Canon Support for imageCLASS MF525dw | Canon U.S.A., Inc.
imageCLASS MF525dw
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 12.20.23
File Size 476.17 KB
Date 12.24.20
File Size 2.92 MB
Date 08.27.25
File Size 1.32 MB
Date 09.25.23
File Size 1.20 MB
Date 09.17.24
File Size 2.27 MB
Date 01.31.23
File Size 144.76 KB
Date 03.01.18
File Size 23.72 MB
Date 09.25.23
File Size 1.20 MB
Date 09.17.24
File Size 1.20 MB
Date 04.24.19
File Size 815.66 KB
Date 07.20.23
File Size 405.58 KB
Date 03.01.18
File Size 407.86 KB
Date 04.24.19
File Size 647.96 KB
Date 01.31.23
File Size 2.92 MB
Date 04.20.22
File Size 1.50 MB
Date 04.04.19
File Size 645.16 KB
Date 09.30.21
File Size 1.50 MB
Date 10.04.19
File Size 815.82 KB
Date 09.17.24
File Size 1.20 MB
Date 02.04.20
File Size 652.13 KB
Date 03.24.23
File Size 1.60 MB
Date 09.25.23
File Size 2.27 MB
Date 10.12.22
File Size 1.59 MB
Date 12.20.23
File Size 1.32 MB
Date 04.24.19
File Size 2.92 MB
Date 09.17.24
File Size 1.32 MB
Date 10.04.19
File Size 2.92 MB
Date 04.27.23
File Size 2.27 MB
Date 07.20.23
File Size 154.27 KB
Date 03.01.18
File Size 6.05 MB
Date 02.04.20
File Size 649.44 KB
Date 12.24.20
File Size 819.56 KB
Date 12.24.20
File Size 649.44 KB
Date 04.27.23
File Size 1.72 MB
Date 07.13.21
File Size 652.14 KB
Date 01.31.23
File Size 1.63 MB
Date 04.27.23
File Size 460.45 KB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
imageCLASS MF525dw
Products High Sierra V10.13 Mojave V10.14 Catalina V10.15 Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15
imageCLASS MF525dw
Products ChromeOS
imageCLASS MF525dw
imageCLASS MF525dw Spec Sheet
imageCLASS MF525dw
MAIN UNIT
TYPEBlack and White Laser Multifunctional
CORE FUNCTIONSStandard: Print, Copy, Scan, Send, Fax
PROCESSOR SPEEDCanon Custom Processor 800MHz
CONTROL PANEL5" Color Touch-panel
MEMORY1GB
PAPER CAPACITY (LTR, 20LB BOND)Standard: 650 Sheets
Maximum: 2,300 Sheets
PAPER SOURCES (LTR, 20LB BOND)
Standard: 550-sheet Paper Cassette, 100-sheet
Stack Bypass
Optional (up to three): 550-sheet Paper Cassettes (Paper Feeder PF-C1)
PAPER OUTPUT CAPACITY (LTR, 20LB BOND)Standard: 150 Sheets
SUPPORTED MEDIA TYPES
Cassettes: Thin paper, Plain paper, Recycled paper,
Color paper, Thick paper, Bond paper
Stack Bypass: Thin paper, Plain paper, Recycled paper, Color paper, Thick paper, Bond paper, Label, Envelope (10 envelopes)
SUPPORTED MEDIA SIZES
Cassettes: Letter, Legal, Statement, Executive
Custom (Min. 4.1" x 5.8" to Max. 8.5" x 14")
Stack Bypass: Letter, Legal, Statement, Executive
Envelope: COM10, Monarch, C5, DL
Custom (Min. 3" x 5" to Max. 8.5" x 14")
SUPPORTED MEDIA WEIGHTS
Cassettes: 16.0 lb. Bond to 32 lb. Bond (52 to 120 g/m2)
Stack Bypass 16.0 lb Bond to 53 lb. Cover (52 to 199 g/m2)
WARM-UP TIMEFrom Power On: 14 Seconds or less
Quick Startup Mode: 4 Seconds or less
DIMENSIONS (W X D X H)Standard (Desktop): 19.5" x 18.3" x 17.8" (494 mm x 464 mm x 452 mm)
For full configuration options and dimensions, please refer to this document.
INSTALLATION SPACE (W X D X H)
Standard (Desktop): 19.5" x 35.7" x 28.6" (494 mm x 905 mm x 724 mm)
Fully Configured: 21.0" x 35.7" x 60.9" (534 mm x 905 mm x 1547 mm)
WEIGHTMachine Only: Approx. 41.9 lb. (19.0kg)
Machine, Cartridge and Box: Approx. 54.0 lb. (24.8 kg)
PRINT SPECIFICATIONS
PRINTING METHODLaser Beam Printing
PRINT SPEED4Up to 45 ppm (Letter); Up to 36 ppm (Legal)
FIRST PRINT-OUT-TIMEApproximately 6 seconds
RECOMMENDED MONTHLY PAGE VOLUME2,000-7,500 pages
PRINT RESOLUTION (dpi)600 x 600
STANDARD PAGE DESCRIPTION LANGUAGESUFR II, PCL6,® PCL5,® Adobe PostScript 3®
DOUBLE SIDED PRINTINGAutomatic (Standard)
DIRECT PRINTAvailable from USB memory (JPEG, TIFF, PDF)
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES5 Apple AirPrint, Canon PRINT Business, Mopria Print Service, Google Cloud Print,6 uniFLOW Secure Mobile Printing
FONTS PCL fonts: 93 fonts, Barcode fonts8
PS fonts: 136 fonts
OPERATING SYSTEM UFR II/PCL/PS:
Windows®7 / Windows®8.1 / Windows® 10/ Windows®Server2008 / Windows®Server2008 R2/ Windows®Server2012 / Windows®Server2012 R2/Windows®Server2016®
Mac OS X v10.8.5® (or later)
COPY SPECIFICATIONS
COPY SPEED Up to 45 ppm (Letter); Up to 36 ppm (Legal)
FIRST-COPY-OUT-TIME (LETTER)As fast as 6.0 seconds
COPY RESOLUTION (dpi)600 x 600
COPY SIZE Platen and ADF: Up to legal
MULTIPLE COPIESUp to 999 copies
MAGNIFICATION25% - 400% (1% Increments)
PRESET REDUCTIONS25%, 50%, 64%, 78%
PRESET ENLARGEMENTS129%, 200%, 400%
COPY FEATURESPaper Setting, Favorite Settings, Two-Sided, Density
Adjustment, Original Type Selection, Cancel, Two-sided
Original, N on 1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card
SCAN SPECIFICATIONS
TYPESingle-Pass Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY50 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZESLegal, Letter, Statement
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTSSingle and Double-sided scanning: 13-28 lb. Bond (50-105 g/m2)
PLATEN ACCEPTABLE ORIGINALSPlaten: Sheet, Book
PULL SCANScanGear MF for TWAIN, WIA and ICA
SUPPORTED OS Windows® 7 / Windows® 8.1 / Windows® 10 / Windows® Server2008 / Windows® Server2008 R2/ Windows® Server2012 / Windows® Server2012 R2 / Windows® Server2016®
SCAN RESOLUTION300 x 600 dpi, 600 x 600 dpi
SCAN TO MOBILE DEVICESCanon PRINT Business
SCAN SPEED (LETTER)Single-sided: 13/38 ipm (300 x 600 dpi) (Color/BW)
Double-Sided: 26/70 ipm (300 dpi) (Color/BW)
MEMORY MEDIA Standard: USB Memory (JPEG, TIFF, PDF)
SEND SPECIFICATIONS
DESTINATIONE-mail/Internet FAX (SMTP), SMB, FTP, Super G3 FAX
ADDRESS BOOKLDAP (50)/Local (300)/Speed dial (281)
SEND RESOLUTION600 x 600 dpi (PullScan), 196 x 204 dpi (IFAX),
300 x 300 dpi (Other)
COMMUNICATION PROTOCOLFile: FTP, SMB
E-mail/I-Fax: SMTP, POP3, I-Fax (Simple)
FILE FORMATStandard: TIFF, JPEG, PDF (Compact, Searchable)
Optional: PDF (Encrypted, Digital Signature)
FAX SPECIFICATIONS
MODEM SPEEDSuper G3: 33.6 kbps
G3: 14.4 kbps
COMPRESSION METHODMH, MR, MMR, JBIG
RESOLUTION (dpi)400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZEStatement to Legal
FAX MEMORYUp to 512 pages
SPEED DIALSMax. 281
GROUP DIALS / DESTINATIONSMax. 299 dials
SEQUENTIAL BROADCASTMax. 310 addresses
MEMORY BACKUPYes
FAX FEATURESRX Mode, Resolution, Two-sided Original, Density,
Sharpness, Favorite Settings, Duplex Fax
STANDARD INTERFACE CONNECTION USB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000 Base-T Ethernet (Network), Wi-Fi 802.11b/g /n, Wi-Fi®Direct Connection
SECURITY SPECIFICATIONS
AUTHENTICATION
Standard: Embedded Universal Login Manager, Department ID Authentication
Optional: uniFLOW, uniFLOW Online
NETWORKStandard: IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP
DOCUMENTStandard: Secure Print
Optional: Encrypted PDF, User and Device signatures
WI-FI AUTHENTICATION METHODS
Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
Wi-Fi Access Point: WPA2-PSK (AES)
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENTTemperature: 50 to 86º F
Humidity: 20 to 80% RH (no condensation)
POWER REQUIREMENTSAC120-127 V:7.1 A, 60 Hz
POWER CONSUMPTION Maximum: Approx. 1390 W
Standby: Approx. 17 W
Sleep Mode: Approx. 0.9 W
CARTRIDGECanon Cartridge 041 H (up to 20,000 pages)
FOOTNOTES
1 Please reference user manuals for details on settings available to export.
2 uniFLOW Scan not supported
3 Print speed is based on internal testing. Print speed may vary depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
4 Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
5 Subscription to a third-party cloud service required. Subject to third-party cloud service providers’ terms and conditions.
PRODUCT LIMITED WARRANTY
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Advisory Type
Date 03.29.15
Title Service Notice: Vulnerabilities Remediation Against Buffer Overflow for Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printers
Advisory Type Service Notice
Date 04.19.23
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
