Canon Support for imageCLASS MF426dw | Canon U.S.A., Inc.
imageCLASS MF426dw
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 12.20.23
File Size 476.17 KB
Date 12.24.20
File Size 2.92 MB
Date 08.27.25
File Size 1.32 MB
Date 09.25.23
File Size 1.20 MB
Date 09.17.24
File Size 2.27 MB
Date 01.31.23
File Size 144.76 KB
Date 09.01.25
File Size 2.27 MB
Date 09.25.23
File Size 1.20 MB
Date 09.17.24
File Size 1.20 MB
Date 04.24.19
File Size 815.66 KB
Date 07.20.23
File Size 405.58 KB
Date 03.01.18
File Size 407.86 KB
Date 04.24.19
File Size 647.96 KB
Date 01.31.23
File Size 2.92 MB
Date 04.20.22
File Size 1.50 MB
Date 04.04.19
File Size 645.16 KB
Date 03.01.18
File Size 6.03 MB
Date 09.30.21
File Size 1.50 MB
Date 10.04.19
File Size 815.82 KB
Date 09.17.24
File Size 1.20 MB
Date 02.04.20
File Size 652.13 KB
Date 03.24.23
File Size 1.60 MB
Date 09.25.23
File Size 2.27 MB
Date 10.12.22
File Size 1.59 MB
Date 12.20.23
File Size 1.32 MB
Date 04.24.19
File Size 2.92 MB
Date 09.17.24
File Size 1.32 MB
Date 10.04.19
File Size 2.92 MB
Date 04.27.23
File Size 2.27 MB
Date 07.20.23
File Size 154.27 KB
Date 02.04.20
File Size 649.44 KB
Date 12.24.20
File Size 819.56 KB
Date 12.24.20
File Size 649.44 KB
Date 04.27.23
File Size 1.72 MB
Date 07.13.21
File Size 652.14 KB
Date 01.31.23
File Size 1.63 MB
Date 04.27.23
File Size 460.45 KB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
imageCLASS MF426dw
Products High Sierra V10.13 Mojave V10.14 Catalina V10.15 Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15
imageCLASS MF426dw
imageCLASS MF426dw / MF424dw Spec Sheet
MAIN UNIT
TYPEBlack and White Laser Multifunctional
CORE FUNCTIONSStandard: Print, Copy, Scan, Send, Fax
PROCESSORCanon Custom Processor
CONTROL PANEL5" Color Touch-panel
MEMORY1GB
STANDARD INTERFACE CONNECTIONUSB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000 Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection
PAPER CAPACITY (LTR, 20LB BOND)Standard: 350 Sheets
Maximum: 900 Sheets
PAPER SOURCES (LTR, 20LB BOND)
Standard: 250-sheet Paper Cassette, 100-sheet
Stack Bypass
Optional: 550-sheet Paper Cassettes (Cassette Unit-AH1)
PAPER OUTPUT CAPACITY (LTR, 20LB BOND)Standard: 65 Sheets
SUPPORTED MEDIA TYPES
Cassettes: Thin, Plain, Recycled, Thick, Bond
Stack Bypass: Thin, Plain, Recycled, Thick, Bond, Label, Envelope (10 Envelopes)
SUPPORTED MEDIA SIZES
Cassettes: Letter, Legal, Statement, Executive
Custom (Min. 4.1" x 5.8" to Max. 8.5" x 14")
Stack Bypass: Letter, Legal, Statement, Executive
Envelope: COM10, Monarch, C5, DL
Custom (Min. 3" x 5" to Max. 8.5" x 14")
SUPPORTED MEDIA WEIGHTS
Cassettes: 14.0 lb. Bond to 32.0 lb. Bond (52 to 120 g/m2)
Stack Bypass: 14.0 lb. Bond to 43.0 lb. Bond (52 to 163 g/m2)
WARM-UP TIMEFrom Power On: 14 Seconds or less
From Sleep Mode: 4 Seconds or less
DIMENSIONS (W x D x H)Standard (Desktop): 17.9" x 18.3" x 15.5" (453 mm x 464 mm x 392 mm)
INSTALLATION SPACE (W x D x H)
Standard (Desktop): 19.5" x 35.7" x 28.6" (453 mm x 883 mm x 664 mm)
Fully Configured: 19.5" x 35.7" x 43.9" (453 mm x 883 mm x 795 mm)
WEIGHTMachine Only: Approx. 35.8 lb. (16.2 kg)
Boxed Weight: Approx. 45.9 lb. (20.8 kg)
PRINT SPECIFICATIONS
PRINTING METHODLaser Beam Printing
PRINT SPEED2Up to 40 ppm (Letter); Up to 32 ppm (Legal)
FIRST PRINT-OUT-TIMEApproximately 6 seconds
RECOMMENDED MONTHLY PAGE VOLUME500 - 4,000 Pages
PRINT RESOLUTION (dpi)600 x 600
STANDARD PAGE DESCRIPTION LANGUAGESUFR II, PCL®6, PCL®5, Adobe PostScript 3® (MF426dw only)
DOUBLE SIDED PRINTINGAutomatic (Standard)
DIRECT PRINTAvailable from USB memory (JPEG, TIFF, PDF)
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES5Apple® AirPrint,® Canon PRINT Business, Mopria™ Print Service, Google Cloud Print,™4
FONTSPCL fonts: 45 Fonts
PS fonts: 136 Fonts (MF426dw only)
OPERATING SYSTEMUFR II/PCL/PS:
Windows®7 / Windows 8.1 / Windows 10 / Windows Server2008 / Windows Server2008 R2 / Windows Server2012 / Windows Server2012 R2 / Windows Server2016
Mac OS X v10.8.5 (or later)
COPY SPECIFICATIONS
COPY SPEEDUp to 40 ppm (Letter); Up to 32 ppm (Legal)
FIRST-COPY-OUT-TIME (LETTER)As fast as 6.0 seconds
COPY RESOLUTION (dpi)600 x 600
COPY SIZEPlaten: Up to Letter
ADF: Up to Legal
MULTIPLE COPIESUp to 999 Copies
MAGNIFICATION25% - 400% (1% Increments)
PRESET REDUCTIONS25%, 50%, 64%, 78%
PRESET ENLARGEMENTS129%, 200%, 400%
COPY FEATURESPaper Setting, Favorite Settings, Two-sided, Original Type Selection, Cancel, N-on-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card
SCAN SPECIFICATIONS
TYPESingle-Pass Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY50 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZESLegal, Letter, Statement
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTSSingle and Double-sided scanning: 13-28 lb. Bond (50-105 g/m2)
PLATEN ACCEPTABLE ORIGINALSSheet, Book
PULL SCANScanGear MF for TWAIN, WIA, and ICA
SUPPORTED OSWindows 7 / Windows 8.1 / Windows 10 / Windows Server2008 / Windows Server2008 R2 / Windows Server2012 / Windows Server2012 R2 / Windows Server2016 / Mac OS X v10.8.5 (or later)
SCAN RESOLUTION (dpi)300 x 600, 600 x 600
SCAN TO MOBILE DEVICESCanon PRINT Business
SCAN SPEED (LETTER)Single-sided: 13/38 ipm (300 x 600 dpi) (Color/BW)
Double-sided: 26/70 ipm (300 dpi) (Color/BW)
MEMORY MEDIAStandard USB Memory (JPEG, TIFF, PDF)
SEND SPECIFICATIONS
DESTINATIONEmail/Internet FAX (SMTP), SMB, FTP, Super G3 FAX
ADDRESS BOOKLDAP (50)/Local (300)/Speed dial (281)
SEND RESOLUTION (dpi)600 x 600 (Pull Scan), 196 x 204 (iFax), 300 x 300 (Other)
COMMUNICATION PROTOCOLFile: FTP, SMB
E-mail/I-Fax: SMTP, POP3, iFax (Simple)
FILE FORMATStandard: TIFF, JPEG, PDF (Compact, Searchable)
FAX SPECIFICATIONS
MODEM SPEEDSuper G3: 33.6 kbps
G3: 14.4 kbps
COMPRESSION METHODMH, MR, MMR, JBIG
RESOLUTION (dpi)400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZEStatement to Legal
FAX MEMORYUp to 512 Pages
SPEED DIALSMax. 281
GROUP DIALS / DESTINATIONSMax. 299 dials
SEQUENTIAL BROADCASTMax. 310 Addresses
MEMORY BACKUPYes
FAX FEATURESRX Mode, Resolution, Two-sided Original, Density,
Sharpness, Favorite Settings, Duplex Fax
SECURITY SPECIFICATIONS
AUTHENTICATION
Standard: Department ID Authentication
NETWORKStandard: IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP
DOCUMENTStandard: Secure Print
WI-FI AUTHENTICATION METHODS
Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
Wi-Fi Access Point: WPA2-PSK (AES)
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENTTemperature: 50 to 86º F
Humidity: 20 to 80% RH (no condensation)
POWER REQUIREMENTSAC 120-127 V:6.5 A, 60 Hz
POWER CONSUMPTIONMaximum: Approx. 1320 W
Standby: Approx. 10 W
Sleep Mode: Approx. 0.9 W
Typical Electricity Consumption (TEC) Rating: 1.3 kWh
STANDARDSENERGY STAR® Qualified, Rated EPEAT Silver
FOOTNOTES
1 For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
2 Print speed is based on internal testing. Print speed may vary depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
3 Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
4 Subscription to a third-party cloud service required. Subject to third-party cloud service providers’ terms and conditions.
5 Warranty program is subject to certain conditions and restrictions. See warranty card for details.
PRODUCT LIMITED WARRANTY
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of three years after delivery to the original purchaser ("Purchaser") by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider ("Service Provider"), to, without charge, repair, or replace any defective part with a new or comparable rebuilt part, or exchange the Product with a new or refurbished Product. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions and the latest driver and firmware downloads available at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday (excluding holidays).
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Advisory Type
Date 03.29.15
Title Service Notice: Vulnerabilities Remediation Against Buffer Overflow for Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printers
Advisory Type Service Notice
Date 04.19.23
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
