Canon Support for imageRUNNER ADVANCE C7565i II | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
imageRUNNER ADVANCE C7500i II Series Spec Sheet
MAIN UNIT
TYPEColor Laser Multifunctional
CORE FUNCTIONSStandard:Print, Copy, Scan, Send, StoreOptional:Fax
PROCESSORCanon Dual Custom Processor (Shared)
CONTROL PANEL Standard:10.1" TFT LCD WSVGA Color Touch-panel
Optional:10.4" TFT LCD WSVGA Color Upright-panel
MEMORY 4.0 GB RAM
HARD DISK DRIVE Standard:250 GB
Maximum:1 TB
MIRRORING HARD DISK DRIVEOptional (250 GB, 1 TB)Method:Raid1
PRINT RESOLUTION 2400 dpi x 2400 dpi
INTERFACE CONNECTION NetworkStandard:1000Base-T/100Base-TX/10Base-T,Wireless LAN (IEEE 802.11 b/g/n)
Optional:NFC, Bluetooth
OthersStandard:USB 2.0 x2 (Host), USB 3.0 x1 (Host),USB 2.0 x1 (Device)
Optional:Serial Interface, Copy Control Interface
PAPER CAPACITY (LTR, 20LB BOND) Standard:3,550 Sheets
Maximum:9,300 Sheets
PAPER SOURCES (LTR, 20LB BOND) Standard:Two 1,100-sheet Paper Drawers,Two 550-sheet Paper Cassettes,250-sheet Stack Bypass
Optional:3,500-sheet Paper Deck (Paper Deck Unit-E1), 3,500-sheet Paper Deck (Pod Deck Lite-C1), 6,000-sheet Paper Deck (Multi-Drawer Paper Deck-C1)
Maximum:9,300 Sheets (With Multi-Drawer Paper Deck-C1)
PAPER OUTPUT CAPACITY (LTR, 20LB BOND) 250 Sheets (with Copy Tray-R2)
3,500 Sheets (with External Finisher-V2)
4,250 Sheets (with External Finisher-X1)
FINISHING CAPABILITIES Standard:Collate, GroupWith Finishers:Collate, Group, Offset, Staple, Booklet, Hole Punch, Staple-Free Staple, Staple On Demand, Document Insertion, Z-Fold, Accordion Z-Fold, C-Fold, Half-Fold, Double Parallel Fold, Trimming
SUPPORTED MEDIA TYPES Paper Drawers(1/2):Thin, Plain, Recycled, Color, Heavy,Pre-punched, Letterhead, Bond, Transparency
Paper Cassettes(3/4):Thin, Plain, Recycled, Color, Heavy,Pre-punched, Letterhead, Bond, Transparency, Tab, EnvelopeStack Bypass:Thin, Plain, Recycled, Color, Heavy,Pre-punched, Labels, Letterhead,Bond, Coated, Transparency, Tab,Tracing, Envelope, Textured
SUPPORTED MEDIA SIZES Paper Drawers(1/2):LetterPaper Cassettes (3/4):13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch,DL, ISO-C5], Custom Size (5-1/2" x 7-1/8" to 13" x 19-1/4"), Envelope Custom Size (3-7/8" x 5-7/8" to 13" x 19-1/4")
Stack Bypass:13" x 19", 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (4" x 5-7/8" to13" x 19-1/4"), Envelope Custom Size(3-1/2" x 5-7/8" to 13" x 19-1/4"), Free Size (4" x 7-1/8" to 13" x 19-1/4")
SUPPORTED MEDIA WEIGHTS Paper Drawers:14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
Paper Cassettes:14 lb. Bond to 140 lb. Index (52 to 256 g/m2)
Stack Bypass:14 lb. Bond to 110 lb. Cover (52 to 300 g/m2)
Duplexing:14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
WARM-UP TIME From Power On:30 Seconds or Less
From Deep Sleep Mode:30 Seconds or Less
Quick Startup Mode:4 Seconds1
DIMENSIONS (W X D X H) 27-1/8" x 37-1/8" x 48" (689 mm x 941 mm x 1,220 mm)
INSTALLATION SPACE (WXD) Basic [With Booklet Finisher-V2 (Stack Bypass and Cassette Drawers Open)]:75-3/8" x 60" (1,913 mm x 1,524 mm)
Fully Configured [With Multi-Drawer PaperDeck-C1+Document Insertion Unit-N1+Multi Function Professional Puncher-A1+Paper Folding Unit-J1+Booklet Finisher-X1 (Cassette Drawers Open)]:150-3/8" x 60" (3,818 mm x 1,524 mm)
WEIGHT Approx. 595.2 lb. (270 kg)2
PRINT SPECIFICATIONS
PRINT / COPY SPEED (BW AND COLOR) Up to 65/60 ppm (Letter); Up to 48/45 ppm (Letter-R); Up to 38/35 ppm (Legal);Up to 32/30 ppm (11" x 17")
DATA PROCESSING RESOLUTION Up to 1200 dpi x 1200 dpi
STANDARD PAGE DESCRIPTION LANGUAGES UFR II, PCL®6, Adobe® PS® 3
DIRECT PRINT Available from USB, Advanced Box, Remote UI,and Web Access3
SUPPORTED FILE TYPES PDF, TIFF, JPEG, EPS,4 XPS
PRINTING FROM MOBILE DEVICES AND CLOUD-BASED SERVICES A range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet-connected devices and cloud-based services depending on your requirements.
FONTS PCL fonts:93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),5 Barcode Fonts6
PS fonts:136 Roman
OPERATING SYSTEM7 UFRII:Windows Vista®/Server 2008/Windows® 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.7 or later)
PCL:Windows Vista/Server 2008/Windows 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016
PS:Windows Vista/Server 2008/Windows 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.7 or later)
PPD:MAC OS X (10.3.9 or later), Windows Vista/Windows 7/Windows 8/Windows 8.1/Windows 10
PRINT FEATURES Suspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Forced Hold Printing, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Toner Reduction, Poster Printing
COPY SPECIFICATIONS
COPY SPEED (BW AND COLOR) Up to 70/65 ppm (Letter); Up to 52/48 ppm (Letter-R); Up to 41/38 ppm (Legal);Up to 35/32 ppm (11" x 17")
FIRST-COPY-OUT-TIME As fast as 4.8 seconds (BW)/5.9 seconds (Color)
COPY RESOLUTION Reading:Up to 600 dpi x 600 dpi
Printing:2400 dpi x 2400 dpi
MULTIPLE COPIES Up to 9,999 copies
COPY EXPOSURE Automatic or Manual (9 Levels)
MAGNIFICATION 25%-400% (1% Increments)
PRESET REDUCTIONS 25%, 50%, 64%, 73%, 78%
PRESET ENLARGEMENTS 121%, 129%, 200%, 400%
BASIC COPY FEATURES Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel
SPECIAL COPY FEATURES Book to Two Pages, Two-sided Original, Finishing, Booklet, Job Build, N on 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Print on Tab, Store in Mail Box, Superimpose Image, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original, Color Balance, Adjust One-Touch Color, Area Designation
SCAN SPECIFICATIONS
TYPE Color Platen and Single-pass Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY 300 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES 11" x 17", Legal, Letter, Letter-R, Statement, Statement-R
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS BW Original:13 lb. Bond to 80 lb. Cover(50 to 220 )
CL Origg/m2inal:17 lb. Bond to 80 lb. Cover(64 to 220 g/m2)
PLATEN ACCEPTABLE ORIGINALS Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2 kg)]
PULL SCAN Color Network ScanGear2 for both Twain and WIA
Supported OS:Windows Vista/7/8.1/10Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/Server 2016
SCAN RESOLUTION 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100dpi
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICES A range of solutions is available to provide scanning tomobile devices and cloud-based services depending onyour requirements.
SCAN SPEED (LETTER) Single-sided Scanning (BW):120 ipm (300 dpi)/120 ipm (600 dpi)
Single-sided Scanning (Color):120 ipm (300 dpi)/70 ipm (600 dpi)
Double-sided Scanning (BW):240 ipm (300 dpi)/150 ipm (600 dpi)
Double-sided Scanning (Color):220 ipm (300 dpi)/90 ipm (600 dpi)
SEND SPECIFICATIONS
DESTINATION E-mail/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional)
COLOR MODE Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White),Full color, Grayscale, and Black-and-White
ADDRESS BOOK LDAP (2,000)/Local (1,600)/Speed dial (200)
SEND RESOLUTION 600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi,100 x 100dpi
COMMUICATION PROTOCOL File:FTP, SMB 3.0, WebDAVE-mail/I-Fax:SMTP, POP3, I-Fax (Simple, Full)
FILE FORMAT Standard:TIFF, JPEG, PDF (Encrypted, Compact, Searchable, Apply Policy, Optimize for Web, PDF A/1-b), XPS (Compact, Searchable),Office Open XML (PowerPoint®, Word), Digital Signature (PDF/XPS)
Optional:PDF (Trace & Smooth)
UNIVERSAL SEND FEATURES Original Type Selection,Two-sided Original, Book to Two Pages, Different-size Originals, Density Adjustment, Sharpness, Copy Ratio, Erase Frame, Job Build, Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-to, E-mail Priority, TX Report, Original Content Orientation, Skip Blank Originals, Detect Feeder Multi Sheet Feed
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES 4
MODEM SPEED Super G3:33.6 Kbps
G3:14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
SENDING / RECORDING SIZE Statement-R to 11" x 17"
FAX MEMORY Up to 30,000 pages
SPEED DIALS Max. 200
GROUP DIALS / DESTINATIONS Max. 199 dials
SEQUENTIAL BROADCAST Max. 256 addresses
MEMORY BACKUP Yes
FAX FEATURES Original Type Selection, Two-sided Original, Book to Two Pages, Different-size Originals, Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Sender's Name (TTI), Select Line, Selecting the Telephone Line (when sending fax), Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, TX Report, Detect Feeder Multi Sheet Feed
STORE SPECIFICATIONS
MAIL BOX SIMPLE(NUMBER SUPPORTED) 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored
ADVANCED BOX Communication Protocol: SMB or WebDAV
SupportedClient PC:Windows (Windows Vista/7/8/8.1/10)
Concurrent Connections (Max.)
SMB:64
WebDAV:3 (Active Sessions)
ADVANCED BOX AVAILABLE DISC SPACE Approx. 16 GB (Standard HDD)
Approx. 480 GB (1 TB HDD)
ADVANCED BOX FEATURES Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
MEMORY MEDIA Standard: USB
SECURITY SPECIFICATIONS
AUTHENTICATION Standard:Universal Login Manager, uniFLOWOnline Express,9,10 User Authentication, Department ID Authentication,Access Management System,Device and Function Level Log-in
Optional:uniFLOW
DATA Standard:Trusted Platform Module (TPM),Hard Disk Password Lock, Hard DiskDrive Erase, Mail Box Password Protection, Hard Disk Drive Encryption(FIPS140-2 Validated)
Optional:Hard Disk Drive Mirroring, Hard Disk Drive removal, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW)
NETWORK Standard:Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP
DOCUMENT Standard:Secure Watermark, Secure Print, Forced Hold Printing, Adobe LiveCycle® Rights Management ES2.5 Integration,Encrypted PDF, Encrypted Secure Print, Device SignaturesOptional:User Signatures, Document Scan Locking
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT Temperature:50 to 86ºF
Humidity:20 to 80% RH (no condensation)
POWER REQUIREMENTS 120-127 V AC, 60 Hz,16 A
PLUG (MAIN UNIT) NEMA 5-20P
POWER CONSUMPTION Maximum: Approx. 2.0 kWh
Standby:Approx. 119.2 W
Sleep Mode:Approx. 0.9 W8
Typical Electricity Consumption (TEC) Rating: 4.5 kWh
STANDARDS ENERGY STAR® Certified
Rated EPEAT® Gold11
RoHS Compliant
CONSUMABLES
TONER GPR-56 Toner
TONER YIELD (ESTIMATED @ 5% COVERAGE) Black:82,000 Images
Color (C,M,Y):66,500 Images
FOOTNOTES
1 Time from device power-on to when copy jobs can be programmed.
2 Includes main unit, ADF, and consumables.
3 PDF print from Web sites is supported.
4 EPS can be printed directly only from the Remote User Interface.
5 Requires the optional PCL International Font Set-A1.
6 Requires the optional Barcode Printer Kit-D1.
7 Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
8 0.9 W Sleep mode is not available in all circumstances due to certain settings.
9 No charge for this solution; however activation is required.
10 Check for availability.
11 For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
SUPPLIES & ACCESSORIES
