Canon Support for PowerShot ELPH 330 HS | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
SELECT ERROR CODE
Type | 12.1 Megapixel, 1/2.3-inch CMOS |
Total Pixels | Approx. 12.8. Megapixels |
Effective Pixels | Approx. 12.1 Megapixels |
Focal Length | 4.3 (W) - 43.0 (T) mm (35mm film equivalent: 24 (W) - 240 (T) mm) |
Optical Zoom | 10x |
Digital Zoom | 4x |
Focusing Range | Normal: 0.4 in. (1cm) - infinity (W), 3.3 ft. (1m) - infinity (T) Macro: 0.4 in. - 1.6 ft. (1 - 50cm) (W)Macro: 1.2 in. - 2.0 ft. (3-60cm) (W) |
Autofocus System | TTL Autofocus |
Optical Viewfinder | N/A |
LCD Monitor | 3.0-inch TFT Color LCD with wide-viewing angle |
LCD Pixels | Approx. 461,000 dots |
LCD Coverage | Approx. 100% |
Maximum Aperture | f/3.0 (W), f/6.9 (T) |
Shutter Speed | 1 - 1/2000 sec. 15 - 1 sec. (Shooting long exposures) |
Sensitivity | Auto, ISO 80 - ISO 6400 1-step increments |
Light Metering Method | Evaluative, Center-weighted average, Spot |
Exposure Control Method | AE Lock, FE Lock, AF Lock |
Exposure Compensation | +/-2 stops in 1/3 stop increments(Not available when shooting movies) |
White Balance Control | Auto, Daylight, Cloudy, Tungsten, Fluorescent, Fluorescent H, Custom |
Built-in Flash | Auto, On, Slow Synchro, OffFacial brightness is also evaluated in Face Detect. |
Flash Range | 1.6 - 13 ft. (W), 3.3 - 6.6 ft. (T) (50cm - 4.0m (W), 1.0 - 2.0m (T)) |
Recycling Time | 10 seconds or less (battery voltage: 3.7 V) |
Flash Exposure Compensation | N/A |
Shooting Modes | Auto, Hybrid Auto, P, Portrait, Smooth Skin, Smart Shutter*, High-Speed Burst, Handheld Night Scene, Fisheye Effect, Miniature Effect, Toy Camera Effect, Soft Focus, Monochrome, Super Vivid, Poster Effect, Color Accent, Color Swap, Snow, Fireworks, Long Shutter, Stitch Assist, Super Slow Motion Movie * Smile, Wink Self-timer, Face Self-timer - Shooting movies is possible with the movie button. |
Photo Effects | My Colors Off, Vivid, Neutral, Sepia, Black & White, Positive Film, Lighter Skin Tone, Darker Skin Tone, Vivid Blue, Vivid Green, Vivid Red, Custom Color |
Self Timer | Approx. 10-sec. delay, approx. 2-sec. delay, custom* * Delay time (0 - 15 sec. (in one-second increments), 20/25/30 sec.) and number of shots (1 - 10 shots (in one-shot increments)) can be specified. |
Wireless Control | N/A |
Continuous Shooting | Approx. 2.4 shots/sec. (In P mode) Approx. 6.2 shots/sec. (in High-Speed Burst mode) |
Storage Media | SD Memory Card, SDHC Memory Card, SDXC Memory Card |
File Format | Design rule for Camera File system, DPOF (Version 1.1) compatible |
JPEG Compression Mode | Still Images: Exif 2.3 (JPEG) Movies: MOV (Image data: H.264; Audio data: Linear PCM(Stereo)) |
Number of Recording Pixels | Still Images: 1) 16:9 - Large: 4000 x 2248; Medium 1: 2816 x 1584; Medium 2: 1920 x 1080; Small: 640 x 360 2) 3:2 - Large: 4000 x 2664; Medium 1: 2816 x 1880; Medium 2: 1600 x 1064; Small: 640 x 424 3) 4:3 - Large: 4000 x 3000; Medium 1: 2816 x 2112; Medium 2: 1600 x 1200; Small: 640 x 480 4) 1:1 - Large: 2992 x 2992; Medium 1: 2112 x 2112; Medium 2: 1200 x 1200; Small: 480 x 480 * 1984 x 1488 when in High-Speed Burst Videos: Full HD 1920 x 1080: 24 fps (23.976) HD 1280 x 720: 30 fps (29.97) Digest Movie HD 1280 x 720: 30 fps (29.97) Miniature Effect HD 1280 x 720: 6 fps*1 / 3 fps*1 / 1.5 fps*1 Miniature Effect 640 x 480: 6 fps*1 / 3 fps*1 / 1.5 fps*1 Super Slow Motion Movie 640 x 480: 120 fps*1 Super Slow Motion Movie 320 x 240: 240 fps*1 640 x 480: 30 fps (29.97) *1 Playback frame rate is 30 fps (29.97) |
Image data | *When in High-Speed Burst. - The approximate number of images recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly. |
Movie data | *1 Actual frame rate is 29.97 fps. *2 Playback frame rate is 30 fps*1. *3 Actual frame rate is 23.976 fps. • The approximate number of videos recordable on memory cards other than the above can be calculated by using the above figures as a reference and extrapolating accordingly. |
Playback Modes File | Still Images and Movies: Auto Rotate, Rotate*1, Search (Date, Movies, Still Images) Still Images: Single, Index (4-100 Thumbnails), Magnification (Approx. 2x10x), Information Display (Histogram, Overexposure Warning), Resume Playback, Transition, Red-Eye Correction, i-Contrast, Resize, Photobook Set-up Movies: Normal Playback*2, Pause, Slow Motion, Skip Backward*3, Previous Frame*4, Next Frame*4, Skip Forward*3 - Displays playback position and shooting time *1 Not available for movies with a recording pixel setting of Full HD or HD *2 Audio settings available in 5 levels *3 Approximately in 4-second intervals *4 Fast-rewind and fast-forward are also available |
Erase Modes | Single Image*, Erase All - The image data in the memory card stored with the design rule for camera file systems format can be erased (however, protected images cannot be erased). * Movies can be erased individually. |
Computer Interface | Hi-Speed USB (dedicated connector (female) with unified type of digital, audio and video) |
Video Out | NTSC/PAL (dedicated connector (female) with unified type of digital, audio and video), HDMI mini connector |
Audio Out | Stereo (dedicated connector (female) with unified type of digital, audio and video) |
Other | Memory card slot; direct connection to Canon SELPHY Compact Photo Printers, PIXMA Inkjet Photo Printers and PictBridge-compatible printers via camera's USB 2.0 Hi-Speed cable |
Power Source | Battery Pack NB-4L |
Shooting Capacity | Normal: Approx. 220 shots ECO Mode: Approx. 300 shots |
Playback Time | Approx. 4 hours |
Operating Temperature | 32-104°F/0-40°C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | 3.83 x 2.22 x 0.89 in. (97.2 x 56.4 x 22.5mm) |
Weight | Approx. 4.41 oz. / 125g (body only) Approx. 5.08 oz. / 144g (CIPA Standard)All data are based on Canon's Standard Test Method. Subject to change without notice. Canon, DIGIC, ELPH, PIXMA, PowerShot and SELPHY are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries. |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
