Canon Support for imageRUNNER ADVANCE C3325i | Canon U.S.A., Inc.
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- macOS 26
- Linux
0 of 0
SELECT ERROR CODE
Model Name | imageRUNNER ADVANCE C3325i |
Type | Color Digital Multifunction Imaging System |
Functions | Standard: Copy, Print (UFR II, PCL 5c/6, Adobe® PostScript® 3™), Scan, Send Optional: Fax (Up to 2 Lines) |
Operation Panel | 7" WVGA Full-Color TFT Screen |
Image Server Memory | Standard: 2 GB RAM Maximum: 2 GB RAM |
Hard Disk Drive | Standard: 215 GB Maximum: 215 GB |
Network Interface Connection | Standard: 1000Base-TX/100Base-TX/10Base-T Optional: Wireless LAN (IEEE 803.1x via third-party adapter) |
Other Interface | Standard: USB 2.0 (Host) x 2, USB 2.0 (Device) Optional: Device Port [USB 2.0 (Host) x 2], Copy Control Interface |
Scanning Resolution | Up to 600 x 600 dpi |
First Copy Time | As fast as 5.9 Seconds (BW), 8.2 Seconds (Color) |
Multiple Copies | 1 to 999 |
Copy Exposure | Automatic or Manual (9 Levels) |
Magnification | 25% - 400% (1% Increments) |
Preset Reductions | 25%, 50%, 64%, 73%, 78% |
Preset Enlargements | 121%, 129%, 200%, 400% |
Acceptable Originals | (Glass) Sheet, Book, 3-Dimensional objects [up to 4.4 lb. (2 kg)] |
Maximum Original Size | Up to 11" x 17" |
Standard Paper Capacity | Up to 100 Sheets (20 lb. Bond) |
Maximum Paper Capacity | Paper Sources (20 lb. Bond) Standard: Two 550-sheet Paper Cassettes 100-sheet Stack Bypass Optional: Dual 550-sheet Paper Cassettes Maximum: 2,300 Sheets |
Output Paper Capacity | (20 lb. Bond) Standard: 250 Sheets (Inner Tray) Maximum: 2,100 Sheets (w/Staple Finisher or Booklet Finisher) |
Warm Up Time | From Power On: Approximately 34 Seconds From Sleep: Approximately 10 Seconds Quick Startup Mode: Within 7 Seconds* |
Power Requirements | 120 V AC, 60 Hz, 7.5 A |
Power Consumption | Maximum: 1.5kW Sleep Mode: 0.8 W |
Plug | NEMA 5-15P |
Dimension | (H x W x D) 34-5/8" x 22-1/4" x 27-5/16" (878 mm x 565 mm x 693 mm) |
Installation Space | (W x D) 35-1/4" x 44" (894 mm x 1117 mm) (when the Multi-purpose Tray is extended.) |
Weight | Approximately 163.4 lb. (74.1 kg)** |
Basic Copy Features | Preset R/E Ratios by Area, Finishing, Two-Sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying, ID Management, Counter Check |
Special Copy Features | Two-page Separation, Cover/Sheet Insertion, Booklet, Transparency Interleaving, Shift, Margin, Frame Erase, Image Combination, Different Size Original, Job Build, Job Done Notice, Scan Image Check, Mode Memory, Recall, Negative/ Positive Inversion, Image Repeat, Mirror Image, Sharpness, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date, Document Scan Lock, Area Designation, ID Card Copy |
Environmental Features | ENERGY STAR® Qualified, Rated EPEAT Gold, EU RoHS Compliant, Ecomark Blue Angel, WEEE Directive |
Advanced Box
Advanced Box Features | Store to Remote Advanced Box: Supported Print/View from Remote Advanced Box: Supported Standard: USB Memory, Mail Box Simple |
Memory Media
Standard | Department ID Management, Single Sign On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, IPV6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP, HDD Format, HDD Initialize (Up to 9x ), HDD Erase (Up to 3x), HDD Lock, IPsec, Adobe® LiveCycle® Rights Management ES2.5 Integration |
Optional | Removable HDD, HDD Encryption, HDD Data Erase Scheduler, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, Secure Watermark, IEEE 2600.1 Common Criteria Certification†† |
Scan Specifications
Network TWAIN Scan | Standard |
Network Scan Utility | Color Network ScanGear |
Output Sizes
Cassette | 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) |
Bypass | 14 lb. Bond to 140 lb. Index (52 to 256 g/m2) |
Duplexing
Duplexing | Paper Size: Standard Automatic Trayless Duplexing (Executive to 12" x 18") Paper Weight: 14 lb. Bond to 80 lb. Cover (220 g/m2) |
Paper Size | Cassette 1: Statement, Letter, Executive, Envelope (ISO-C5), Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 8-1/2") Cassette 2: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Statement, Executive, Custom Size (5-1/2" x 7-1/8" to 12" x 18"), Envelopes (COM10 No.10, Monarch, DL) Cassettes 3/4: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Statement, Executive, Custom Size (5-1/2" x 7-1/8" to 12" x 18") Bypass: 12" x 18", 12-5/8" x 17-11/16", 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size (3-7/8" x 5-1/2" to 12-5/8" x 18"), Envelopes (COM10 No.10, Monarch, DL, ISO-C5) |
Paper Weight | Cassettes: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) Bypass: 14 lb. Bond to 140 lb. Index (52 to 256 g/m2) |
Special Media Support | Tracing, Coated, Labels, Transparency, Pre-punched, Bond, and Envelopes Envelope Feeding Attachment Paper Capacity: Up to 50 Sheets (or 45 mm in height) Acceptable Envelope Type: COM10 No.10, Monarch, DL, ISO-C5 Feeding Speed: 10 cpm |
Image Reader
Scan Resolution | Up to 600 x 600 dpi |
Acceptable Originals | Sheet, Book, 3-Dimensional objects [up to 4.4 lb. (2 kg)] |
Security Features
Standard | USB Memory, Mail Box Simple |
Toner | (Estimated Yield @ 5% Coverage) Black: 36,000 copies/bottle Color: 19,000 copies/bottle |
Feeders
Description | Image Reader Unit |
Acceptable Originals | (Glass) Sheet, Book, 3-Dimensional objects [up to 4.4 lb. (2 kg)] Maximum Original Size: Up to 11" x 17" Scan Resolution: Up to 600 x 600 dpi |
Description | Document Feeder |
Acceptable Originals | Paper Sizes: 11" x 17", Legal, Letter, Letter-R, Statement, or Statement-R Paper Weights: 13 lb. Bond to 34 lb. Bond (50 to 128 g/m2) |
Scan Method | Duplex Automatic Document Feeder |
Scanning Speed | Simplex: Up to 55 ipm (300 dpi) Up to 30 ipm (600 dpi) Duplex: Up to 27.5 ipm (300 dpi) Up to 15 ipm (600 dpi) |
Paper Supply Options
Description | Cassette Feeding Unit-AL1 |
Paper Capacity | 550 Sheets x 2 Cassettes [20 lb. Bond (80 g/m2)] |
Paper Size | 12" x 18", 11" x 17", Legal, Letter, Letter-R, Statement-R, Executive, and Custom Size [5-1/2" x 7-1/8" to 12"x 18" (139.7 mm x 182 mm to 304.8 mm x 457.2 mm)] |
Paper Weight | 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) |
Power Source | From the Main Unit |
Power Consumption | Approximately 30 W |
Dimensions | 9-13/16" x 22-1/4" x 24-1/4" (248 mm x 565 mm x 615 mm) |
Weight | Approximately 35.5 lb. (16.1 kg) |
