Canon Support for imageCLASS LBP226dw | Canon U.S.A., Inc.
imageCLASS LBP226dw
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
SELECT ERROR CODE
WINDOWS
macOS X
ChromeOS
Products | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 | Tahoe 26 |
Products | ChromeOS |
imageCLASS LBP226dw Spec Sheet
imageCLASS LBP226dw | |
MAIN UNIT | |
CORE FUNCTIONS | Standard: Print |
ITEM CODE | 3516C005 |
PROCESSOR | Canon Custom Processor |
CONTROL PANEL | 5-line LCD |
MEMORY | 1 GB |
STANDARD INTERFACE CONNECTION | USB 2.0 x1 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection |
PAPER CAPACITY (LETTER, 20 LB. BOND) | Standard: 350 Sheets Maximum: 900 Sheets |
PAPER SOURCES (LETTER, 20 LB. BOND) | Standard: 250-sheet Paper Cassette, 100-sheet Multipurpose Tray Optional: 550-sheet Paper Cassette (Cassette Unit-AH1) |
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) | Standard: 65 Sheets |
SUPPORTED MEDIA TYPES | Cassettes: Thin, Plain, Recycled, Thick, Bond Multipurpose Tray: Thin, Plain, Recycled, Thick, Bond, Label, Envelope (10 Envelopes) |
SUPPORTED MEDIA SIZES | Cassettes: Letter, Legal, Statement, Executive Custom (Min. 4.1" x 5.8" to Max. 8.5" x 14") Multipurpose Tray: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" x 5" to Max. 8.5" x 14") |
SUPPORTED MEDIA WEIGHTS | Cassettes: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2) Multipurpose Tray: 16 lb. Bond to 43 lb. Bond (60 to 163 g/m2) |
WARM-UP TIME | From Power On: 14 Seconds or Less From Sleep Mode: 4 Seconds or Less |
DIMENSIONS (W x D x H) | Standard (Desktop): 15.8" x 14.7" x 9.9" (401 mm x 373 mm x 250 mm) |
INSTALLATION SPACE (W x D x H) | Standard (Desktop): 15.8" x 31.7" x 12.3" (401 mm x 804 mm x 312 mm) Fully Configured: 15.8" x 34.4" x 15.0" (401 mm x 874 mm x 381 mm) |
WEIGHT | Machine Only: Approx. 19.4 lb. (8.8 kg) Boxed Weight: Approx. 28.7 lb. (13.0 kg) |
OPERATING SYSTEMS | UFR II/PCL/PS: Windows® 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/ Windows Server 2012/Windows Server 2012 R2/Windows Server 2016/Mac OS X v10.9.5 (or later) |
PRINT SPECIFICATIONS | |
PRINTING METHOD | Laser Beam Printing |
PRINT SPEED4 | Up to 40 ppm (Letter); Up to 32 ppm (Legal) |
FIRST PRINT OUT TIME | Approx. 5.3 Seconds |
RECOMMENDED MONTHLY PAGE VOLUME | 750 - 4,000 Pages |
PRINT RESOLUTION (dpi) | 600 x 600 |
STANDARD PAGE DESCRIPTION LANGUAGES | UFR II, PCL®6, PCL®5, Adobe PostScript 3® |
DOUBLE-SIDED PRINTING | Automatic (Standard) |
DIRECT PRINT | Available from USB Memory (JPEG, TIFF, PDF) |
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES1 | Apple® AirPrint,® Canon PRINT Business, Mopria™ Print Service |
FONTS | PCL: 45 Fonts PS: 136 Fonts |
PRINT FEATURES | Secure Print, Page Border, Header/Footer, Page Layout, Two-sided printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations |
SECURITY SPECIFICATIONS | |
AUTHENTICATION | Standard: Department ID Authentication |
DATA | Standard: Verify System at Startup |
NETWORK | Standard: IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6 |
DOCUMENT | Standard: Secure Print |
WI-FI AUTHENTICATION METHODS | Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) Wi-Fi Access Point: WPA2-PSK (AES) |
ENVIRONMENTAL SPECIFICATIONS | |
OPERATING ENVIRONMENT | Temperature: 50 to 86º F Humidity: 20 to 80% RH (no condensation) |
POWER REQUIREMENTS | AC 120-127 V:6.5 A, 60 Hz |
POWER CONSUMPTION | Maximum: Approx. 1300 W Standby: Approx. 8.5 W Sleep Mode: Approx. 0.9 W Typical Electricity Consumption (TEC) Rating: 0.33 kWh |
STANDARDS | ENERGY STAR® Qualified, Currently Rated EPEAT Silver¿2 |
CONSUMABLES | |
TONER | Cartridge 057 Black, Standard - Yields up to 3,100 Pages Cartridge 057 Black, High Capacity - Yields up to 10,000 Pages |
FOOTNOTES | |
PRODUCT LIMITED WARRANTY
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
