Canon Support for imagePRESS 1110+ | Canon U.S.A., Inc.
imagePRESS 1110+
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Model Name imagePRESS 1110+
Imaging System Laser Electrostatic Transfer System
Printing Resolution Up to 1200 x 1200 dpi
Halftone 256-Level Grayscale
Letter Simplex: 110
Duplex/Perfect: 55
Ledger Simplex: 68
Duplex/Perfect: 34
Maximum Original Size 13" x 19.2"
Standard Paper Capacity 2,000 Sheets (20 lb. Bond)
Acceptable Paper Weights
Cassette Uncoated: 14 lb. Bond to 110 lb. Bond Cover
Coated: 24 lb. Bond to 90 lb. Cover
Duplexing Automatic Duplex/Perfect
Any Supported Stock
Power Requirements 208V/30A+208V/15A
Dimension (H x W x D): 54.12" x 54.62" x 31.87"
Weight 1,103 lb.
Estimated Toner Yield 69,000 impressions at 6% coverage (LTR pgs)
Feeders
Description Color Image Reader-L1 (Opt.) (Includes DADF (Duplex Automatic Document Feeder)
Acceptable Originals Statement to 11" x 17"
Resolution: Up to 600 x 600 dpi, 256 Gradations
Scanning Speed B/W: Up to 200 ipm (300 dpi)
Up to 120 ipm (600 dpi)
Color: Up to 80 ipm (300 dpi)
Up to 40 ipm (600 dpi)*
Capacity 300 sheets (20 lb. Bond)
Paper Weights 14 lb. Bond to 120 lb. Index
Power Source From Main Unit
Dimensions (H x W x D): 7.12" x 23.25" x 25"
Weight 81.6 lb.
Paper Supply Options
Description POD Deck-C1 (Std.)
Paper Capacity 4,000 Sheets (1,000 x 2 + 2,000) (20 lb. Bond)
Paper Sizes 13" x 19.2"
Paper Weights Uncoated: 14 lb. Bond to 110 lb. Bond Cover (All Trays)
Coated: 24 lb. Bond to 90 lb. Cover (All Trays)
Power Source 120-127VAC, 60Hz, 15A
Dimensions 43.12" x 29.37" x 31.25"
Weight 499 lb.
Description POD Deck-C1 and Secondary POD Deck-C1 (Opt.)***
Power Source 120-127VAC, 60Hz, 15A x (2)
Dimensions 43.12" x 61.5" x 31.25"
Weight 997 lb.
Description POD Deck-C1 & Sec. POD Deck-C1 (2) (Opt) ***
Dimensions 43.12" x 93.62" x 31.25"
Weight 1,495 lb.&rang;
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
