Canon Support for imageCLASS MF242dw | Canon U.S.A., Inc.
imageCLASS MF242dw
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.11.25
File Size 1.20 MB
Date 05.05.21
File Size 5.07 MB
Date 01.30.23
File Size 2.92 MB
Date 04.19.22
File Size 1.50 MB
Date 07.19.23
File Size 154.27 KB
Date 09.16.24
File Size 1.20 MB
Date 07.12.21
File Size 652.14 KB
Date 09.01.21
File Size 408.57 KB
Date 01.30.23
File Size 144.76 KB
Date 04.26.23
File Size 2.27 MB
Date 09.16.24
File Size 2.27 MB
Date 09.24.23
File Size 2.27 MB
Date 03.23.23
File Size 1.60 MB
Date 09.24.23
File Size 1.20 MB
Date 09.11.25
File Size 2.27 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
imageCLASS MF242dw
imageCLASS MF242dw
Products ChromeOS
imageCLASS MF242dw
Printer Specifications
Printer Type Black and White Laser
Print Speed Up to 40 ppm (Letter); Up to 32 ppm (Legal) Footnote3
First Print Time Approx. 5.3 Seconds
Printer Language UFR II, PCL®6, PCL®5, Adobe PostScript 3®
Print Resolution 600 x 600 (dpi)
Duplex Print Automatic (Standard)
Print Memory 1GB
Direct Print from USB Available from USB memory (JPEG, TIFF, PDF)
Copier Specifications
Copy Speed Up to 40 ppm (Letter); Up to 32 ppm (Letter)
Copy Resolution 600 x 600 (dpi)
First Copy Time Approx. 6.2 seconds
Maximum Number of Copies Up to 999 Copies
Reduction/Enlargement Preset Reductions: 25%, 50%, 64%, 78%
Preset Enlargements: 129%, 200%, 400%
Copy Size Platen: Up to Letter
Copy Features Paper Setting, Favorite Settings, Two-sided, Original Type Selection, Cancel, N-on-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card
Fax Specifications
Modem Speed Super G3: 33.6 kbps
G3: 14.4 kbps
Fax Resolution 400 x 400, 200 x 400, 200 x 200, 200 x 100
Memory Capacity Up to 512 Pages
Speed Dials Max. 281
Group Dialing Max. 299 dials
Sequential Broadcasting Max. 310 Addresses
Fax Features RX Mode, Resolution, Two-sided Original, Density, Sharpness, Favorite Settings, Duplex Fax
Memory Backup Yes
Scanner Specifications
Scan Type Platen / Manual
Scan Resolution 300 x 600, 600 x 600
Scan Size Letter, Statement
Duplex Scan Yes
Output File Formats Standard: TIFF, JPEG, PDF (Compact, Searchable) Optional: PDF (Encrypted, Digital Signature)
Pull Scan ScanGear MF for TWAIN, WIA, and ICA
Paper Handling Specifications
Standard Paper Source(s) 250-sheet Paper Cassette, 100-sheet Multipurpose Tray
Paper Output Standard: 65 Sheets
Paper Weight Cassettes: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2)
Multipurpose Tray: 16 lb. Bond to 43 lb. Bond (60 to 163 g/m2)
Media Sizes Cassettes: Letter, Legal, Statement, Executive Custom (Min. 4.1" x 5.8" to Max. 8.5" x 14")
Multipurpose Tray: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" x 5" to Max. 8.5" x 14")
Media Types Cassettes: Thin, Plain, Recycled, Thick, Bond
Multipurpose Tray: Thin, Plain, Recycled, Thick, Bond, Label, Envelope (10 Envelopes)
Connectivity and Software Specifications
Standard Interface(s) USB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection
WiFi Authentication Methods WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
Mobile Functions Apple® AirPrint,® Canon PRINT Business, Mopria Print Service
Network Management Protocols IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP
OS Compatibility UFR II/PCL/PS: Windows® 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/ Windows Server 2012/Windows Server 2012 R2/Windows Server 2016/Mac OS X v10.8.5 (or later)
Environmental Specifications
Power Consumption Maximum: Approx. 1330 W
Standby: Approx. 10 W
Sleep Mode: Approx. 0.9 W
Typical Energy Consumption 0.34 kWh
General Specifications
Dimensions Standard (Desktop): 17.9" x 18.3" x 15.5" (453 mm x 464 mm x 392 mm)
Unit Weight (without/with cartridge) Approx. 35.8 lb. (16.2 kg) Footnote2
Package Weight Approx. 45.9 lb. (20.8 kg) Footnote2
LCD Display 5" Color Touch-panel
PRODUCT LIMITED WARRANTY
Cartridge Warranty
** In Canada
CAUTION:
Advisory Type
Date 03.29.15
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
