Canon Support for imageRUNNER ADVANCE C3530i III | Canon U.S.A., Inc.
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
SELECT ERROR CODE
imageRUNNER ADVANCE C3500 III Series
imageRUNNER ADVANCE C3530i III | |
MAIN UNIT | |
TYPE | Color Laser Multifunctional |
CORE FUNCTIONS | Standard: Print, Copy, Scan, Send, Store |
PROCESSOR | Canon Dual Custom Processor (Shared) |
CONTROL PANEL | 10.1" TFT LCD WSVGA Color Flat-panel |
MEMORY | 3.0 GB RAM |
HARD DISK DRIVE | Standard: 250 GB |
INTERFACE CONNECTION | Network: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n) |
PAPER CAPACITY (LETTER, 20 LB. BOND) | Standard: 1,200 Sheets |
PAPER SOURCES (LETTER, 20 LB. BOND) | Standard: Dual 550-sheet Paper Cassettes, 100-sheet Stack Bypass |
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND) | Standard: 250 Sheets |
FINISHING CAPABILITIES | Standard: Collate, Group |
SUPPORTED MEDIA TYPES | Paper Cassettes (1/2): Thin, Plain, Recycled, Color, Heavy, Pre-punched, Bond, Transparency, Envelope |
SUPPORTED MEDIA SIZES | Paper Cassette 1: Letter, Executive, Statement-R, Envelope [ISO-C5], Custom Size (5-1/2" x 7-1/8" to 11-3/4" x 8-1/2") |
SUPPORTED MEDIA WEIGHTS | Cassettes: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2) |
WARM-UP TIME | From Power On: Approx. 10 Seconds2 |
DIMENSIONS (W x D x H) | 22-1/4" x 29-1/4" x 45-1/5"(565 mm x 742 mm x 1148 mm)5 |
INSTALLATION SPACE (W x D x H) | Basic: Stack Bypass + Cassette Drawers open: 38-1/2" x 44-1/4" (978 mm x 1123 mm)5 |
WEIGHT | Approx. 213.8 lb. (97 kg)7 |
PRINT SPECIFICATIONS | |
PRINT / COPY SPEED (BW AND COLOR) | Up to 30 ppm (Letter) |
PRINT RESOLUTION (dpi) | 1200 x 1200, 600 x 600 |
STANDARD PAGE DESCRIPTION LANGUAGES | UFR II, PCL®6, Adobe® PS® 3 |
DIRECT PRINT | Available from USB, Advanced Box, Remote UI, and Web Access8 |
SUPPORTED FILES | PDF, TIFF, JPEG, EPS, XPS |
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES | A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet-connected devices and cloud-based services depending on your requirements. |
FONTS | PCL fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),9 Barcode Fonts10 |
OPERATING SYSTEM 11 | UFRII/PS: Windows® Server 2008/Windows® 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.9 or later) |
PRINT FEATURES | Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Forced Hold Printing, Watermark, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Front/Back Covers, Toner Reduction |
COPY SPECIFICATIONS | |
FIRST-COPY-OUT-TIM | As fast as 5.9 seconds (BW)/8.2 seconds (Color) |
MULTIPLE COPIES | Up to 999 Copies |
COPY EXPOSURE | Automatic or Manual (9 Levels) |
MAGNIFICATION | 25%-400% (1% Increments) |
PRESET REDUCTIONS | 25%, 50%, 64%, 73%, 78% |
PRESET ENLARGEMENTS | 121%, 129%, 200%, 400% |
BASIC COPY FEATURES | Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
SPECIAL COPY FEATURES | Book to Two Pages, Two-Sided Original, Finishing, Booklet, Job Build, N on 1, Add Cover, Insert Sheets, Different-Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Job Done Notice, Mirror Image, Copy ID Card, Multi Sheet Feed Detection, Free Size Original, AdjustOne-Touch Color, Color Balance, Area Designation,Skip Blank Pages |
SCAN SPECIFICATIONS | |
TYPE | Single-pass Duplexing Automatic Document Feeder |
DOCUMENT FEEDER PAPER CAPACITY | 150 Sheets (20 lb. Bond) |
DOCUMENT FEEDER SUPPORTED MEDIA SIZES | 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R, |
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS | Standard: Department ID Authentication |
PLATEN ACCEPTABLE ORIGINALS | Standard: Department ID Sheet, Book, 3-Dimensional Objects [Height: Up to 2" (50mm), |
PULL SCAN | Color Network ScanGear2 for both Twain and WIA |
SCAN RESOLUTION | 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x 100, 150 x 150, 100 x 100 |
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES | A range of solutions is available to provide scanning tomobile devices and cloud-based services depending onyour requirements. |
SCAN SPEED (LETTER) | Single-sided Scanning (BW and Color): 80 ipm (300 dpi)/51 ipm (600 dpi) |
SEND SPECIFICATIONS | |
DESTINATION | Email/Internet Fax (SMTP), SMB v3.0, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional) |
COLOR MODE | Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White), |
ADDRESS BOOK | LDAP (2,000)/Local (1,600)/Speed dial (200) |
SEND RESOLUTION | 600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200,200 x 100, 150 x 150, 100 x 100 |
COMMUICATION PROTOCOL | File: FTP (TCP/IP), SMB v3.0, WebDAV |
FILE FORMAT | Standard: TIFF, JPEG, PDF (Compact, Searchable, Apply policy, Optimize for Web, PDF A/1-b, Encrypted, Device Signature), XPS (Searchable, Compact, Device Signature), Office Open XML (PowerPoint, Word) |
UNIVERSAL SEND FEATURES | Original Type Selection,Two-Sided Original, Book to Two Pages, Different-Size Originals, Density Adjustment, Sharpness, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Job Done Notice, File Name, Subject/Message, Reply-To, Email Priority, TX Report, Original Content Orientation, Skip Blank Originals, Multi Sheet Feed Detection |
FAX SPECIFICATIONS | |
MAXIMUM NUMBER OF LINES | 2 |
MODEM SPEED | Super G3: 33.6 Kbps |
COMPRESSION METHOD | MH, MR, MMR, JBIG |
RESOLUTION | 400 x 400, 200 x 400, 200 x 200, 200 x 100 |
SENDING / RECORDING SIZE | Statement-R to 11" x 17" |
FAX MEMORY | Up to 30,000 Pages |
SPEED DIALS | Max. 200 |
GROUP DIALS / DESTINATIONS | Max. 199 Dials |
SEQUENTIAL BROADCAST | Max. 256 Addresses |
MEMORY BACKUP | Yes |
FAX FEATURES | Original Type Selection, Two-Sided Original, Book to Two Pages, Different-Size Originals, Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Sender's Name (TTI), Select Line, Selecting the Telephone Line, Direct Send, Delayed Send, Preview, Job Done Notice, TX Report, Multi Sheet Feed Detection |
STORE SPECIFICATIONS | |
MAIL BOX SIMPLE (NUMBER SUPPORTED) | 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored |
ADVANCED BOX | Communication Protocol: SMB or WebDAV |
ADVANCED BOX AVAILABLE DISC SPACE | Approx. 16 GB (Standard HDD) |
ADVANCED BOX FEATURES | Authentication for Advanced Box Log-in, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support |
MEMORY MEDIA | Standard: USB |
SECURITY SPECIFICATIONS | |
AUTHENTICATION | Standard: Universal Login Manager, uniFLOWOnline Express,12 User Authentication, Department ID Authentication,Access Management System,Device and Function Level Log-in |
DATA | Standard: Trusted Platform Module (TPM),Hard Disk Password Lock, Hard DiskDrive Erase, Mail Box Password Protection, Hard Disk Drive Encryption(FIPS140-2 Validated), Verify System at Startup, McAfee Embedded Control 13 |
NETWORK | Standard: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication,POP Authentication before SMTP, S/MIME, SIEM Integration |
DOCUMENT | Standard: Secure Watermark, Encrypted PDF, Encrypted Secure Print, Digital Signatures, Adobe LiveCycle® Rights ManagementES2.5 Integration |
ENVIRONMENTAL SPECIFICATIONS | |
OPERATING ENVIRONMENT | Temperature: 50 to 86 ºF |
POWER REQUIREMENTS | 120-127V AC 60 Hz,7.5 A |
PLUG (MAIN UNIT) | NEMA 5-15P |
POWER CONSUMPTION | Maximum: Approx. 1,500 W |
STANDARDS | ENERGY STAR® Certified |
CONSUMABLES | |
TONER | GPR-53 Toner17 |
TONER YIELD (ESTIMATED @ 5% COVERAGE) | Black: 36,000 Images |
FOOTNOTES | |
