Canon Support for imageCLASS MF267dw | Canon U.S.A., Inc.
        imageCLASS MF267dw
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
 - Windows 10 (x64)
 - Windows 10
 - Windows 8.1 (x64)
 - Windows 8.1
 - Windows 8 (x64)
 - Windows 8
 - Windows 7 (x64)
 - Windows 7
 - Windows Vista (x64)
 - Windows Vista
 - Windows Me
 - Windows XP (x64)
 - Windows XP
 - Windows 98
 - Windows 95
 - Windows Server 2022
 - Windows Server 2019 (x64)
 - Windows Server 2016 (x64)
 - Windows Server 2012 (x64)
 - Windows Server 2008 (x64)
 - Windows Server 2003 (x64)
 - Windows Server 2003 R2
 - macOS Tahoe v26
 - macOS Sequoia v15
 - macOS Sonoma v14
 - macOS Ventura v13
 - macOS Monterey v12
 - macOS Big Sur v11.0
 - macOS Catalina v10.15
 - macOS Mojave v10.14
 - macOS High Sierra v10.13
 - macOS Sierra v10.12
 - OS X El Capitan v10.11
 - OS X Yosemite v10.10
 - OS X Mavericks v10.9
 - OS X Mountain Lion v10.8
 - OS X Lion v10.7
 - Mac OS X Snow Leopard v10.6
 - Mac OS X v10.1
 - Mac OS 9
 - Linux ARM
 - Linux MIPS
 - Linux 64bit
 - Linux 32bit
 - SAP
 - Windows Server 2025
 - Windows NT
 - Linux
Canon PRINT - iOS
Canon PRINT - Android
SELECT ERROR CODE
                                WINDOWS
                                macOS X
                                ChromeOS
| Products | Windows 7 | Windows 8 | Windows 10 | Windows 10s | Windows 11 |
| Products | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 | Tahoe 26 |
| Products | ChromeOS |
imageCLASS MF269dw / MF267dw / MF264dw Spec Sheet
imageCLASS MF269dw / MF267dw / MF264dw | |||
| imageCLASS MF269dw | imageCLASS MF267dw | imageCLASS MF264dw | |
MAIN UNIT  |   |||
FUNCTIONS  | Print/Scan/Copy/Fax  | Print/Scan/Copy  | |
CONTROL PANEL  | 6-line LCD  | 5-line LCD  | |
MEMORY  | 256 MB  | ||
STANDARD INTERFACE CONNECTION  |   USB Device 2.0 High-Speed, 10/100 Base-T Ethernet (Network), Wi-Fi 802.11 b/g/n, Wi-Fi Direct Connection  |   ||
PAPER INPUT / OUTPUT CAPACITY (LETTER, 20 LB. BOND)  | 250/50 Sheets  | ||
PAPER SOURCES (LETTER, 20 LB. BOND)  | 250-sheet Paper Cassette, 1-sheet Stack Bypass  | ||
SUPPORTED MEDIA TYPES  | Cassette/Bypass: Plain, Recycled, Thick, Bond, Label, Envelope  | ||
SUPPORTED MEDIA SIZES      | Cassette/Bypass: Letter, Legal, Statement, Executive;   | ||
SUPPORTED MEDIA WEIGHTS  | Cassette/Bypass: 16 lb. Bond to 43 lb. Bond (60 to 163 g/m2)  | ||
WARM-UP TIME  | From Power On: 15 Seconds or Less;   | ||
DIMENSIONS (W x D x H)  | 15.4" x 16.0" x 14.8" (390 mm x 405 mm x 375 mm)  | ||
WEIGHT (MACHINE ONLY / BOXED WEIGHT)  | 29.3 lb. (13.3 kg)/37.4 lb. (17.0 kg)  | 27.3 lb. (12.4 kg)/35.2 lb. (16.0 kg) | |
PRINT SPECIFICATIONS  | |||
PRINTING METHOD  | Laser Beam Printing  | ||
PRINT SPEEDS1  | Up to 30 ppm (Letter); Up to 24 ppm (Legal)  | ||
FIRST PRINT-OUT TIME  | Approx. 5.1 Seconds  | ||
RECOMMENDED MONTHLY PAGE VOLUME  | 250 - 2,500 Pages  | ||
PRINT RESOLUTION (dpi)  | 600 x 600  | ||
STANDARD PAGE DESCRIPTION LANGUAGES  | UFR II-LT, PCL®6, PCL®5e  | ||
TWO-SIDED PRINTING  | Automatic (Standard)  | ||
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES2  |   Canon PRINT Business, Apple® AirPrint®, Mopria™ Print Service  |   ||
OPERATING SYSTEMS (PRINT / SCAN)  |   Windows® 10/8.1/7, Windows Server® 2016/ 2012 R2/ 2012/ 2008 R2/ 2008; Mac OS 10.8.5 and Up.  |   ||
COPY SPECIFICATIONS  | |||
COPY SPEED  |   Up to 30 ppm (Letter); Up to 24 ppm (Legal)  |   ||
FIRST COPY-OUT TIME (LETTER)  | 8 Seconds or Less  | ||
COPY RESOLUTION (dpi)  | Up to 600 x 600  | ||
COPY SIZE  |   Platen: Up to Letter;   |   ||
PRESETS  | Magnifications: 25% - 400% (1% Increments)   | ||
SCAN SPECIFICATIONS  | |||
TYPE  | Duplexing Automatic Document Feeder  | Automatic Document Feeder  | |
DOCUMENT FEEDER PAPER CAPACITY (20 LB. BOND)  | 50 Sheets  | 35 Sheets  | |
DOCUMENT FEEDER SUPPORTED MEDIA SIZES  | Legal, Letter  | ||
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS  | Single-sided Scanning: 13 - 28 lb. Bond (50-105 g/m2)  | Single-sided Scanning: 13 - 28 lb. Bond (50-105 g/m2)  | |
SCAN RESOLUTION (dpi)  | 600 x 600  | ||
SCAN TO MOBILE DEVICES  | Canon PRINT Business  | ||
SCAN SPEED (LETTER) (IPM)  | Single-sided (Color/BW): 7.7/11.6  | Single-sided (Color/BW): 8 /10.6 Two-sided (Color/BW): N/A  | |
SEND SPECIFICATIONS  | |||
DESTINATION  | Email (SMTP), SMB, Super G3 FAX  | NA  | |
ADDRESS BOOK  | Local (50)  | ||
SEND RESOLUTION (dpi)  | 300 x 300  | ||
COMMUNICATION PROTOCOL  | File: SMB; Email: SMTP, POP3  | ||
FILE FORMAT  | TIFF, JPEG, PDF (Compact, Searchable)  | ||
FAX SPECIFICATIONS  | |||
MODEM SPEED  | Super G3: 33.6 kbps  | NA  | |
RESOLUTION (dpi)  | 200 x 400, 200 x 200, 200 x 100  | ||
SENDING / RECORDING SIZE  | Statement to Letter  | ||
FAX MEMORY  | Up to 256 Pages  | ||
SPEED DIALS  | Max. 104  | ||
GROUP DIALS / DESTINATIONS  | Max. 50 Dials  | ||
SEQUENTIAL BROADCAST  | Max. 114 Addresses  | ||
FAX FEATURES  | Rx Mode, Resolution, Two-sided Original, Density, Sharpness, Duplex Fax  | ||
SECURITY SPECIFICATIONS  | |||
NETWORK  | IP/MAC Address Filtering, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication Before SMTP  | ||
WI-FI® AUTHENTICATION METHODS  | WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)  | ||
ENVIRONMENTAL SPECIFICATIONS  | |||
OPERATING ENVIRONMENT  | Temperature: 50 to 86º F;   | ||
POWER CONSUMPTION  | Maximum: Approx. 1080 W or Less;   | ||
STANDARDS  | ENERGY STAR® Qualified, Rated EPEAT Silver3  | ||
FOOTNOTES  | |||
  1 Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.  | |||
PRODUCT LIMITED WARRANTY
Cartridge Warranty
 ** In Canada
CAUTION:
Click here to download the Warranty Card.
 next to your download
