Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Camera Connect
Camera Connect
image.canon
image.canon
Sensor 35mm Full Frame CMOS (16:9 extract)
Total Pixels Approx. 2.59M (2160 x 1200)
Effective Pixels Approx. 2.26M (2000 x 1128)
Resolution 1920 x 1080, 1280 x 720
Pixel Size 19um x 19um
Min. Sub. Illum. 0.0005 lux or less (at 75dB, F1.2, 1/30s, 50IRE)
Color Filter Array RGB Bayer
Canon EF Mount Cinema Lock type
Canon EF Lenses Select EF, EF-S and Cinema (EF-mount) Lenses
GEN LOCK Black burst or Tri-level reference
Microphone 3.5mm stereo mini jack (plug-in power mic supported)
Remote Control Remote A: 2.5mm stereo mini jack (Canon protocol)
Remote B: Circular 8-pin for RS-422 (Canon protocol)
3G/HD-SDI Terminal 1 (On screen display optional)
Terminal 2 (Clean out only)
Bit Depth: YCbCr422 10bits (effective bits: 8)
Frame Rates:
1920 x 1080: 59.94P/59.94i/50P/50i/29.97P/25P/23.98P
1280 x 720: 59.94P/50P/29.97P/25P/23.98P
* Cannot set frame rate and output size separately by SDI and HDMI.
HDMI Terminal 1 (On screen display optional)
Bit Depth: RGB444, YCbCr422, YCbCr444 (effective bits: 8 for each format)
Frame Rates:
** 640x480: 59.94P & 768x576: 50P will be output when connected with a monitor that support 480P and 576P inputs. Cannot be set from the menu and the on screen display will not show.
Auto Exposure (AE) Iris, Gain, Shutter and ND filter operating together (Cannot set auto/manual separately)
AE shift/AE response selectable
AGC limit can be set from 36dB to Off/75dB (3-dB intervals)
Manual Iris: 1/2 stops (push auto iris can be set to an assign button)
Gain: 0dB to 75dB @ 3-dB intervals (approx. ISO 4,560,000 equivalent at 75dB)
Shutter: 1/3 to 1/2000 (1/4 stops)
Focus Control One-Shot AF (can be set to an assign button)
W/B AWB (2,000K-15,000K), Daylight, Tungsten, Custom Set A, Custom Set B
Optical FiltersND filters: ND filters: 1/8 & 1/64 Built-in (auto or motorized manual)
IR cut filter: On/Off (motorized manual)
Digital Teleconverter 2x, 3x, 4x
Custom Picture Setting EOS Standard, Wide DR, Canon Log, crispImg2, Custom 1-6
Other Functions Auto black balance, color bar, test tone (interlocking with color bar), assign buttons, peripheral illumination correction, focus limit, crop for EF-S Lens, scan reverse, flicker reduction, noise reduction, time display, hour meter
Terminals XLR 4-pin or terminal block 2-pin jack
Input DC +11V , +17V
Consumption Power Consumption Approx. 12W (body only)
Operating Temperature Approx. 0 - 40 °C (32-104 °F)
Dimensions 4.0 x 4.6 x 4.4 in. (102 x 116 x 113mm)
Weight Approx. 2.2 lbs. (1,000g)
Included in the Box ME200S-SH, 2-pin DC Power Contact
Related Accessories Canon RC-V100 Remote Controller, Canon EF Lenses
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
