Canon Support for imageRUNNER ADVANCE 4535i | Canon U.S.A., Inc.
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
Model Name | imageRUNNER ADVANCE 4535i |
Type | Monochrome Laser Multifunctional |
Functions | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
Operation Panel | 10.1" TFT LCD WSVGA Color Touch-panel |
Imaging System | Canon Dual Custom Processor (Shared) |
Image Server Memory | 3.0 GB RAM |
Hard Disk Drive | Standard: 250 GB Maximum: 1 TB |
Mirroring Hard Disk Drive | Optional (250 GB, 1 TB) Method: Raid1 |
Network Interface Connection | Standard: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n) Optional: NFC, Bluetooth |
Other Interface | Standard: USB 2.0 x2 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device) Optional: Serial Interface, Copy Control Interface |
Scanning Resolution | 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100dpi |
Printing Resolution | 1200 dpi x 1200 dpi |
Warm Up Time | From Power On: 24 Seconds or Less From Deep Sleep Mode: 10 Seconds or Less Quick Startup Mode: 4 Seconds4 |
Power Requirements | 120-127 V AC, 60 Hz, 9.3A |
Power Consumption | Maximum Approx. 1.5 kWh Standby: Approx. 38 W Sleep Mode: Approx. 0.9 W11 Typical Electricity Consumption (TEC) Rating: 1.8 kWh |
Plug | NEMA 5-15P |
Dimension | 23-1/8" x 29-1/8" x 47" (587 mm x 740 mm x 1,193 mm)5 |
Installation Space | Basic [With ADF (Stack Bypass and Cassette Drawers Open)]: 35" x 46-1/2" (889 mm x 1,182 mm) Fully Configured [With ADF+Paper Deck Unit-F1+ Booklet Finisher-Y1 (Cassette Drawers Open)]: 71-3/8" x 50-3/8" (1,811 mm x 1,280 mm) |
Weight | Approx. 240.7 lb. (109.2 kg)6 |
Basic Copy Features | Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
Special Copy Features | Book to Two Pages, Two-sided Original, Finishing, Booklet, Job Build, N on 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Store in Mail Box, Superimpose Image, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original |
Advanced Box
Available Disk Space | Approx. 16 GB (Standard HDD) Approx. 480 GB (1 TB HDD) |
Advanced Box Features | Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support |
Memory Media
Standard | USB |
Copy/Print Speed (BW/Color)
Letter | Up to 35 ppm |
Letter R | Up to 32 ppm |
Legal | Up to 25 ppm |
Ledger | Up to 22 ppm |
Copy Specifications
First Copy Time | (Letter): As fast as 3.8 seconds |
Multiple Copies | Up to 999 copies |
Copy Exposure | Automatic or Manual (9 Levels) |
Magnification | 25%-400% (1% Increments) |
Preset Reductions | 25%, 50%, 64%, 73%, 78% |
Preset Enlargements | 121%, 129%, 200%, 400% |
Acceptable Originals | Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2 kg)] |
Standard Paper Capacity | (LTR, 20 lb. Bond): 1,180 Sheets |
Optional | (LTR, 20 lb. Bond): Two 550-sheet Paper Cassettes (Cassette Feeding Unit-AN1), 2,450-sheet Paper Deck (High Capacity Cassette Feeding Unit-B1), 2,700-sheet Paper Deck (Paper Deck Unit-F1) |
Manual Bypass | 80-sheet Stack Bypass |
Maximum Paper Capacity | (LTR, 20 lb. Bond): 6,330 Sheets |
Output Paper Capacity | (LTR, 20 lb. Bond): Standard: 250 Sheets Maximum: 3,350 Sheets (with External Finishers) |
Output Sizes
Cassette | Paper Cassette (1): Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 15-3/8") Paper Cassette (2): 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 15-3/8") |
Bypass | 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (3-7/8" x 5-7/8" to 11-3/4" x 17") |
Acceptable Paper Weights
Cassette | 16 lb. Bond to 34 lb. Bond (60 to 128 g/m2) |
Bypass | 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) |
Duplexing
Duplexing | 16 lb. Bond to 28 lb. Cover (60 to 105 g/m2) |
Toner | GPR-57 Toner BK |
Estimated Toner Yield | (Estimated @ 6% Coverage): 42,100 Copies |
