Canon Support for imageCLASS D1320 | Canon U.S.A., Inc.
imageCLASS D1320
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.02.15
File Size 67.21 MB
Date 03.02.15
File Size 12.72 MB
Date 03.22.12
File Size 11.94 MB
Date 09.22.17
File Size 2.92 MB
Date 12.24.20
File Size 2.92 MB
Date 09.17.24
File Size 2.27 MB
Date 09.25.23
File Size 1.20 MB
Date 04.24.19
File Size 647.96 KB
Date 01.31.23
File Size 2.92 MB
Date 04.20.22
File Size 1.50 MB
Date 09.17.24
File Size 1.20 MB
Date 02.04.20
File Size 652.13 KB
Date 03.24.23
File Size 1.60 MB
Date 09.25.23
File Size 2.27 MB
Date 10.04.19
File Size 2.92 MB
Date 04.24.19
File Size 2.92 MB
Date 04.27.23
File Size 2.27 MB
Date 07.13.21
File Size 652.14 KB
Date 12.22.17
File Size 647.92 KB
Date 03.02.15
File Size 18.00 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
imageCLASS D1320
Products High Sierra V10.13 Mojave V10.14 Catalina V10.15 Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15
imageCLASS D1320
Printer Specifications
Printer Type Monochrome Laser
Print Speed Up to 17 ppm (2-sided plain paper letter)2
Up to 35 ppm (1-sided plain paper letter)2
First Print Time 6 seconds or less (letter)
Printer Language UFR II LT (Host-based)
Print Resolution Up to 600 x 600 dpi
(1200 x 600 dpi quality)
Maximum Print Size Up to Legal
Duplex Print Yes
Print Modes Poster, Booklet, Watermark, Toner Save, Page Composer
Print Memory 128 MB (Shared)
Direct Print from USB JPEG, TIFF
Copier Specifications
Copy Type Monochrome Laser
Copy Speed Up to 35 ppm (letter)
Duplex Copy Speed Up to 17 cpm (letter)
Copy Resolution Up to 600 x 600 dpi
Original Type Text, Text/Photo, Text/Photo+, Photo
Halftones 256 Levels
Warm-up Time Approx. 17 seconds
First Copy Time Less than 8 seconds3
Recovery Time 5 seconds or less
Maximum Number of Copies 99 copies
Duplex Copy/Bind Time 1 to 2 / Book, Calendar
Reduction/Enlargement 25%, 50%, 64%, 78% / 129%, 200%, 400%
Zoom 25 - 400% in 1% increments
Copy Size Platen: Up to Legal
ADF: 5.5" x 5" to Legal
Copy Features Memory Sort
2 on 1
4 on 1
ID Card Copy
Copy Memory 128 MB (shared)
Scanner Specifications
Scan Type Color Contact Image Sensor (CIS)
Color Depth 24-bit
Scan Resolution Up to 600 x 600 dpi (optical)
9600 x 9600 (interpolated)
Scan Size Platen: Up to Legal
Duplex Scan Yes
Compatibility TWAIN, WIA
Output File Formats Hi-Compression PDF, Searchable PDF, PDF, JPEG, TIFF, BMP, PNG4
Scan Features Scan to USB Host 1.1 (PDF, JPEG, TIFF), Rotate Image
Pull Scan USB and Network
Push Scan (Scan to pC) USB and Network
Paper Handling Specifications
Standard Paper Source(s) 500-sheet cassette plus 50-sheet multipurpose tray1
Optional Paper Source(s) 500-sheet cassette1
Document Feeder 50-sheet duplex1
Paper Output 150 sheets (face down)
Paper Weight 16-32 lb. bond (cassette)
16-51 lb. bond (multipurpose tray)
Media Sizes Letter, Legal, A4, A5, B5, Statement, Executive
Media Types Plain Paper, Heavy Paper, Bond Paper, Label, Small Documents (i.e. Index Card)
Envelope Capacity 5 envelopes (multipurpose tray)
Envelope Types Com 10, Monarch, DL, C5, B5
Connectivity and Software Specifications
Standard Interface(s) USB Device 2.0 Hi-Speed5, 10/100 Base-T Ethernet
Embedded Web Server (Remote UI) Yes
Web Browser Support for Remote UI Microsoft Internet Explore 6.0 or higher, Safari 1.3.2 or higher
Print Protocols LPD, RAW, WSD
Supported Network Protocols TCP/IP v4, TCP/IP v6 (print only)
TCP/IP Set of Application Services DHCP, BOOTP, RARP, ARP+PING, Auto IP, Bonjour, HTTP, SHTTP, NetBIOS
Network Management Protocols SNMPv1, SNMPv36
MIB RFC1213 (MIB-II), RFC1514 (Host Resources MIB), RFC1759 (Printer MIB), Canon MIB
OS Compatibility Windows&reg; 8, Windows 7, Windows Server&reg; 2008, Windows Vista&reg;, Windows Server 2003, Windows XP/2000, Mac&reg; OS X 10.4.9 & up, Linux (print only)
Cable Included Power Cord (USB not included)
Bundled Software Canon Drivers, MF Toolbox, Document Management & OCR Software
Environmental Specifications
Power Consumption Max: Approx. 1,100W
During Operation: Approx. 550W
Standby: Approx. 9W
Energy Saver: Approx. 2.3W
Typical Energy Consumption 1.5kWh
General Specifications
Dimensions 17.8" (W) x 18.6" (D) x 18.4" (H)
Unit Weight (without/with cartridge) 45.3 lbs. (w/o cartridge)
47.1 lbs. (w/cartridge)
Package Weight Approx. 61.7 lbs.
Cartridge Type Cartridge 120 (Yields approximately 5,000 pages*)
Single Cartridge System
*Yields based on ISO/IEC Standard
Department Counter Yes
LCD Display 5-row backlit LCD w/ animation (fax installation, toner installation, paper jam)
Duty Cycle Up to 20,000 pages per month
Department ID Management Up to 300 IDs
Security IP Filtering, MAC Address Filtering
Languages English, French, Spanish, Portuguese
Warranty 1 year limited exchange/carry-in warranty7 (Extended warranty available)
CANON imageCLASS SERIES EXCHANGE/CARRY-IN PRODUCT LIMITED WARRANTY
CARTRIDGES FOR THE PRODUCT (EXCEPT THE CARTRIDGE BUNDLED WITH THE PRODUCT, FOR WHICH THERE IS NO WARRANTY) ARE COVERED BY A SEPARATE WARRANTY. ACCORDINGLY, THIS LIMITED WARRANTY DOES NOT COVER ANY CARTRIDGES FOR THE PRODUCT, WHETHER SHIPPED WITH THE PRODUCT OR PURCHASED THEREAFTER.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
If the service or exchange is performed, and (1) the Product malfunction is not covered by this limited warranty, or (2) the applicable warranty period has expired or has not been sufficiently established by appropriate documentation, then you will be charged for such service at the then current service rates of Canon USA or the Service Provider, or for such exchange, as applicable. This warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment, and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty ("Separate Warranty"). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON USA, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. (SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS, SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU.) NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
This warranty shall be void and of no force and effect if the Product is damaged as a result of (a) abuse, neglect, mishandling, alteration, electric current fluctuation or accident, (b) improper use, including failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA's operator's manual or other documentation, (c) installation or repair by other than authorized service representatives qualified by Canon USA who are acting in accordance with Canon USA's service bulletins, (d) use of supplies or parts (other than those distributed by Canon USA) which damage the Product or cause abnormally frequent service calls or service problems, or (e) use of the Product with non-compatible computers, peripheral equipment or software, including the use of the Product in any system configuration not recommended in any manual distributed with the Product. Nor does this warranty extend to any Product on which the original identification marks or serial numbers have been defaced, removed, or altered. ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE CD-ROM'S ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD "AS IS" AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
NEITHER CANON USA NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, INCLUDING, WITHOUT LIMITATION, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON USA OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCAHSE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
Support options are subject to change without notice.
Click Here to download the D1300 Series Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Advisory Type
Date 03.29.15
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
