Canon Support for imageCLASS MF212w | Canon U.S.A., Inc.
imageCLASS MF212w
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 08.29.14
File Size 4.79 MB
Date 09.22.17
File Size 2.92 MB
Date 12.24.20
File Size 2.92 MB
Date 09.17.24
File Size 2.27 MB
Date 09.12.25
File Size 1.20 MB
Date 08.29.14
File Size 10.31 MB
Date 09.25.23
File Size 1.20 MB
Date 09.12.25
File Size 2.27 MB
Date 04.24.19
File Size 647.96 KB
Date 01.31.23
File Size 2.92 MB
Date 04.20.22
File Size 1.50 MB
Date 09.17.24
File Size 1.20 MB
Date 02.04.20
File Size 652.13 KB
Date 03.24.23
File Size 1.60 MB
Date 09.25.23
File Size 2.27 MB
Date 10.04.19
File Size 2.92 MB
Date 04.24.19
File Size 2.92 MB
Date 04.27.23
File Size 2.27 MB
Date 07.07.15
File Size 8.82 MB
Date 07.13.21
File Size 652.14 KB
Date 12.22.17
File Size 647.92 KB
Date 10.03.17
File Size 80.0 KB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
imageCLASS MF212w
imageCLASS MF212w
Printer Specifications
Printer Type Monochrome Laser
Print Speed Up to 24ppm (1-sided plain paper letter)6
First Print Time 6 seconds or less (letter)5
Printer Language UFR II LT (Host-based)
Print Resolution Up to 600 x 600 dpi
(1200 x 12000 dpi quality)
Maximum Print Size Up to Legal
Duplex Print No
Print Modes Watermark, Toner Saver, Page Composer
Print Memory 256 MB (Shared)
Copier Specifications
Copy Type Monochrome Laser
Copy Speed Up to 24cpm (letter)
Copy Resolution Up to 600 x 600 dpi
Original Type Text/Photo, Photo, Text
Halftones 256 Levels
Warm-up Time Approximately 13.5 seconds
First Copy Time Approximately 9 seconds9
Recovery Time Approximately 2 seconds
Maximum Number of Copies 99 copies
Reduction/Enlargement 25%, 50%, 64%, 78%129%, 200%, 400%
Zoom 25 - 400% in 1% increments
Copy Size Platen: Up to Letter
Copy Features Collate
2 on 1
4 on 1
ID Card Copy
Copy Memory 256 MB (Shared)
Scanner Specifications
Scan Type Color Contact Image Sensor (CIS)
Color Depth 24-bit
Scan Resolution Up to 600 x 600 dpi (optical)
9600 x 9600 (interpolated)
Scan Size Platen: Up to Letter
Duplex Scan No
Compatibility TWAIN, WIA
Scan Features Push Scan, Pull Scan
Pull Scan USB and Network
Push Scan (Scan to pC) USB and Network
Paper Handling Specifications
Standard Paper Source(s) 250-sheet cassette plus 1-sheet multipurpose tray7
Paper Output 100 sheets (face down)
Paper Weight 16-43 lb. bond (cassette)
16-43 lb. bond (multipurpose tray)
Media Sizes Letter, Legal, A4, A5, B5, Executive, Statement
Media Types Plain Paper, Heavy Paper, Recycled, Transparency, Label, Envelope, Index Card
Envelope Capacity 20 envelopes
Envelope Types Com 10, Monarch, DL, C5
Connectivity and Software Specifications
Standard Interface(s) USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet, Wi-Fi 802.11 b/g/n1
WiFi Access Mode Infrastructure Mode
WiFi Authentication Methods WPA-PSK, WPA2-PSK
WiFi Encryption Modes WEP (64/128 bit), TKIP, AES
WPS Easy Setup Support Methods Push-button mode, PIN code mode
Mobile Functions Canon Mobile Printing10, Apple&reg; AirPrint&trade;2, Mopria&trade; Print Service3, Canon Mobile Scanning for Business4
Embedded Web Server (Remote UI) Yes
Web Browser Support for Remote UI Microsoft Internet Explore 7.0 or higher, Safari 3.2.1 or higher
Print Protocols LPD, RAW, WSD-Print (IPv4,IPv6)
TCP/IP Set of Application Services Bonjour(mDNS), DHCP, BOOTP, RARP, Auto IP (IPv4), DHCPv6 (IPv6)
Network Management Protocols SNMPv1 (IPv4,IPv6)
OS Compatibility Windows&reg; 8.1, Windows 8, Windows 7, Windows Server&reg; 2012, Windows Server 2012 R2, Windows Server 2008 R2, Windows Server 2008, Windows Vista&reg;, Windows Server 2003, Windows&reg; XP, Mac&reg; OS X 10.5.8 & up
Cable Included Power Cord (USB not included)
Bundled Software Printer driver, Scanner driver, MF Toolbox, Presto! PageManager, Address Book Tool,Toner Status
Environmental Specifications
Power Consumption Max: Approx. 1,190W
During Operation: Approx. 500W
Standby: Approx. 3.2W
Energy Saver: Approx. 1.6W (Wired)
Approx. 2 W (Wireless)
Typical Energy Consumption 0.7kWh
General Specifications
Dimensions 15.4" (W) x 14.6" (D) x 12.3" (H)
Unit Weight (without/with cartridge) 22.5 lbs. (w/o cartridge)
23.8 lbs. (w/cartridge)
Package Weight Approx. 34.2 lbs.
Cartridge Type Cartridge 137 (Yields approximately 2,400 pages)
Single Cartridge System
*Yields based on ISO/IEC Standard
LCD Display 5-line LCD
Duty Cycle Up to 8,000 pages per month
Security IP Filtering, MAC Address Filtering
Languages English, French, Spanish, Portuguese
Warranty 1 year limited exchange/carry-in warranty11 (Extended warranty available)
CANON imageCLASS SERIES EXCHANGE/CARRY-IN PRODUCT LIMITED WARRANTY
CARTRIDGES FOR THE PRODUCT (EXCEPT THE CARTRIDGE BUNDLED WITH THE PRODUCT, FOR WHICH THERE IS NO WARRANTY) ARE COVERED BY A SEPARATE WARRANTY. ACCORDINGLY, THIS LIMITED WARRANTY DOES NOT COVER ANY CARTRIDGES FOR THE PRODUCT, WHETHER SHIPPED WITH THE PRODUCT OR PURCHASED THEREAFTER.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.usa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666),
Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
NEITHER CANON USA NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, INCLUDING, WITHOUT LIMITATION, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON USA OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCAHSE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
Click Here to download the Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Support | Service Notice: Windows Scanning for imageCLASS
Advisory Type
Date 07.11.16
Title Canon Support | Service Notice: Canon Laser Printer & Small Office Multifunctional Printer IP Stack protocol
Advisory Type
Date 09.29.20
Title Canon Support | Service Notice: Laser Printer & Small Office Multifunctional Printer cross-site scripting
Advisory Type
Date 12.30.21
Advisory Type
Date 03.29.15
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
