Canon Support for imageCLASS MF269dw Value Pack | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 12.20.23
File Size 476.17 KB
Date 12.24.20
File Size 2.92 MB
Date 09.12.25
File Size 1.32 MB
Date 09.17.24
File Size 2.27 MB
Date 01.31.23
File Size 144.76 KB
Date 09.12.25
File Size 1.20 MB
Date 09.25.23
File Size 1.20 MB
Date 04.24.19
File Size 815.66 KB
Date 09.12.25
File Size 2.27 MB
Date 04.24.19
File Size 408.63 KB
Date 04.24.19
File Size 647.96 KB
Date 01.31.23
File Size 2.92 MB
Date 04.20.22
File Size 1.50 MB
Date 10.04.19
File Size 815.82 KB
Date 09.17.24
File Size 1.20 MB
Date 02.04.20
File Size 652.13 KB
Date 03.24.23
File Size 1.60 MB
Date 09.25.23
File Size 2.27 MB
Date 10.04.19
File Size 2.92 MB
Date 12.20.23
File Size 1.32 MB
Date 04.24.19
File Size 2.92 MB
Date 07.20.23
File Size 146.85 KB
Date 04.27.23
File Size 2.27 MB
Date 07.20.23
File Size 154.27 KB
Date 09.17.24
File Size 1.32 MB
Date 12.24.20
File Size 819.56 KB
Date 07.13.21
File Size 652.14 KB
Date 01.31.23
File Size 1.63 MB
Date 04.27.23
File Size 460.45 KB
Date 04.27.23
File Size 1.72 MB
Date 05.07.19
File Size 80.0 KB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
Products Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sequoia 15 Tahoe 26
Products ChromeOS
imageCLASS MF269dw Value Pack Spec Sheet
MAIN UNIT
FUNCTIONS
Print/Scan/Copy/Fax
CONTROL PANEL
6-line LCD
MEMORY
256 MB
STANDARD INTERFACE CONNECTION
USB Device 2.0 High-Speed, 10/100 Base-T Ethernet (Network), Wi-Fi 802.11 b/g/n, Wi-Fi Direct Connection
PAPER INPUT / OUTPUT CAPACITY (LETTER, 20 LB. BOND)
250/50 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)
250-sheet Paper Cassette, 1-sheet Stack Bypass
SUPPORTED MEDIA TYPES
Cassette/Bypass: Plain, Recycled, Thick, Bond, Label, Envelope
SUPPORTED MEDIA SIZES
(CASSETTE, STACK BYPASS)
Cassette/Bypass: Letter, Legal, Statement, Executive;
Envelope: COM10, Monarch, C5, DL; Custom (Min. 3" x 5" to Max. 8.5" x 14")
SUPPORTED MEDIA WEIGHTS
Cassette/Bypass: 16 lb. Bond to 43 lb. Bond (60 to 163 g/m2)
WARM-UP TIME
From Power On: 15 Seconds or Less;
From Sleep Mode: 1.6 Seconds or Less
DIMENSIONS (W x D x H)
15.4" x 16.0" x 14.8" (390 mm x 405 mm x 375 mm)
WEIGHT (MACHINE ONLY / BOXED WEIGHT)
29.7 lb. (13.5 kg)/39.6 lb. (18.0 kg)
PRINT SPECIFICATIONS
PRINTING METHOD
Laser Beam Printing
PRINT SPEEDS2
Up to 30 ppm (Letter); Up to 24 ppm (Legal)
FIRST PRINT-OUT TIME
Approx. 5.1 Seconds
RECOMMENDED MONTHLY PAGE VOLUME
250 - 2,500 Pages
PRINT RESOLUTION (dpi)
600 x 600
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II-LT, PCL®6, PCL®5e
TWO-SIDED PRINTING
Automatic (Standard)
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES3
Canon PRINT Business, Apple® AirPrint®, Mopria™ Print Service
OPERATING SYSTEMS (PRINT / SCAN)
Windows® 10/8.1/7, Windows Server® 2016/ 2012 R2/ 2012/ 2008 R2/ 2008; Mac OS 10.8.5 and Up.
Drivers Available For Download From www.usa.canon.com/support
COPY SPECIFICATIONS
COPY SPEED
FIRST COPY-OUT TIME (LETTER)
8 Seconds or Less
COPY RESOLUTION (dpi)
Up to 600 x 600
COPY SIZE
Platen: Up to Letter;
ADF: Up to Legal
PRESETS
Magnifications: 25% - 400% (1% Increments)
Reductions
: 25%, 50%, 64%, 78%
Enlargements
: 129%, 200%, 400%
SCAN SPECIFICATIONS
TYPE
Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY (20 LB. BOND)
50 Sheets
DOCUMENT FEEDER SUPPORTED MEDIA SIZES
Legal, Letter
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS
Single-sided Scanning: 13 - 28 lb. Bond (50-105 g/m2)
Two-sided Scanning: 16 - 28 lb. Bond (60-105 g/m2)
SCAN RESOLUTION (dpi)
600 x 600
SCAN TO MOBILE DEVICES
SCAN SPEED (LETTER) (IPM)
Single-sided (Color/BW): 7.7/11.6
Two-sided (Color/BW): 2.4/4
SEND SPECIFICATIONS
DESTINATION
Email (SMTP), SMB, Super G3 FAX
ADDRESS BOOK
Local (50)
SEND RESOLUTION (dpi)
300 x 300
COMMUNICATION PROTOCOL
File: SMB; Email: SMTP, POP3
FILE FORMAT
TIFF, JPEG, PDF (Compact, Searchable)
FAX SPECIFICATIONS
MODEM SPEED
Super G3: 33.6 kbps
G3: 14.4 kbps
RESOLUTION (dpi)
200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE
Statement to Letter
FAX MEMORY
Up to 256 Pages
SPEED DIALS
Max. 104
GROUP DIALS / DESTINATIONS
Max. 50 Dials
SEQUENTIAL BROADCAST
Max. 114 Addresses
FAX FEATURES
Rx Mode, Resolution, Two-sided Original, Density, Sharpness, Duplex Fax
SECURITY SPECIFICATIONS
NETWORK
IP/MAC Address Filtering, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication Before SMTP
WI-FI® AUTHENTICATION METHODS
WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT
Temperature: 50 to 86º F;
Humidity: 20 to 80% RH (no condensation)
POWER CONSUMPTION
Maximum: Approx. 1080 W or Less;
Average: Approx. 340 W;
Sleep Mode: Approx. 0.7 W;
Typical Electricity Consumption (TEC) Rating: 0.9 kWh
STANDARDS
ENERGY STAR® Qualified, Rated EPEAT Silver1
FOOTNOTES
1 For latest EPEAT ratings (Gold/Silver/Bronze), please visit www.epeat.net.
2 Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
3 Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
4 Warranty program is subject to certain conditions and restrictions. See warranty card for details.
5 Replacement model may be new or refurbished quality.
CANON imageCLASS SERIES EXCHANGE/CARRY-IN PRODUCT LIMITED WARRANTY
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of two years after delivery to the original purchaser ("Purchaser") by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider ("Service Provider"), to, without charge, repair, or replace any defective part with a new or comparable rebuilt part, or exchange the Product with a new or refurbished Product. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions and the latest driver and firmware downloads available at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday (excluding holidays).
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Support | Service Notice: Canon Laser Printer & Small Office Multifunctional Printer IP Stack protocol
Advisory Type
Date 09.29.20
Title Canon Support | Service Notice: Laser Printer & Small Office Multifunctional Printer cross-site scripting
Advisory Type
Date 12.30.21
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
Advisory Type
Date 03.29.15
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
