Canon Support for PowerShot A1100 IS | Canon U.S.A., Inc.
PowerShot A1100 IS
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 03.04.10
File Size 6.23 MB
Date 12.08.08
File Size 3.59 MB
Date 03.04.10
File Size 6.07 MB
Date 02.18.09
File Size 6.05 MB
Date 11.11.09
File Size 4.04 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
12.1 Megapixel, 1/2.3-inch type Charge Coupled Device (CCD)
Total Pixels
Approx. 12.4 Megapixels
Effective Pixels
Approx. 12.1 Megapixels
Focal Length
6.2-24.8mm f/2.7-5.6 (35mm film equivalent: 35-140mm)
Digital Zoom
4x
Focusing Range
Normal: 1.6 ft./50cm-infinity
Macro: 1.2 in.-1.6 ft./3-50cm (W), 1-1.6 ft./30-50cm (T)
Autofocus System
TTL Autofocus
Optical Viewfinder
Real-image zoom viewfinder
LCD Monitor
2.5-inch TFT color LCD
LCD Pixels
Approx. 115,000 pixels
LCD Coverage
100%
Maximum Aperture
f/2.7 (W) - f/5.6 (T)
Shutter Speed
15-1/1600 sec.; Long Shutter operates with noise reduction when manually set at 1.3-15 sec.
Sensitivity
Auto, ISO 80/100/200/400/800/1600 equivalent (Standard output sensitivity. Recommended exposure index)
Light Metering Method
Evaluative*, Center-weighted average, Spot**
* Control to incorporate facial brightness in Face Detection AF
** Metering frame is fixed to the center
Exposure Control Method
Program AE, i-Contrast; AE Lock
Exposure Compensation
+/-2 stops in 1/3-stop increments
White Balance Control
Auto, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
Built-in Flash
Auto, Red-eye Reduction, Auto Red-eye Correction, Flash On, Flash Off; FE lock, Slow Synchro
Flash Range
1-13 ft./30cm-4.0m (W), 1-6.6 ft./30cm-2.0m (T) (when sensitivity is set to ISO Auto)
Recycling Time
10 sec. or less (battery voltage=3.0V)
Flash Exposure Compensation
N/A
Shooting Modes
Auto, Easy, P, Portrait, Landscape, Special Scene (Night Scene, Foliage, Snow, Beach, Sunset, Fireworks, Aquarium, ISO 3200, Long Shutter), Indoor, Kids & Pets, Night Snapshot, Movie
Photo Effects
My Colors
Vivid, Neutral, Sepia, Black & White, Custom
Self Timer
Activates shutter after an approx. 2-sec./10-sec. delay, Custom
Wireless Control
N/A
Continuous Shooting
Approx. 1.1 fps (Large/Fine)
Storage Media
SD/SDHC Memory Card, MultiMediaCard, MMC Plus Card, HC MMC Plus Card
File Format
Design rule for camera file system, DPOF Version 1.1
Image Recording Format
Normal, Fine, SuperFine
JPEG Compression Mode
Still Image: Exif 2.2 (JPEG)
Movie: AVI (Image: Motion JPEG; Audio: WAVE (Monaural))
Number of Recording Pixels
Still Image: 4000 x 3000 (Large), 3264 x 2448 (Medium 1), 2592 x 1944 (Medium 2), 1600 x 1200 (Medium 3/Date Stamp), 640 x 480 (Small), 4000 x 2248 (Widescreen)
Movie: Standard Definition: 640 x 480 (30 fps/30 fps LP), 320 x 240 (30 fps)
Available up to 4GB or 60 minutes per clip
Image data
Movie data
Note: N=Normal F=Fine
Storage capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media.
Playback Modes File
Still Image: Single, Magnification (approx. 2x-10x), Jump, Auto Rotate, Rotate, Resume, Transition Effects, Histogram, Index (9 thumbnails), Over Exposure Warning, Slide Show, Red-eye Correction, Resize, Image Inspection Tool, i-Contrast, Easy
Movie: Normal Playback, Special Playback, Auto Rotate, Resume, Easy
Erase Modes
Still Image: single image, all images
Movie: any movie file
Computer Interface
USB 2.0 Hi-Speed (mini-B jack)
Video Out
NTSC/PAL
Audio Out
Monaural
Other
Memory card slot; direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable
Power Supply
1.AA-size Alkaline Battery (x2)
2.Rechargeable AA-size Ni-MH Battery (x2) (NB-3AH)
3.AC Adapter Kit ACK800 (optional)Still Image: approx. 140 shots (AA-size Alkaline Battery), approx. 350 shots (AA-size Ni-MH Battery (NB-3AH))*Approx. 360 min. (AA-size Alkaline Battery), approx. 480 min. (AA-size Ni-MH Battery)* LCD screen on. The above figures comply with CIPA testing standards and apply when fully-charged batteries are used.
Power Source
Shooting Capacity
Playback Time
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
3.76 x 2.46 x 1.22 in./95.4 x 62.4 x 31.0mm
Weight
Approx. 5.47 oz./155g (camera body only)Note: 26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi)
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, PIXMA, PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
