Canon Support for imageCLASS MF242dw | Canon U.S.A., Inc.
imageCLASS MF242dw
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
SELECT ERROR CODE
WINDOWS
macOS X
ChromeOS
Products | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 | Tahoe 26 |
Products | ChromeOS |
Printer Specifications
Printer Type | Black and White Laser |
Print Speed | Up to 40 ppm (Letter); Up to 32 ppm (Legal) 3 |
First Print Time | Approx. 5.3 Seconds |
Printer Language | UFR II, PCL®6, PCL®5, Adobe PostScript 3® |
Print Resolution | 600 x 600 (dpi) |
Duplex Print | Automatic (Standard) |
Print Memory | 1GB |
Direct Print from USB | Available from USB memory (JPEG, TIFF, PDF) |
Copier Specifications
Copy Speed | Up to 40 ppm (Letter); Up to 32 ppm (Letter) |
Copy Resolution | 600 x 600 (dpi) |
First Copy Time | Approx. 6.2 seconds |
Maximum Number of Copies | Up to 999 Copies |
Reduction/Enlargement | Preset Reductions: 25%, 50%, 64%, 78% Preset Enlargements: 129%, 200%, 400% |
Copy Size | Platen: Up to Letter |
Copy Features | Paper Setting, Favorite Settings, Two-sided, Original Type Selection, Cancel, N-on-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card |
Fax Specifications
Modem Speed | Super G3: 33.6 kbps G3: 14.4 kbps |
Fax Resolution | 400 x 400, 200 x 400, 200 x 200, 200 x 100 |
Memory Capacity | Up to 512 Pages |
Speed Dials | Max. 281 |
Group Dialing | Max. 299 dials |
Sequential Broadcasting | Max. 310 Addresses |
Fax Features | RX Mode, Resolution, Two-sided Original, Density, Sharpness, Favorite Settings, Duplex Fax |
Memory Backup | Yes |
Scanner Specifications
Scan Type | Platen / Manual |
Scan Resolution | 300 x 600, 600 x 600 |
Scan Size | Letter, Statement |
Duplex Scan | Yes |
Output File Formats | Standard: TIFF, JPEG, PDF (Compact, Searchable) Optional: PDF (Encrypted, Digital Signature) |
Pull Scan | ScanGear MF for TWAIN, WIA, and ICA |
Paper Handling Specifications
Standard Paper Source(s) | 250-sheet Paper Cassette, 100-sheet Multipurpose Tray |
Paper Output | Standard: 65 Sheets |
Paper Weight | Cassettes: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2) Multipurpose Tray: 16 lb. Bond to 43 lb. Bond (60 to 163 g/m2) |
Media Sizes | Cassettes: Letter, Legal, Statement, Executive Custom (Min. 4.1" x 5.8" to Max. 8.5" x 14") Multipurpose Tray: Letter, Legal, Statement, Executive Envelope: COM10, Monarch, C5, DL Custom (Min. 3" x 5" to Max. 8.5" x 14") |
Media Types | Cassettes: Thin, Plain, Recycled, Thick, Bond Multipurpose Tray: Thin, Plain, Recycled, Thick, Bond, Label, Envelope (10 Envelopes) |
Connectivity and Software Specifications
Standard Interface(s) | USB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection |
WiFi Authentication Methods | WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) |
Mobile Functions | Apple® AirPrint,® Canon PRINT Business, Mopria™ Print Service |
Network Management Protocols | IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP |
OS Compatibility | UFR II/PCL/PS: Windows® 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/ Windows Server 2012/Windows Server 2012 R2/Windows Server 2016/Mac OS X v10.8.5 (or later) |
Environmental Specifications
Power Consumption | Maximum: Approx. 1330 W Standby: Approx. 10 W Sleep Mode: Approx. 0.9 W |
Typical Energy Consumption | 0.34 kWh |
General Specifications
Dimensions | Standard (Desktop): 17.9" x 18.3" x 15.5" (453 mm x 464 mm x 392 mm) |
Unit Weight (without/with cartridge) | Approx. 35.8 lb. (16.2 kg) 2 |
Package Weight | Approx. 45.9 lb. (20.8 kg) 2 |
LCD Display | 5" Color Touch-panel |
PRODUCT LIMITED WARRANTY
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
