Canon Support for PowerShot G1 X Mark III | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Camera Connect
image.canon
Software Development Kit
We've got plenty more how-to videos with tips and tutorials to help you with your Canon product.
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital camera with built-in flash, 3x Optical, 4x Digital and 12x Combined Zoom with Optical Image Stabilizer |
Type | 24.2 Megapixel*, APS-C CMOS (sensor aspect ratio 3:2) * Image processing may cause a decrease in the number of pixels. |
Total Pixels | Approx. 25.8 megapixels |
Effective Pixels | Approx. 24.2 megapixels |
Focal Length | 15.0 (W) - 45.0 (T) mm (35mm film equivalent: 24-72mm) |
Optical Zoom | 3x |
Digital Zoom | 4x |
Focusing Range | Normal/Auto: 3.9 in. (10cm) - infinity (W), 11.8 in. (30cm) - infinity (T) Macro/Underwater Macro: 3.9 in. - 1.6 ft. (10-50 cm) (W) |
Autofocus System | TTL Autofocus, Manual Focus |
Optical Viewfinder | Built-in electronic color viewfinder with 0.39-type screen size and approx. 2.36 million dots |
LCD Monitor | 3.0" TFT color liquid crystal type Vari-angle with electrostatic capacitance touchscreen panel |
LCD Pixels | Approx. 1.04 million dots |
LCD Coverage | Approx. 100% |
Maximum Aperture | f/2.8 (W), f/5.6 (T) |
Shutter Speed | 1-1/2000 sec. (in Auto mode) 301/2000 sec. (in all shooting modes) BULB (in M mode only) 1/8 minimum in Manual Movie Mode |
Sensitivity | ISO 100-3200 (in Auto mode) Max. ISO Speed in P mode is ISO 25600 |
Light Metering Method | Evaluative, Center Weighted Average, Spot |
Exposure Control Method | Manual Exposure, Program Shift, AE Lock, AE Bracketing |
Exposure Compensation | ±3 stops in 1/3-stop increments |
White Balance Control | Auto, Day Light, Shade, Cloudy, Tungsten, Fluorescent, Flash, Underwater WB, Color Temperature |
Built-in Flash | Manual Pop-up Flash (Auto, On, Slow Synchro, Off) |
Flash Range | 1.6 ft. (50cm) - 29.5 ft. (9.0m) (W), 1.6 ft. (50cm) - 14.8 ft. (4.5m) (T) |
Flash Exposure Compensation | ±2 stops in 1/3 increments |
Picture Style | Auto, Standard, Portrait, Landscape, Fine Detail, Neutral, Faithful, Monochrome, User Def. 1-3 |
Self Timer | Off, 2 sec., 10 sec., Custom |
Wireless Control | Wi-Fi® / NFC / Bluetooth® |
JPEG Compression Mode | Still Image: Exif. 2.3 (JPEG), RAW (Canon original: 14-bit, CR2) Video: MP4 (Image: MPEG-4 AVC/H.264; Audio: MPEG-4 AAC-LC (Stereo)) |
Storage Media | SD/SDHC/SDXC and UHS-I Memory Cards |
File Format | Design rule for Camera File system (DCF) compliant; DPOF (Version 1.1) compatible |
Image Recording Format | Fine/Normal |
Number of Recording Pixels | Approx. Number of Shots per a Canon Metric 16GB SD Card |
Audio Out | Stereo |
Wired | Hi-Speed USB (Micro USB), HDMI (Type D) |
Wireless | Wi-Fi®* Specifications: IEEE 802. 11b/g/n Frequency: 2.4 GHz Channels: 1-11 Security: WEP, WPA-PSK (AES/TKIP), WPA2-PSK (AES/TKIP) NFC** Bluetooth®*** Version: Ver. 4.0 * Compatible with iOS® versions 9.3/10.3, Android™ smartphone and tablet versions 4.4/5.0/5.1/6.0/7.0/7.1. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app. ** Compatible with Android™ smartphone and tablet versions 4.4/5.0/5.1/6.0/7.0/7.1. *** Compatible with select smartphone and tablet devices (Android™ version 5.0 or later and the following iOS® devices: iPhone 4s or later, iPad 3rd gen. or later, iPod Touch 5th gen. or later) equipped with Bluetooth® version 4.0 or later and the Camera Connect App Ver. 2.1.30. This application is not guaranteed to operate on all listed devices, even if minimum requirements are met. |
Other | Direct connection to Canon SELPHY, PIXMA Photo Printers & PictBridge compatible printers |
Power Source | Battery Pack NB-13L, Battery Charger CB-2LH |
Shooting Capacity | Approx. 200 shots with Screen On (CIPA compliant) Approx. 250 shots with ECO Mode |
Playback Time | Approx. 4 hrs. |
Operating Temperature | 32-104°F/0-40°C |
Operating Humidity | 10-90% |
Dimensions (W x H x D) | Approx. 4.5 x 3.1 x 2.0 in. / 115.0 x 77.9 x 51.4mm |
Weight | Approx. 14.1 oz. / 399g (including battery and memory card) Approx. 13.2 oz. / 375g (camera body only) |
- Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service center for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the camera, scratches, abrasions or damage to the body, lenses or LCD display or damage to any of the accessories mentioned in the first paragraph above, will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions.
- Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems.
Canon U.S.A.
Canon Canada
