Canon Support for imageRUNNER ADVANCE 4551i | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
imageRUNNER ADVANCE 4500 Series Spec Sheet
MAIN UNIT
TYPEMonochrome Laser Multifunctional
CORE FUNCTIONSStandard: Print, Copy, Scan, Send, Store
Optional: Fax
PROCESSORCanon Dual Custom Processor (Shared)
CONTROL PANEL 10.1" TFT LCD WSVGA Color Touch-panel
MEMORY 3.0 GB RAM
HARD DISK DRIVE Standard: 250 GB
Maximum: 1 TB
MIRRORING HARD DISK DRIVE Optional (250 GB, 1 TB)
Method: Raid1
PRINT RESOLUTION 1200 dpi x 1200 dpi
INTERFACE CONNECTION Network
Standard: 1000Base-T/100Base-TX/10Base-T,Wireless LAN (IEEE 802.11 b/g/n)
Optional: NFC, Bluetooth
Others
Standard: USB 2.0 x2 (Host), USB 3.0 x1 (Host),USB 2.0 x1 (Device)
Optional: Serial Interface, Copy Control Interface
PAPER CAPACITY (LTR, 20LB BOND) Standard: 1,180 SheetsMaximum: 6,330 Sheets
PAPER SOURCES (LTR, 20LB BOND) Standard: Two 550-sheet Paper Cassettes,80-sheet Stack Bypass
Optional: Two 550-sheet Paper Cassettes(Cassette Feeding Unit-AN1), 2,450-sheetPaper Deck (High Capacity CassetteFeeding Unit-B1), 2,700-sheet Paper Deck(Paper Deck Unit-F1)
PAPER OUTPUT CAPACITY (LTR, 20LB BOND) Standard: 250 Sheets
Maximum: 3,350 Sheets (with External Finishers)
FINISHING CAPABILITIES Standard: Collate, Group
With InnerFinisher:Collate, Group, Offset, Staple,Hole Punch,1 Staple-Free Staple,Staple On Demand
With ExternalFinisher:Collate, Group, Offset, Staple, Booklet,2Staple-Free Staple, Staple On Demand,Hole Punch3
SUPPORTED MEDIA TYPES Paper Cassettes:Thin, Plain, Recycled, Color, Heavy,Pre-punched
Stack Bypass:Thin, Plain, Recycled, Color, Heavy,Pre-punched, Bond, Transparency,Label, Envelope
SUPPORTED MEDIA SIZES Paper Cassette (1):Legal, Letter, Letter-R, Executive, Statement-R, Custom Size(5-1/2" x 7-1/8" to 11-3/4" x 15-3/8")
PaperCassette (2):11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size(5-1/2" x 7-1/8" to 11-3/4" x 15-3/8")Stack Bypass:11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (3-7/8" x 5-7/8" to 11-3/4" x 17")
SUPPORTED MEDIA WEIGHTS Paper Drawers:Paper Cassettes:16 lb. Bond to 34 lb. Bond (60 to 128 g/m2)
Stack Bypass:14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
Duplexing:16 lb. Bond to 28 lb. Cover (60 to 105 g/m2)
WARM-UP TIME From Power On:24 Seconds or Less
From Deep Sleep Mode:10 Seconds or Less
Quick Startup Mode:4 Seconds4
DIMENSIONS (W X D X H) 23-1/8" x 29-1/8" x 47" (587 mm x 740 mm x 1,193 mm)5
INSTALLATION SPACE (WXD) Basic [With ADF (Stack Bypass and Cassette Drawers Open)]: 35" x 46-1/2" (889 mm x 1,182 mm)
Fully Configured [With ADF+Paper Deck Unit-F1+Booklet Finisher-Y1 (Cassette Drawers Open)]:71-3/8" x 50-3/8" (1,811 mm x 1,280 mm)
WEIGHT Approx. 240.7 lb. (109.2 kg)6
PRINT SPECIFICATIONS
PRINT SPEED Up to 51 ppm (Letter); Up to 37 ppm (Letter-R); Up to 25 ppm (Legal);Up to 25 ppm (11" x 17")
STANDARD PAGE DESCRIPTION LANGUAGES UFR II, PCL®6, Adobe® PS® 3
DIRECT PRINT Available from USB, Advanced Box, Remote UI,and Web Access (Opt.)7
SUPPORTED FILE TYPES FOR DIRECT PRINT PDF, TIFF, JPEG, EPS, XPS
PRINTING FROM MOBILE AND CLOUD A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet-connected devices and cloud-based services depending on your requirements.
FONTS PCL fonts:93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),8 Barcode Fonts9
PS fonts:136 Roman
OPERATING SYSTEM10 UFRII:Windows Vista®/Server 2008/Windows® 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10, MAC OS X (10.6.8 or later)
PCL:Windows Vista/Server 2008/Windows 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10
PS:Windows Vista/Server 2008/Windows 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10, MAC OS X (10.6.8 or later)
PPD:MAC OS 9.1 or later, MAC OS X (10.3.9 or later), Windows Vista/Windows 7/Windows 8/Windows 8.1/Windows 10
PRINT FEATURES Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Forced Hold Printing, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Toner Reduction, Poster Printing
COPY SPECIFICATIONS
COPY SPEED Up to 51 ppm (Letter); Up to 37 ppm (Letter-R); Up to 25 ppm (Legal);Up to 25 ppm (11" x 17")
FIRST-COPY-OUT-TIME As fast as 3.7 seconds
COPY RESOLUTION Reading:Up to 600 dpi x 600 dpi
Printing:1200 dpi x 1200 dpi
MULTIPLE COPIES Up to 999 copies
COPY EXPOSURE Automatic or Manual (9 Levels)
MAGNIFICATION 25%-400% (1% Increments)
PRESET REDUCTIONS 25%, 50%, 64%, 73%, 78%
PRESET ENLARGEMENTS 121%, 129%, 200%, 400%
BASIC COPY FEATURES Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel
SPECIAL COPY FEATURES Book to Two Pages, Two-sided Original, Finishing, Booklet, Job Build, N on 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter,Print & Check, Negative/Positive, Repeat Images,Merge Job Blocks, Job Done Notice, Mirror Image,Store in Mail Box, Superimpose Image, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original
SCAN SPECIFICATIONS
TYPE Standard Single Pass Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY Single Pass DADF-A1: 150 Sheets (20 lb. Bond)DADF-AV1: 100 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHT Single Pass DADF-A1
BW Original:13 lb. Bond to 58 lb. Cover(50 to 157 g/m2)
CL Original:17 lb. Bond to 58 lb. Cover(64 to 157 g/m2)
DADF-AV1
BW Original:13 lb. Bond to 34 lb. Bond(50 to 128 g/m2)
CL Original:17 lb. Bond to 34 lb. Bond(64 to 128 g/m2)
PLATEN ACCEPTABLE ORIGINALS Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2 kg)]
PULL SCAN Color Network ScanGear2 for both Twain and WIA
Supported OS:Windows Vista/7/8/8.1/10Windows Server 2008/Server 2008 R2/Server 2012/Server 2012 R2
SCAN RESOLUTION 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100dpi
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES A range of solutions is available to provide scanning tomobile devices and cloud-based services depending onyour requirements.
SCAN SPEED (LETTER) Single Pass DADF-A1
Single-sided Scanning (BW):80 ipm (300 dpi)/80 ipm (600 dpi)
Single-sided Scanning (Color):80 ipm (300 dpi)/60 ipm (600 dpi)
Double-sided Scanning (BW):160 ipm (300 dpi)/150 ipm (600 dpi)
Double-sided Scanning (Color):160 ipm (300 dpi)/80 ipm (600 dpi)
DADF-AV1
Single-sided Scanning (BW):70 ipm (300 dpi)/51 ipm (600 dpi)
Single-sided Scanning (Color):70 ipm (300 dpi)/51 ipm (600 dpi)
Double-sided Scanning (BW):35 ipm (300 dpi)/25.5 ipm (600 dpi)
Double-sided Scanning (Color):35 ipm (300 dpi)/25.5 ipm (600 dpi)
SEND SPECIFICATIONS
DESTINATION E-mail/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional)
COLOR MODE Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White),Full color, Grayscale, and Black-and-White
ADDRESS BOOK Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White),Full color, Grayscale, and Black-and-White
SEND RESOLUTION 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi,100 x 100dpi
COMMUICATION PROTOCOL File:FTP, SMB v3.0, WebDAV
E-mail/I-Fax:SMTP, POP3, I-Fax (Simple, Full)
FILE FORMAT Standard:TIFF, JPEG, PDF(Compact, Searchable, Apply policy, Optimize for Web, PDF A/1-b), XPS (Compact, Searchable),Office Open XML (PowerPoint®, Word)
Optional:PDF (Trace & Smooth, Encrypted),PDF/XPS (Digital Signature)
UNIVERSAL SEND FEATURES Original Type Selection,Two-sided Original, Book to Two Pages, Different-size Originals, Density Adjustment, Sharpness, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-to, E-mail Priority, TX Report, Original Content Orientation, Skip Blank Originals, Detect Feeder Multi Sheet Feed
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES 4
MODEM SPEED Super G3:33.6 Kbps
G3:14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
SENDING / RECORDING SIZE Statement-R to 11" x 17"
FAX MEMORY Up to 30,000 pages
SPEED DIALS Max. 200
GROUP DIALS / DESTINATIONS Max. 199 dials
SEQUENTIAL BROADCAST Max. 256 addresses
MEMORY BACKUP Yes
FAX FEATURES Original Type Selection, Two-sided Original, Book to Two Pages, Different-size Originals, Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Sender's Name (TTI), Select Line, Selecting the Telephone Line (when sending fax), Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, TX Report, Detect Feeder Multi Sheet Feed
STORE SPECIFICATIONS
MAIL BOX (NUMBER SUPPORTED) 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored
ADVANCED BOX Communication Protocol: SMB or WebDAVSupportedClient PC:Windows (Windows Vista/7/8/8.1/10)
Concurrent Connections (Max.)
SMB:64
WebDAV:3 (Active Sessions)
ADVANCED BOX AVAILABLE DISC SPACE Approx. 16 GB (Standard HDD)
Approx. 480 GB (1 TB HDD)
ADVANCED BOX FEATURES Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
MEMORY MEDIA Standard: USB
SECURITY SPECIFICATIONS
AUTHENTICATION Standard:Universal Login Manager, User Authentication, Department ID Authentication, AccessManagement System, Deviceand Function Level Log-in
Optional:uniFLOW
DATA Standard:Trusted Platform Module (TPM),Hard Disk Password Lock, Hard DiskDrive Erase, Mail Box Password Protection, Hard Disk Drive Encryption(FIPS140-2 Validated)
Optional:Hard Disk Drive Mirroring, Hard Disk Drive removal, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW)
NETWORK Standard:IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP
DOCUMENT Standard:Secure Print, Forced Hold Printing,Adobe LiveCycle® Rights Management ES2.5 Integration
Optional:Encrypted PDF, Encrypted Secure Print, User and Device signatures, Secure Watermarks, Document Scan Locking
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT Temperature:50 to 86ºF
Humidity:20 to 80% RH (no condensation)
POWER REQUIREMENTS 120-127 V AC, 60 Hz, 10.4A
PLUG (MAIN UNIT) NEMA 5-15P
POWER CONSUMPTION MaximumApprox. 1.5 kWh
Standby:Approx. 38 W
Sleep Mode:Approx. 0.9 W11
Typical Electricity Consumption (TEC) Rating:2.5 kWh
STANDARDS ENERGY STAR® Certified
Rated EPEAT® Gold12
RoHS Compliant
CONSUMABLES
TONER GPR-57 Toner
TONER YIELD (ESTIMATED @ 6% COVERAGE) Black: 42, 100 Copies
FOOTNOTES
1 Requires the optional Inner 2/3 Hole Puncher-C1.
2 Booklet Finisher-Y1 only.
3 Requires the optional 2/3 Hole Puncher Unit-A1.
4 Time from device power-on to when copy jobs can be programmed.
5 Includes Main Unit, Single Pass DADF-A1, and Cassette Feeding Unit-AN1.
6 Includes Main Unit, Single Pass DADF-A1, Cassette Feeding Unit-AN1, and consumables.
7 PDF print from Web sites is supported.
8 Requires the optional PCL International Font Set-A1.
9 Requires the optional Barcode Printer Kit-D1.
10 Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
11 0.9 W Sleep mode is not available in all circumstances due to certain settings.
12 For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
SUPPLIES & ACCESSORIES
