W
General Specifications
Dimensions 14.7" (W) x 12.0" (D) x 12.0" (H)
Unit Weight (without/with cartridge) 18.1 lbs. (w/o cartridge)
19.5 lbs. (w/cartridge)
Package Weight Approx. 25.4 lbs.
Cartridge Type Cartridge 128 (Yields approximately 2,100 pages*)
Single Cartridge System
*Yields based on ISO/IEC Standard
LCD Display 5-row backlit LCD
Duty Cycle Up to 8,000 pages per month
Languages English, French, Spanish, Portuguese
Warranty 1 year limited exchange/carry-in warranty4 (Extended warranty available)
CANON FAXPHONE EXCHANGE/CARRY-IN PRODUCT WARRANTY
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon USA") with respect to the Canon FAXPHONE product and accessories packaged with this limited warranty (collectively, the "Product") when purchased and used in the United States. CARTRIDGES FOR THE PRODUCT (EXCEPT THE STARTER CARTRIDGE BUNDLED WITH THE PRODUCT, FOR WHICH THERE IS NO WARRANTY) ARE COVERED BY A SEPARATE WARRANTY. ACCORDINGLY, THIS LIMITED WARRANTY DOES NOT COVER ANY CARTRIDGES FOR THE PRODUCT, WHETHER SHIPPED WITH THE PRODUCT OR PURCHASED THEREAFTER.
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of one year after delivery to the original purchaser ("Purchaser") by Canon USA or its authorized Reseller. During the relevant warranty period, Canon USA shall in its sole discretion and without charge, repair or replace any defective part with a new or comparable rebuilt part, or exchange the product with a new or refurbished product. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
Canon USA shall provide assistance for installation, operation and support* of the Product as follows:
(a) Toll-free telephone support for troubleshooting issues at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. E.T. (b) Automated 24 hour and email support at www.usa.canon.com/support
If Canon USA's remote assistance cannot fix your Product's malfunction, Canon USA shall provide the contact information of the nearest authorized Canon USA Service Provider ("Service Provider") for carry-in service or exchange the Product, except where the malfunction involves a user replaceable item, in which case Canon USA will send you a replacement part with installation instructions. You will be responsible for installing the user replaceable items in your Product.
If carry-in service or exchange is performed, and (1) the Product malfunction is not covered by this limited warranty, or (2) the applicable warranty period has expired or has not been sufficiently established by appropriate documentation, then you will be charged for such service at the then current service rates of Canon USA or the Service Provider.
This warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty ("Separate Warranty"). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON USA, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU.) NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
NEITHER CANON USA NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, INCLUDING, WITHOUT LIMITATION, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON USA OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCAHSE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
Defective parts must be returned to Canon USA or a Service Provider with all necessary documentation.
Click Here to download the FAXPHONE L100 Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
