Canon Support for imageRUNNER ADVANCE C5235 | Canon U.S.A., Inc.
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
Model Name | imageRUNNER ADVANCE C5235 |
Type | Color Digital Multifunction Imaging System Letter: Up to 35/30 ppm Legal: Up to 20/18 ppm Ledger: Up to 20/18 ppm |
Functions | Standard: Copy, Print (UFR II), Scan, Send, Store Optional: Print (PCL, Adobe® PostScript® 3™), Fax (Up to 4 Lines) |
Operation Panel | 8.4" SVGA Full-Color TFT Screen |
Image Server Memory | Standard: 2GB RAM Maximum: 2.5GB RAM |
Hard Disk Drive | Standard: 160GB Maximum: 1TB |
Mirroring Hard Disk Drive | Optional (160GB, 1TB), Method: RAID1 |
Network Interface Connection | Standard: 1000Base-T/100Base-TX/10Base-T Optional: Wireless LAN (IEEE 802.1x via third-party adapter) |
Other Interface | Standard: USB 2.0 (Host) x 2, USB 2.0 (Device) Optional: Device Port [USB 2.0 (Host) x 2], Serial Interface, Copy Control Interface |
Max Mailboxes Supported | 100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes Approx. |
Max Pages Stored | 6,000 Maximum Pages Stored |
Standard Paper Capacity | Dual 550-sheet Paper Cassettes, 100-sheet Stack Bypass |
Optional | Dual 550 Sheet Paper Cassettes, 2,700-sheet Paper Deck |
Maximum Paper Capacity | 5,000 Sheets |
Output Paper Capacity | (20 lb. Bond): Standard: 250 Sheets (Inner Tray) Maximum: 3,250 Sheets (w/Staple Finisher or Booklet Finisher) |
Warm Up Time | From Power On: 31 Seconds, From Sleep: 15 Seconds Quick Startup Mode: 7 Seconds*** |
Power Requirements | 120V AC, 60Hz, 15A |
Power Consumption | Maximum: 1.5kW Sleep Mode: 0.8W |
Plug | NEMA 5-15P |
Dimension | 36-5/8" x 24-3/8" x 28" (931mm x 620mm x 712mm) |
Installation Space | 33-1/2" x 28" (850mm x 712mm) |
Weight | Approx. 333 lb. (151kg)† |
Basic Copy Features | First Copy Time: BW: 5.4 Seconds, Color: 8.1 Seconds Multiple Copies: 1 to 999 Copy Exposure: Automatic or Manual (9 Levels) Magnification: 25% - 400% (1% Increments) Preset Reductions: 25%, 50%, 64%, 73%, 78% Preset Enlargements: 121%, 129%, 200%, 400% |
Environmental Features | EPEAT® Rated ENERGY STAR® Qualified RoHS Compliant Ecomark Blue Angel WEEE Directive |
Advanced Box
Available Disk Space | 15GB (Standard HDD) Approx. 629GB (1TB HDD) |
Common Protocol | SMB or WebDAV |
Supported Client PC | Windows® (Windows 2000/XP/Windows Vista®) |
Max. Number of Concurrent Connections | SMB: 32, WebDAV: 12 (Active Sessions) |
Advanced Box Features | Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support |
Memory Media
Standard | USB Memory |
Optional | SD, SDHC, CompactFlash, Memory Stick, Microdrive |
Scan Specifications
Network TWAIN Scan | Standard |
Network Scan Utility | Color Network ScanGear |
Output Sizes
Cassette | 12" x 18",* 11" x 17",* Legal, Letter, Letter-R, Statement-R, Executive, Custom Size (5-1/2" x 7-1/8" to 12" x 18") |
Bypass | 12" x 18", 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size (3-7/8" x 5-1/2" to 12-5/8" x 18") Paper Deck: Letter |
Other Option | Envelope Feeder Attachment (COM10 No.10, Monarch, DL, ISO-C5)** Tab Feeding Attachment Kit** |
Acceptable Paper Weights
Cassette | 14 lb. Bond to 80 lb. Cover (52 to 220g/m2) |
Bypass | 14 lb. Bond to 140 lb. Index (52 to 256g/m2) |
Duplexing
Paper Size | Standard Automatic Trayless Duplexing (Executive to 12" x 18") |
Paper Weight | 14 lb. Bond to 80 lb. Cover (52 to 220g/m2) |
Special Media Support | Thin, Plain 1 [17 lb. Bond to 21 lb. Bond (64g/m2 to 81g/m2)], Plain 2 [22 lb. Bond to 28 lb. Bond (82g/m2 to 105g/m2)], Recycled, Color, Pre-Punched, Bond, Heavy 1 [29 lb. Bond to 60 lb. Cover (106g/m2 to 163g/m2)], Heavy 2 [61 lb. Cover to 80 lb. Cover (164g/m2 to 220g/m2)], Heavy 3 [82 lb. Cover to 140 lb. Index (221g/m2 to 256g/m2)], Tracing, Coated, Labels, Transparency, Tab, Letterhead, and Envelopes |
Image Reader
Scan Resolution | Up to 600 x 600 dpi |
Acceptable Originals | (Glass): Sheet, Book, 3-Dimensional objects [up to 4.4 lb. (2kg)] |
Maximum Original Size | Up to 11" x 17" |
Security Features
Standard | Department ID Management, Single Sign On-H, Access Management System (Device and Function Level Log-in), Secured Print, Trusted Platform Module, User Access Control of Advanced Box, Mail Box Password Protection, IPV6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book), SSL Encrypted Communication, SNMPv1/v3, MAC/IP Address Port Filtering, SMTP Authentication, POP Authentication before SMTP, HDD Erase (Up to 3x), HDD Initialize (Up to 9x), HDD Lock, IPSec, Adobe LiveCycle Rights Management ES2.5 Integration |
Optional | Removable HDD, HDD Encryption, HDD Mirroring, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, Secure Watermark, IEEE 2600.1 Common Criteria CertificationΔΔ |
Estimated Toner Yield | (Estimated Yield @ 5% Coverage): Black: 36,000 Copies/Bottle, Color (C,M,Y): 27,000 Copies/Bottle |
Feeders
Acceptable Originals | 11" x 17", Legal, Letter, Letter-R, Statement, or Statement-R |
Scan Method | Duplex Automatic Document Feeder |
Scanning Speed | (BW/Color; Letter): Simplex: Up to 51/51 ipm (300 dpi)/ Up to 46/46 ipm (600 dpi) Duplex: Up to 19.6/19.6 ipm (300 dpi)/ Up to 17.5/17.5 ipm (600 dpi) |
Capacity | (20 lb. Bond): 100 Sheets |
Paper Weight | 1-sided scanning: 11 lb. Bond to 58 lb. Cover (42 to 157g/m2) 2-sided scanning: 13 lb. Bond to 58 lb. Cover (50 to 157g/m2) |
Paper Supply Options
Description | Cassette Feeding Unit-AD2 |
Paper Capacity | 550 Sheets x 2 Cassettes [20 lb. Bond (80g/m2)] |
Paper Size | 12" x 18", 11" x 17", Legal, Letter, Letter-R, Statement-R, Executive, and Custom Size [5-1/2" x 7-1/8" to 12" x 18" (139.7mm x 182mm to 304.8mm x 457.2mm)] |
Power Source | From the Main Unit |
Power Consumption | Approximately 30W |
Dimensions | 9-7/8" x 24-3/8" x 27-5/8" (251mm x 620mm x 700mm) |
Weight | Approximately 61.7 lb. (28kg) |
Description | Paper Deck Unit-B2 |
Number Of Cassettes | 1 |
Paper Capacity | 2,700 sheets [20 lb. Bond (80g/m2)] |
Paper Size | Letter |
Paper Weight | 14 lb. Bond to 60 lb. Cover (52 to 163g/m2) |
Power Source | From Main Unit |
Power Consumption | Approximately 45W |
Dimensions | 18-5/8" x 14-5/8" x 23-3/4" (473mm x 372mm x 603mm) |
Weight | Approximately 81.6 lb. (37kg) |
Description | Envelope Feeder Attachment-D1** |
Paper Capacity | 50 Sheets (or 30mm in height) |
Paper Size | COM10 No.10, Monarch, DL, ISO-C5Feeding Speed: 10 cpm |
Dimensions | 3-1/4" x 17-1/4" x 12-1/8" (81mm x 439mm x 307mm) |
Weight | Approximately 2.6 lb. (1.2kg) |
Title
Canon Support | Feature Notice: 2600.1 Security Kits Update
Title
Canon Support | Service Notice: NFC function with the Canon PRINT Inkjet / SELPHY App Version 2.7.0 or Later for Android Will Be Discontinued for Select Models.
Title
Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
