Canon Support for imageCLASS MF217w | Canon U.S.A., Inc.
imageCLASS MF217w
Technical support for this product is provided exclusively through our FAQs and Knowledge Base.
Please click FAQs or Knowledge Base and enter your search term to find a resolution to your inquiry.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
SELECT ERROR CODE
WINDOWS
macOS X
imageCLASS MF217w |
Products | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 |
imageCLASS MF217w |
Printer Specifications
Printer Type | Monochrome Laser |
Print Speed | Up to 24ppm (1-sided plain paper letter), Up to 23ppm (1-sided plain paper A4)1 |
First Print Time | 6 seconds or less (letter)2 |
Printer Language | UFR II LT (Host-based) |
Print Resolution | Up to 600 x 600 dpi (1200 x 1200 dpi quality) |
Maximum Print Size | Up to Legal |
Duplex Print | No |
Print Modes | Watermark, Toner Save, Page Composer |
Print Memory | 256 MB (Shared) |
Copier Specifications
Copy Type | Monochrome Laser |
Copy Speed | Up to 24ppm (letter), Up to 23ppm (A4) |
Copy Resolution | Up to 600 x 600 dpi |
Original Type | Text/Photo, Photo, Text |
Halftones | 256 Levels |
Warm-up Time | Approximately 13.5 seconds |
First Copy Time | Approximately 8.7 seconds or less (letter)3 |
Recovery Time | Approximately 2 seconds |
Maximum Number of Copies | 99 copies |
Reduction/Enlargement | 25 - 400% in 1% increments |
Zoom | 25 - 400% in 1% increments |
Copy Size | Platen: Up to Letter ADF: Up to Legal |
Copy Features | Collate 2 on 1 4 on 1 ID Card Copy |
Copy Memory | 256 MB (Shared) |
Fax Specifications
Modem Speed | Up to 33.6 Kbps (Super G3)4 |
Fax Resolution | Up to 200 x 400 dpi (super fine) |
Transmission Time | JBIG (approx. 3 seconds) |
Memory Capacity | Up to 256 sheets5 |
Speed Dials | 100 coded dials |
Group Dialing | 103 destinations |
Sequential Broadcasting | 114 destinations |
Duplex Fax | No |
Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
Fax Features | Fax forwarding, Dual Access, Remote Reception, PC Fax (TX only), Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial, Fax Activity Result and Management Reports |
Memory Backup | Permanent fax memory back up |
Scanner Specifications
Scan Type | Color Contact Image Sensor (CIS) |
Color Depth | 24-bit |
Scan Resolution | Optical: Up to 600 x 600 dpi Driver(digital): Up to 9600 x 9600 dpi |
Scan Size | Platen: Up to Letter ADF: Up to Legal |
Duplex Scan | No |
Compatibility | TWAIN, WIA (Scan Driver Compatibility) |
Scan Features | Push Scan, Pull Scan |
Pull Scan | USB and Network |
Push Scan (Scan to pC) | USB and Network |
Paper Handling Specifications
Standard Paper Source(s) | 250-sheet cassette plus 1-sheet multipurpose tray6 |
Document Feeder | 35-sheet simplex |
Paper Output | 100 sheets (face down) |
Paper Weight | 16-43 lb. bond (cassette) 16-43 lb. bond (multipurpose tray) |
Media Sizes | Letter, Legal, A4, A5, B5, B6, Executive |
Media Types | Plain, Heavy, Recycled, Transparency, Label, Envelope, Index |
Envelope Capacity | 20 Envelopes Cassette, 1 Envelope Manual Feed |
Envelope Types | Com 10, DL, C5, Monarch |
Connectivity and Software Specifications
Standard Interface(s) | USB Device 2.0 High-Speed, 10/100 Base-T Ethernet, Wi-Fi 802.11b/g/n Wireless7 |
WiFi Access Mode | Infrastructure Mode |
WiFi Encryption Modes | WEP (64/128 bit), TKIP, AES |
Mobile Functions | Canon PRINT Business8, Apple AirPrint™9, Mopria Print Service10 |
Network Functions | Print / Scan |
Embedded Web Server (Remote UI) | Yes |
Web Browser Support for Remote UI | IE 7.0 or higher, Safari 3.2.1 or higher |
TCP/IP Set of Application Services | Bonjour(mDNS), DHCP, BOOTP, RARP, Auto IP (IPv4), DHCPv6 (IPv6) |
Network Management Protocols | SNMPv1 (IPv4,IPv6) |
OS Compatibility | Windows® 10, Windows® 8.1, Windows 8, Windows 7, Windows XP, Windows Vista®, Windows Server® 2012 R2, Windows Server 2012, Windows Server 2008 R2, Windows Server 2008, Windows Server 2003, Mac OS X® 10.5.8 or later, Linux |
Cable Included | Power Cord, Telephone Cable |
Bundled Software | Printer driver, Fax driver, Scanner driver, MF Toolbox, Address Book Tool, Presto! PageManager, SSID Tool, Toner Status |
Environmental Specifications
Power Consumption | Max: Approx. 1,190W, Approx. 500w (during operation), Approx. 5.4w (standby), Approx. 2.0w (energy saver) |
Typical Energy Consumption | 0.7kWh |
General Specifications
Dimensions | 15.4" (W) x 14.6" (D) x 14.2" (H) |
Unit Weight (without/with cartridge) | 25.4 lbs. (w/o cartridge) 26.7 lbs. (w/cartridge) |
Package Weight | Approx. 38.6 lbs. |
Cartridge Type | Cartridge 137 (Yields approximately 2,400 pages) Single Cartridge System *Yields based on ISO/IEC Standard |
LCD Display | 6-line BW LCD Touch |
Duty Cycle | Up to 8,000 pages per month |
Security | IP Filtering, MAC Address Filtering |
Languages | English, French, Spanish, Portuguese |
Warranty | 1 year limited exchange/carry-in warranty (Extended warranty available)11 |
CANON imageCLASS SERIES EXCHANGE/CARRY-IN PRODUCT LIMITED WARRANTY
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
NO IMPLIED WARRANTY, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, APPLIES TO THE PRODUCT AFTER THE APPLICABLE PERIOD OF THE EXPRESS LIMITED WARRANTY STATED ABOVE. NO OTHER WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM, OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON USA OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
