Canon Support for imageRUNNER ADVANCE C3325i | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Model Name imageRUNNER ADVANCE C3325i
Type Color Digital Multifunction Imaging System
Functions Standard: Copy, Print (UFR II, PCL 5c/6, Adobe® PostScript® 3&trade;), Scan, Send
Optional: Fax (Up to 2 Lines)
Operation Panel 7" WVGA Full-Color TFT Screen
Image Server Memory Standard: 2 GB RAM
Maximum: 2 GB RAM
Hard Disk Drive Standard: 215 GB
Maximum: 215 GB
Network Interface Connection Standard: 1000Base-TX/100Base-TX/10Base-T
Optional: Wireless LAN (IEEE 803.1x via third-party adapter)
Other Interface Standard: USB 2.0 (Host) x 2, USB 2.0 (Device)
Optional: Device Port [USB 2.0 (Host) x 2], Copy Control Interface
Scanning Resolution Up to 600 x 600 dpi
First Copy Time As fast as 5.9 Seconds (BW), 8.2 Seconds (Color)
Multiple Copies 1 to 999
Copy Exposure Automatic or Manual (9 Levels)
Magnification 25% - 400% (1% Increments)
Preset Reductions 25%, 50%, 64%, 73%, 78%
Preset Enlargements 121%, 129%, 200%, 400%
Acceptable Originals (Glass) Sheet, Book, 3-Dimensional objects [up to 4.4 lb. (2 kg)]
Maximum Original Size Up to 11" x 17"
Standard Paper Capacity Up to 100 Sheets (20 lb. Bond)
Maximum Paper Capacity Paper Sources (20 lb. Bond)
Standard: Two 550-sheet Paper Cassettes 100-sheet Stack Bypass
Optional: Dual 550-sheet Paper Cassettes
Maximum: 2,300 Sheets
Output Paper Capacity (20 lb. Bond)
Standard: 250 Sheets (Inner Tray)
Maximum: 2,100 Sheets (w/Staple Finisher or Booklet Finisher)
Warm Up Time From Power On: Approximately 34 Seconds
From Sleep: Approximately 10 Seconds
Quick Startup Mode: Within 7 Seconds*
Power Requirements 120 V AC, 60 Hz, 7.5 A
Power Consumption Maximum: 1.5kW
Sleep Mode: 0.8 W
Plug NEMA 5-15P
Dimension (H x W x D)
34-5/8" x 22-1/4" x 27-5/16"
(878 mm x 565 mm x 693 mm)
Installation Space (W x D)
35-1/4" x 44" (894 mm x 1117 mm) (when the Multi-purpose Tray is extended.)
Weight Approximately 163.4 lb. (74.1 kg)**
Basic Copy Features Preset R/E Ratios by Area, Finishing, Two-Sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying, ID Management, Counter Check
Special Copy Features Two-page Separation, Cover/Sheet Insertion, Booklet, Transparency Interleaving, Shift, Margin, Frame Erase, Image Combination, Different Size Original, Job Build, Job Done Notice, Scan Image Check, Mode Memory, Recall, Negative/ Positive Inversion, Image Repeat, Mirror Image, Sharpness, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark and Date, Document Scan Lock, Area Designation, ID Card Copy
Environmental Features ENERGY STAR® Qualified, Rated EPEAT Gold, EU RoHS Compliant, Ecomark Blue Angel, WEEE Directive
Advanced Box
Advanced Box Features Store to Remote Advanced Box: Supported Print/View from Remote Advanced Box: Supported
Standard: USB Memory, Mail Box Simple
Memory Media
Standard Department ID Management, Single Sign On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, IPV6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP, HDD Format, HDD Initialize (Up to 9x ), HDD Erase (Up to 3x), HDD Lock, IPsec, Adobe® LiveCycle® Rights Management ES2.5 Integration
Optional Removable HDD, HDD Encryption, HDD Data Erase Scheduler, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, Secure Watermark, IEEE 2600.1 Common Criteria Certification&dagger;&dagger;
Scan Specifications
Network TWAIN Scan Standard
Network Scan Utility Color Network ScanGear
Output Sizes
Cassette 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
Bypass 14 lb. Bond to 140 lb. Index (52 to 256 g/m2)
Duplexing
Duplexing Paper Size: Standard Automatic Trayless Duplexing (Executive to 12" x 18")
Paper Weight: 14 lb. Bond to 80 lb. Cover (220 g/m2)
Paper Size Cassette 1: Statement, Letter, Executive, Envelope (ISO-C5), Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 8-1/2")
Cassette 2: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Statement, Executive, Custom Size (5-1/2" x 7-1/8" to 12" x 18"), Envelopes (COM10 No.10, Monarch, DL)
Cassettes 3/4: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Statement, Executive, Custom Size (5-1/2" x 7-1/8" to 12" x 18")
Bypass: 12" x 18", 12-5/8" x 17-11/16", 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size (3-7/8" x 5-1/2" to 12-5/8" x 18"), Envelopes (COM10 No.10, Monarch, DL, ISO-C5)
Paper Weight Cassettes: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
Bypass: 14 lb. Bond to 140 lb. Index (52 to 256 g/m2)
Special Media Support Tracing, Coated, Labels, Transparency, Pre-punched, Bond, and Envelopes
Envelope Feeding Attachment
Paper Capacity: Up to 50 Sheets (or 45 mm in height)
Acceptable Envelope Type: COM10 No.10, Monarch, DL, ISO-C5
Feeding Speed: 10 cpm
Image Reader
Scan Resolution Up to 600 x 600 dpi
Acceptable Originals Sheet, Book, 3-Dimensional objects [up to 4.4 lb. (2 kg)]
Security Features
Standard USB Memory, Mail Box Simple
Toner (Estimated Yield @ 5% Coverage)
Black: 36,000 copies/bottle
Color: 19,000 copies/bottle
Feeders
Description Image Reader Unit
Maximum Original Size: Up to 11" x 17"
Scan Resolution: Up to 600 x 600 dpi
Description Document Feeder
Acceptable Originals Paper Sizes: 11" x 17", Legal, Letter, Letter-R, Statement, or Statement-R
Paper Weights: 13 lb. Bond to 34 lb. Bond (50 to 128 g/m2)
Scan Method Duplex Automatic Document Feeder
Scanning Speed Simplex: Up to 55 ipm (300 dpi) Up to 30 ipm (600 dpi)
Duplex: Up to 27.5 ipm (300 dpi) Up to 15 ipm (600 dpi)
Paper Supply Options
Description Cassette Feeding Unit-AL1
Paper Capacity 550 Sheets x 2 Cassettes [20 lb. Bond (80 g/m2)]
Paper Size 12" x 18", 11" x 17", Legal, Letter, Letter-R, Statement-R, Executive, and Custom Size [5-1/2" x 7-1/8" to 12"x 18" (139.7 mm x 182 mm to 304.8 mm x 457.2 mm)]
Paper Weight 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
Power Source From the Main Unit
Power Consumption Approximately 30 W
Dimensions 9-13/16" x 22-1/4" x 24-1/4" (248 mm x 565 mm x 615 mm)
Weight Approximately 35.5 lb. (16.1 kg)
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
SUPPLIES & ACCESSORIES
