Canon Support for imageCLASS D570 | Canon U.S.A., Inc.
imageCLASS D570
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.11.25
File Size 1.20 MB
Date 02.03.20
File Size 652.13 KB
Date 01.30.23
File Size 2.92 MB
Date 04.19.22
File Size 1.50 MB
Date 07.19.23
File Size 154.27 KB
Date 09.16.24
File Size 1.20 MB
Date 07.12.21
File Size 652.14 KB
Date 04.23.19
File Size 2.92 MB
Date 01.30.23
File Size 144.76 KB
Date 04.23.19
File Size 647.96 KB
Date 04.26.23
File Size 2.27 MB
Date 09.16.24
File Size 2.27 MB
Date 09.24.23
File Size 2.27 MB
Date 03.23.23
File Size 1.60 MB
Date 12.21.17
File Size 647.92 KB
Date 12.23.20
File Size 2.92 MB
Date 10.03.19
File Size 2.92 MB
Date 09.21.17
File Size 2.92 MB
Date 09.24.23
File Size 1.20 MB
Date 09.11.25
File Size 2.27 MB
Date 03.26.17
File Size 4.21 MB
Date 10.31.19
File Size 4.83 MB
Date 10.03.17
File Size 80.00 KB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
imageCLASS D570
imageCLASS D570
Products ChromeOS
imageCLASS D570
Printer Specifications
Printer Type Monochrome Laser
Print Speed Up to 28 ppm (letter, 1-sided), Up to 16 ppm (letter, 2-sided)1
First Print Time 6 seconds or less (letter)2
Printer Language UFR II LT (Host-based), PCL (5e, 6)
Print Resolution Up to 600 x 600 dpi
Maximum Print Size Up to Legal (8.5 x 14 inches)
Duplex Print Yes
Print Modes Watermark, Page Composer, Toner Saver
Print Memory 512 MB (shared)
Copier Specifications
Copy Type Monochrome Laser
Copy Speed Up to 28 ppm (letter, 1-sided), Up to 16 ppm (letter, 2-sided)
Copy Resolution Up to 600 x 600 dpi
Original Type Text/Photo, Text, Photo
Halftones 256 Levels
Warm-up Time 13.5 seconds or less from power on
First Copy Time 9 seconds or less (letter)3
Recovery Time Approximately 2 seconds
Maximum Number of Copies Up to 999 copies
Reduction/Enlargement 25-400% in 1% increments
Copy Size Platen: Up to 8.5 x 11
Copy Features Memory Sort, 2 on 1, 4 on 1, ID Card Copy
Copy Memory 512 MB (shared)
Scanner Specifications
Scan Type Color Contact Image Sensor (CIS)
Color Depth 24-bit
Scan Resolution Up to 600 x 600 dpi (optical)
Scan Size Platen: Up to Letter
Duplex Scan No
Compatibility TWAIN, WIA, ICA
Output File Formats TIFF/JPEG/PDF/Compact PDF/Searchable PDF
Scan Features Push Scan, Pull Scan: USB and Network
Pull Scan USB and Network
Push Scan (Scan to pC) USB and Network
Paper Handling Specifications
Standard Paper Source(s) 250-sheet cassette plus 1-sheet multipurpose tray
Paper Output 100 sheets (face down)
Paper Weight 16-43 lb. (bond, plain paper)4
Media Sizes A4, B5, A5, Letter, Legal, Executive, Statement
Media Types Plain, Color, Recycled, Heavy, Bond, Label, Envelope
Envelope Capacity 1 (multipurpose tray)
Envelope Types Com 10, Monarch, DL, C5
Connectivity and Software Specifications
Standard Interface(s) USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet (network), Wi-Fi&reg; 802.11 b/g/n5
WiFi Access Mode Infrastructure Mode, WPS Easy Set Up, Wi-Fi&reg; Direct Connection6
WiFi Authentication Methods WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
WiFi Encryption Modes WEP 64/128 bit, TKIP, AES
WPS Easy Setup Support Methods Push-button mode, PIN code mode
Mobile Functions Canon PRINT Business7, Apple&reg; AirPrint&reg;8, Mopria&trade; Print Service9
Network Functions Print, Scan
Web Browser Support for Remote UI IE 7.0 or higher, Safari 3.2.1 or higher
Print Protocols LPD, RAW, WSD-Print (IPv4,IPv6), IPP, IPPS
TCP/IP Set of Application Services Bonjour(mDNS), DHCP, BOOTP, RARP, Auto IP (IPv4), DHCPv6 (IPv6)
Network Management Protocols SNMPv1/SNMPv3 (IPv4,IPv6), HTTP/HTTPS, SNTP
OS Compatibility Windows&reg; 10, 8.1, 8, 7, Windows Vista&reg;,Windows Server&reg; 2016, 2012, 2012 R2, 2008, 2008 R2, Mac OS 10.7.5 & up
Cable Included Power Cord (USB not included)
Bundled Software Printer driver, Scanner driver, MF Scan Utility, Address Book Tool, Toner Status
Environmental Specifications
Power Consumption Approx: Operation: 480 W, Standby: 4.1 W, Energy Saver: 1.2 W (USB), 1.3 W (wired), 2 W (wireless)
General Specifications
Dimensions 15.4 inches (W) x 14.6 inches (D) x 12.3 inches (H)
Unit Weight (without/with cartridge) 24 lbs. w/o cartridge,
25.2 lbs. w/ cartridge
Package Weight 37.4 lbs
Cartridge Type Cartridge 137 (Yields approximately 2,400 pages), Single Cartridge System
*Yields based on ISO/IEC Standard
LCD Display 5-Line, Tiltable LCD
Duty Cycle Up to 15,000 pages
Security IP/MAC address filtering
Languages English, Japanese, French, Spanish, German, Italian, Portuguese, Simplified Chinese, Traditional Chinese, Korean
Warranty 1 year limited exchange/carry-in warranty11 (Extended warranty available)
Other Features:
Recommended Monthly Print Volume: 750-3,000 pages
Operating Temperature: 50°-86° F
Operating Humidity: 20 - 80% RH (no condensation)
PRODUCT LIMITED WARRANTY
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
