Canon Support for imageRUNNER 1435i | Canon U.S.A., Inc.
imageRUNNER 1435i
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
imageRUNNER 1400 Series Spec Sheet
imageRUNNER 1435i
MAIN UNIT
SYSTEM TYPEDigital Multifunction Imaging System
FUNCTIONSCopy, Print, Scan, Send
OPERATION PANEL5-line LCD
MEMORYRAM 512 MB; Standard USB Port
NETWORK INTERFACE CONNECTIONStandard: 1000Base-T, 100Base-TX, 10Base-T
Other: USB2.0 x1 (Host), USB1.1 x1(Host), USB (Device)
COPY SPEEDLetter: Up to 37 ppm Legal: Up to 25 ppm
PRINT SPEEDLetter: Up to 37 ppm Legal: Up to 25 ppm
FIRST-COPY-OUT TIME (LETTER)As fast as 6.9 Seconds
FIRST-PRINT-OUT TIME (LETTER)As fast as 5.0 Seconds
PAPER SOURCES (20 lb. Bond)Standard: 500-sheet Cassette 100-sheet Bypass
Optional: 500-sheet Cassette
Maximum: 1,100 Sheets
OUTPUT CAPACITY (20 lb. Bond)Maximum: 100 Sheets
OUTPUT PAPER SIZESCassette: Letter, Legal
Bypass: Letter, Legal, Statement, Executive, Custom Size (3” x 5” to 8-1/2” x 14”), Envelope (C5/DL/ COM-10/Monarch)
ACCEPTABLE PAPER WEIGHTSCassette: 17 lb. Bond to 24 lb. Bond (64 to 90 g/m2)
Bypass: 16 lb. Bond to 34 lb. Bond (60 to 128 g/m2
WARM-UP TIMEFrom Power On: 20 Seconds or Less
From Sleep: 7.8 Seconds or Less
POWER REQUIREMENTS / PLUG120-127 V AC, 60 Hz, 7.8 A/NEMA 5-15P
POWER CONSUMPTIONMaximum: 1,500 W
Sleep Mode: 2.0 W or Less
DIMENSIONS (W X D X H)18-3/4” x 21-1/2” x 18” (475.3 mm x 545 mm x 457 mm)
INSTALLATION SPACE (WXD)30-3/8” x 18” (772.1 mm x 457 mm) (when the Multi-purpose Tray is extended)
WEIGHTApprox. 52.3 lb. (23.74 kg)
IMAGE READER UNIT
SCAN RESOLUTIONUp to 600 x 600 dpi
ACCEPTABLE ORIGINALS (GLASS)Sheet, Book, 3-Dimensional objects up to 4.4 lb. (2 kg)
MAXIMUM ORIGINAL SIZEUp to 8-1/2” x 14”
DOCUMENT FEEDER
SCAN METHODDuplexing Automatic Document Feeder
ACCEPTABLE ORIGINALSPaper Sizes: 5-1/2” x 5” to 8-1/2” x 14”
Paper Weights:
Simplex: 13 lb. to 28 lb. Bond (50 to 105 g/m2)
Duplex: 17 lb. to 28 lb. Bond (64 to 105 g/m2)
SCAN SPEED (BW / COLOR; LETTER)Simplex: Up to 29 ipm (BW)/10 ipm (Color)
Duplex: Up to 10 ipm (BW)/6 ipm (Color)
PAPER CAPACITY (20 lb. Bond): Up to 50 Sheets (20 lb. Bond)
COPY SPECIFICATIONS
MULTIPLE COPIES1 to 999
COPY EXPOSUREAutomatic or Manual (17 Levels)
MAGNIFICATION25% - 400% (1% Increments) from Platen Glass
PRESET REDUCTIONS25%, 50%, 64%, 78%
PRESET ENLARGEMENTS129%, 200%, 400%
BASIC COPY FEATURESPreset R/E Ratios by Area, Two-Sided, Exposure Adjustment, Original Type Selection, Setting Confirmation/Cancel, Standard Keys, Reset, ID Management, Counter Check
SPECIAL COPY FEATURESID Card Copy, Frame Erase, Mode Memory, Sharpness, Image Combination, Different Size Original
PRINT SPECIFICATIONS
PROCESSORCanon Dual Custom Processor (Shared)
ENGINE RESOLUTION600 x 600 dpi; 1200 x 600 dpi (Enhanced)
PDL SUPPORTStandard: UFR II LT
Standard (1435iF/1435P): PCL 5e/6, and Adobe PS 3
Optional: Barcode Printing Kit
PRINT DRIVERS SUPPORTED OSUFR II LT, PCL 5e/6, Adobe PS 3, Windows® (XP/Windows Vista®/7/8/8.1), Windows Server (2003/2003R2/2008 /2008 R2/ 2012/2012 R2), Windows Terminal Server (2003/2003R2/2008/2008 R2/2012/2012 R2), Microsoft Clustering Server 2003/2003R2/2008/ 2008 R2/2012/2012 R2),Microsoft App-V, Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5/7.5, XenDesktop 4.0/5.0/5.5/5.6/7.0/7.1/7.5), VMware (vSphere 4/5/5.1), SAP (PS3, PCL), Macintosh® (OS X 10.5.8 or later) (UFR II LT, PS 3)
DIRECT PRINT SUPPORT
Standard: TIFF, JPEG
Standard:: PDF
Optional: PDF (with optional USB Direct Print Kit or PS Printer Kit)
PRINT FEATURESSecured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-Sided Printing, Collating, Booklet Printing, Grouping, Printing on Transparencies, Front/ Back Covers, Objective, Toner Reduction, Poster Printing
SCAN SPECIFICATIONS
NETWORK TWAIN SCANStandard
NETWORK SCAN UTILITYScanGear MF
UNIVERSAL SEND SPECIFICATIONS
SENDING METHODE-mail, USB, File Server (FTP, SMB)
COLOR MODEColor: 300 dpi, 200 dpi, 150 dpi
BW: 300 dpi, 150dpi
SCAN RESOLUTION600 x 600 dpi, 400
ADDRESS BOOK CAPACITYMax. 300 Destinations (Incl. 19 One-Touch Buttons)
COMMUICATION PROTOCOLFile: FTP (TCP/IP), SMB (TCP/IP)
E-mail: SMTP, POP3
FILE FORMATStandard: TIFF, JPEG, PDF, PDF (Compact), PDF (Compact/OCR), PDF (OCR)
Optional: Encrypted PDF, Digital Signature PDF
UNIVERSAL SEND FEATURESTwo Sided Original, Original Type Selection, Density Adjustment, Sharpness, Subject/Message, Reply-to, E-mail Priority, Senders Name
STORE SPECIFICATIONS
STANDARDUSB Memory
SECURITY SPECIFICATIONS
STANDARDDepartment ID Management, IPv6, Restricting Features (Restricting New Addresses on Address Book, Allow Fax Driver TX, Restrict Recall, Confirm Entered Fax Numbers, Restrict Sequential Broadcast, Restrict USB Interface), Memory Lock, MAC/IP Address Filtering, SMTP Authentication POP Authentication before SMTP, IEEE802.1x, Authentication Feature for Send Operation (ASend), Secured Print, SNMP v1/v3, SSL Encrypted Communication, Fax Forwarding, Fax Destination Confirmation, USB Block, TLS Support for E-mail , Fax TX Archive
OPTIONALEncrypted PDF, Device Signature PDF, uniFLOW
ENVIRONMENTAL INFORMATION
ENERGY STAR® Qualified
Rated EPEAT® Silver
EU RoHS Compliant
Blue Angel
WEEE Directive
CONSUMABLES
TONERGPR-54 Toner
TONER YIELD (ESTIMATED @ 6% COVERAGE)Black: 17, 600 Copies/Case
FOOTNOTES
* Duplexing Automat
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Title Service Notice: Google Termination of Support for Google Cloud Print will be ending December 31, 2020.
Advisory Type
Date 12.01.20
SUPPLIES & ACCESSORIES
