Canon Support for imageFORMULA DR-3010C Office Document Scanner | Canon U.S.A., Inc.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
3010UM.pdf
File Name
3010RG.pdf
File Name
3010ESG.pdf
File Name
Flatbed Scanner Unit 101 User Manual
SELECT ERROR CODE
WINDOWS
Products | Windows 8 | Windows 10 | Windows 10s | Windows 11 |
Model Name | imageFORMULA DR-3010C Compact Workgroup Scanner |
Type | Compact Workgroup Scanner |
Document Feeding | Automatic or Manual |
Document Size Width | 2" - 8.5" |
Document Size Length | 2.1" - 14"*Document Weight Automatic Feeding: 14 - 54 lb. Bond Manual Feeding: 11 - 54 lb. Bond (Cards up to .03" thick) |
Feeder Capacity | 50 Sheets |
Grayscale | 8-bit |
Color | 24-bit |
Scanning Element | Contact Image Sensor (CMOS) |
Light Source | RGB LED |
Operating Modes | Simplex, Duplex, Color, Grayscale, Black and White, Error Diffusion, Advanced Text Enhancement (Two Types) |
Drop Out Color | Red, Green, Blue |
Optical Resolution | 600 dpi |
Output Resolution | 100/150/200/240/300/400/600 dpi |
Scanning Speeds
Black And White | 40 ppm / 80 ipm |
Grayscale | 40 ppm / 80 ipm |
Color 24 Bit | 30 ppm / 60 ipm |
Interface | Hi-Speed USB 2.0 |
Scanner Drivers | ISIS®/TWAIN for Windows® 2000,XP, Windows Vista® |
Dimensions | 7.8" x 12.2" x 11.5" |
Weight | 6.4 lb. |
Power Consumption | 18W or less (Energy Saving Mode: 4W or less) |
Other Features | Ultrasonic Double-Feed Detection Auto Color Detection Moire Reduction MultiStream Prevent Bleed Through/Remove Background User Registration Skip Blank Page Auto Paper Size Detection Deskew Batch Separation Text Orientation Recognition Edge Emphasis Folio BUNDLED SOFTWARE Canon CapturePerfect Canon CaptureOnTouch Nuance eCopy PDF Pro Office Nuance PaperPort SE Nuance OmniPage SE Presto! BizCard Kofax VRS Nocson EasyConnect (available via download from the Nocson website) |
Options | Flatbed Scanner Unit 101, Exchange Roller Kit, Barcode Module III, Soft Carrying Case, eCarePAK (Exchange Service)* 118" in Long Document Mode ** Examples based on typical settings, rated in pages/images per minute with letter-sized documents at 200 dpi, portrait-feeding direction. Actual processing speeds may vary based on PC performance and application. |
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
