Canon Support for imageRUNNER ADVANCE 500iF | Canon U.S.A., Inc.
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
Model Name | imageRUNNER ADVANCE 500iF |
Type | Color Digital Multifunction Imaging System |
Functions | Copy, Print (UFR II, PCL 5e/6, Adobe® PostScript® 3™),Fax (Up to 2 Lines), Scan, Send, Store |
Operation Panel | 7" WVGA Full-Color, TFT Screen |
Image Server Memory | Standard: 1.5GB RAM Maximum: 1.5GB RAM |
Hard Disk Drive | Standard: 80GB Maximum: 80GB |
Network Interface Connection | Ethernet 10/100 Base-TX, Ethernet 1000 Base-TX |
Other Interface | USB 2.0 X3 (Host), USB 2.0 (Device) |
Special Media Support | Plain 1 [17 lb. Bond to 21 lb. Bond (64 to 80g/m2)], Plain 2 [22 lb. Bond to 24 lb. Bond (81 to 90g/m2)], Recycled [17 lb. Bond to 21 lb. Bond (64 to 80g/m2)], Color [17 lb. Bond to 24 lb. Bond (64 to 90g/m2)], Heavy 1 [25 lb. Bond to 28 lb. Bond (91 to 105g/m2)], Heavy 2 [29 lb. Bond to 34 lb. Bond (106 to 128g/m2)], Transparency [40 lb. Bond to 67 lb. Cover (151 to 181g/m2)]**, Pre-punched [20 lb. Bond to 21 lb. Bond (75 to 80g/m2)], Bond [20 lb. Bond to 24 lb. Bond (75 to 90g/m2)], Labels [40 lb. Bond to 67 lb. Cover (151 to 181g/m2)], Envelope |
Warm Up Time | From Power On: 34 Seconds From Sleep Mode: 10 Seconds or Less Quick Startup Mode: Within 7 Seconds or Less*** |
Power Requirements | 120V AC, 60Hz |
Power Consumption | Maximum: 1.5 kW Sleep Mode: 1 W |
Plug | 10.5A |
Dimension | 24-7/8" x 22-1/8" x 22-3/8" (633mm x 560mm x 567mm) |
Installation Space | Without Staple Finisher-R1: 34-3/4" x 40-7/8" (881mm x 1035mm) With Staple Finisher-R1: 50-1/4" x 40-7/8" (1276mm x 1035mm) |
Weight | Approximately 107 lb. (48.7kg)Δ |
Basic Copy Features | Preset R/E Ratios by Area, Finishing, Two-sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel, Standard Keys, Reset, Job Duration Display, Reserved Copying, ID Management, Counter Check |
Special Copy Features | ID Card Copy, Shift, Frame Erase, Scan Image Check, Mode Memory, Recall, Sharpness, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date |
Environmental Features | ENERGY STAR® Qualified RoHS Compliant Blue Angel EPEAT® Rated WEEE Directive |
Advanced Box
Advanced Box Features | Store To Remote Advanced Box:♦ Supported Print/View from Remote Advanced Box:♦ Supported |
Memory Media
Standard | USB Memory |
Scan Specifications
Network TWAIN Scan | Standard |
Network Scan Utility | Color Network ScanGear |
Copy/Print Speed (BW/Color)
Letter | (BW): Up to 52/52 ppm |
Legal | (BW): Up to 43/43 ppm |
Copy Specifications
First Copy Time | (Letter): 5 Seconds or Less |
Multiple Copies | 1 to 999 |
Copy Exposure | Automatic or Manual (9 Levels) |
Magnification | 25 - 400% (1% Increments) from Platen Glass 25 - 200% (1% Increments) from Document Feeder |
Preset Reductions | 78%, 73%, 64%, 50%, 25% |
Preset Enlargements | 400%, 200%, 129% |
Standard Paper Capacity | (20 lb. Bond): 550-sheet Paper Cassette 100-sheet Stack Bypass |
Optional | (20 lb. Bond): 550-sheet Paper Cassette (Up to 3) |
Maximum Paper Capacity | (20 lb. Bond): 2,300 Sheets |
Output Paper Capacity | (20 lb. Bond): Standard: 250 Sheets Maximum: 500 Sheets (with Staple Finisher-R1) |
Output Sizes
Cassette | LGL, LTR, STMT, EXEC, Custom size 5-1/2" x 8-1/4" to 8-1/2" to 14" (139.7mm x 210mm to 216mm x 355.6 mm), and Envelopes (COM10, Monarch, DL, ISO-C5)* |
Bypass | LGL, LTR, STMT, EXEC, Custom size [3-7/8" x 5-1/2" to 8-1/2" x 14" (99mm x 139.7mm to 216mm x 355.6mm)], and Envelopes (COM10, Monarch, DL, ISO-C5) |
Other Option | Envelope Feeder Attachment (COM10, Monarch, DL, ISO-C5)* |
Acceptable Paper Weights
Cassette | 17 lb. Bond to 28 lb. Bond (64 to 105g/m2) |
Bypass | 17 lb. Bond to 34 lb. Bond (64 to 128g/m2) |
Duplexing
Duplexing | Standard Automatic Trayless Duplexing |
Paper Size | Statement to Legal |
Paper Weight | Up to 34 lb. Bond (128g/m2) |
Image Reader
Scan Resolution | Up to 600 x 600 dpi |
Acceptable Originals | (Glass): Sheet, Book, 3-Dimensional Objects [up to 4.4 lb. (2kg)] |
Maximum Original Size | Legal (8-1/2" to 14") |
Security Features
Standard | Department ID Management, Single Sign On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, IPv6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), Send to Myself (only), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, IEEE 802.1x (wired/wireless), SMTP Authentication, POP Authentication before SMTP, HDD Initialize (Up to 9x) HDD Erase (Up to 3x), HDD Lock, IPsec, Adobe® LiveCycle® Rights Management ES2.5 Integration |
Optional | HDD Encryption, Encrypted Secure Print, Encrypted PDF, Secure Watermark, IEEE 2600.1 Common Criteria Certification♦♦ |
Estimated Toner Yield | 15,200 Copies/Bottle (Estimated @ 6% Coverage) |
Feeders
Description | Document Feeder |
Acceptable Originals | Legal, Letter, Statement |
Scan Method | Duplexing Automatic Document Feeder |
Scanning Speed | (BW/Color; Letter): Simplex: 52 ipm (600 dpi)/52 ipm (300 dpi) Duplex: 33 ipm (600 dpi)/33 ipm (300 dpi) |
Capacity | (20 lb. Bond): 100 Sheets |
Paper Weight | One-sided scanning: 11 lb. Bond to 34 lb. Bond (42 to 128g/m2), Two-sided scanning: 13 lb. Bond to 34 lb. Bond (50 to 128g/m2) |
Paper Supply Options
Description | Cassette Module-AA1 |
Paper Capacity | 550 Sheets [20 lb. Bond (80g/m2)] |
Paper Size | LGL, LTR, STMT, EXEC, Custom size [5-1/2" x 8-1/4" to 8-1/2" x 14" (139.7mm x 210mm to 216mm x 355.6mm)] |
Paper Weight | 17 lb. Bond to 28 lb. Bond (64 to 105g/m2) |
Power Source | From the Main Unit |
Power Consumption | Approximately 20W |
Dimensions | 4-3/4" x 21-1/4" x 19-3/4" (248mm x 565mm x 650mm) |
Weight | Approximately 17 lb. (7.7kg) |
Description | Envelope Cassette-E1 |
Paper Capacity | 50 sheets |
Paper Size | COM10, Monarch, DL, ISO-C5Feeding Speed: 12 cpm |
Dimensions | 3-1/4" x 21-1/4" x 18-7/8" (96mm x 54 mm x 480mm) |
Weight | Approximately 5.5 lb. (2.5kg) |
