Canon Support for imageCLASS MF451dw | Canon U.S.A., Inc.
imageCLASS MF451dw
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
SELECT ERROR CODE
WINDOWS
macOS X
ChromeOS
Products | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 |
Products | ChromeOS |
imageCLASS MF451dw | |
MAIN UNIT | |
CORE FUNCTIONS | Print/Scan/Copy |
ITEM CODE | 5161C013 |
PROCESSOR | Canon Custom Processor |
CONTROL PANEL | 5" Color Touch Panel |
MEMORY | 1 GB |
STANDARD INTERFACE CONNECTION | USB 2.0 High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection |
PAPER CAPACITY (LETTER, 20 LB. BOND) | Standard: 350 Sheets |
PAPER SOURCES (LETTER, 20 LB. BOND) | Standard: 250-sheet Paper Cassette, 100-sheet Multipurpose Tray |
SUPPORTED MEDIA TYPES | Cassettes: Thin, Plain, Recycled, Thick, Bond |
SUPPORTED MEDIA SIZES | Cassettes: Letter, Legal, Statement, ExecutiveCustom (Min. 4.1" x 5.8" to Max. 8.5" x 14") |
SUPPORTED MEDIA WEIGHTS | Cassettes: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2) |
WARM-UP TIME | From Power On: 14 Seconds or Less |
DIMENSIONS (W x D x H) | Standard (Desktop):17.8" x 18.3" x 15.4"(453 mm x 464 mm x 392 mm) |
INSTALLATION SPACE (W x D x H) | Standard (Desktop): 17.9" x 34.8" x 26.2" (453 mm x 883 mm x 664 mm) |
WEIGHT 4 | Unit:Approx. 35.7 lb. (16.2 kg) |
OPERATING SYSTEM | UFR II/PCL/PS: Windows® 8.1/10, Windows Server 2012 R2/2016/2019, Mac OS X v10.11 (or later) |
PRINT SPECIFICATIONS | |
PRINTING METHOD | Laser Beam Printing |
PRINT SPEED5 | Up to 34 ppm (Letter); Up to 32.4 ppm (Legal) |
FIRST PRINT OUT TIME | Approx. 5.4 Seconds |
RECOMMENDED MONTHLY PAGE VOLUME | 750 - 4,000 Pages |
PRINT RESOLUTION (dpi) | 600 x 600 dpi |
STANDARD PAGE DESCRIPTION LANGUAGES | UFR II, PCL®6, PCL®5, Adobe PostScript 3® |
DOUBLE-SIDED PRINTING | Automatic (Standard) |
DIRECT PRINT | Available from USB Memory (JPEG, TIFF, PDF) |
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES3 | Apple® AirPrint®, Canon PRINT Business1, Mopria™Print Service |
FONTS | PCL: 45 Fonts |
PRINT FEATURES | Secured Watermark, Header/Footer, Page Layout,Two-sided Printing, Mixed Paper Sizes, Orientations,Toner Reduction, Poster Printing, Print Date, Collating, Grouping, Page Border,6 Booklet Printing6 |
COPY SPECIFICATIONS | |
COPY SPEED | 40 ppm (Letter) |
FIRST-COPY-OUT-TIME (LETTER) | Approximately 6.2 Seconds |
COPY RESOLUTION | 600 x 600 dpi |
COPY SIZE | Platen: Up to Letter |
MULTIPLE COPIES | Up to 999 Copies |
MAGNIFICATION | 25% - 400% (1% Increments) |
PRESET REDUCTIONS | 25%, 50%, 64%, 78% |
PRESET ENLARGEMENTS | 129%, 200%, 400% |
COPY FEATURES | Preset R/E Ratios by Area, Two-Sided, Density Adjustment, Original Type Selection, Two-sided Original, Sort, N on 1, Different Size Originals, Sharpness, Erase Frame, Copy ID Card, Copy Passport, Paper Settings, Favorite Settings, Cancel, Collate |
SCAN SPECIFICATIONS | |
TYPE | Single-Pass Duplexing Automatic Document Feeder |
DOCUMENT FEEDER PAPER CAPACITY | 50 Sheets (20 lb. Bond) |
DOCUMENT FEEDER SUPPORTED MEDIA SIZES | Legal, Letter, Statement |
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS | Single and Double-sided scanning: 13-28 lb.Bond (50-105 g/m2) |
PLATEN ACCEPTABLE ORIGINALS | Sheet, Book |
PULL SCAN | ScanGear MF for TWAIN, WIA, and ICA |
SCAN RESOLUTION | Up to 600 x 600 |
SCAN TO MOBILE DEVICES | Canon PRINT Business |
SCAN SPEED (LETTER) | Single-sided: 13/38 ipm (300 x 300 dpi) (Color/BW) |
MEMORY MEDIA | Standard USB Memory (JPEG, TIFF, PDF) |
SEND SPECIFICATIONS | |
DESTINATION | Email/Internet FAX (SMTP), SMB, FTP, Super G3 FAX |
ADDRESS BOOK | LDAP (50)/Local (300)/Speed Dial (281) |
SEND RESOLUTION (DPI) | 300 x 300 |
COMMUNICATION PROTOCOL | File:FTP, SMBEmail/iFax:SMTP, POP3, iFax (Simple) |
FILE FORMAT | Standard:TIFF, JPEG, PDF (Compact, Searchable) |
SECURITY SPECIFICATIONS | |
AUTHENTICATION | Standard:Department ID Authentication |
DATA | Standard:Verify System at Startup |
NETWORK | Standard:IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.11b/g/n, IPv6, SMTP Authentication, POP Authentication before SMTP |
DOCUMENT | Standard:Secure Print, Searchable PDF |
WI-FI AUTHENTICATION METHODS | Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES) |
ENVIRONMENTAL SPECIFICATIONS | |
OPERATING ENVIRONMENT | Temperature: 50 to 86º F |
POWER REQUIREMENTS | AC 120-127 V:5.9 A, 60 Hz |
POWER CONSUMPTION | Maximum:Approx. 1330 W |
STANDARDS | ENERGY STAR® Qualified, Currently Rated EPEAT Silver2 |
CONSUMABLES | |
TONER | Cartridge 057 - Yields up to 3,100 Pages (In-box toner) |
PRODUCT LIMITED WARRANTY
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
