Canon Support for imageRUNNER ADVANCE C356iF III | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
imageRUNNER ADVANCE C356iF / C256iF III Series Spec Sheet
MAIN UNIT
TYPE
Color Laser Multifunctional
CORE FUNCTIONS
Print, Copy, Scan, Send, Store, Fax (Line One Standard, Line Two Optional)
PROCESSOR
Canon Dual Custom Processor (Shared)
CONTROL PANEL
10.1" TFT LCD WSVGA Color Flat-panel
MEMORY
3.0 GB RAM
HARD DISK DRIVE
250 GB
INTERFACE CONNECTION
Network: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n)
Others
Standard: USB 2.0 x1 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device)
Optional: Serial Interface, Copy Control Interface
PAPER CAPACITY (LETTER, 20 LB. BOND)
Standard: 650 Sheets
Maximum: 2,300 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)
Standard: 550-sheet Paper Cassette, 100-sheet Stack Bypass
Optional: 550-sheet Paper Cassette (CASSETTE MODULE-AE1), 550-sheet Paper Cassette with Cabinet (CASSETTE FEEDING UNIT-AJ1), Triple 550-sheet Paper Cassettes (CASSETTE FEEDING UNIT-AK1)
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)
Standard: 250 Sheets
Maximum: 500 Sheets (with STAPLE FINISHER-Z1)
FINISHING CAPABILITIES
Standard: Collate, Group
With External Finisher: Collate, Group, Offset, Staple
SUPPORTED MEDIA TYPES
Paper Cassette: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Bond, Envelope
Stack Bypass: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Labels, Bond, Transparency, Envelope
Cassette Module-AE1: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Bond
Cassette Feeding Unit-AJ1: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Bond
Cassette Feeding Unit-AK1: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Bond
SUPPORTED MEDIA SIZES
Paper Cassette 1: Legal, Letter, Executive, Statement, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (3-7/8" x 7-1/2" to 8-1/2" x 14")
Stack Bypass: Legal, Letter, Executive, Statement, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Envelope Custom Size (3-7/8" x 5-7/8" to 8-1/2" x 14"), Custom Size (3-7/8" x 5-7/8" to 8-1/2" x 14")
Cassette Module-AE1: Legal, Letter, Executive, Statement, Custom Size (3-7/8" x 7-1/2" to 8-1/2" x 14")
Cassette Feeding Unit-AJ1: Legal, Letter, Executive, Statement, Custom Size (3-7/8" x 7-1/2" to 8-1/2" x 14")
Cassette Feeding Unit-AK1: Legal, Letter, Executive, Statement, Custom Size (3-7/8" x 7-1/2" to 8-1/2" x 14")
SUPPORTED MEDIA WEIGHTS
Cassettes: 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2 )
Stack Bypass: 16 lb. Bond to 80 lb. Cover (60 to 220 g/m2 )
Duplexing: 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2 )
WARM-UP TIME
From Power On: 34 Seconds
From Sleep Mode: 10 Seconds
Quick Startup Mode: 4 Seconds1
DIMENSIONS (W x D x H)
Standard (Desktop): 20-1/8" x 25-5/8" x 25-1/8" (511 mm x 651 mm x 639 mm)
With Cassette Feeding UnitAJ1 or AK1: 20-1/8" x 25-5/8" x 41-7/8” (511 mm x 651 mm x 1,064 mm)
INSTALLATION SPACE (W x D x H)
Basic: 33-1/2" x 35-3/4" (852 mm x 908 mm)
With Staple Finisher-Z1: 55-3/8" x 35-3/4" (1,407 mm x 908 mm)
WEIGHT2
Standard (Desktop): Approx. 108 lb. (49 kg)
With Cassette Feeding UnitAJ1: Approx. 143.3 lb. (65 kg)
With Cassette Feeding UnitAK1: Approx. 149.9 lb. (68 kg)
With Cassette Module AE-1: Approx. 130.1 lb. (59 kg)
PRINT SPECIFICATIONS
PRINT / COPY SPEED (BW AND COLOR)
Up to 36 ppm (Letter); Up to 29 ppm (Legal)
PRINT RESOLUTION (dpi)
1200 x 600
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II, PCL®6, Adobe® PS® 3
DIRECT PRINT
Available from USB, Advanced Box, Remote UI, and Web Access3
SUPPORTED FILES
PDF, TIFF, JPEG, EPS, XPS
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES
A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet connected devices and cloud-based services depending on your requirements.
FONTS
PCL fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),4 Barcode Fonts5
PS fonts: 136 Roman
OPERATING SYSTEM 6
UFRII/PS: Windows Vista®/Server 2008/Windows® 7/ Server 2008 R2/Server 2012/Windows 8.1/ Server 2012 R2/Windows 10/Server 2016/ MAC OS X (10.6.8 or later)
PCL: Windows Vista/Server 2008/Windows 7/ Server 2008 R2/Server 2012/Windows 8.1/ Server 2012 R2/Windows 10
PRINT FEATURES
Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Forced Hold Printing, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Grouping, Mixed Paper Sizes/ Orientations, Offsetting, Front/Back Covers, Toner Reduction
COPY SPECIFICATIONS
FIRST-COPY-OUT-TIME
As fast as 5.1 seconds (BW)/6.9 seconds (Color)
COPY RESOLUTION
Reading: 600 x 600
Printing: 2400 x 600
MULTIPLE COPIES
Up to 999 Copies
COPY EXPOSURE
Automatic or Manual (9 Levels)
MAGNIFICATION
25%-400% (1% Increments)
PRESET REDUCTIONS
25%, 50%, 64%, 78%
PRESET ENLARGEMENTS
129%, 200%, 400%
BASIC COPY FEATURES
Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel
SPECIAL COPY FEATURES
Two-Sided Original, Finishing, Job Build, N on 1, Density Adjustment, Original Type Selection, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Job Done Notice, Copy ID Card, Multi Sheet Feed Detection
SCAN SPECIFICATIONS
TYPE
Single-pass Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY
100 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES
Legal, Letter, Statement
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS
BW Original: 13 lb. Bond to 34 lb. Cover (50 to 128 g/m2 )
CL Original: 17 lb. Bond to 34 lb. Cover (64 to 128 g/m2 )
PLATEN ACCEPTABLE ORIGINALS
Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2 kg)]
PULL SCAN
Color Network ScanGear2 for both Twain and WIA
Supported OS: Windows Vista/7/8.1/10/ Server 2008/Server 2008 R2/ Server 2012/Server 2012 R2/Server 2016
SCAN RESOLUTION
600 x 600, 400 x 400, 300 x 300, 200 x 400, 200 x 200, 200 x 100, 150 x 150, 100 x 100
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES
A range of solutions is available to provide scanning to mobile devices and cloud-based services depending on your requirements.
SCAN SPEED (LETTER)
Single-sided Scanning (BW and Color): 50 ipm (300 dpi )/30 ipm (600 dpi)
Double-sided Scanning (BW and Color): 100 ipm (300 dpi)/50 ipm (600 dpi)
SEND SPECIFICATIONS
DESTINATION
E-mail/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax, IP Fax (Optional)
COLOR MODE
Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White), Full color, Grayscale, and Black-and-White
ADDRESS BOOK
LDAP (2,000)/Local (1,600)/Speed Dial (200)
SEND RESOLUTION
COMMUICATION PROTOCOL
File: FTP, SMB, WebDAV
E-mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full)
FILE FORMAT
Standard: TIFF, JPEG, PDF (Encrypted, Compact, Searchable, Apply Policy, Optimize for Web, PDF A/1-b), XPS (Compact, Searchable), Office Open XML (PowerPoint®, Word, Digital Signature (PDF/XPS)
Optional: PDF (Trace & Smooth)
UNIVERSAL SEND FEATURES
Original Type Selection,Two-Sided Original, Density Adjustment, Sharpness, Erase Frame, Job Build, Direct Send, Delayed Send, Preview, Job Done Notice, File Name, Subject/ Message, Reply-To, Email Priority, TX Report, Original Content Orientation, Skip Blank Originals, Multi Sheet Feed Detection
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES
2 (Line One Standard, Line Two Optional)
MODEM SPEED
Super G3: 33.6 Kbps
G3: 14.4 Kbps
COMPRESSION METHOD
MH, MR, MMR, JBIG
RESOLUTION
400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE
Statement to Legal
FAX MEMORY
Up to 30,000 Pages
SPEED DIALS
Max. 200
GROUP DIALS / DESTINATIONS
Max. 199 Dials
SEQUENTIAL BROADCAST
Max. 256 Addresses
MEMORY BACKUP
Yes
FAX FEATURES
Original Type Selection, Two-Sided Original, Density for Scanning, Sharpness, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Sender's Name (TTI), Direct Send, Delayed Send, Preview, Job Done Notice, TX Report, Multi Sheet Feed Detection
STORE SPECIFICATIONS
MAIL BOX SIMPLE (NUMBER SUPPORTED)
100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored
ADVANCED BOX
Communication Protocol: SMB or WebDAV
Supported Client PC:
Windows (Windows Vista/7/8/8.1/10) Concurrent Connections (Max.)
SMB:
64 WebDAV: 3 (Active Sessions)
ADVANCED BOX AVAILABLE DISC SPACE
Approx. 16 GB
ADVANCED BOX FEATURES
Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
MEMORY MEDIA
Standard: USB
SECURITY SPECIFICATIONS
AUTHENTICATION
Standard: Universal Login Manager, uniFLOW Online Express,7 User Authentication, Department ID Authentication, Access Management System, Device and Function Level Log-in
Optional: uniFLOW
DATA
Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated), McAfee Embedded Control8
Optional: IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW)
NETWORK
Standard: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP
DOCUMENT
Standard: Secure Watermark, Secure Print, Adobe LiveCycle¿ Rights Management ES2.5 Integration
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT
Temperature: 50 to 86 ºF
Humidity: 20 to 80 % RH (no condensation)
POWER REQUIREMENTS
120-127V AC 60 Hz, 6.9 A
PLUG (MAIN UNIT)
NEMA 5-15P
POWER CONSUMPTION
Maximum: Approx. 1.5 kWh
Standby: Approx. 38.9 W
Sleep Mode: Approx. 0.8 W9
Typical Electricity Consumption (TEC) Rating: 0.35 kWh*
STANDARDS
ENERGY STAR® Certified
Rated EPEAT® Gold10
CONSUMABLES
TONER
GPR-58 Toner
TONER YIELD (ESTIMATED @ 5% COVERAGE)
Black: 23,000 Images
Color (C,M,Y): 18,000 Images
FOOTNOTES
  1. Time from device power-on to when copy jobs can be programmed.
  2. Includes consumables.
  3. PDF print from Web sites is supported.
  4. Requires the optional PCL International Font Set-A1.
  5. Requires the optional Barcode Printer Kit-D1.
  6. Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
  7. No charge for this solution; however activation is required.
  8. Requires Unified Firmware Platform v3.9.
  9. 0.8 W sleep mode not available in all circumstances due to certain settings.
  10. For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
* Based on ENERGY STAR Product Specification for Imaging Equipment Version 3.0.
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
SUPPLIES & ACCESSORIES
