Canon Support for PowerShot A610 | Canon U.S.A., Inc.
PowerShot A610
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 03.05.10
File Size 6.07 MB
Date 10.25.07
File Size 1.60 MB
Date 03.05.10
File Size 6.23 MB
Date 10.25.07
File Size 2.25 MB
Date 10.25.07
File Size 5.72 MB
Date 05.23.08
File Size 5.72 MB
Date 05.23.08
File Size 2.25 MB
Date 05.23.08
File Size 1.60 MB
Date 10.25.07
File Size 320.59 KB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type of Camera
Type Compact digital still camera with built-in flash, 4x Optical/4x Digital/16x Combined Zoom
Image Capture Device
Type 5.0 Megapixel, 1/1.8 inch type Charge Coupled Device (CCD)
Total Pixels Approx. 5.3 Megapixels
Effective Pixels Approx. 5.0 Megapixels
Lens
Focal Length 7.3 - 29.2mm f/2.8-4.1 (35mm film equivalent: 35-140mm)
Digital Zoom 4x
Focusing Range Normal: 1.5 ft./45cm-infinityMacro: 0.4 in.-1.5 ft./1-45cm (WIDE), 9.8 in. - 1.5 ft./25-45cm (except WIDE)
Autofocus System TTL Autofocus (continuous/single)
Viewfinders
Optical Viewfinder Real-image optical zoom viewfinder
LCD Monitor 2.0 inch low-temperature polycrystalline silicon TFT color LCD (vari-angle)
LCD Pixels Approx. 115,000 pixels
LCD Coverage 100%
Aperture and Shutter
Maximum Aperture f/2.8 (W) - f/4.1 (T)
Shutter Speed 15-1/2000 sec.; Slow shutter operates with noise reduction when manually set at 1.3-15 sec.
Exposure Control
Sensitivity AUTO, ISO 50/100/200/400 equivalent
Light Metering Method Evaluative, Center-weighted average, Spot*
* Metering frame with Spot Mode fixed to center or linked to AF frame.
Exposure Control Method Program AE, Shutter-priority AE, Aperture-priority AE, Manual.AE Lock is available
Exposure Compensation +/- 2 stops in 1/3-stop increments
White Balance
White Balance Control Auto, Preset (Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Underwater), Custom
Flash
Built-in Flash Operation Modes: Auto, On/Off, Red-Eye Reduction On/Off, Slow Synchro
Flash Range Normal: 1.5-13.8 ft./45cm - 4.2m (W), 1.5-9.8 ft./45cm - 3.0m (T)
Macro: 0.8-1.5 ft./25-45cm (when sensitivity is set to ISO 100 equivalent)
Recycling Time Approx. 10 sec. or less (battery voltage=6.0V)
Flash Exposure Compensation +/- 2 stops in 1/3-stop increments
Shooting Specifications
Shooting Modes Auto; Creative: P, Av, Tv, M, C; Image: Portrait, Landscape, Night Scene, Special Scene (Foliage, Snow, Beach, Fireworks, Underwater, Indoor, Kids & Pets, Night Snapshot), My Colors, Stitch Assist, Movie
Photo Effects Vivid, Neutral, Low Sharpening, Sepia, Black & White
Self Timer Activates shutter after an approx. 2 sec./10 sec. delay, Custom
Wireless Control Not available
Continuous Shooting Approx. 2.4 fps
Image Storage
Storage Media SD Memory Card, MultiMediaCard
File Format Design rule for camera file system, DPOF Version 1.1 (Digital Print Order Format)
Image Recording Format Still Image: Exif 2.2 (JPEG)
Movie: AVI (Image: Motion JPEG; Audio: WAVE (Monaural))
JPEG Compression Mode Normal, Fine, SuperFine
Number of Recording Pixels Still Image: 2,592 x 1,944 (Large), 2,048 x 1,536 (Medium 1), 1,600 x 1,200 (Medium 2), 640 x 480 (Small)Movie: 640 x 480/320 x 240 (30 fps/15 fps), 320 x 240 (1 min. at 60 fps), 160 x 120 (3 min. at 15 fps)
Number of Recordable Images
Image data
Time of Recordable Movies
Movie data Note: N=Normal F=Fine SF=SuperFine
Storage Capacity varies depending on camera settings. This data is estimated from Canon's standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media.
Playback Specifications
Playback Modes File Still Image: Single, Magnification (approx. 2x-10x), Jump, Auto Rotate, Rotation, Histogram, Index (9 thumbnails), Sound Memos, Slide Show
Movie: Normal Playback, Special Playback, Slow Motion, Editing
Erasing Specifications
Erase Modes Still Image: Single image, All images
Movie: Part of movie, All of movie
Interfaces
Computer Interface USB 2.0 Hi-Speed (mini-B PTP)
Video Out NTSC/PAL
Audio Out Monaural
Other Memory card slot. Direct connection to Canon CP, SELPHY, PIXMA Photo Printers and PictBridge compatible printers via camera's USB cable.
Power Supply 1. AA-size Alkaline Battery (x4)
2. Rechargeable AA-size NiMH Battery (x4)
3. AC Adapter Kit ACK600Still Image: approx. 350 shots (AA-size Alkaline Battery), approx. 500 shots (AA-size NiMH Battery) *1Approx. 960 min. (AA-size Alkaline Battery), approx. 960 min. (AA-size NiMH Battery)*
Power Source 1. AA-size Alkaline Battery (x4)
Shooting Capacity Still Image: approx. 350 shots (AA-size Alkaline Battery), approx. 500 shots (AA-size NiMH Battery) *1
Playback Time Approx. 960 min. (AA-size Alkaline Battery), approx. 960 min. (AA-size NiMH Battery)*
Physical Specifications
Operating Temperature 32-104&deg F/0-40&deg C
Operating Humidity 10-90%
Dimensions (W x H x D) 4.13 x 2.60 x 1.93 in./104.8 x 66.0 x 49.1mm
Weight Approx. 8.29 oz./235g (camera body only)
*1
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
