Canon Support for MAXIFY MB2120 | Canon U.S.A., Inc.
MAXIFY MB2120
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 05.31.16
File Size 4.39 MB
Date 01.26.17
File Size 89.11 KB
Date 01.26.17
File Size 75.59 KB
Date 08.28.24
File Size 771.01 KB
Date 09.01.16
File Size 13.87 MB
Date 05.25.25
File Size 5.20 MB
Date 08.28.24
File Size 760.69 KB
Date 09.01.16
File Size 17.06 MB
Date 08.28.24
File Size 770.22 KB
Date 05.31.16
File Size 4.54 MB
Date 08.28.24
File Size 6.13 MB
Date 05.31.16
File Size 13.32 MB
Date 08.28.24
File Size 781.78 KB
Date 05.31.16
File Size 4.39 MB
Date 09.01.16
File Size 17.38 MB
Date 09.01.16
File Size 14.12 MB
Date 10.28.25
File Size 1.16 MB
Date 10.28.25
File Size 1.15 MB
Date 05.31.16
File Size 13.32 MB
Date 08.28.24
File Size 6.10 MB
Date 05.31.16
File Size 4.53 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Print and scan wirelessly from any Wi-Fi® enabled computer from your local network connection. Wireless printing requires a working network with wireless 802.11b/g/n capability. You will need a Wi-Fi enabled Computer, a wireless router and a wireless printer. All three devices must be connected to the same wireless network connection. Click on the specific topic below to get detail information.
Initial Setup
Need additional information or assistance
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
MAXIFY MB2120
MAXIFY MB2120
Products ChromeOS
MAXIFY MB2120
Printer
Print Speed (up to) Black:FPOT (Black): 6 Seconds - ESAT (Black): 19.0 ipm 1
Color:FPOT (Color): 7 Seconds - ESAT (Color): 13.0 ipm 1
Number of Nozzles Pigment Black: 1,280 / Color: 3,072 / Total: 4,352
Print Resolution (Up to) Up to 600 x 1200 dpi 8
Ink Compatibility PGI-1200 Black - 12.4 ml (Std) / 34.7 ml (XL)
PGI-1200 Cyan - 4.5 ml (Std) / 12.0 ml (XL)
PGI-1200 Magenta - 4.5 ml (Std) / 12.0 ml (XL)
PGI-1200 Yellow - 4.5 ml (Std) / 12.0 ml (XL)
Up to 1,200 Black & White / 900 Color Pages when using XL ink tanks.
Paper Sizes 4" x 6", 5" x 7", 8" x 10", Letter, Legal, U.S. #10 Envelopes
Paper Compatibility Plain: Plain Paper, High Resolution Paper
Glossy: Photo Paper Plus Glossy II, Photo Paper Glossy
Semi-Gloss: Photo Paper Plus Semi-Gloss, Photo Paper Pro Luster
Matte: Matte Photo Paper
Other: Business Card, Label Paper, U.S.#10 Envelopes
Recycled paper and Chlorine-free paper can be used.
Printer Features AirPrint 5 , Mopria® Print Service 7 , Auto 2-Sided Printing, Advanced Auto Sheet Feeder, Canon PRINT app 4 , Document Printing, Microsoft Mobile Print, Quick Toolbox, Wireless Printing 3
Output Tray Capacity Cassette: 250 Sheets Plain Paper (Letter or Legal) or 20 Sheets Photo Paper 4" x 6"
Noise Level (Approx.) Approx. 56.0 dB(A) 15
Copier
Copy Speed (up to) FCOT (Color): Approx. 11 Seconds 1
Reduction / Enlargement 25% - 400%
Copy Features 2-on-1 Copy, 4-on-1 Copy, ID Card Copy, AE (Auto Exposure / Intensity) Copy, Collated Copy (ADF only), Fit-to-Page, Frame Erase Copy (Flatbed), Preset Copy Ratios, Preview, Standard Copy, 2-Sided Copy, Zoom
Scanner
Scanning Element Contact Image Sensor (CIS)
Max. Resolutions Optical:ADF & Flatbed: 1200 x 1200 dpi (Optical) 10
Interpolated:19,200 x 19,200 dpi (Interpolated) 10
Scanner Features Push Scan, Scan to Memory (USB Flash Memory), Network Scan, Scan to Cloud, Scan to Email, Scan to Network Folder
Color Depth 48-bit Internal/24-bit External
Max. Document Size Flatbed: 8.5" x 11" (Letter); ADF - 50 Sheet Capacity
ADF: 8.5" x 14" (Legal); ADF - 10 Sheet Capacity
Fax
Modem Speed 33.6 Kbps (Super G3 Color FAX) 11
Transmission Speed (approx.) Black: Approx. 3 sec. per page 12
Color: Approx. 1 min. per page 12
Memory Capacity Approx. 250 Pages 13
Speed Dialing 100 Locations
Fax Features Answering Machine Connectivity, Caller Rejection, Check RX Fax Info., Dial Search, Double-Sided Printing (Fax Images), FAX to Network Folder, Extra Fine Mode, Fax Reception Reject, Fax Number Re-Entry, F/T Changing (Manual), Memory Transmission, Redial, Remote Reception
General
Other Features Custom Profiles, 2.5" LCD, Folder Setting Utility, Highlighter and Smudge Resistant Ink, Access Point Mode, High Page Yield, Job Reservation, Low Cost Per Page Printing,15,000 Duty Cycle 2 , Quick First Print, MAXIFY Cloud Link 14 , Quiet Mode, Standard MIB Support, SNMP Support, Records of Use, Job Reservation, Remote UI, Setting Restrictions, Up to 20,000 Pages Duty Cycle 2 , Auto Power On, Schedule On/Off
OS Compatibility Computer Operating Systems:
Windows: 16,17 Windows ® 10, Windows 8, Windows 8.1, Windows 7, Windows 7 SP1, Windows Vista ® SP1, Vista SP2, Windows Server ® 2012, 2012 R2 17 , Windows Server ® 2008, 2008 R2 17
Mac: 18 Mac OS ® X v10.8.5 - 10.11
Mobile Operating Systems: 19
iOS ® , Android, Windows RT 20 and Windows 10 Mobile
Standard Interface Wireless LAN (IEEE 802.11b/g/n) 3
USB Flash Memory
Hi-Speed USB
Software Included WINDOWS 16,17 /MAC 18
MAXIFY MB2120 Printer Driver
Master Setup
PosterArtist Lite 21 (Windows Only)
Scan Utility
My Printer (Windows Only)
Network Tool
Speed Dial Utility
Power Consumption (approx.) 27.0W Copying (0.9W Standby)
Dimension (W x D x H) 18.1" (W) x 18.3" (D) x 10.3" (H)
Weight 23.2 lbs.
Warranty 1-Year limited warranty with InstantExchange Program. 22
Recommended Monthly Print Volume 200 - 1,000 Pages per Month - Ideal for 1-4 users
Limited Warranty & InstantExchange Program Details
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon USA") with respect to the new or refurbished Canon-brand product ("Product") packaged with this limited warranty, when purchased and used in the United States only.
The Product is warranted against defects in materials and workmanship under normal use and service (a) for a period of one (1) year from the date of original purchase when delivered to you in new condition in its original container or (b) for (1) year from the date of original purchase for refurbished Products. Product returned to a Canon USA repair facility or a Canon USA Authorized Service Facility ("ASF"), and proven to be defective upon inspection will be (a) repaired utilizing new, remanufactured, repaired and/or recycled parts (b) exchanged for new or; (c) exchanged for a refurbished Product, as determined by the Canon USA repair facility or the ASF. Warranty repair or replacement shall not extend the original warranty period of the Product. A dated proof of purchase is required at the time of warranty service. A copy of your dated bill of sale will satisfy this requirement. This warranty does not cover any accessories, or any consumables, such as paper or ink cartridges, as to which there shall be no warranty or replacement.
This limited warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty ("Separate Warranty"). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. Non-Canon brand equipment and software that may be distributed with the Product are sold "as is" and without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose, and all such warranties are disclaimed. The sole warranty, if any, with respect to such non-Canon brand items is given by the manufacturer or producer thereof.
  1. Loss of or damage to the Product due to abuse, neglect, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, improper use, failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA's user's manual or other documentation, or services performed by someone other than a Canon USA repair facility or ASF. Without limiting the foregoing, dropping the Product, scratches, and abrasions will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the user's manual or other documentation for the Product.
  2. Use of parts, media, software or supplies (other than those sold by Canon USA), including non-Canon ink cartridges or refilled ink cartridges, that cause damage to the Product or cause abnormally frequent service calls or service problems.
  3. If the Product has had its serial number or dating defaced, altered or removed.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE DISKETTES OR CD-ROMS ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD "AS IS" AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
Canon USA offers a full range of customer technical support* options:
    Interactive troubleshooting, e-mail technical support, the latest driver downloads and answers to frequently asked questions (www.canontechsupport.com)
    Toll-free live technical support within the limited warranty
    Monday - Friday 8:00 a.m. - 10:00 p.m. ET(excluding holidays)
    Saturday 10:00 a.m. - 7:00 p.m. EST
    at 1-844-4-MAXIFY (1-844-462-9439)
    Telephone Device for the Deaf (TDD-1-855-270-3277)
    Repair or Exchange Service Options: In the event service is required for the Product during the limited warranty period, Canon USA offers two hardware support options:
Canon USA's Carry-In/Mail-In Service provides repair or exchange, at Canon USA's option, through Canon USA's Authorized Service Facility (ASF) network. The name and telephone number of the ASF(s) near you may be obtained from Canon USA's Web site at www.canontechsupport.com or by calling the Canon USA Customer Care Center at 1-800-828-4040, or any time while speaking to a technical support person. A Product covered by this limited warranty will be repaired or exchanged, as determined by Canon USA, and returned without charge by the ASF.
InstantExchange Service **
The Canon USA repair facility will ship out the replacement Product prepaid by Canon USA. After receipt of the replacement Product (with instructions and a prepaid waybill), follow the enclosed instructions on how to ship your product to the Canon USA repair facility. Your Product must be returned in the shipping carton in which the replacement Product was packed and include the reference number, A COPY OF YOUR DATED PROOF OF PURCHASE (BILL OF SALE), and a complete explanation of the problem. DO NOT INCLUDE ANY OTHER ITEMS WITH THE YOUR PRODUCT IN THE RETURN SHIPPING CARTON, AND BE SURE TO RETAIN YOUR PRINTHEAD, INK CARTRIDGE(S) AND TANK(S).
InstantExchange Service exchanges your Product with a replacement Product, which will normally be shipped the same day if your request for this service is by 3 p.m. E.T. Monday through Friday, except holidays. Canon USA does not guarantee same day shipment in the event of the occurrence of factors beyond its reasonable control. The replacement Product you receive may be a refurbished or reconditioned unit and will be covered for the balance of the period remaining on your original limited warranty. NOTE THAT BY USING THIS SERVICE YOU WILL KEEP THE REPLACEMENT PRODUCT THAT IS SENT TO YOU. CANON USA WILL RETAIN THE PRODUCT THAT YOU ORIGINALLY PURCHASED, WHICH SHALL BECOME THE PROPERTY OF CANON USA. InstantExchange warranty program service is available only during the express limited-warranty period for your Product and only in the continental United States, Alaska and Hawaii during such period.
InstantExchange warranty service is subject to the availability of refurbished or new replacement units.
Canon U.S.A., Inc.
One Canon Park
Melville, NY 11747
USA
Title Canon Support | Canon print services provided on the IFTTT platform will discontinued
Advisory Type
Date 07.14.20
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
