Canon Support for imageCLASS MF453dw | Canon U.S.A., Inc.
        imageCLASS MF453dw
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
 - Windows 10 (x64)
 - Windows 10
 - Windows 8.1 (x64)
 - Windows 8.1
 - Windows 8 (x64)
 - Windows 8
 - Windows 7 (x64)
 - Windows 7
 - Windows Vista (x64)
 - Windows Vista
 - Windows Me
 - Windows XP (x64)
 - Windows XP
 - Windows 98
 - Windows 95
 - Windows Server 2022
 - Windows Server 2019 (x64)
 - Windows Server 2016 (x64)
 - Windows Server 2012 (x64)
 - Windows Server 2008 (x64)
 - Windows Server 2003 (x64)
 - Windows Server 2003 R2
 - macOS Tahoe v26
 - macOS Sequoia v15
 - macOS Sonoma v14
 - macOS Ventura v13
 - macOS Monterey v12
 - macOS Big Sur v11.0
 - macOS Catalina v10.15
 - macOS Mojave v10.14
 - macOS High Sierra v10.13
 - macOS Sierra v10.12
 - OS X El Capitan v10.11
 - OS X Yosemite v10.10
 - OS X Mavericks v10.9
 - OS X Mountain Lion v10.8
 - OS X Lion v10.7
 - Mac OS X Snow Leopard v10.6
 - Mac OS X v10.1
 - Mac OS 9
 - Linux ARM
 - Linux MIPS
 - Linux 64bit
 - Linux 32bit
 - SAP
 - Windows Server 2025
 - Windows NT
 - Linux
Canon PRINT - iOS
Canon PRINT - Android
SELECT ERROR CODE
                                WINDOWS
                                macOS X
                                ChromeOS
| Products | Windows 7 | Windows 8 | Windows 10 | Windows 10s | Windows 11 |
| Products | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 | Tahoe 26 |
| Products | ChromeOS |
imageCLASS MF453dw | |
MAIN UNIT  | |
| CORE FUNCTIONS | Print/Scan/Copy  |
| ITEM CODE | 5161C011  |
| PROCESSOR | Canon Custom Processor  |
| CONTROL PANEL | 5" Color Touch Panel  |
| MEMORY | 1 GB  |
| STANDARD INTERFACE CONNECTION | USB 2.0 High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection  |
PAPER CAPACITY (LETTER, 20 LB. BOND)  | Standard: 350 Sheets   |
| PAPER SOURCES (LETTER, 20 LB. BOND) | Standard: 250-sheet Paper Cassette, 100-sheet Multipurpose Tray   |
| SUPPORTED MEDIA TYPES | Cassettes: Thin, Plain, Recycled, Thick, Bond   |
SUPPORTED MEDIA SIZES  | Cassettes: Letter, Legal, Statement, ExecutiveCustom (Min. 4.1" x 5.8" to Max. 8.5" x 14")   |
| SUPPORTED MEDIA WEIGHTS | Cassettes: 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2)   |
| WARM-UP TIME | From Power On: 14 Seconds or Less   |
| DIMENSIONS (W x D x H) | Standard (Desktop):17.8" x 18.3" x 15.4"(453 mm x 464 mm x 392 mm)  |
| INSTALLATION SPACE (W x D x H) | Standard (Desktop): 17.9" x 34.8" x 26.2" (453 mm x 883 mm x 664 mm)  |
| WEIGHT 4 | Unit:Approx. 35.7 lb. (16.2 kg)   |
| OPERATING SYSTEM | UFR II/PCL/PS: Windows® 8.1/10, Windows Server 2012 R2/2016/2019, Mac OS X v10.11 (or later)  |
PRINT SPECIFICATIONS  | |
| PRINTING METHOD | Laser Beam Printing  |
| PRINT SPEED5 | Up to 40 ppm (Letter); Up to 32.4 ppm (Legal)  |
| FIRST PRINT OUT TIME | Approx. 5.4 Seconds  |
| RECOMMENDED MONTHLY PAGE VOLUME | 750 - 4,000 Pages  |
| PRINT RESOLUTION (dpi) | 600 x 600 dpi  |
| STANDARD PAGE DESCRIPTION LANGUAGES | UFR II, PCL®6, PCL®5, Adobe PostScript 3®  |
| DOUBLE-SIDED PRINTING | Automatic (Standard)  |
| DIRECT PRINT | Available from USB Memory (JPEG, TIFF, PDF)  |
| PRINTING FROM MOBILE AND CLOUD-BASED SERVICES3 | Apple® AirPrint®, Canon PRINT Business, Mopria™Print Service  |
| FONTS | PCL: 45 Fonts  |
| PRINT FEATURES | Secured Watermark, Header/Footer, Page Layout,Two-sided Printing, Mixed Paper Sizes, Orientations,Toner Reduction, Poster Printing, Print Date, Collating, Grouping, Page Border,6 Booklet Printing6  |
COPY SPECIFICATIONS  | |
| COPY SPEED | 40 ppm (Letter)  |
| FIRST-COPY-OUT-TIME (LETTER) | Approximately 6.2 Seconds  |
| COPY RESOLUTION | 600 x 600 dpi  |
| COPY SIZE | Platen: Up to Letter   |
| MULTIPLE COPIES | Up to 999 Copies  |
| MAGNIFICATION | 25% - 400% (1% Increments)  |
| PRESET REDUCTIONS | 25%, 50%, 64%, 78%  |
| PRESET ENLARGEMENTS | 129%, 200%, 400%  |
| COPY FEATURES | Preset R/E Ratios by Area, Two-Sided, Density Adjustment, Original Type Selection, Two-sided Original, Sort, N on 1, Different Size Originals, Sharpness, Erase Frame, Copy ID Card, Copy Passport, Paper Settings, Favorite Settings, Cancel, Collate  |
SCAN SPECIFICATIONS  | |
| TYPE | Single-Pass Duplexing Automatic Document Feeder  |
| DOCUMENT FEEDER PAPER CAPACITY | 50 Sheets (20 lb. Bond)  |
| DOCUMENT FEEDER SUPPORTED MEDIA SIZES | Legal, Letter, Statement  |
| DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS | Single and Double-sided scanning: 13-28 lb.Bond (50-105 g/m2)  |
| PLATEN ACCEPTABLE ORIGINALS | Sheet, Book  |
| PULL SCAN | ScanGear MF for TWAIN, WIA, and ICA  |
| SCAN RESOLUTION | Up to 600 x 600  |
| SCAN TO MOBILE DEVICES | Canon PRINT Business  |
| SCAN SPEED (LETTER) | Single-sided: 13/38 ipm (300 x 300 dpi) (Color/BW)   |
| MEMORY MEDIA | Standard USB Memory (JPEG, TIFF, PDF)  |
SEND SPECIFICATIONS  | |
| DESTINATION | Email/Internet FAX (SMTP), SMB, FTP, Super G3 FAX  |
| ADDRESS BOOK | LDAP (50)/Local (300)/Speed Dial (281)  |
| SEND RESOLUTION (DPI) | 300 x 300  |
| COMMUNICATION PROTOCOL | File:FTP, SMBEmail/iFax:SMTP, POP3, iFax (Simple)  |
| FILE FORMAT | Standard:TIFF, JPEG, PDF (Compact, Searchable)  |
SECURITY SPECIFICATIONS  | |
| AUTHENTICATION | Standard:Department ID Authentication  |
| DATA | Standard:Verify System at Startup  |
| NETWORK | Standard:IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.11b/g/n, IPv6, SMTP Authentication, POP Authentication before SMTP  |
| DOCUMENT | Standard:Secure Print, Searchable PDF  |
| WI-FI AUTHENTICATION METHODS | Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)   |
ENVIRONMENTAL SPECIFICATIONS  | |
| OPERATING ENVIRONMENT | Temperature: 50 to 86º F   |
| POWER REQUIREMENTS | AC 120-127 V:5.9 A, 60 Hz  |
| POWER CONSUMPTION | Maximum:Approx. 1330 W    |
| STANDARDS | ENERGY STAR® Qualified, Currently Rated EPEAT Silver2  |
CONSUMABLES  | |
| TONER | Cartridge 057 - Yields up to 3,100 Pages (In-box toner)  |
PRODUCT LIMITED WARRANTY
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of three years after delivery to the original purchaser ("Purchaser") by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider ("Service Provider"), to, without charge, repair, or replace any defective part with a new or comparable rebuilt part, or exchange the Product with a new or refurbished Product. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions and the latest driver and firmware downloads available at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday (excluding holidays).
Cartridge Warranty
 ** In Canada
CAUTION:
Click here to download the Warranty Card.
 next to your download
