Canon Support for PowerShot ELPH 300 HS | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 02.08.11
File Size 8.69 MB
Date 02.08.11
File Size 10.96 MB
Date 02.08.11
File Size 8.36 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
12.1 Megapixel, 1/2.3-inch CMOS
Total Pixels
Approx. 12.8 Megapixels
Effective Pixels
Approx. 12.1 Megapixels
Focal Length
4.3 (W) - 21.5mm (T) (35mm film equivalent: 24-120mm)
Digital Zoom
Approx. 4x
Focusing Range
Normal AF: 2.0 in. (5cm) - infinity (W), 3.0 ft. (90cm) - infinity (T)
Macro: 1.2 in. - 1.6 ft. (3 - 50cm) (W)
Autofocus System
TTL Autofocus
Optical Viewfinder
N/A
LCD Monitor
2.7-inch TFT color LCD (wide viewing angle type)
LCD Pixels
Approx. 230,000 dots
LCD Coverage
Approx. 100%
Maximum Aperture
f/2.7 (W) - f/5.9 (T)
Shutter Speed
1 1/2000 sec.15 - 1/2000 sec. (Total Shutter speed range)
Sensitivity
Auto, ISO 100/200/400/800/1600/3200
Light Metering Method
Evaluative*, Center weighted average, Spot**
* Facial brightness is evaluated in Face AiAF.
** Fixed to center.
Exposure Control Method
AE Lock
Exposure Compensation
+/-2 stops in 1/3-stop increments
White Balance Control
Auto*, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom
* Facial color is evaluated in Face AiAF
Built-in Flash
Auto, Red-eye Reduction, Auto Red-eye Correction, Flash On, Flash Off; FE Lock, Smart Flash, Slow Synchro
Flash Range
1.611.5 ft. (W), 3.06.6 ft. (T) (50cm3.5m (W), 90cm2.0m (T))* Image brightness may diminish depending on the shooting distance
Recycling Time
10 sec. or less (battery voltage: 3.7 V)
Flash Exposure Compensation
N/A
Shooting Modes
P, Auto1, Movie Digest, Portrait, Kids & Pets, Smart Shutter2, High-speed Burst, Best Image Selection, Handheld Night Scene, Low Light, Fish-eye Effect, Miniature Effect, Toy Camera Effect, Monochrome, Super Vivid, Poster Effect, Color Accent, Color Swap, Beach, Underwater, Foliage, Snow, Fireworks, Long Shutter, Stitch Assist, Movie3*Videos are recorded by pressing the movie button
1Smart Auto also available for videos
2Smile, Wink Self-timer, Face Self-timer
3Standard, Super Slow Motion Movie, Miniature Effect for Movies (Videos are recorded by pressing the movie button)
Photo Effects
My colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin, Darker Skin, Vivid Blue, Vivid Green, Vivid Red, Custom Color**Adjustment of contrast, sharpness, saturation, red, green, blue and skin tone are available
Self Timer
Approx. 10-sec. delay/approx. 2-sec. delay/custom Shooting start time (0 - 10 sec. (in one-second increments), 20/25/30 sec.) and number of shots (1 - 10 shots (in one-shot increments)) can be specified.
Wireless Control
N/A
Continuous Shooting
Approx. 3.4 shots/sec. (in P mode)
Approx. 8.2 shots/sec. (in High-speed Burst)
Storage Media
SD/SDHC/SDXC memory card, Eye-Fi, MultiMediaCard, MMCplus card, HC MMCplus card
File Format
Design rule for camera file system, DPOF Version 1.1 compliant
Image Recording Format
Normal, Fine
JPEG Compression Mode
Still Image: Exif 2.3 (JPEG)
Video: MOV (Image: H.264; Audio: Linear PCM (stereo))
Number of Recording Pixels
16:9
4000 x 2248 (Large), 2816 x 1584 (Medium 1), 1920 x 1080 (Medium 2), 640 x 360 (Small)3:2
4000 x 2664 (Large), 2816 x 1880 (Medium 1), 1600 x 1064 (Medium 2), 640 X 424 (Small)4:3
4000 x 3000 (Large), 2816 x 2112 (Medium 1), 1600 x 1200 (Medium 2), 640 x 480 (Small)1:1
2992 x 2992 (Large), 2112 x 2112 (Medium 1), 1200 x 1200 (Medium 2), 480 x 480 (Small)
Image data
Note: N=Normal F=FineStorage Capacity varies depending on camera settings. This data is estimated from Canonfs standard shooting conditions. Figures for Movie Mode represent total capacity of the particular media.
Movie data
Playback Modes File
- Stills & Videos: Auto Rotate (Automatic vertical/horizontal detection), Image Advance (Operation Tools, Transition effects, Scroll Display), Rotate, Favorites, My Category, Smart Shuffle, Filtered Playback, Slide Show (Playback Interval, Repeat, Effect, Playlist)- Still Images: Single, Index (4-100 thumbnails), Magnification (2-10x), Information Display, Red-eye Correction, i-Contrast, Trimming, Resize, My Colors, Focus Check, Histogram, Overexposure Warning- Videos: Normal Playback*, Slow Motion**, Special Playback, Editing, Resume*Auto settings available in 5 levels
** 5 levels (including normal playback), sound not available.
Erase Modes
Select image, select range, all images (all filtered images)- The image data in the memory card stored with the Design rule for Camera File systems format can be erased (however, protected images cannot be erased).- Using the Movie editing function, sections of the movie (1 sec. increments) can be deleted.
Video Out
NTSC/PAL (dedicated connector (female) with unified type of digital, audio and video)
Mini-HDMI connector
Audio Out
Stereo (dedicated connector (female) unified type of digital, audio, and video)
Other
Mini-HDMI cable: connection to high definition monitor; SD Memory card slot; direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-speed cable
Power Supply
Battery Pack NB-4L, Compact Power Adapter CA-DC10 (when used with DC Couple DR-10)Approx. 220 shots Approx. 5 hours
Power Source
Shooting Capacity
Approx. 220 shots
Playback Time
Approx. 5 hours
Operating Temperature
32-104&deg;F/0-40&deg;C
Operating Humidity
10-90%
Dimensions (W x H x D)
3.63 x 2.20 x 0.77 in. / 92.2 x 55.9 x 19.5mm
Weight
Approx. 4.97 oz. / 141g (Including batteries and memory card)
Approx. 4.30 oz. / 122 g (Camera body only)Note: 26 display languages provided (English, German, French, Dutch, Danish, Finnish, Italian, Norwegian, Swedish, Spanish, Simplified/Traditional Chinese, Japanese, Russian, Portuguese, Korean, Greek, Polish, Czech, Hungarian, Turkish, Thai, Arabic, Romanian, Ukrainian, Farsi).
All data are based on Canon's Standard Test Method. Subject to change without notice.
Canon, DIGIC, ELPH, PIXMA, and PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
