Canon Support for imageFORMULA P-215II Mobile Document Scanner | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
WINDOWS
macOS X
Products | Windows 8 | Windows 10 | Windows 10s | Windows 11 |
Products | Sierra V10.12 | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 |
Model Name | imageFORMULA P-215II Scan-tini |
Type | Mobile Document Scanner |
Document Feeding | Automatic or Manual |
Document Size | Width: 2.0" - 8.5" Length: 2.8" - 14.0" |
Long Document Mode | Up to 39.4" |
Document Weight | Automatic Feeding: 14 - 34 lb. Bond |
Feeder Capacity | Up to 20 Sheets |
Grayscale | 8-bit |
Color | 24-bit |
Light Source | RGB LED |
Scanning Modes | Color, Grayscale, Black and White |
Optical Resolution | 600 dpi |
Output Resolution | 150/200/300/400/600 dpi |
Scanning Speeds | (Simplex/Duplex):* Black and White: 15 ppm / 30 ipm Grayscale: 15 ppm / 30 ipm Color: 10 ppm / 20 ipm |
Interface | USB 2.0, USB 3.0 |
Dimensions (H x W x D) | 1.6" x 11.0" x 3.7" (with trays closed) |
Weight | 2.2 lb. |
Power Consumption | 2.5 W -7 W** |
Suggested Daily Volume | Approximately 500 Scans*** |
Bundled Windows Software | ISIS/TWAIN Drivers, Canon CaptureOnTouch and CaptureOnTouch Lite (built-in), Cardiris |
Bundled Mac Software: | TWAIN Driver, Canon CaptureOnTouch and CaptureOnTouch Lite (built-in) |
Supported Operating Systems | Windows 8.1 (32bit/64bit), Windows 10 (32bit/64bit), Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Mac OS 10.13, Mac OS 10.14, Mac OS 10.15* |
Options | Carrying Case, eCarePAK Extended Service, Separation Pad, USB Cable, Canon CaptureOnTouch Mobile (available at the App Store or from the Google Play Store) |
Other Features | Automatic Color Detection, Automatic Page Size Detection, Automatic Resolution Setting, Background Smoothing, Character Emphasis, Color Dropout/ Red Color Enhance, Deskew, Double-Feed Detection, Duplex, Image Rotation, Long Document Mode, Moiré Reduction, MultiStream, Photograph Corrections, Pre-Scan, Prevent Bleed-Through/Remove Background, Shadow Cropping/Removal, Simplex, Skip Blank Page, Text Enhancement, Text Orientation Recognition, Three-Dimensional Color Correction, Trimming, User Preferences |
P150, P150M, DR-C125, DR-M160, DR-M140, P-215, P-208, DR-M160II, DR-C225, P-215II, DR-M1060, DR-F120, DR-C225W, P-208II
The limited warranty set forth below is given by Canon U.S.A., Inc. and Canon Canada, Inc. ("Canon") with respect to your Canon imageFORMULA DR Scanner Product packaged with this limited warranty (the "Product"). Canon warrants the Product and Canon-brand accessories designed for use with the Product to be free from defects in workmanship and material under normal use and service for a period of one-year after delivery to the original purchaser (“Purchaser”) by Canon or its authorized dealer or reseller. During the relevant warranty period, Canon shall, in its sole discretion and without charge, repair or replace any defective part with a new or comparable rebuilt part or exchange the Product with a new or rebuilt Product. Warranty replacement shall not extend the warranty period of the defective Product. This warranty shall not extend to consumables (such as feed rollers, separation rollers, etc.) as to which there shall be no warranty or replacement.
The Product covered by this Limited Warranty will be exchanged or repaired by Canon or an authorized service provider (the "Service Provider"). To arrange for service for the Product under warranty, please call:
In the United States:
Your local Service Provider; or call
1-800-423-2366, Monday through Friday from 8:00 a.m. to 8:00 p.m., E.T.
In Canada:
1-800-OK-CANON, Monday through Friday from 9:00 a.m. to 8:00 p.m., E.T.
If the Product malfunction is not covered by this Limited Warranty or the applicable warranty period has expired or has not been sufficiently established by appropriate documentation, you will be charged for such service at the then-current service call rates of Canon or the Service Provider.
This warranty shall only apply if this Product is used in conjunction with compatible computers, peripheral equipment and software, as to which items Canon shall have no responsibility. NON-CANON Brand COMPUTERS, PERIPHERAL EQUIPMENT and SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
THIS WARRANTY IS IN LIEU OF ALL OTHER WARRANTIES AND CONDITIONS, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES AND CONDITIONS REGARDING MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, RELATING TO THE USE OR PERFORMANCE OF THE PRODUCT. NO OTHER EXPRESS WARRANTY, CONDITION OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON OR ANY SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
THIS WARRANTY SHALL BE VOID AND OF NO FORCE AND EFFECT IF THE PRODUCT IS DAMAGED AS A RESULT OF (A) ABUSE, NEGLECT, MISHANDLING, ALTERATION, ELECTRIC CURRENT FLUCTUATION OR ACCIDENT, (B) IMPROPER USE, INCLUDING FAILURE TO FOLLOW OPERATING OR MAINTENANCE INSTRUCTIONS IN OR ENVIRONMENTAL CONDITIONS PRESCRIBED IN, CANON'S USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT, (C) REPAIR BY OTHER THAN AUTHORIZED SERVICE PROVIDER REPRESENTATIVES QUALIFIED BY CANON WHO ARE ACTING IN ACCORDANCE WITH CANON'S SERVICE BULLETINS, (D) USE OF SUPPLIES OR PARTS (OTHER THAN THOSE DISTRIBUTED BY CANON) WHICH DAMAGE THE PRODUCT OR CAUSE ABNORMALLY FREQUENT SERVICE CALLS OR SERVICE PROBLEMS, OR (E) USE OF THE PRODUCT WITH NON-COMPATIBLE COMPUTERS, PERIPHERAL EQUIPMENT OR SOFTWARE, INCLUDING THE USE OF THE PRODUCT IN ANY SYSTEM CONFIGURATION NOT RECOMMENDED IN ANY MANUAL OR OTHER DOCUMENTATION FOR THE PRODUCT. NOR DOES THIS WARRANTY EXTEND TO ANY PRODUCT ON WHICH THE ORIGINAL IDENTIFICATION MARKS OR SERIAL NUMBERS HAVE BEEN DEFACED, REMOVED, OR ALTERED.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE DISKETTES OR CD-ROMS ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD "AS IS" AND WITHOUT WARRANTY BY CANON. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
NEITHER CANON NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON OR ANY SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT SOLD BY CANON NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON OR ANY SERVICE PROVIDER. THIS LIMITED WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
CONDITIONS OF WARRANTY
THIS WARRANTY APPLIES TO PRODUCTS PURCHASED AND USED IN THE U.S.A. AND CANADA ONLY.
CANON U.S.A., INC.
One Canon Park
Melville
New York 11747-3036
CANON CANADA, INC.
6390 Dixie Road
Mississauga, Ontario L5T 1P7
Canada
