Canon Support for imageCLASS D570 | Canon U.S.A., Inc.
imageCLASS D570
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
SELECT ERROR CODE
WINDOWS
macOS X
ChromeOS
imageCLASS D570 |
Products | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 | Tahoe 26 |
imageCLASS D570 |
Products | ChromeOS |
imageCLASS D570 |
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Printer Specifications
Printer Type | Monochrome Laser |
Print Speed | Up to 28 ppm (letter, 1-sided), Up to 16 ppm (letter, 2-sided)1 |
First Print Time | 6 seconds or less (letter)2 |
Printer Language | UFR II LT (Host-based), PCL (5e, 6) |
Print Resolution | Up to 600 x 600 dpi |
Maximum Print Size | Up to Legal (8.5 x 14 inches) |
Duplex Print | Yes |
Print Modes | Watermark, Page Composer, Toner Saver |
Print Memory | 512 MB (shared) |
Copier Specifications
Copy Type | Monochrome Laser |
Copy Speed | Up to 28 ppm (letter, 1-sided), Up to 16 ppm (letter, 2-sided) |
Copy Resolution | Up to 600 x 600 dpi |
Original Type | Text/Photo, Text, Photo |
Halftones | 256 Levels |
Warm-up Time | 13.5 seconds or less from power on |
First Copy Time | 9 seconds or less (letter)3 |
Recovery Time | Approximately 2 seconds |
Maximum Number of Copies | Up to 999 copies |
Reduction/Enlargement | 25-400% in 1% increments |
Copy Size | Platen: Up to 8.5 x 11 |
Copy Features | Memory Sort, 2 on 1, 4 on 1, ID Card Copy |
Copy Memory | 512 MB (shared) |
Scanner Specifications
Scan Type | Color Contact Image Sensor (CIS) |
Color Depth | 24-bit |
Scan Resolution | Up to 600 x 600 dpi (optical) |
Scan Size | Platen: Up to Letter |
Duplex Scan | No |
Compatibility | TWAIN, WIA, ICA |
Output File Formats | TIFF/JPEG/PDF/Compact PDF/Searchable PDF |
Scan Features | Push Scan, Pull Scan: USB and Network |
Pull Scan | USB and Network |
Push Scan (Scan to pC) | USB and Network |
Paper Handling Specifications
Standard Paper Source(s) | 250-sheet cassette plus 1-sheet multipurpose tray |
Paper Output | 100 sheets (face down) |
Paper Weight | 16-43 lb. (bond, plain paper)4 |
Media Sizes | A4, B5, A5, Letter, Legal, Executive, Statement |
Media Types | Plain, Color, Recycled, Heavy, Bond, Label, Envelope |
Envelope Capacity | 1 (multipurpose tray) |
Envelope Types | Com 10, Monarch, DL, C5 |
Connectivity and Software Specifications
Standard Interface(s) | USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet (network), Wi-Fi® 802.11 b/g/n5 |
WiFi Access Mode | Infrastructure Mode, WPS Easy Set Up, Wi-Fi® Direct Connection6 |
WiFi Authentication Methods | WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) |
WiFi Encryption Modes | WEP 64/128 bit, TKIP, AES |
WPS Easy Setup Support Methods | Push-button mode, PIN code mode |
Mobile Functions | Canon PRINT Business7, Apple® AirPrint®8, Mopria™ Print Service9 |
Network Functions | Print, Scan |
Web Browser Support for Remote UI | IE 7.0 or higher, Safari 3.2.1 or higher |
Print Protocols | LPD, RAW, WSD-Print (IPv4,IPv6), IPP, IPPS |
TCP/IP Set of Application Services | Bonjour(mDNS), DHCP, BOOTP, RARP, Auto IP (IPv4), DHCPv6 (IPv6) |
Network Management Protocols | SNMPv1/SNMPv3 (IPv4,IPv6), HTTP/HTTPS, SNTP |
OS Compatibility | Windows® 10, 8.1, 8, 7, Windows Vista®,Windows Server® 2016, 2012, 2012 R2, 2008, 2008 R2, Mac OS 10.7.5 & up |
Cable Included | Power Cord (USB not included) |
Bundled Software | Printer driver, Scanner driver, MF Scan Utility, Address Book Tool, Toner Status |
Environmental Specifications
Power Consumption | Approx: Operation: 480 W, Standby: 4.1 W, Energy Saver: 1.2 W (USB), 1.3 W (wired), 2 W (wireless) |
General Specifications
Dimensions | 15.4 inches (W) x 14.6 inches (D) x 12.3 inches (H) |
Unit Weight (without/with cartridge) | 24 lbs. w/o cartridge, 25.2 lbs. w/ cartridge |
Package Weight | 37.4 lbs |
Cartridge Type | Cartridge 137 (Yields approximately 2,400 pages), Single Cartridge System *Yields based on ISO/IEC Standard |
LCD Display | 5-Line, Tiltable LCD |
Duty Cycle | Up to 15,000 pages |
Security | IP/MAC address filtering |
Languages | English, Japanese, French, Spanish, German, Italian, Portuguese, Simplified Chinese, Traditional Chinese, Korean |
Warranty | 1 year limited exchange/carry-in warranty11 (Extended warranty available) |
Other Features: Recommended Monthly Print Volume: 750-3,000 pages Operating Temperature: 50°-86° F Operating Humidity: 20 - 80% RH (no condensation) |
PRODUCT LIMITED WARRANTY
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
