Canon Support for imageCLASS MF4880dw | Canon U.S.A., Inc.
imageCLASS MF4880dw
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 05.16.13
File Size 9.95 MB
Date 05.16.13
File Size 1.48 MB
Date 09.22.17
File Size 2.92 MB
Date 12.24.20
File Size 2.92 MB
Date 09.12.25
File Size 1.32 MB
Date 09.17.24
File Size 2.27 MB
Date 09.12.25
File Size 1.20 MB
Date 12.22.17
File Size 809.44 KB
Date 09.25.23
File Size 1.20 MB
Date 04.24.19
File Size 815.66 KB
Date 09.12.25
File Size 2.27 MB
Date 04.24.19
File Size 647.96 KB
Date 01.31.23
File Size 2.92 MB
Date 04.20.22
File Size 1.50 MB
Date 10.04.19
File Size 815.82 KB
Date 09.17.24
File Size 1.20 MB
Date 02.04.20
File Size 652.13 KB
Date 03.24.23
File Size 1.60 MB
Date 09.25.23
File Size 2.27 MB
Date 10.04.19
File Size 2.92 MB
Date 12.20.23
File Size 1.32 MB
Date 04.24.19
File Size 2.92 MB
Date 04.27.23
File Size 2.27 MB
Date 09.17.24
File Size 1.32 MB
Date 12.24.20
File Size 819.56 KB
Date 07.13.21
File Size 652.14 KB
Date 01.31.23
File Size 1.63 MB
Date 12.22.17
File Size 647.92 KB
Date 04.27.23
File Size 1.72 MB
Date 05.16.13
File Size 2.41 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Initial Setup
Setting up additional computers
Finding your Network Key/Password
Re-establishing Printer Connection After A Network Change?
Need additional information or assistance?
imageCLASS MF4880dw
Products High Sierra V10.13 Mojave V10.14 Catalina V10.15 Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15
imageCLASS MF4880dw
Printer Specifications
Printer Type Monochrome Laser
Print Speed Up to 16ppm (2-sided plain paper letter)1
Up to 26ppm (1-sided plain paper letter)1
First Print Time 5.8 seconds or less (letter)2
Printer Language UFR II LT (Host-based)
Print Resolution Up to 600 x 600 dpi
(1200 x 600 dpi quality)
Maximum Print Size Up to Legal
Duplex Print Yes
Print Modes Watermark, Toner Saver, Page Composer
Print Memory 128 MB (Shared)
Copier Specifications
Copy Type Monochrome Laser
Copy Speed Up to 26cpm (letter)
Copy Resolution Up to 600 x 600 dpi
Original Type Text, Text/Photo, Text/Photo+, Photo
Halftones 256 Levels
Warm-up Time Approximately 13.5 seconds
First Copy Time Approximately 8.7 seconds3
Recovery Time Approximately 2 seconds
Maximum Number of Copies 99 copies
Reduction/Enlargement 25%, 50%, 64% 78%129%, 200%, 400%
Zoom 25 - 400% in 1% increments
Copy Size Platen: Up to Letter
ADF: 5.8" x 4.1" to Legal
Copy Features Collate
2 on 1
4 on 1
ID Card Copy
Copy Memory 128 MB (Shared)
Fax Specifications
Modem Speed Up to 33.6 Kbps (Super G3)4
Fax Resolution Up to 200 x 400 dpi (super fine)
Transmission Time JBIG (approx. 3 seconds)
Memory Capacity Up to 256 sheets5
Speed Dials 4 one-touch speed dials
100 coded dials
Group Dialing 103 destinations
Sequential Broadcasting 114 destinations
Receive Modes FAX Only, Manual, Answering, Fax/Tel Auto Switch
Fax Features Remote RX, Dual Access, Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial
Activity Reports Activity Result & Activity Management
pC Fax Sending only
Fax Forwarding (FAX -> FAX)
Scanner Specifications
Scan Type Color Contact Image Sensor (CIS)
Color Depth 24-bit
Scan Resolution Up to 600 x 600 dpi (optical)
9600 x 9600 (interpolated)
Scan Size Platen: Up to Letter
Compatibility TWAIN, WIA
Output File Formats Hi-Compression PDF (Windows only), Searchable PDF (Windows only), PDF, JPEG, TIFF, BMP, PNG6
Scan Features Rotate Image
Pull Scan USB and Network
Push Scan (Scan to pC) USB and Network
Paper Handling Specifications
Standard Paper Source(s) 250-sheet cassette plus 1-sheet multipurpose tray7
Document Feeder 35-sheet simplex7
Paper Output 100 sheets (face down)
Paper Weight 16-43 lb. bond (cassette)
16-43 lb. bond (multipurpose tray)
Media Sizes Letter, Legal, A4, A5, B5, Statement, Executive
Media Types Plain Paper, Heavy Paper, Recycled, Transparency, Label, Envelope
Envelope Capacity 20 envelopes
Envelope Types Com 10, Monarch, DL, C5
Connectivity and Software Specifications
Standard Interface(s) USB Device 2.0 Hi-Speed8, 10/100 Base-T Ethernet, 802.11 b/g/n Wireless9
WiFi Access Mode Infrastructure Mode
WiFi Authentication Methods Open System, Shared Key, WPA-PSK, WPA2-PSK
WiFi Encryption Modes WEP (64/128 bit), TKIP, AES
WPS Easy Setup Support Methods Push-button mode, PIN code mode
Mobile Functions Print
Network Functions Print, PC Fax and Scan
Embedded Web Server (Remote UI) Yes
Web Browser Support for Remote UI Microsoft Internet Explore 6.0 or higher, Safari 3.2.1 or higher
Print Protocols LPD, RAW, WSD-Print (IPv4,IPv6)
TCP/IP Set of Application Services DHCP, BOOTP, RARP, Auto IP (IPv4), Bonjour(mDNS), DHCPv6 (IPv6)
Network Management Protocols SNMPv1 (IPv4,IPv6)
MIB RFC1213 (MIB-II), RFC1514 (Host Resources MIB), RFC1759 (Printer MIB), Canon MIB
OS Compatibility Windows&reg; 8, Windows 7, Windows Server&reg; 2008 R2, Windows Server&reg; 2008, Windows Vista&reg;, Windows Server 2003, Windows XP, Mac OS X 10.5.8 and up
Cable Included Power Cord (USB not included)
Bundled Software Printer driver, Fax driver, Scanner driver, MF Toolbox, AddressBook Tool, Presto! PageManager, SSID Tool
Environmental Specifications
Power Consumption Max: Approx. 1,110W
During Operation: Approx. 520W
Standby: Approx. 5W
Energy Saver: Approx. 2.1W
Typical Energy Consumption 0.8kWh
General Specifications
Dimensions 15.4" (W) x 14.3" (D) x 14.2" (H)
Unit Weight (without/with cartridge) 26.7 lbs. (w/o cartridge)
28.0 lbs. (w/cartridge)
Package Weight Approx. 37.0 lbs.
Cartridge Type Cartridge 128 (Yields approximately 2,100 pages)
Single Cartridge System
*Yields based on ISO/IEC Standard
LCD Display 5-row backlit LCD
Duty Cycle Up to 10,000 pages per month
Security IP Filtering, MAC Address Filtering
Languages English, French, Spanish, Portuguese
Warranty 1 year limited exchange/carry-in warranty10 (Extended warranty available)
CANON imageCLASS SERIES EXCHANGE/CARRY-IN PRODUCT LIMITED WARRANTY
The limited warranty set forth below is given by Canon U.S.A., Inc. ('Canon USA') with respect to the Canon imageCLASS Series product and accessories packaged with this limited warranty (collectively, the 'Product') when purchased and used in the United States.
CARTRIDGES FOR THE PRODUCT (EXCEPT THE CARTRIDGE BUNDLED WITH THE PRODUCT, FOR WHICH THERE IS NO WARRANTY) ARE COVERED BY A SEPARATE WARRANTY. ACCORDINGLY, THIS LIMITED WARRANTY DOES NOT COVER ANY CARTRIDGES FOR THE PRODUCT, WHETHER SHIPPED WITH THE PRODUCT OR PURCHASED THEREAFTER.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE CD-ROM'S ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD 'AS IS' AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
Click Here to download the Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Support | Service Notice: Windows Scanning for imageCLASS
Advisory Type
Date 07.11.16
Title Canon Support | Service Notice: Canon Laser Printer & Small Office Multifunctional Printer IP Stack protocol
Advisory Type
Date 09.29.20
Title Canon Support | Service Notice: Laser Printer & Small Office Multifunctional Printer cross-site scripting
Advisory Type
Date 12.30.21
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
